FPF06FT-R080
FPF06FT-R080
    PSA(信昌电陶)
    电流采样电阻 1206
FPF06FT-R080 数据手册
信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Tel.:886-3-3224471 Fax:886-3-3212216 SPECIFICATION FOR APPROVAL DATE: CUSTOMER: PART NAME: Thick-Film Type High-Power Lead Free & Halogen Free Chip Resistors CUSTOMER'S DWG. NO. CUSTOMER'S PART NO. PDC PART NO. FPF SERIES APPROVED DESCRIPTION. ACTION RESULT " ˇ" CUSTOMER'S SIGNATURE NOTE FULL APPROVED CONDITIONAL APPROVED REJECTED OUR ACTION SIGNATURE PREPARED BY Jenny Tseng CHECKED BY Tony Chou APPROVED BY Byron Tsai Edition : F P F - R E V 1 4. 0 . F 1 4 CUSTOMER SIGNATURE FOR ACCEPTANCE Serial Number : M PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors 1. Features ………………………………………..……………..…….2 2. Applications…..…..………………………………..………………. 2 3. Dimension and construction ………………………..……………..2 4. Power Derating Curve …..…………………………….…………..3 5. Rating ……………………………………………………………….3~4 6. Part Number ………………………………..………………………4 7. Resistance Marking / Soldering 8. Reliability Performance…………………………………………….7~9 9. ………………………………..5~6 Packing ………………………………………………….…………..10 9.1 Peel Strength of Top Cover Tape……………………………….10 9.2 Tape Packaging Dimensions……………………………………10 9.3 Reel Dimensions………………………………………………....11 10. Storage / Handling ……………………………………….…………..11 ※. Appendix ……………………………………….………….…………..12 Prosperity Dielectrics Co., Ltd. 1/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors 1. Features ¾ ¾ ¾ ¾ High power rating to 2W and compact size. High reliability and high precision (1%). Suitable for lead free soldering. Meet AEC-Q200, RoHS compliant & Halogen Free. 2. Applications ¾ ¾ ¾ ¾ ¾ Power supply. Automotive industry. Digital meter, Consumer electronics, M/B. LED Lighting. Industry control board. 3.Dimension and Construction Type Unit:mm T L W C D FPF03 1.60±0.10 0.80±0.10 0.30±0.20 0.30±0.20 0.45±0.10 FPF05 2.00±0.10 1.25±0.10 0.40±0.20 0.40±0.20 0.50±0.10 FPF06 3.10±0.10 1.60±0.10 0.50±0.25 0.50±0.25 0.55±0.10 FPF12 3.10±0.10 2.60±0.10 0.50±0.25 0.50±0.25 0.55±0.10 FPF20 5.00±0.20 2.50±0.20 0.65±0.25 0.60±0.25 0.60±0.10 FPF25 6.40±0.20 3.10±0.20 0.60±0.25 1.80±0.25 0.60±0.15 Prosperity Dielectrics Co., Ltd. 2/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors 4.Power Derating Curve Operating Temperature Range: -55 to +155 deg.C 5.Rating Type Size Power Max. Max. Resistance Temperature Rating RCWV Overload Tolerance at 70℃ FPF03 0603 FPF05 0805 FPF06 1206 FPF12 1210 FPF20 2010 FPF25 2512 1/8W 1/4W 1/2W 1/2W 1W 2W 150V 200V 200V 200V 300V Prosperity Dielectrics Co., Ltd. 100V 300V 400V 400V 400V 600V Standard Range Resistance Coefficient ( ppm/℃) Min. Max. Values ±1%(F) ±100ppm 10Ω 1MΩ E96/E24 ±1%(F) ±200ppm 1Ω 9.76Ω E96/E24 ±5%(J) ±200ppm 1Ω 1MΩ E24 ±1%(F) ±100ppm 10Ω 1MΩ E96/E24 ±1%(F) ±150ppm 1Ω 9.76Ω E96/E24 ±5%(J) ±200ppm 1Ω 1MΩ E24 ±1%(F) ±100ppm 1Ω 1MΩ E96/E24 ±5%(J) ±200ppm 1Ω 1MΩ E24 ±1%(F) ±100ppm 1Ω 1MΩ E96/E24 ±5%(J) ±200ppm 1Ω 1MΩ E24 ±1%(F) ±100ppm 1Ω 1MΩ E96/E24 ±5%(J) ±200ppm 1Ω 1MΩ E24 ±1%(F) ±100ppm 1Ω 1MΩ E96/E24 ±5%(J) ±200ppm 1Ω 1MΩ E24 Voltage 50V Resistance 3/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors Max. Type Size Description Resistance FPF03 0603 Zero Ohm,Jumper ≦ 2A <20mΩ FPF05 0805 Zero Ohm,Jumper ≦ 4A <20mΩ FPF06 1206 Zero Ohm,Jumper ≦ 4A <20mΩ FPF12 1210 Zero Ohm,Jumper ≦ 4A <20mΩ FPF20 2010 Zero Ohm,Jumper ≦ 6A <20mΩ FPF25 2512 Zero Ohm,Jumper ≦ 6A <20mΩ Rated Current Note:RCWV=(P×R)1/2 or Max. RCWV listed above, whichever is lower. RCWV:Working Voltage (V),P:Rated Power (W),R:Resistance Value (Ω) 2512 2W loading with total solder-pad and trace size of 300 mm2 6.Part Number Tolerance Special FPF 03 :0603 F :±1% Paper Tape: -: XXXX -: ” Null ” : 05 :0805 J :±5% 0603.0805. As XXX As Standard 1206.1210 Rating 12 :1210 T : 5Kpcs 20 :2010 V : 10Kpcs 25 :2512 W : 20Kpcs Watt TCR Size 06 :1206 Packing R Value Type Info (GM) Code Rating 0603: Info 3 digit M: Meet AEC-Q200 Plastic Tape: Others: 4 digit 2010.2512 P : 4Kpcs X : 8Kpcs Y : 16Kpcs Example: FPF25FP-1004-M Î2512 size, tolerance 1%, plastic tape, 2W, 1 MΩ, Aec-Q200. FPF06JT-104 Î1206 size, tolerance 5%, paper tape, 1/2W, 100 KΩ, standard. Prosperity Dielectrics Co., Ltd. 4/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors 7.Marking/Soldering Resistance value identify: E24 ±5%:3 Digits marking to identify the resistance value 0603/0805/1206/1210/2010/2512 301 1 301 → 30 x 10 = 300Ω E24/E96 ±1%:4 Digits marking to identify the resistance value 0805/1206/1210/2010/2512 1542 2 1542 → 154 x 10 = 15.4 KΩ E24 ±1%:3 Digits marking to identify the resistance value 0603 222 2 222 → 22 x 10 = 2.2 KΩ E96 ±1%:3 Digits marking to identify the resistance value 0603 01B 01B → Refer 0603 marking table = 1 KΩ Prosperity Dielectrics Co., Ltd. 5/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors Soldering Reference: Recommend Solder Pad Dimensions: Type W D L FPF03 0.90 1.00 3.00 FPF05 1.30 1.15 3.50 FPF06 1.80 1.30 4.70 FPF12 3.00 1.30 4.70 FPF20 3.00 1.50 6.80 FPF25 3.70 2.45 7.60 Prosperity Dielectrics Co., Ltd. Unit:mm 6/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors 8. Reliability Performance (AEC-Q200) Test Item Test Method (AEC-Q200. IEC 60115) Specification *DC Resistance F:±1%;J:±5% AEC-Q200 TABLE 7.1 IEC 60115-1 / JIS C 5201-1 , Clause 4.5 Measure the resistance Value. High Temperature Exposure (Storage) J:△R≦ ±(3%+0.1Ω) AEC-Q200 TABLE 7.3 F:△R≦ ±(1%+0.05Ω) 1000 hrs. @ T=125℃. Unpowered. *Temperature Cycling J:∆R≦ ±(1%+0.1Ω) AEC-Q200 TABLE 7.4 F:∆R≦ ±(0.5%+0.05Ω) 1000 Cycles (-55°C to +125°C). Measurement at No mechanical damage. 24±2 hours after test conclusion. J:△R≦ ±(1%+0.1Ω) AEC-Q200 TABLE 7.6 F:△R≦ ±(0.5%+0.05Ω) Test 65℃/80~100%RH/10Cycles. Moisture Resistance Measurement at 24 ±2 hours after test conclusion. Measurement at 24±2 hours after test conclusion. (t=24hrs/cycle). Biased Humidity J:△R≦ ±(3%+0.1Ω) AEC-Q200 TABLE 7.7 F:△R≦ ±(1%+0.05Ω) 1000 hours 85℃/85%RH. 10% of operating power. Measurement at 24 ±2 hours after test conclusion. Operational Life J:△R≦ ±(3%+0.1Ω) AEC-Q200 TABLE 7.8 F:△R≦ ±(1%+0.05Ω) Test 1000hr @ TA=125℃ at specified rated power. Measurement at 24±2 hours after test conclusion. External Visual No visual damage and refer AEC-Q200 TABLE 7.9 PDC marking code. Inspect device construction, marking and workmanship. Physical Dimension Within the spec. AEC-Q200 TABLE 7.10 Verify physical dimensions to the applicable device detail specification. Mechanical Shock Within product specification AEC-Q200 TABLE 7.13 tolerance and no visible Test Peak value:100g's,Wave:Hail-sine, damage. Duration:6ms,Velocity:12.3ft/sec. Prosperity Dielectrics Co., Ltd. 7/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors Vibration No mechanical damage. AEC-Q200 TABLE 7.14 5 g's for 20 min., 12 cycles each of 3 orientations. Test from 10-2000 Hz. *Resistance to J:∆R≦ ±(1%+0.1Ω) F:∆R≦ ±(0.5%+0.05Ω) Solder Heat AEC-Q200 TABLE 7.15 Solder dipping @ 270℃±5℃ for 10sec.±1sec. No mechanical damage. Thermal Shock J:∆R≦ ±(1%+0.1Ω) ESD AEC-Q200 TABLE 7.16 F:∆R≦ ±(0.5%+0.05Ω) -55 to 155℃/ dwell time 15min/ Max transfer time No mechanical damage. 20sec/ 300cycles. ∆R≦ ±(1%+0.1Ω) AEC-Q200-002 No mechanical damage. Test contact min. 1KV. *Solder Ability Over 95% of termination AEC-Q200 TABLE 7.18 must be covered with a)Baking 155℃ 4H, dipping 235℃ 5s solder. b)Steam 1H, dipping 215℃ 5s c)Steam 1H, dipping 260℃ 7s Flammability Refer UL-94. AEC-Q200 TABLE 7.20 UL-94 V-0 or V-1 are acceptable *Board Flex Terminal Strength J:∆R≦ ±(1%+0.1Ω) AEC-Q200 TABLE 7.21 F:∆R≦ ±(0.5%+0.05Ω) Bending 2mm 2512.2010.1210.1206, No mechanical damage. 3mm 0805.0603. No mechanical damage AEC-Q200 TABLE 7.22 Force 1 Kg for 60 seconds. *Short Time J:∆R≦ ±(2%+0.1Ω) F:∆R≦ ±(1%+0.05Ω) Overload *Load Life Humidity IEC 60115-1, Clause 4.13 5 × Rated power for 5 seconds J:△R≦ ±(3%+0.1Ω) IEC 60115-1, Clause 4.24 F:△R≦ ±(1%+0.05Ω) 40±2℃ with relative humidity 90% ~ 95% D.C. rated voltage for 1.5 hours ON 30 minutes OFF. Cycle repeated 1000 hours. Prosperity Dielectrics Co., Ltd. 8/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors *Temperature Coefficient of Resistance (TCR) Within the spec. IEC 60115-1, Clause 4.8 T1 T2 Test temperature: 25℃~ -55℃ 25℃~ +155℃ TCR(ppm/℃) = (R2-R1)/R1×1 / (T2-T1)×106 *Load Life J:△R≦ ±(3%+0.1Ω) IEC 60115-1, Clause 4.25 F:△R≦ ±(1%+0.05Ω) Rated voltage for 1.5 hours for followed by a pause 0.5 hour at 70±2℃. Cycle repeated 1000 hours. *Insulation Resistance Between termination and IEC 60115-1, Clause 4.6 coating must over 1000MΩ Test voltage:100±15V * Normal test items for standard product. Prosperity Dielectrics Co., Ltd. 9/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors 9. PACKAGING 9.1 Peel Strength of Top Cover Tape The peel speed shall be about 300 mm/min The peel force of top cover tape shall between 0.1 to 0.7N 9.2 Tape Packaging Dimensions unit:mm Size A B W F E P1 P2 P0 D 0603 1.10±0.20 1.90±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 0805 1.65±0.20 2.40±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 1206 2.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 1210 3.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 2010 2.80±0.20 5.50±0.20 12.00±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 2512 3.50±0.20 6.70±0.20 12.00±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 Prosperity Dielectrics Co., Ltd. 10/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors unit:mm 9.3 Reel Dimensions unit:mm Size 0603 0805 1206 1210 2010 2512 Packaging Q’ty A N C D B G T 5kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 10kpcs/Reel 254.0±2.0 100.0±1.0 13.5±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 20kpcs/Reel 330.0±2.0 100.0±1.0 13.5±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 4kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.) 2.0±0.5 13.8±1.5 16.7max. 8kpcs/Reel 254.0±2.0 100.0±0.5 13.5±0.5 20(Min.) 2.0±0.5 13.8±1.5 20.0max. 16kpcs/Reel 330.0±2.0 100.0±1.0 13.5±0.5 20(Min.) 2.0±0.5 13.8±1.5 20.0max. 10. Storage &. Handling … Products are recommended to be used up within one year as ensured shelf life. Check solder ability in case shelf life extension is needed. … To store products with following condition: Temperature:5 to 40℃;Humidity: 20 to 70% relative humidity. Precaution for use: The AEC-Q200 series resistors is mainly used on general automotive equipment without safety considerations. Please contact our company in advanced if you intend to use resistor for designing the equipment which may damage itself and the safety of third party. If necessary, please consider to add the protect circuit in devising process and obtaining fully safety evaluation. The contents of the acknowledgment is only used for our parent company, marketing subsidiaries and official marketing agents who purchase our products. Not applicable for the other nonofficial channels. Prosperity Dielectrics Co., Ltd. 11/12 FPF-REV.14.0.F14 PDC FPF series. (AEC-Q200) High Rated Power Thick-film Lead Free Chip Resistors Appendix ■ 0603 1% Marking Table (Table 1) Code E48 E96 Code E48 E96 Code E48 E96 Code E48 E96 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 100 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 178 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 316 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 562 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 Code Multiplier 105 110 115 121 127 133 140 147 154 162 169 A 10 0 B 10 1 187 196 205 215 226 237 249 261 274 287 301 C 10 2 D 10 3 E 10 4 F 10 5 332 348 365 383 402 422 442 464 487 511 536 G 10 6 H 10 7 X 10 '-1 590 619 649 681 715 750 787 825 866 909 953 Y 10 '-2 Z 10 '-3 ※ All product specification and data are subject to change without notice. Prosperity Dielectrics Co., Ltd. 12/12 FPF-REV.14.0.F14 PDC
FPF06FT-R080 价格&库存
很抱歉,暂时无法提供与“FPF06FT-R080”相匹配的价格&库存,您可以联系我们找货
