X2B040000BF1H-HZ
X2B040000BF1H-HZ
    HELE(加高电子)
    SMD2520_4P
    无源晶振 SMD2520_4P
X2B040000BF1H-HZ 数据手册
SPECIFICATIONS FOR APPROVAL GP Customer Customer Part No.: HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: HSX221SA / 40.000MHz Sample Order No: X2B040000BF1H-HZ CRYSTAL Date: EOS-F80305-1 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號 2 樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄市大寮區大發工業區華東路 39 號 No.39, HWA DONG RD., DALLIAO DIST.,DAFA INDUSTRIAL PARK., KAOHSIUNG CITY 831, TAIWAN TEL: (07)787-1555-6 FAX: (07)787-1557 THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-27309272 / 27309262 FAX: 0755-27309755 TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 1 HSX221SA SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION............ 3 2. MARKING & DIMENSIONS................... 4 3. INSIDE STRUCTURE...................... 5 4. EMBOSS CARRIER TAPE&REEL................ a. DIMENSIONS OF CARRIER TAPE............... 6 b. DIMENSIONS OF REEL.................... 6-7 c. STORAGE CONDITION.................... 7 d. STANDARD PACKING QUANTITY............... 7 e. MATERIAL OF TAPE..................... 7 f. LABEL CONTENTS...................... 7 g. TAPING DIMENSION..................... 8 h. JOINT OF TAPE....................... 8 i. RELEASE STRENGHT OF COVER TAPE............ 8 j. PACKAGE........................... 9 5. MECHANICAL ENDURANCE.................. 10 6. ENVIRONMENTAL ENDURANCE................ 11 7. SUPPLEMENT......................... 12-13 8. Flow Chart........................... 14 9. Environmental Workload Chemical Substance Components List. 15 Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 40.000000MHz 2. Holder type : HSX221SA 3. Frequency tolerance: +/-10 ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 30 ohms Max. / SERIES 5. Storage temperature range: -40 deg.C To +85 deg.C 6. Operable temperature range: -30 deg.C To +85 deg.C 7. Temperature drift: +/-10ppm 8. Loading capacitance (CL) : 15.0 pF 9. Drive level: 10 μW 10. Shunt Capacitance: 2.0 pF Max. 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 120 cm height 3 times on Concrete floor Variation : -30 deg.C To +85 deg.C (100uW Max.) Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/- 3 ppm/Year 16. Holder HSX221SA Seam type 17. Dimensions and marking Refer to page.4 18. Emboss carrier tape & reel Refer to page.6 and page.7 19. Moisture Sensitivity Level 20. Note: Level 1 Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 3 2. HSX221SA MARKING & DIMENSIONS 2.5±0.15 Frequency 3 4 3 1 2 1 2 0.50 Max 2±0.15 4 1.15 0.73 4 3 1 2 1 1.3 0.9 0.7 1.0 0.58 2 1.75 4 3 UNIT: mm TOLERANCE: ±0.1 Chamfer index mark depends on the ceramic base supplier *Marking should be printed as following: Logo, Nominal Frequency, Manufactured year & month *Nominal frequency = integer only ( ex. 14.31818 MHz  14 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2). Marking : Laser marking. (Table-1) Year 2000 2010 0 Code 2001 2011 1 2002 2012 2 2003 2013 3 2004 2014 4 2005 2015 5 2006 2016 6 2007 2017 7 2008 2018 8 2009 2019 9 (Table-2) Jan. A Feb. B Mar. C Apr. D May. E Jun. F Jul. G Aug. H Sep. J Oct. K Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. Nov. L Dec. M TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 4 3. INSIDE STRUCTURE Cover Ring(8) ELECTRODE(7) PAD(6) PAD(6) LID(2) CRYSTAL BLANK(4) ADHESIVE(5) Base(1 ※Reference drawing (1) Base: Alumina Ceramic (Al2O3) (6) Metallized Pad: W Ni Plating Au Plating (2) Lid : Fe- Ni -Co (3) Crystal Enclosure Seal: Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin (7) Electrode (8) Cover Ring: Fe-Ni-Co Alloy The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in this item. Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 5 4. HSX221SA EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 9.3+/-0.3 Outer Width W2 11.3+/-1.0 Out Line diameter B ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 Q 120deg C ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Width Center Core slit Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 3,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material PS Conductive Polyester f.) Label contents Sticks label for every reel. Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 8 j.) Package TYPE: SPEC. No.: Parts No.: Lot No.: Label Up side(Produce) Q.C PASS H10 FREQ.: Q'TY: MHz PCS HSF HARMONY ELECTRONICS CORP. Under side(Fixing Hole) One reel quantity: [1000pcs]&[3000pcs] 1 Top and bottom with 2.3cm thickness foam-rubber cushion for protection 2 Carton's Q'TY:1~15 pcs. 3 Carton Type=A,B ,C use 4 trigon pillar to fasten the Reel. 4 Need to add 3 pages dry agent in each outer box. use 4 trigon pilla OR Green Product ROHS Compliant A Carton Type B 630/531/ 321/221 211/111 Produce Type 840/751 421 Reel OTHER 15 15 15 1~7 200 200 200 195 200 200 200 195 230/260 230 230 150 Gree n Prod uct ROHS Co mp lian D C t 1.Every Carton with 3 desiccant. 2.Top and bottom with 2.3cm thickness foam-rubber cushion for protection Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 9 5. Mechanical Performance Test Methods 1 Natural Drop 2 Vibration Dropping from 120 cm height 3 times on Concrete floor Refer to: JIS C 60068-2-6 Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z 3 axes, Duration of 2 hours to each axis. Refer to: MIL-HDBK-781A 6.5.2/ JIS C 60068-2-6 Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak detector. After applying ROSIN Flux, dipping in solder bath at 245deg.C+/-5deg.C for 3+/-0.5 sec. Refer to: JIS C 60068-2-20 Mount a sample on board. Apply Pressure to the center of board until it is bent to 3 mm and hold for 5 ±1 sec Pressure speed :0.5 mm / sec Refer to: EIAJ ET-7403 Mount a sample on the circuit board. Apply pressure vertically to the side of specimen attached to the circuit board with the pressure jig. Pressure : 5N for 10±1 sec Refer to: EIAJ ET-7403 Apply pressure to the center of body with the R0.5 pressure jig. pressure :10N for 10±1sec Refer to: EIAJ ET-7403 3 Sealing Tightness 4 Solder ability 5 6 7 Substrate Bending Adhesion Body strength Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Specifications Code Item Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. A --B A A A TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS A CORP. 0 10 6. Environment Performance Item 1 2 3 4 Specifications Code Test Methods Humidity Temperature 60℃+/-2℃, RH 90~95%, Duration of 240 hours. Back to room temperature first, then in 1~2 hours, the component shall be checked. Refer to: JIS C 60068-2-3 -40deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. Refer to: JIS C 60068-2-1 +85deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. Refer to: JIS C 60068-2-2 -40deg.C +/-2deg.C (30min)  +85deg.C +/-2deg.C (30min) 25 cycles. Back to the room temperature first, then in 1~2 hours, the component shall be checked. Refer to: JIS C 0025 Storage in Low Temperature Storage in High Temperature Temperature cycles A A A A Specifications code Specifications A Frequency variation shall be within +/-5ppm and equivalent resistance shall be within +/-15% or 2Ω More than 90% of lead shall be covered by new solder. B Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 11 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering 260 deg.C Temperature 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 7.3.Land pattern layout(Example) 7.4.Solder iron (Example) Bit temp.: 350℃max., Time:3sec max. , Each terminal solder a 1 time max. Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 12 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be Sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering process. Avoid mounting and processing by Ultrasonic welding because this method has a Possibility of an excessive vibration spreading inside the crystal products and Becoming the cause of characteristic deterioration and not oscillating. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity, which may cause put solderbility. No direct Sunlight, No dew as well. Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 13 8. Flow Chart LID(外 殼 蓋 ) BLANK(晶 片 ) BLANK進 料 檢 查 LID進 料 檢 查 1 Incoming Inspection of Lid 2 LID洗 淨 Lid Cleaning and Dry BASE(基 座 ) 5 6 7 8 9 10 11 12 13 14 15 16 17 3 Incoming Inspection of Base 4 Base Cleaning 化學蝕刻 Etching BASE(基 座 )洗 淨 頻率選別 Frequency Sorting 晶片排盤 Blank Filling 洗 淨 +微 蝕 刻 Blank Cleaning (Individule cleaning+flash etching) 基礎蒸著 Base Plating 押入接著 Blank Mounting and Bonding 接著硬化 Bonding Curing 接著外觀檢查 24 Bonding Inspection 氣 密 檢 查 I (Air) Sealing Inspection I (Air Leak) 調整蒸著 Partial Adjustment (Ion Partial) 25 氣 密 檢 查 II (氦 氣 加 壓 ) Sealing Inspection II (He Pressurization) 中 間 檢 查 ($) Middle Check 26 氣 密 檢 查 II (He) Sealing Inspection II (He Leak) 高真空烘烤 High Vacuum Anneal 27 溫度特性抽檢 28 最 終 檢 查 ($) LID點 焊 Temporary Positioning 18 熔 接 (seam) 19 強 勵 振 Overdrive 20 Relow 21 老 化 Aging 22 印字排盤 23 BASE(基 座 )進 料 檢 查 Incoming Inspection of Crystal blank Sealing (seam) 29 30 31 Temperature characteristics adjustment inspection Final Inspection TAPPING外 觀 檢 查 Appearance inspection after Taping 出 貨 檢 查 ($) Outgoing Inspection 出貨捆包 Packing Mark Loading 印 字 +外 觀 檢 查 出 貨 Shipment Laser Marking and Appearance Inspection ($): 特 殊 特 性 (For Critical prcoess had been monitored) Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 14 9. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE HSX221S PERCENTAGE 9.6(mg) ppm Si 0.316800 30.412800 Au 0.048000 4.608000 Co & Co Compound 0.784320 75.294720 Mo & Mo Compound 0.017280 1.658880 Ag 1.875840 180.080640 Cu 0.075840 7.280640 Cr & Cr Compound 0.024000 2.304000 Al 2.083200 199.987200 Mn & Mn Compound 0.014400 1.382400 W & W Compound 0.042240 4.055040 Ni & Ni Compound 2.090880 200.724480 Fe 2.220480 213.166080 Chemical Substance Components Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 15 REV. No. DATE REASON 0 2015/08/31 New CONTENTS Country of origin Tittle HSX221SA QUARTZ CRYSTAL SPECIFICATION Date Confirm 2015/08/31 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X2B040000BF1H-HZ ELECTRONICS CORP. 0 16
X2B040000BF1H-HZ 价格&库存
很抱歉,暂时无法提供与“X2B040000BF1H-HZ”相匹配的价格&库存,您可以联系我们找货
