CXC5X271200CLVRB00
CXC5X271200CLVRB00
    PARTRON(帕创)
    SMD2016_4P
    无源晶振 SMD2016_4P
CXC5X271200CLVRB00 数据手册
APPROVAL SHEET PRODUCT NAME SMD CRYSTAL UNIT FREQUENCY 27.1200MHz (10.0pF) USER PART NO. PARTRON MODEL CXC5X271200CLVRB00 Issued by Checked by Approved by Issued by Checked by Approved by In Charge J.S.B. M.N.S. K.J.M. Division R & D Q C R & D CUSTOMER PARTRON MSL LEAD FREE Halogen-Free MSL LEVEL 1 ※ Please return one copy with approval to PARTRON 2013. 11. 05 22-6, Seokwoo-dong, Hwaseong-si, Gyeonggi-do, Korea TEL : (031)201-7750 A1-PTR A717 - 1 /15- Contents A1-PTR A717 1. Revision History - - - 2. Electrical characteristics - - - 4 3. Mechanical characteristics - - - 6 4. A Primary test result - - - 7 5. Reliability test - - - 8 6. Construction - - - 9 7. Notices - - - 10 8. Packing - - - 11 3 - 2 /15- 1. Revision History Rev. Date Rev. page Revision Content and Reason V1.0 '13.11.05 All Page First-edition A1-PTR A717 Remark - 3 /15- 1. Scope This document contains specifications related to Crystal Unit. 2. Electrical Characteristics No. Item Symbol 2.1 Frequency fo 2.2 Frequency Tolerance 2.3 Temperature range Content 27.1200 MHz Δf/fo ± 30 ppm (@+25℃ ±2℃) Storage TSTG -40 to 85℃ Operating TOPR -40 to 85℃ Δf/fo ± 30ppm CTQ 2.4 Frequency stability 2.5 Drive level DL 100 uW max. 2.6 Equivalent series resistance R1 80 Ω max. 2.7 Oscillation mode O/T Fundamental 2.8 Shunt capacitance CO 3.0 pF Max 2.9 Motional capacitance C1 10.0 fF Max 2.10 Load capacitance CL 10.0 pF 2.11 Aging fa ± 5ppm Max / year 2.12 Insulation resistance IR 500 MΩ min @ 100VDC [REMARK] A1-PTR A717 - 4 /15- 2-1 Crystal Equivalent Circuit and Application Circuit [Crystal and equivalent circuit] [Application circuit for oscillation] A1-PTR A717 - 5 /15- 3. Mechanical characteristics 3-1 Outline Dimensions and Pin connections Pin connections #1 HOT #2 #3 #4 GND HOT GND [Recommended solder pad layout] 3-2 Marking and LOT No ITEM 19 26 200M 00M P 27 1 ① ② MARKING ① P Partron logo ② 27 1 Frequency: 27.1200MHz ③ XX CRYSTAL CL 24 00M xx YMD S ③ ④ Y : the last 1 digit of year ⑤ ※Laser Marking REMARK M : 1 digit of month (Jan to Sept; 1 to 9, Oct; A,Nov B, Dec;C) ④ YMD D : 1 digit of day 1 to 9, A to V (A=10, V=31) EX) 769 = 2007.06.09, 8AS = 2008.10.28 Manufacturing Site ⑤ A1-PTR A717 S K .. Korea C .. China - 6 /15- 4. A Primary test result 4-1 Electrical Characteristics Testing Data A1-PTR A717 - 7 /15- 5. Reliability test 5.1 Environment Test Contents Condition Remark High temperature Storage +125℃±5℃, 240 hr *Testing is complete, leave at room temperature for -55℃±5℃, 240 hr Low temperature Storage High temperature High humidity Storage 24 hours, and Measure.(25℃±5℃) +85℃±5℃, RH=85%, 96 hr * Be satisfied with contents No 2. +121℃±5℃, RH=100%, 24hr PCT Specification 5.2 Thermal shock , Reflow Test Contents Condition Remark *Testing is complete, leave Thermal shock -40℃±5℃,+85℃±5℃, 30 min, 32 cycle at room temperature for 24 hours, and Measure.(25℃±5℃) REFLOW Pre Heating 200±5℃ , 30∼60 sec Peak Heating 260℃±5℃ , 30sec Max * Be satisfied with contents No 2. Specification 5.3 Mechanical Test Contents Condition Remark *Testing is complete, leave Vibration Frequency : 10~500Hz, 10 ×9.8㎨(G) Sweep time 15min ,X.Y.Z each 5 times at room temperature for 1 hours, and Measure.(25℃±5℃) 12 times falling at a 152cm height Drop test (falling with jig) * Be satisfied with contents No 2. Specification 5.4 Table Frequency change permitted A1-PTR A717 ±3ppm Max. - 8 /15- 6. Soldering Condition 6.1 Standard Reflow soldering condition Max temp 최대 온도 240 ±5 ℃ 240℃ 200℃ 160℃ pre heating 예열 130 ~ 130~180℃ 180℃ 100℃ 25℃ 0℃ 90 sec 90 ~180 ~ 180초 최대 30초 max 30sec 30~60sec 30∼60 초 6.2 The maximum temperature guarantees to the 260℃(10sec Max) 6.3 Soldering Iron Method - Pre heating - Max temp - Time A1-PTR A717 : 120℃ (30 ~ 300 sec) : 410℃ Max : Max 4 sec - 9 /15- 7. Construction I Ceramic package 2 Crystal blank 5 Electrode 3 Conductive epoxy 4 Cover A1-PTR A717 No item 1 Ceramic package 2 Crystal blank 3 Conductive Epoxy 4 Lid(Cover) 5 Electrode - 10 /15- 8. Notices 8-1 Max. two(2) times reflow is allowed. Once miss soldering is happen, hand work soldering by soldering iron is recommended. (+400℃ x within 5 sec) 8-2 Ultrasonic vibration may cause deterioration and destruction of the components. Please avoid ultrasonic cleaning 8-3 We recommend storing products at +15℃ to +35℃ and 25% R.H to 75% R.H 8-4 ESD Level : 8-5 MSL LEVEL 1 (JEDEC J-STD-020C) ITEM 1 Class2(2000V ~ 4000V) Floor Life Soak Requirements Time Conditions Time Conditions Unlimited =< 30℃/85%RH 165+5/-0 =< 85℃/85%RH 8-6 Unless adequate negative resistance is allocated in the oscillation circuit, start up time of oscillation may be increased, or no oscillation may occur. In order to avoid this, please provide enough negative resistance in the circuit design. ◎ How to check the negative resistance (1) Connect the resister (R) to the circuit in series with the crystal resonator. (2) Adjust R so that oscillation can start (or stop). (3) Measure R when oscillation just start (or stop) in above (2). (4) Get the negative resistance -R = R + CI value (5) Recommended -R [-R] > CI × 5 A1-PTR A717 - 11 /15- 9. Packing 9.1 Reel, carrier tape material item Main Material Cover Tape PE (Polyester film) Carrier Tape PC (Poly Carbonate +Carbon) or (Clear Poly Carbonate) Reel PS (Poly Styrene) 9.2 inner Box :1 reel/inner box and 2,000 pcs/1 reel. 9.3 Outer Box : 10 inner boxes/Outer Box Total 20,000 pcs are packed in a 1 outer box 9.4 Reel and Carrier tape dimensions(unit : mm) ■ Carrier tape *Heating press cover tape A1-PTR A717 - 12 /15- 9.5 Reel Dimensions (unit : mm) Customer LABEL Process LABEL A1-PTR A717 - 13 /15- 9.6 Tape and Reel Leader Trailer Top Tape 200 min Empty Pockets 150 min Products Empty Pockets 150 min Top Tape 250 min Unreeling Direction A1-PTR A717 - 14 /15- 9.7 Inner, outer box Dimensions (unit : mm) customer label MSL LEVEL 1 Process label RoHS Pb ESD Pb-free RoHS RoHS A1-PTR A717 - 15 /15-
CXC5X271200CLVRB00 价格&库存
很抱歉,暂时无法提供与“CXC5X271200CLVRB00”相匹配的价格&库存,您可以联系我们找货
