LRP12FTDSR035
LRP12FTDSR035
    VIKING(光颉)
    电流采样电阻 2512
LRP12FTDSR035 数据手册
Data Sheet Customer: Product: Low Ohm (Metal Strip) Chip Resistor – LRP Series Size: 1206 / 2512 Issued Date: 03-Aug-18 Edition: REV.A7 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 03-Aug-18 03-Aug-18 03-Aug-18 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) LRP Series Low Ohm (Metal Strip) Chip Resistor Low Ohm (Metal Strip) Chip Resistor- LRP Series Features High power rating up to 3 Watts Low TCR down to ±50 PPM/°C Resistance values from 3m to 200m Customized resistance available AEC-Q200 Compliance ( LRP12 3m to 200m ) Applications NB (for Power Management) MB (for Power Management) SWPS (DC-DC Converter, Charger, Adaptor) Monitor (for Power Management) Derating Curve Part Numbering LRP Product Type 12 Dimensions (L×W) 06: 1206 12: 2512 www.viking.com.tw F T D Resistance Tolerance D: ±0.5% F: ±1% J: ±5% Packaging Code TCR (PPM/°C) T: Taping Reel D: ±50 W: ±75 E: ±100 S Power Rating R: 3W S: 2W T: 1W For detail questions, contact : sales@viking.com.tw 1 R015 Resistance R015: 0.015Ω R050: 0.05Ω Edition : REV.A7 Revision: 03-Aug-2018 LRP Series Low Ohm (Metal Strip) Chip Resistor Construction  Alloy Plate  Overcoat  Internal Electrode  Barrier Layer  Marking  Solder Plating Dimensions Type Size (Inch) L (mm) W (mm) T (mm) D (mm) LRP06 1206 3.10±0.10 1.60±0.10 0.60±0.10 0.45±0.15 LRP12 2512 6.40±0.25 3.20±0.25 0.70±0.20 0.90±0.30 Electrical Specifications Item Type Power Rating at 70°C Resistance Range (mΩ) Operating Temp. Range ±0.5% LRP06 (1206) 1W ±1% 8 -55 ~ +170C 10 12 15 TCR (PPM/°C) ±5% 20 ±100 15, 18, 20, 22, 25, 30, 33, 35, 39, 40, 47, 50, LRP12 (2512) 2W, 3W -55 ~ +170C 60, 68, 70, 75, 80, 82, 90, 91, 100, 120, 150, 180, 200 3, 4, 5, 6, 7, 8, 9, 10, 12, 15, 18, 20, 22, 25, 30, 33, 35, 39, 40, 47, 50, 60, 68, 70, 75, 80, 82, 90, 91, 100, 120, 150, 180, 200 ±50 ±75 Operating Current =√(P/R) , Operationg Voltage=√(P*R) Viking is capable of manufacturing the optional spec based on customer’s requirement. Soldering Condition (Reflow Soldering Only) IR Reflow Soldering (1) Time of IR reflow soldering at maximum temperature point 260C:10s Notice:Wave soldering and hand soldering are not available. www.viking.com.tw For detail questions, contact : sales@viking.com.tw 2 Edition : REV.A7 Revision: 03-Aug-2018 LRP Series Low Ohm (Metal Strip) Chip Resistor Environmental Characteristics Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. IEC60115-1 4.8 JIS-C-5201-1 4.8 +25C ~125C, 25C is the reference temperature Short Time Overload 1.0% IEC60115-1 4.13 JIS-C-5201-1 4.13 5*rated power for 5 seconds Insulation Resistance 10G IEC60115-1 4.6 JIS-C-5201-1 4.13 100V DC for 1 minute Endurance 1.0% IEC60115-1 4.25 JIS-C-5201-1 4.25.1 702C, rated power for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” Biased Humidity 1.0% Dry Heat 1.0% IEC60115-1 4.23.2 JIS-C-5201-1 4.23.2 at +170C for 1000 hrs Bending Strength 1.0% JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending width 2mm once for 5 seconds Solderability 95% min. coverage JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds Resistance to Soldering Heat 0.5% JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds Rapid Change of Temperature MIL-STD-202 Method 103 1000 hrs 85C/85%RH 10% of operating power JIS-C-5201-1 4.19 IEC-60115-1 4.19 1.0% -55C to +155C, 5 cycles Low Temperature Storage IEC60115-1 4.23.4 JIS-C-5201-1 4.23.4 at -55C for 2 hrs 1.0% RCWV(Rated Continuous Working Voltage)= √(P*R) or Max. Operating Voltage whichever is lower. ■Storage Temperature: 15~28C; Humidity < 80%RH www.viking.com.tw For detail questions, contact : sales@viking.com.tw 3 Edition : REV.A7 Revision: 03-Aug-2018 LRP Series Low Ohm (Metal Strip) Chip Resistor Packaging Reel Specifications & Packaging Quantity Type Resistance (mΩ) LRP06 8~20 Paper LRP12 4~200 LRP12 3 Tape Width Reel Diameter ΦA (mm) 5K 8mm 7 inch 178.5±1.5 Embossed 4K 12mm 7 inch Embossed 2K 12mm 7 inch Packaging Quantity ΦB (mm) ΦC (mm) W (mm) T (mm) +1/-0 13.0±0.2 9.0±0.5 12.5±0.5 178.5+/-1.5 60±1.0 13.0±0.5 13.0±1.0 15.5±0.5 178.5+/-1.5 60±1.0 13.0±0.5 13.0±1.0 15.5±0.5 60 Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B T P1 Resistor P2 P0 Direction of unreeling ψD11.5+0.25,-0 Embossed Tape Type A (mm) B (mm) LRP12 3.50±0.10 6.70±0.10 LRP12 (3mΩ) 3.50±0.10 6.70±0.10 W (mm) E (mm) P2 (mm) ΦD0 (mm) F (mm) P0 (mm) P1 (mm) T (mm) 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.45±0.2 1.20+0 Paper Tape Specifications Bottom Tape Top Tape ψ D0 E A F W B T Paper Tape P1 Resistor P2 P0 Direction of unreeling Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) LRP06 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 P2 (mm) ΦD0 (mm) T (mm) 2.00±0.05 1.50+0.1,-0 0.85±0.10 Recommend Land Pattern C B A www.viking.com.tw Type A (mm) B (mm) C (mm) LRP06 1.50 1.40 1.70 LRP12 4.00 2.00 3.50 *FR4 copper board, 100µm of copper pad thickness For detail questions, contact : sales@viking.com.tw 4 Edition : REV.A7 Revision: 03-Aug-2018 LRP Series Low Ohm (Metal Strip) Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version A Apr 30, 2015 - - First issue of this specification Version A1 Jul 30, 2015 - - Add 0.5% Resistance Range Version A2 Nov 27, 2015 - - Change TCR75 ppm Resistance Range 10mR~100mR 7mR~100mR Version A3 Jul 15, 2016 - - Remove Material Description - Modify Storage Temperature Version A4 Jun 01, 2017 - - Add 1206 Size Resistance Range - Add 2512 Size R003~R006 TCR75ppm Version A5 Nov 02, 2017 - Version A6 Jan 12, 2018 - - Environmental Characteristics update - Electrical Specifications update Version A7 Aug 03, 2018 - - Electrical Specifications update www.viking.com.tw DESCRIPTION - Features Item Add AEC-Q200 Compliance (LRP12 7m to 100m For detail questions, contact : sales@viking.com.tw 5 ) Edition : REV.A7 Revision: 03-Aug-2018
LRP12FTDSR035 价格&库存
很抱歉,暂时无法提供与“LRP12FTDSR035”相匹配的价格&库存,您可以联系我们找货
