TAI-TECH
TBM02-180300989
SMD Power Inductor
HPC5020CF-Series
ECN HISTORY LIST
REV
DATE
P1
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
16/06/16 新發行
楊祥忠
詹偉特
何秦芝
1.1
尺寸更改:
原 C= 2.0MAX 修改為 2.1MAX
原 D= 2.0±0.2 修改為 1.4±0.3
16/11/03
原 E= 1.5±0.2 修改為 1.8±0.3
包裝數量更改:
原 3000PCS/REEL 修改為 2000PCS/REEL
楊祥忠
詹偉特
何秦芝
備
註
www.tai-tech.com.tw
TAI-TECH
TBM02-180300989
SMD Power Inductor
HPC5020CF-Series
1. Features
1. This specification applies Low Profile Power Inductors.
Halogen
Pb
Halogen-free
Pb-free
2. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Dimension
Recommended Land pattern
2R2
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
F(mm)
G(mm)
H(mm)
HPC5020CF
5.0±0.2
5.0±0.2
2.1max
1.4±0.3
1.8±0.3
1.4
1.8
4.2
3. Part Numbering
HPC
5020
CF
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
P2
2R2
M
D
E
A/B*C
2R2=2.20uH 100=10uH,101=100uH
M=±20%,Y=±30%.
marking Color: Black,
www.tai-tech.com.tw
TAI-TECH
TBM02-180300989
4. Specification
Part Number
Inductance
L0 (uH)
@0A
Tolerance
DCR(Ω)
±30%.
Isat(A)
Max
Irms(A)
Max
HPC5020CF-1R0Y
1.0
±30%
0.020
4.10
3.80
HPC5020CF-1R5Y
1.5
±30%
0.030
4.10
3.20
HPC5020CF-2R2Y
2.2
±30%
0.040
3.20
2.70
HPC5020CF-3R3Y
3.3
±30%
0.050
2.55
2.30
HPC5020CF-4R7M
4.7
±20%
0.057
2.50
2.20
HPC5020CF-6R8M
6.8
±20%
0.083
2.05
1.80
HPC5020CF-8R2M
8.2
±20%
0.098
1.85
1.65
HPC5020CF-100M
10.0
±20%
0.120
1.70
1.55
HPC5020CF-150M
15.0
±20%
0.165
1.35
1.25
HPC5020CF-180M
18.0
±20%
0.200
1.25
1.15
HPC5020CF-220M-
22.0
±20%
0.250
1.15
1.10
HPC5020CF-330M
33.0
±20%
0.400
0.92
0.90
HPC5020CF-470M
47.0
±20%
0.580
0.77
0.75
HPC5020CF-680M
68.0
±20%
0.740
0.65
0.64
HPC5020CF-101M
100
±20%
1.100
0.53
0.40
Note:
1.All test data referenced to 25℃ ambient , Ls:100KHz/1V.
2Isat: DC current at which the inductance drops approximate 30% from its value without current;
3.Irms: DC current that causes the temperature rise (△T =40°C ) from 25°C ambient.
www.tai-tech.com.tw
P3
TAI-TECH
TBM02-180300989
P4
5. Material List
b
e
a
c
d
NO
Items
Materials
a
Core
Ferrite Core
b
Wire
Enameled Copper Wire
c
Glue
Epoxy with magnetic powder
d
Terminal
Ag/Ni/Sn+ Sn Solder
e
Ink
Halogen-free ketone
Void appearance tolerance Limit
Size of voids occurring to coating resin is specified below.
Appearance of exposed wire tolerance limit :
1. Width direction(dimension a):Acceptable when a≦w/2
Nonconforming when a>w/2
2. Length direction(dimension b):Dimension b is not specified.
3. The total area of exposed wire occurring to each sides is
not greater than 50% of coating resin area, and is acceptable.
External appearance criterion for exposed wire
Exposed end of the winding wire at the secondary side should be 2mm and below.
www.tai-tech.com.tw
TAI-TECH
TBM02-180300989
P5
6. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃(on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Saturation Current (Isat)
Approximately △L30%.
Saturation DC Current (Isat) will cause L0
to drop △L(%)
Heat Rated Current (Irms)
△T40℃
Heat Rated Current (Irms) will cause the coil temperature rise
△T(℃).
1.Applied the allowed DC current
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles)
Temperature: 125±2℃
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs..
Humidity:85±2﹪R.H,
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Life Test
Load Humidity
Moisture Resistance
Appearance:No damage.
Impedance:within±15% of initial value
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles:500
Measured at room fempraturc after placing for 24±2 hrs.
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Thermal shock
Vibration
www.tai-tech.com.tw
TAI-TECH
Item
TBM02-180300989
Performance
Bending
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805inch(2012mm):1kg ,
很抱歉,暂时无法提供与“HPC5020CF-2R2Y”相匹配的价格&库存,您可以联系我们找货
