CRYSTAL UNIT
HC-49US DIP
Applications
Features
‧Industrial Control
Consumers .
‧Dimensions:11.5 x 4.50 x3.68 mm.
‧Through hole type crystal units.
‧Frequency range:3.2768~64MHz
‧A great number of standard frequencies.
Specifications
Standard Frequency
3.2768~64 MHz
Vibration Mode
AT Fundamental
Load Capacitance
12pF,20pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
±20ppm,or specify
Operating Temperature
-20~+70℃,-40~+85℃,or specify
Storage Temperature
-40~+85℃ or specify
Shunt Capacitance
7 pF Max.
Level of Drive
1~500μWMax.(100uW typical)
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
3.2768 ~ 4MHz
4 ~ 5MHz
5 ~ 6 MHz
180 Ω Max.
120 Ω Max.
100 Ω Max.
20 ~ 25 MHz
100 Ω Max.
Fundamental
3rd Overtone
6 ~ 17 MHz
7 ~ 10 MHz
10 ~ 27MHz
80 Ω Max.
60 Ω Max.
40 Ω Max.
25 ~ 64 MHz
80 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
4.5
Marking
6.0
3.5
www.yxc.hk
第1页共2页
CRYSTAL UNIT
HC-49US DIP
Solder ability
Dip terminals in RMA flux for5±0.5 seconds. Under room temperature. Dip terminals in a 260±5℃ solder
bath for 5±0.5 seconds. The solder shall leave an undipped terminal length of 2 mm at their base .
Resistance to Soldering Heat
Dip terminals in a 260±5℃ solder bath for 10±0.5 seconds. The solder shall leave an undipped terminal
length of 2 mm at their base.
Packing
Deposit 200 pieces of the quartz crystal units in a polyethylene bag, and pack enough bags in a packing case
to make a 10,000 pieces package. The packing format may be subject to change by quantity.
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X49SD20MSD2SI”相匹配的价格&库存,您可以联系我们找货
