INPAQ
Global RF/Component Solutions
MIP 2012-2520 Series
Specification
Product Name
Series
Size
Power Inductor
MIP Series
EIAJ 2012-2520
INPAQ
RoHS
Pb
Multilayer Power Inductor (MIP Series) Engineering Spec.
This product belongs to the industrial grade standard, not the vehicle gauge
product! Can not use auto parts, if the customer is not expressly informed and
privately used to auto parts, produce any consequences, the original is not
responsible for after-sales service, thank you!
Features
The monolithic construction performs high reliability and ensures a closed magnetic flux in
a component avoids magnetic leakage and interference .
Allow for higher mounting density.
Low DC resistance.
Applications
Suitable for DVD , DSC , PND , PC , NB , Power Line
Shapes and Dimensions
2012
2016
(EIA0805)
(EIA0806)
(EIA1008)
L
2.00±0.20
2.00±0.20
2.50±0.20
W
1.25±0.20
1.60±0.20
2.00±0.20
T
0.90±0.10
0.90±0.10
0.90±0.10
E
0.50±0.30
0.50±0.30
0.50±0.30
TYPE
Unit
2520
mm
MIP 2012-2520 Series Engineer Specification
All Specifications are subject to change without notice.
Version: A7
Page 1 of 6
www.inpaq.com.tw ; www.inpaqgp.com
INPAQ
Part Number Code
MIP 2012 2R2
1
2
3
M
4
B
5
E
6
1 Series Name
2 Size Code : The first two digitals: length(mm) the last two digitals: width(mm)
3 Inductance : R = Decimal point
4 Tolerance : M = ±20%
,Unit = μH
5 Soldering : Green Parts B= Lead-Free for whole chip
6 Packaging : E = Embossed plastic tape, 7" reel
Part Number and Characteristics Table
Inductance±20%
(μH)
Test Freq.
(MHz)
SRF
(MHz)
DCR±25%
(Ω
Ω)
Rated Current
(mA)
MIP2012 1R0MBE
MIP2012 2R2MBE
1.00
2.20
1
1
90
70
0.100
0.170
1100
900
MIP2012 3R3MBE
3.30
1
50
0.200
800
MIP2012 4R7MBE
4.70
1
40
0.230
700
MIP2016 2R2MBE
2.20
1
40
0.120
1100
MIP2016 4R7MBE
4.70
1
900
MIP2520 R47MBE
0.47
1
100
0.040
1800
MIP2520 1R0MBE
1.00
1
60
0.055
1600
MIP2520 1R5MBE
1.50
1
50
0.070
1500
MIP2520 2R2MBE
2.20
1
40
0.080
1300
MIP2520 3R3MBE
3.30
1
30
0.100
1200
MIP2520 4R7MBE
4.70
1
25
0.110
1100
MIP2520 6R8MBE
6.80
1
25
0.200
1100
Part Number.
2012 Series
2016 Series
2520 Series
•HP4291B-RF Impedance / Material Analyzer
Test Instruments and
•HP4338A/B Milliohm meter
Conditions
Test Frequency : 1 MHz / OSC Level : 100mV
:For special part number which is not shown in the above table, please refer to appendix.
*2:Apply DC 0.4 ~ 0.6A to chip for 1 ~ 3 sec. before to measure inductance.
*1
Version: A7
Page 2 of 6
INPAQ
Tape and Reel Specifications
Plastic Carrier (E)
Taping Dimensions
(mm)
2012
2016
2520
Symbol
E
E
E
W
8.00 ± 0.10
8.00 ± 0.10
8.00 ± 0.10
P
4.00 ± 0.10
4.00 ± 0.10
4.00 ± 0.10
E
1.75 ± 0.10
1.75 ± 0.10
1.75 ± 0.10
F
3.50 ± 0.10
3.50 ± 0.10
3.50 ± 0.10
D
1.55 ± 0.05
1.55 ± 0.05
1.55 ± 0.05
D1
1.00 ± 0.05
1.00 ± 0.05
1.00 ± 0.05
Po
4.00 ± 0.10
4.00 ± 0.10
4.00 ± 0.10
10Po
40.0 ± 0.20
40.0 ± 0.20
40.0 ± 0.20
P2
2.00 ± 0.10
2.00 ± 0.10
2.00 ± 0.10
Ao
1.40 ± 0.10
1.80 ± 0.10
2.25 ± 0.10
Bo
2.30 ± 0.10
2.20 ± 0.10
2.80 ± 0.10
Ko(T)
1.13 ± 0.10
1.15 ± 0.10
1.35 ± 0.10
t
0.22 ± 0.05
0.22 ± 0.05
0.22 ± 0.05
Version: A7
Page 3 of 6
INPAQ
Reel Dimensions
7” Reel Packaging Quantity
PART SIZE
(EIA SIZE)
2012
(0805)
2016
(0806)
2520
(1008)
Qty.(pcs)
3,000
3,000
3,000
BOX
5 reels / inner box 5 reels / inner box 5 reels / inner box
Recommended Soldering Conditions
Version: A7
Page 4 of 6
INPAQ
Land Patterns for Reflow Soldering
Solder land information:
Size(mm)
A
B
C
2012
1.0 ~ 1.2
3.0 ~ 4.0
0.8 ~ 1.1
2016
1.0 ~ 1.2
3.0 ~ 4.0
1.0 ~ 1.5
2520
1.2~1.5
3.5~4.0
1.5~2.0
Reliability and Test Condition
Test item
Test condition
1.
Resistance to Solder Heat 2.
3.
Criteria
Solder temperature : 260 ± 5
Flux : Rosin
DIP time : 10 ± 1 sec
Solderability
1. Solder temperature : 235 ± 5
2. Flux : Rosin
3. DIP time : 5 ± 1 sec
1. More than 95 % of terminal
electrode should be covered
with new solder
2. No mechanical damage
3. Inductance value should be
within ± 20 % of the initial value
* Apply DC 0.4 ~ 0.6A to chip for
inductance.
with new solder
Version: A7
Page 5 of 6
INPAQ
Test item
Test condition
Criteria
Adhesive Test
1. Reflow temperature : 245 It
shall be Soldered on the substrate
applying direction parallel to the
substrate
2. Apply force(F) : 5 N
3. Test time : 10 sec
1. No mechanical damage
2. Soldering the products on
PCB after the pulling test
force > 5 N
Temperature Cycle
1. Temperature:-40 ~ 85℃ For 30
minutes each
2. Cycle: 100 cycles
3. Measurement:At ambient
temperature 24 hours after test
completion
2. Inductance should be within
±20% of the initial value
inductance.
1. Temperature: 85 ± 5℃
2. Testing time: 1000 hrs
3. Measurement: at ambient
completion
inductance.
High Temperature
Resistance
Humidity
Rated Current
1. Temperature: 40℃ ± 2
2. Humidity: 90-95 % RH
3. Testing time: 1000 hrs
4. Measurement:At ambient
completion
inductance.
At ambient temperature & humidity
Testing time:5 minutes
( under full rated current )
MIP product surface temp
below room temperature plus
40℃
General Technical Data
Operating temperature range : - 40℃ ~ +85℃
Storage Condition : Less than 40℃ and 70% RH
Storage Time : 12 months Max.
Soldering method : Reflow
Version: A7
Page 6 of 6
很抱歉,暂时无法提供与“MIP25204R7MBE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.49648
- 100+0.40338
- 300+0.35694
