(SMD Power Inductors)
Powder Molding Type
BCIHP0412/18/20/30 Series
● Photograph picture
● Dimensions
MARKING
ITEM
BCIHP0412-Series
BCIHP0418-Series
BCIHP0420-Series
BCIHP0420TB-Series
BCIHP0430-Series
Recommend PC Board Pattern
A(mm)
4.10±0.25
4.10±0.25
4.10±0.25
4.10±0.25
4.10±0.25
B(mm)
4.45±0.25
4.45±0.25
4.45±0.25
4.45±0.25
4.45±0.25
C(mm)
1.2MAX
1.8MAX
2.0MAX
2.0MAX
3.0MAX
D(mm)
1.60±0.3
1.60±0.3
1.60±0.3
1.60±0.3
1.60±0.3
E(mm) F(mm) G(mm) H(mm)
0.76±0.3 4.95
1.95
1.60
0.76±0.3 4.95
1.95
1.60
0.76±0.3 4.95
1.95
1.60
0.76±0.3 4.95
1.95
1.60
0.76±0.3 4.95
1.95
1.60
● Part Numbering
BCIHP
0410 – 4R7
M
A
B
C
D
A:Series(系列代號)
B:Dimension(尺寸)
B×C
C:Inductance(電感值)
4R7=4.7uH
D:Inductance Tolerance(電感值公差) M=±20%
● Features
1. Compliance with RoHs.
2. Lowest DCR.
3. Frequency range up to 3.0MHz.
Height 1.0~1.5mm frequency of 1.0 MHz
4. Handles high transient current spikes without saturation
5. Ultra low buzz noise, due to composite construction.
● Applications
1.
2.
3.
4.
Notebook/Desktop/Server applications.
Low profile, high current power supplies.
Battery powered devices.
DC/DC converter for Field Programmable Gate Array
(FPGA).
TEL:+86-512-57823500
TAX:+86-512-57823503
● 特點
1. 符合 RoHs.
2. 低電阻.
3. 頻率可達到 3.0 MHz..
高度 1.0~1.5mm 頻率為 1.0 MHz
4. 可處理在未飽和時的高瞬間電流.
5. 設計緊湊/超低噪音
● 應用
1. 筆記本型電腦/伺服器等設.
2. 備形體小,可耐高電流.
3. 電源,電池設備.
4. 用於 FPGA 領域中的 DC/DC 轉換設備
Cheng YangElectronics Corp Ltd
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 1 / 9
Powder Molding Type
● Specification
ITEM
BCIHP0412-R047NIHLP-1616AB-01/11
BCIHP0412-R10N IHLP-1616AB-01/11
BCIHP0412-R15N IHLP-1616AB-01/11
BCIHP0412-R20N IHLP-1616AB-01/11
BCIHP0412-R22N IHLP-1616AB-01
BCIHP0412-R47M IHLP-1616AB-01
BCIHP0412-R68M IHLP-1616AB-01
BCIHP0412HC-1R0M IHLP-1616AB-01
BCIHP0412HC-1R2M IHLP-1616AB-01
BCIHP0412HC-1R5M[14]
BCIHP0412HC-2R2M
BCIHP0412-3R3M
BCIHP0412-4R7M
BCIHP0412-6R8M
BCIHP0412-100M
BCIHP0418-R20M
BCIHP0418-R47M
BCIHP0418-R80N
BCIHP0418-1R0M
BCIHP0420-R10N [IHLP-1616BZ-01]
BCIHP0420-R20N [IHLP-1616BZ-01]
BCIHP0420-R22N[15] [IHLP-1616BZ-01]
BCIHP0420-R47M [IHLP-1616BZ-01]
BCIHP0420-R56M
BCIHP0420-R68M
BCIHP0420-1R0M IHLP-1616BZ-01
BCIHP0420-1R2M
BCIHP0420HC-1R5M
BCIHP0420HC-2R2M IHLP-1616BZ-01
BCIHP0420-3R3M
BCIHP0420-4R7M
BCIHP0420-6R8M
BCIHP0420-8R2M
BCIHP0420-100M
BCIHP0420-220M[17]
HEAT RATING
SATU RATION
INDUCTANCE uH
DCR mΩ DCR mΩ
CURRENT
DC
AMPS
CURRENT
DC AMPS
@200KHZ,0.25V,0A(1
25℃ MAX. 25℃ Typ.
(5)
(6)
TYPICAL(Irms)
TYPICAL(Isat)
0.047
3.75
3.10
13.00[1]
32.00
0.10
10.2
7.5
8.00
25.00
0.15
13.2
9.4
7.00
23.00
0.20
13.2
9.4
7.00
23.00
0.22
12.00
9.9
8.50
15.00
0.47
22.00[5] 19.50
6.00
7.00
0.68
39.00
33.5
5.00
9.00
1.00
47.00
41.5
4.20
4.50
1.20
55.00
50.00
3.75
3.75
1.50
75.00
66.00
3.25
3.25
2.20
100.00
2.75
3.00
91.5
3.30
185.00
155.00
2.00
2.30
4.70
246.00
225.00
1.80
2.00
6.80
360.00
325.00
1.50
1.70
10.00
550.00
515.00
1.20[9]
1.50[9]
0.20
11.00
7.80
8..00
9.00
0.47
18.50
16.50
6.00
8.00
0.80
33.00
25.50
5.00
6.00
1.00
42.00
32.00
4.50
5.50
0.10
5.00
4.40
11.0[12]
28.00
[11]
0.20
7.80
11.0
8.00[12]
9.00[
11]
0.22
7.30
6.60
9.00
12.50
0.47
18.00
15.00
7.00[1
8.00[1
2]
2]
0.56
21.30
17.80
6.50
7.80
0.68
26.00
21.50
6.00
7.50
1.00
42.00[12]
31.50[1
4.50[1
7.00[
2]
2]
12]
1.20
46.00
40.00
3.50
7.50
1.50
63.00
53.50
3.30
4.00
2.20
58.00
47.00
5.00[
3.00
12]
3.30
106.00
90.00
2.50
3.00
4.70
132.00
120.00
2.40
3.00
6.80
202.00
185.00
2.00
2.50
8.20
255.00
232.00
1.60
1.80
10.00
282.00
252.00
1.60
1.80[16]
22.00
640.00
590.00
1.20
1.40
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 2 / 9
Powder Molding Type
● Specification
ITEM
BCIHP0420TB-R22N[IHLP-1616BZ-11]
BCIHP0420TB-R33M
BCIHP0420TB-R47M[IHLP-1616BZ-11]
BCIHP0420TB-R68M
BCIHP0420TB-1R0M[IHLP-1616BZ-11]
BCIHP0420TB-1R2M PCMB042T-1R2MS
BCIHP0420TB-1R5M PCMB042T-1R5MS
BCIHP0420TB-2R2M PCMB042T-2R2MS
BCIHP0420TB-3R3M [IHLP-1616BZ-11]
BCIHP0420TB-4R7M[17][IHLP-1616BZ-11]
BCIHP0420TB-5R6M[17]
BCIHP0420TB-6R8M[17]
BCIHP0430-R47M
BCIHP0430-R56M
BCIHP0430-1R0M
BCIHP0430-1R5M
BCIHP0430-2R2M
Note:
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
HEAT RATING
SATU RATION
INDUCTANCE uH
DCR mΩ DCR mΩ
CURRENT DC AMPS CURRENT DC AMPS
@200KHZ,0.25V,0A(1
25℃ MAX. 25℃ Typ. (5)
(6)
TYPICAL(Irms)
TYPICAL(Isat)
0.22
6.60
6.00
9.00
12.50
0.33
13.00
10.50
10.0
12.00
0.47
14.00
12.50 0
7.00
9.50
0.68
26.00
19.50
6.00
7.50
1.00
27.00
23.50
4.50
7.00
1.20
29.00
25.00
4.50
7.00
1.50
46.00
41.50
4.00
6.00
2.20
58.00
52.50
3.00[13]
5.00
3.30
87.00
80.00
2.50
4.00
4.70
110.00
92.50
2.00
3.50
5.60
125.00
107.50
2.20
3.00
6.80
172.00
150.00
2.10
2.80
0.47
16.00
15.00
7.50
8.50
0.56
19.30
16.50
7.00
8.00
1.00
43.50
38.80
3.50
5.00
1.50
63.80
49.00
4.00
4.50
2.20
65.00
55.00
4.00
4.00
Tolerance of Inductance: N=±30% ,M=±20%.
All test data is referenced to 25℃ ambient.
Inductance is measured at 200KHz. 25℃ ambient.
Operating Temperature Range-40℃ to +125℃.
DC current (Irms) (A) that will cause an approximate △T of 40℃.
DC current (Isat) (A) that will cause Lo to drop approximately 20%.
BCIHP0410/BCIHP0420TB-Seraes DC current (Isat) (A) that will cause Lo to drop approximately 30%.
The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all
affect the part temperature Part temperature should be verified in the end application.
電感的公差:N=±30%,M=±20%.
所有的測試資料應該是在 25℃的環境溫度下測試.
感值測試頻率 200KHz.
操作溫度範圍-40℃到+125℃.
加 DC(Irms)電流值(A)會導致△T 40℃左右的變化.
加 DC(Isat)電流值(A)會導致初始值下降 20%左右.
BCIHP0410/BCIHP0420TB-Seraes 加 DC(Isat)電流值(A)會導致初始值下降 30%左右.
產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度,氣流
和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證.
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 3 / 9
Powder Molding Type
● Material List
NO
1
2
ITEM
Core
Wire
External Electode
3
Electroplating
4
Paint
Materials
Magnetic Metal Powder or equivalen
Polyester Wire or equivalen
Copper
Ni/Sn
Epoxy resin
● Packaging Information
(1) Reel Dimension & Tape Dimension / Packaging Quantity.
ITEN
DIMENSIONS (m/m)
Q’TY (PCS) W1±0.3
W2±0.5
W±0.3
P±0.1
F±0.1
T±0.05
BCIHP0412
4,000
12.80
17.00
12.00
A0±0.1 B0±0.1 K0±0.1
4.30
4.60
1.50
8.00
5.50
0.30
BCIHP0418
3,000
12.80
17.00
12.00
4.30
4.60
2.20
8.00
5.50
0.30
BCIHP0420
3,000
12.80
17.00
12.00
4.30
4.60
2.20
8.00
5.50
0.30
BCIHP0420TB
3,000
12.80
17.00
12.00
4.30
4.60
2.20
8.00
5.50
0.30
BCIHP0430
2,000
12.80
17.00
12.00
4.30
4.60
3.20
8.00
5.50
0.30
(2) Tearing Off Force
The force tearing off cover 10 to 130 grams
(0.1N to 1.3N) in the arrow direction under the
following conditions.
● Storage conditions/Note things
(1) Storage temperature and humidity conditions :
1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH.
2. Product alone: -20℃~+60℃ and less than 60% RH.
(2) Products should be used within 6 months.
(3) The packaging material should be kept where no chlorine or sulfur exists in the air.
(4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of
solder ability.
(5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(6) Bulk handling should ensure that abrasion and mechanical shock are minimized.
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 4 / 9
Powder Molding Type
● Inside and Outside package for standard
ITEM
Packing method & Dimensions
Box Size
W=345mm
D=345mm
H=185mm
ITEM
BCIHP0412
Packing Quantity
4,000 Pcs/Reel (0.76Kg(Ref))
Reel Quantity
8 Reel/Box
Total Quantity
32,000 Pcs/Box (6.80Kg(Ref))
BCIHP0418
3,000 Pcs/Reel (0.80Kg(Ref))
8 Reel/Box
24,000 Pcs/Box (7.20Kg(Ref))
BCIHP0420
8 Reel/Box
BCIHP0420TB
8 Reel/Box
BCIHP0430
2,000 Pcs/Reel (0.85Kg(Ref))
8 Reel/Box
16,000 Pcs/Box (7.60Kg(Ref))
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 5 / 9
Powder Molding Type
● General Characteristics
Operation Temperature
External Appearance
-40℃ to +125℃ (Includes temperature when the coil is heated)
On visual inspection, the coil has no external defects.
● Electrical Performance Test
Inductance
DCR
Refer to standard electrical characteristics list.
Saturation Current(Isat)
Heat Rated Current(Irms)
BCIHP0412/18/20/30-Series △L≦20% typical.
BCIHP0410/0420TB-Series △L≦30% typical.
Approximately △T≦40℃.
● Reliability Test
Solder Ability Test
1. More than 90% of terminal electrode should be covered with solder.
After fluxing, component shall be dipped in
a melted.
Solder: bath at 245℃±5℃ for 5±0.5
seconds.
1.
2.
Heat resistance of
Reflow Soldering Test
1.
Adhesion strength
Test
Components should have not evidence of electrical and mechanical damage.
Inductance: within±10% of initial value.
Preheat:150±5℃ 60seconds.
Solder temperature: 255+5℃/-0℃.
Flux: rosin.
Dip time:10±0.5seconds.
No apparent damage
Product is mounted on PCB. Thereafter R340
pressure fixture is used to apply pressure to product
from backside of the board at a rate of approx.
1mm/sec. until bending width becomes 1mm and
keep it for 5sec.
1. No separation or indication of electrode.
Welding strength Test A static load using a R5.0 pressing tool shall be applied to the
body of the specimen in the direction of the arrow and shall
be hold for 3±1 sec.
Insulating Resistance Over 100MΩ at 100V D.C. between coil and core.
Dielectric Strength
Vibration Test
Drop Test
No dielectric breakdown at 30V D.C. for 1 minute between coil and core.
1. No separation or
Inductance deviation within +10% after vibration for 1
hour. In each of three orientations at Sweep vibration
indication of
(10~55~10HZ) with 1.5mmP-P amplitudes.
electrode.
Inductance deviation within +10% after being dropped
2. △L/L≦15%
once with 981m/s2 (100G) shock Attitude upon a rubber
block method shock testing machine, in three different
orientations.
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 6 / 9
Powder Molding Type
● Reliability Test
Item
High Temperature
Storage Test
Low Temperature
Storage Test
High Temperature
Humidity Test
Thermal Shock Test
Storage Test
Required Characteristics
1. No case deformation or change in appearance
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
Test Method/Condition
Temperature:125℃±3℃ Time:96±2 hours.
Tested not less than 1 hour, nor more than 2
hours at room.
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
Temperature:-40℃±3℃ Time:96±2 hours.
hours at room.
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
Temperature:85℃±3℃.
Humidity:85±5%RH
Test Time:96±2 hours
Tested not less than 1 hour. Nor more than 2
hours at room temperature.
1.
2.
3.
4.
△L/L≦15%
△Q/Q≦30%
DCR/DCR≦15%
First–40℃ for 30 Minutes, last 125℃ for 30
Minutes as 1 cycle. Go through 20 cycles.
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 7 / 9
Powder Molding Type
● Soldering re-flow
IPC/JEDEC J-STD-020C, Figure 5-1
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 8 / 9
Powder Molding Type
● Modify records
Numbering
Date
[1] [
2]
[3]
[4]
[5]
[6]
[7]
[8]
[9]
[10]
[11]
[12]
[12]
[12]
[12]
[13]
[14]
[15]
[16]
[17]
2015/4/29
2015/4/29
2015/4/29
2015/4/29
2015/4/29
2015/4/29
2015/4/29
2015/5/9
2015/5/9
2015/5/9
2015/8/21
2015/8/21
2015/8/21
2015/8/21
2015/8/21
2015/10/28
2015/11/16
2015/11/16
2015/11/16
2015/11/16
2018/6/8
[18]
Modify content
BCIHP0412-47NN Irms:12A>13A.
BCIHP0412-R10N DCR:10.2mΩ>6.0mΩ. Irms:10A>11.5A. Isat:15A>25A.
BCIHP0412-R20N Isat:10A>20A.
BCIHP0412-R22N Isat:12A>20A.
BCIHP0412-R47N DCR:26mΩ>22mΩ. Irms:6A>5A. Isat:7A>13A.
BCIHP0412-R68N DCR:39mΩ>31.4mΩ. Irms:3.3A>4.9A. Isat:9A>9.3A.
BCIHP0412-1R0N DCR:55.5mΩ>52.5mΩ. Irms:4.5A>4A.
BCIHP0410-100M DCR:550mΩ>800mΩ.
BCIHP0412-100M Irms:0.90A>1.20A. Isat:1.00A>1.50A.
BCIHP0412-R68N Isat:7.0A>9.3A.
BCIHP0420-R10N Isat:22A>35A.
BCIHP0420-R10N Irms:12A>11A.
BCIHP0420-R47M Irms:7A>5.6A. Isat:8A>11.50A.
BCIHP0420-1R0N DCR:42mΩ>37mΩ. Irms:4A>3.75A. Isat:5.7A>8.5A.
BCIHP0420-2R2M Isat:3A>6A.
BCIHP0420TB-2R2M Irms:3.0A>3.25A
Added BCIHP0412-1R5M.
Added BCIHP0420-R22M. BCIHP0420-R20M
BCIHP0420-100M Isat:1.8A>2.3A.
Added BCIHP0420-220M’BCIHP0420TB-4R7M’BCIHP0420TB-5R6M’BCIHP0420TB-6R8M
删除未量产过机种,已量产机种实际参数为准!
www.baocheng.biz
17 March 2015
TAPE BCIHP04-Series P: 9 / 9
很抱歉,暂时无法提供与“BCIHP0420TB-1R5M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.94854
- 50+1.54030
- 150+1.36534
