CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 1 OF 15
0201 Series Thin Film Chip Inductor (Lead / Halogen Free)
1. Scope
This specification applies to 0.6mm x 0.3mm (0201) size, fixed thin film chip inductor
rectangular type.
2. Type Designation
CML 0306 - *** - * NH
(1)
(2)
(3)
(4) (5)
Where (1) Product Type
CML : fixed thin film chip inductor
(2) Size
0306 : 0.30 × 0.60mm
(3) Nominal inductance value : three digits of number, refer to Table 1.
The nominal inductance value shell is represented by two significant figures and
a code “N” representing the unit.
(4) Tolerance
B : ±0.1nH ; C : ± 0.2nH ; S : ± 0.3nH
H : ± 3% ; J : ± 5%
(5) NH = Sn plating ( Lead free / Halogen free)
3. Construction and Physical Dimensions
L
a
a
W
Code Letter
Dimensions
L
0.61 ± 0.05
W
0.31 ± 0.05
t
0.28 ± 0.05
a
0.08 ± 0.05
b
0.15 ± 0.05
Unit : mm
t
b
Downloaded from DatasheetLib.com - datasheet search engine
Note :
① Coil : Cu
② Electrode : plating
Sn plating (Lead free)
③ Protective Coat : Epoxy Resin coating
④ Substrate : Alumina ceramic
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 2 OF 15
4. Specifications
Table 1
Electric Specification Characteristics
Inductance
Tolerance
(nH)
CML0306-0N6
± 0.1nH
CML0306-0N7
CML0306-0N8
± 0.2nH
CML0306-0N9
CML0306-1N0
± 0.3nH
CML0306-1N1
CML0306-1N2
CML0306-1N3
CML0306-1N4
CML0306-1N5
CML0306-1N6
CML0306-1N7
CML0306-1N8
CML0306-1N9
CML0306-2N0
CML0306-2N1
CML0306-2N2
CML0306-2N3
CML0306-2N4
CML0306-2N5
CML0306-2N6
CML0306-2N7
CML0306-2N8
CML0306-2N9
CML0306-3N0
CML0306-3N1
CML0306-3N2
CML0306-3N3
CML0306-3N4
CML0306-3N5
CML0306-3N6
CML0306-3N7
Q
min.
--------------4
4
4
4
4
4
4
4
4
4
4
4
4
4
5
5
5
5
5
5
5
5
5
5
5
LQ
Meas.
Freq.
(MHz)
100
Self Resonance
Freq.
(MHz)min.
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
6000
DC Resistance Rated Current
(Ω
Ω)max.
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.12
0.13
0.16
0.16
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.23
0.25
0.25
0.25
0.25
0.25
0.30
0.32
0.32
0.32
0.40
(mA)
500
490
490
480
470
460
450
440
440
430
420
410
390
390
380
370
360
360
350
340
340
340
330
330
330
330
330
320
310
310
310
300
CYNTEC CO., LTD.
乾坤科技股份有限公司
CML0306-3N8
CML0306-3N9
CML0306-4N3
CML0306-4N7
CML0306-5N1
CML0306-5N6
CML0306-6N2
CML0306-6N8
± 3%
CML0306-7N5
CML0306-8N2
± 5%
CML0306-9N1
CML0306-10N
CML0306-12N
CML0306-15N
CML0306-18N
CML0306-22N
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
100
: CYNP-8Z-031
REVISION
PAGE
: A5
: 3 OF 15
0.40
0.40
0.40
0.45
0.45
0.50
0.55
0.70
1.10
1.20
1.20
1.30
1.30
1.50
1.60
1.80
300
300
280
280
270
270
250
250
240
230
220
220
190
180
170
150
L, Q vs Frequency Typical Characteristics Chart
1000
80
60
100
H
n(
L
6000
6000
6000
6000
6000
6000
6000
5500
5000
5000
4500
4500
3700
3700
3100
2800
DOCUMENT
22nH
10
Q 40
15nH
10nH
6.8nH
1000
Frequency(MHz)
3.3nH
6.8nH
10nH
22nH
1.0nH
100
2.0nH
3.3nH
2.0nH
1
1.0nH
15nH
100
1000
Frequency(MHz)
10000
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 4 OF 15
L, Q vs Frequency Reference Characteristics Table
Inductance ( nH )
Part Number
Q
500MHz
800MHz
1.8GHz
2.4GHz
500MHz
800MHz
1.8GHz
2.4GHz
CML0306-0N6
0.6
0.6
0.6
0.6
25min
30min
45min
50min
CML0306-0N7
0.7
0.7
0.7
0.7
25min
30min
45min
50min
CML0306-0N8
0.8
0.8
0.8
0.8
25min
30min
45min
50min
CML0306-0N9
0.9
0.9
0.9
0.9
24min
30min
45min
50min
CML0306-1N0
1
1
1
1
25
31
45
51
CML0306-1N1
1.1
1.1
1.1
1.1
25
31
45
52
CML0306-1N2
1.2
1.2
1.2
1.2
25
31
45
52
CML0306-1N3
1.3
1.3
1.3
1.3
24
30
45
52
CML0306-1N4
1.3
1.3
1.3
1.3
22
28
41
48
CML0306-1N5
1.5
1.4
1.4
1.4
21
26
39
45
CML0306-1N6
1.6
1.6
1.6
1.6
19
23
38
43
CML0306-1N7
1.7
1.7
1.7
1.7
19
24
37
43
CML0306-1N8
1.8
1.8
1.8
1.8
19
25
38
43
CML0306-1N9
1.9
1.9
1.9
1.9
38
43
CML0306-2N0
2
2
2
2
38
42
CML0306-2N1
2.1
2.1
2.1
2.1
38
43
CML0306-2N2
2.2
2.2
2.2
2.2
21
26
38
44
CML0306-2N3
2.3
2.3
2.3
2.3
21
26
37
43
CML0306-2N4
2.4
2.4
2.4
2.4
37
43
CML0306-2N5
2.5
2.5
2.5
2.5
37
42
CML0306-2N6
2.6
2.6
2.6
2.6
19
24
35
40
CML0306-2N7
2.7
2.6
2.6
2.7
19
24
35
40
CML0306-2N8
2.8
2.8
2.8
2.8
18
23
33
38
CML0306-2N9
2.9
2.9
2.9
2.9
18
22
33
37
CML0306-3N0
3
3
3
3
17
21
32
37
CML0306-3N1
3.1
3.1
3.1
3.1
17
21
30
33
CML0306-3N2
3.2
3.2
3.2
3.3
17
21
31
35
CML0306-3N3
3.3
3.3
3.3
3.3
17
21
31
35
CML0306-3N4
3.4
3.4
3.4
3.4
17
21
31
35
CML0306-3N6
3.5
3.5
3.6
3.7
15
19
28
30
CML0306-3N9
3.7
3.7
3.8
4
17
21
31
34
CML0306-4N3
4.1
4.1
4.3
4.5
17
22
31
34
CML0306-4N7
4.5
4.5
4.7
5
16
19
28
30
CML0306-5N1
5
5
5.2
5.6
17
19
28
29
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 5 OF 15
CML0306-5N6
5.6
5.6
5.8
6.1
16
19
28
29
CML0306-6N2
6.2
6.2
6.4
6.7
16
19
27
27
CML0306-6N8
6.6
6.6
6.9
7.3
16
19
27
27
CML0306-7N5
7.3
7.3
7.8
8.4
16
19
27
27
CML0306-8N2
8
8
8.3
9.1
15
19
23
22
CML0306-9N1
8.9
8.9
9.4
10.5
12
15
CML0306-10N
10
10
11
12.5
15
17
CML0306-12N
12
12
14
18
13
15
18
15
CML0306-15N
15
15
18
13
15
18
CML0306-18N
18
18
24
13
15
17
CML0306-22N
22
24
15
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 6 OF 15
5. Characteristics
Unless otherwise specified, the standard range of atmospheric conditions for marking measurements
tests is as follows;
Temperature
24 ± 5℃
Relative humidity
45 to 85%RH
Air pressure
86 to 106kPa
If there is any doubt about results, measurements shall be made within the following limits;
Temperature
20 ± 2℃
Relative humidity
60 to 70%RH
Air pressure
86 to 106kPa
5-1 Electrical
Item
Inductance
Conditions
DC Resistance
Measurement shall be performed by
Impedance Analyzer 4287A with the
frequency specified in Table 1.
Refer to IEC 60115-1, Sub-clause 4.5.
Self Resonance
Frequency
Measurement shall be performed by Network
Analyzer Agilent N5230A.
Temperature
Coefficient
Measurement shall be performed at RT and
RT+100℃ , and the calculation shall be performed
with the measured values.
Overload
Test current : 2 times of the maximum current.
Duration : 5 minutes
Q value
Specifications
Refer to Table 1.
Refer to Table 1.
DC Resistance shall be
within the specified
tolerance.
Self resistance frequency
shall be within the
specified frequency.
( Table 1.)
TCL:0 ~ +125 ppm/℃.
TCQ: -0.25% ~ 0%/℃
TCR:0 ~ +0.45% /℃
No smoke, Fire nor
significant damage shall
be observed.
CYNTEC CO., LTD.
乾坤科技股份有限公司
Item
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 7 OF 15
Conditions
Specifications
Rated Current
Rated current shall be the current with which the
temperature raise of the inductor becomes 20℃.
Refer to Table 1.
Insulation
Resistance
(1) Between Electrode
Place the specimen on the groove of metal plate so
and insulating
that the edge of metal block positions almost center
enclosure.
of both electrodes, with the surface of insulation
100MΩ or more
enclosure located downward or upward and
(2) Between Electrode
pressurize the block by a force or 1.0 ± 0.2N.
The test voltage shall be 100 ± 15Vdc, and maintain
and base material
this voltage for about 1 minute. The insulation
1,000MΩ or more
resistance shall then be measured while applying the
voltage.
Insulation plate
Measurement Point A on metallic block
Measurement Point B
on metallic plate
R0.25mm~R0.5mm
Insulating enclosure surface
Spring
Specimen
Figure 2 : Measurement Setup
Refer to IEC 60115-1, Sub-clause 4.6
Voltage Proof
The inductor shall be tested as shown in Figure 2.
Test Voltage : 100VAC (rms.) for 60 ± 5 seconds
Refer to IEC 60115-1, Sub-clause 4.7.
No mechanical damage
shall be observed.
Electrical
characteristics shall be
within specification.
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 8 OF 15
5-2 Mechanical
Item
Substrate
bending test
(Bond strength
of the face
plating)
Conditions
Specifications
Apply pressure in the direction of the arrow at a rate
of about 1mm/s. until bent width reaches 3 mm and
hold for 30 seconds.
Testing board A
DC Resistance
Characteristics shall be
Within ±2mm
Solder
45
Supports
Unit : mm
Specimen
shall be observed.
45
( 5)
Amplitude of bend 3mm
50
Pressure
Press Jig
R230
Refer to IEC 60115-1, Sub-clause 4.33
Body Strength
A load of 10N (1.02kgf) using a R0.5 pressure rod
shall be applied to the center in the direction of
arrow and held for 10 ± 1 seconds.
Pressure rod
Loading
R0.5
Specimen
1/2L
L
Unit : mm
shall be observed.
Electric haracteris-tics
shall be within
specification.
CYNTEC CO., LTD.
乾坤科技股份有限公司
Item
Resistance to
Soldering Heat
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 9 OF 15
Conditions
Specifications
(1) Solder bath method
Pre-heat : 100 to 110℃
30 seconds
Temperature : 270 ± 5℃
10 ± 1seconds
(2) Reflow Soldering method
Peak temperature : 260 ± 5℃ 10seconds or less
Temperature : 220 ± 5℃
60 seconds max.
2cycles or less
The temperature shall be board surface
temperature
shall be observed.
Electrical characteristics
shall be within
specification.
(3) Soldering iron method
Bit temperature : 350 ± 5℃
Time : 3 +1/-0 seconds
The specimen shall be stored at standard
atmospheric conditions for 1hour after which the
measurement shall be made.
Refer to IEC 60115-1, Sub-clause 4.18
Solderability
Solder temperature : 245 ± 5℃
Duration of immersion : 2 ± 0.5 seconds
A new uniform coating
of 95% of the surface
being immersed.
Refer to IEC 60115-1, Sub-clause 4.17
Solvent
Resistance
Immersion cleaning
At normal temperature 5 minutes Isopropyl alcohol.
Without distinct damage
in appearance.
Refer to IEC 60115-1, Sub-clause 4.29
5-3 Endurance
Item
Rapid change of
temperature
Conditions
Specifications
The specimen shall be subjected to 5 continuous
cycles, each as shown in the figure below.
Temperature
1
-40 ± 3℃
2
Room temperature
3
+125 ± 2℃
4
Room temperature
Use for Testing board B
Time
30 minutes
2 ∼ 3minutes
30 minutes
2 ∼ 3minutes
Refer to IEC 60115-1, Sub-clause 4.19
shall be observed.
shall be within
specification.
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 10 OF 15
Mounting of the test sample onto the test board shall be either of following methods.
(1) Mounting by solder dipping
Epoxy based glue shall be applied in the middle of two lands of the test board. The
resistor shall be mounted in such a way that the electrodes of resistors will be evenly
placed in the land area and then adhesive resin shall be cured. After applying the Resin
Flux with 25 weight % Methyl Alcohol, the board shall be soldered by dipping into a
molten solder bath with 260 ± 5℃ for 3 to 5 seconds
(2) Mounting by Reflow soldering
Solder paste with approximate 100μm thickness shall be applied to the land of test board.
The resistor shall be mounted in such way that the electrodes of resistors will be evenly
placed in the land area and then shall be soldered under the circumstance that the surface
temperature of the board shall be raised 245 ± 5℃(peak) for 5 to 10 seconds in an
upper-heater oven.
Test board
Material : Glass Fabric Epoxy Resin ( Refer to JIS C 6484 )
Board thickness : 1.6mm
Copper foil thickness : 0.035mm
Solder Resist Coating
Land
15 ± 1
7.5
a
3.0
33.0
P/N
3.0
2.0
20.0
10.0
35.0 ± 1
a
b
c
0.28 ± 0.02 0.34 ± 0.02 0.76 ± 0.04
Unit : mm
40 ± 1
21 ± 1
8.0
4.0 ± 1
16.0
4.0
b
11.0
15 ± 1
100 ± 1
f
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 11 OF 15
+0.0
58.5-1.0
1.24
5.08
1.32
1.22
2.00
0.5
1.35
0.42
0.42
Unit : mm
1.35
1.32
+0.05
0.36-0.00
25.0 ± 1.0
3.0 3.0
15.10
1.2
16.5
50.5
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 12 OF 15
6. Packaging
6-1 Dimensions
6-1-1 Tape Packaging Dimensions
1.5 +-0.1
0.0
0.3 ± 0.05
4.0 ± 0.1
Sprocket hole
3.5 ± 0.05
B
Inductor
1.75 ±0.1
8.0 ± 0.3
A
Carrier cavity
0.42 ± 0.05
4.0 ± 0.1
2.0 ± 0.05
Pull Direction
※ “Bottom less type” of tape is used.
※ Pre.emptied holes:150 holes (or 30cm) or more
Code Letter
A
B
Dimension
0.70 ± 0.03
0.43 ± 0.03
Unit : mm
6-1-2 Reel Dimensions
13 ± 1.4
50
105
2 ± 0.5
13 ± 0.2
+1
60-0
21 ± 0.8
R1
Label
+0
180-3
9 ± 0.3
Unit : mm
Plastic Reel Thickness : 0.5mm
Plastic Reel : Correspond with EIAJ RRV08B
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 13 OF 15
6-2 Peel Strength of Top Cover Tape
The peel speed shall be about 300 mm/minute
The peel strength of top cover tape shall be between 0.1 to 0.7N.
Top Cover Tape
165 ~ 180
Pull out
0.1 ~0.7N
Bottom Cover Tape
Carrier Tape
6-3 Quantity per Reel
10,000 pieces / reel
6-4 Label Marking
The following items shall be marked on the reel.
(1) Manufactures parts number
(2) Quantity
(3) Manufacturing date code
(4) Manufacturer’s name
(5) The country of origin
(6) Shipping number
(7) Identification showing lead-free products.
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
REVISION
PAGE
: A5
: 14 OF 15
7. Precautions
7-1 Storage
(1) The product shall be stored in a room where temperature and humidity must be controlled.
(temperature: 5-35℃, humidity : 45-85% RH).
However, humidity keeps it low, as it is possible.
(2) The product shall be stored as direct sunshine doesn't hit on it.
(3) The product shall be stored with on moisture, dust, a material that will make solderability
inferior, and a harmful gas (hydrogen chloride, sulfurous acid gas, and hydrogen sulfide).
(4) The product shall be stored as tape packaging condition.
7-2 Term for use
(1) The term for use is within one year from the shipping day of the product.
(2) If the product has been left unused for more than one year after delivered, check solderability
before use.
7-3 Chip mounting
(1) When chip are mounted on PC board, protective coat of the product must not be scratched. If
it will be scratched, it will make characteristic inferior.
(2) In case that product will be soldered by soldering iron, heating shall be done on the land, and
soldering iron must not hit on the product itself.
(3) In case that resin coating or resin seal will be made for a PC board after chip mounting, do
washing and drying it enough before coating or sealing. If ion bear or moisture will be sealed
in resin coating, it will make characteristic inferior.
(4) For resinous use, it is necessary to set up enough the curing conditions. As it gets improper
for the condition, changes of a resistance value are large and are a case.
(5) According to shape, material, and pressure of clamping in chip mounting machine, there is
the case that crack will be appeared on the product.
Control a shock energy for clamping the product under 7 x 10-4 J .
With a shock energy around clamping that says here, it is suited to a potential energy, in case
that iron block of 25 g is dropped naturally to the product placed on iron plate for the height
of 2.8mm.
(6) The glue to fix the product on the PC board around chip mounting, it is needed high
insulation resistance and great performance or moisture. And it is needed that these
characteristics are not inferno in using temperature range and a hot spot temperature to be
acting.
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNP-8Z-031
(Preliminary specification)
REVISION
PAGE
: A0
: 15 OF 1516
7-4 Using and Handling
(1) It is necessary to investigate the performance and reliability enough when using under harsh
environment.
(2) It is necessary to protect the and protective coat of the product from mechanical stress.
(3) Handle with care when PC board is divided or fixed on support body, because bending of PC
board after chip mounting will make mechanical stress for the product.
(4) The product shall be used within rated range shown in specification.
Especially, if current more than specified value will be loaded to the product, there is a case
it will make damage for machine because of temperature rise depending on generation of
heat, and characteristic inferior.
(5) In case that product is loaded a rated current, it is necessary to confirm temperature of the
product and to reduce a load current according to load reduction curve, because a
temperature rise of the product depends on influence of heat from mounting density and
neighboring element.
(6) If there is a possibility that a large voltage (pulse voltage, shock voltage) charge to the
product, It is necessary that operating condition shall be set up before use, because
performance of the product is affected by a large shock voltage.
(7) The items listed listed in the specifications assure the product quality as the product alone.
Evaluation and confirmation of the product quality after mounting, in accordance with the
operation condition, is required for actual use.
