SLO1365S220MTT
SLO1365S220MTT
    SUNLTECH(顺磁)
    IND-2P_14.4X12.8MM_SM
    功率电感 SMD
SLO1365S220MTT 数据手册
SLO1365S Series SMD Molding Power Inductor ◆ Features Pb 、Magnetically shielded construction, low DC resistance; 、The use of magnetic iron powder ensure capability for large current; 3、Low audible core noise; 4、Ideal for DC-DC converter applications in hand held personal computer and etc; 5、Frequency Range: up to 3.0MHz; 6、RoHS compliant。 1 2 ◆ Applications 、Smart phone、MID; 、Next-generation mobile devices with multifunction such as adding color TV and digital movie cameras; 3、Flat-screen TVs, blue-ray disc recorders, set top box; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems; 7、Telecomm base stations。 1 2 ◆ Lead Free Part Numbering SLO 1365 (1) (2) S (3) : : (1) (2) (3) (4) 100 M (4) (5) T T (6) (7) Series Type Dimension A X C Material Code Inductance 2R2=2.2μH 100=10μH 101=100μH (5) Inductance Tolerance M= 20%, Y= 30% (6) Company Code (7) Packaging packed in embossed carrier tape : ; ; : ± ± ◆ Dimensions Series SLO1365S Rev.01 A (mm) B (mm) C (mm) 14.5 Max 13.0 Max 6.5 Max Page 1 of 4 D±0.3 (mm) E±0.3 (mm) 3.5 2.5 www.sunltech.com SLO1365S Series ◆ Specification Ω Rdc (m ) Test a condition HEAT RATING CURRENT(Idc) DC AMPS1 (Typ.) SATURATION CURRENT(Isat) DC AMPS2 (Typ.) μ Typ. Max SLO1365SR56MTT 0.56 1.2 1.6 100KHz/1V 37.0 62.0 SLO1365SR68MTT 0.68 1.3 1.8 100KHz/1V 34.0 54.0 SLO1365SR82MTT 0.82 1.6 2.0 100KHz/1V 33.0 50.0 SLO1365S1R0MTT 1.0 1.7 2.5 100KHz/1V 25.0 47.0 SLO1365S1R5MTT 1.5 2.5 3.5 100KHz/1V 22.0 45.0 SLO1365S1R8MTT 1.8 2.8 3.6 100KHz/1V 20.0 41.0 SLO1365S2R2MTT 2.2 3.5 4.5 100KHz/1V 18.0 40.0 SLO1365S3R3MTT 3.3 6.3 7.0 100KHz/1V 15.0 35.0 SLO1365S4R7MTT 4.7 10.8 13.0 100KHz/1V 12.0 30.0 SLO1365S5R6MTT 5.6 11.0 15.0 100KHz/1V 11.0 26.5 SLO1365S6R8MTT 6.8 13.1 17.0 100KHz/1V 10.0 16.5 SLO1365S8R2MTT 8.2 14.5 18.0 100KHz/1V 8.0 16.0 SLO1365S100MTT 10.0 17.0 25.0 100KHz/1V 9.0 15.5 SLO1365S150MTT 15.0 30.5 38.0 100KHz/1V 6.0 9.0 SLO1365S220MTT 22.0 44.0 48.0 100KHz/1V 5.0 7.5 SLO1365S330MTT 33.0 57.5 66.0 100KHz/1V 5.0 6.5 SLO1365S470MTT 47.0 80.0 90.0 100KHz/1V 3.5 5.5 SLO1365S560MTT 56.0 90.0 110.0 100KHz/1V 3.0 6.0 SLO1365S680MTT 68.0 96.0 115.0 100KHz/1V 4.0 6.0 SLO1365S820MTT 82.0 101.0 121.0 100KHz/1V 2.5 4.5 SLO1365S101MTT 100.0 122.0 147.0 100KHz/1V 2.0 4.0 Part Number INDUCTANCE Lo( H) SLO1365S Series NOTES: △ ℃ 1. DC current (Idc) that will cause an approximate T of 40 2. DC current (Isat) that will cause Lo to drop approximately 20% 3. All test data is referenced to 25 ambient 4. Operating Temperature Range -55 to +150 5. The part temperature (ambient + temp rise) should not exceed 150 under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. ℃ Rev.01 ℃ ℃ Page 2 of 4 ℃ www.sunltech.com SLO1365S Series ◆ Wave Soldering ◆ Hand soldering Rev.01 Page 3 of 4 www.sunltech.com SLO1365S Series ◆ Reliability Mechanical ℃ ~+125℃ -45℃ ~ + 1 2 5 ℃ -55 Rev.01 Page 4 of 4 www.sunltech.com
