6R3AREP391M05X8E14P00
    APAQ(钰邦)
    插件,D5xL8mm
    贴片铝电解电容 AEC_D5X8MM_TM
6R3AREP391M05X8E14P00 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor AREP Series Power   Super low ESR, high ripple current capability, high voltage Rated voltage: 6.3~16Vdc    Endurance 3000hrs at 105℃ Suitable for AC-DC DC-DC converters, voltage regulators and decoupling applications RoHS Compliant Specification Category Temperature Range -55 to 105℃ `` Rated Voltage Range Capacitance Tolerance Surge Voltage Rated voltage X 1.15 (at 105°C) Dissipation Factor Leakage Current Shall not exceed values shown in standard ratings. 6.3 to 16Vdc ±20% (M) 0.1 max. (at 20°C 120Hz) (at 20°C after 2 mins.) 105℃, 3000hrs, rated voltage applied Appearance No significant damage Endurance Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 60℃, 90 to 95% RH, 1000hrs, no voltage applied Appearance No significant damage Damp Heat (Steady State) Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a protective resistor (R=1kΩ) and discharge for 5.5min. Appearance No significant damage Surge Voltage Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Dimensions and Marking Series Polarity marking (-) Date code Capacitance SIZE Code øD±0.5 max L α ød ±0.05 F±0.4 05X8 06X8 06A0 06A1 08A2 08A6 10A2 10A6 10B0 5.0 6.3 6.3 6.3 8.0 8.0 10.0 10.0 10.0 8.0 8.0 10.0 11.0 11.5 16.0 11.5 16.0 20.0 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 1.5 0.5 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 2.0 2.5 2.5 2.5 3.5 3.5 5.0 5.0 5.0 Voltage Product Specifications are subject to change without notice. Rev.A AP-CON Aluminum Solid Electrolytic Capacitor AREP Series Power Standard Ratings WV/Vdc (SV) 6.3 (7.2) 7.5 (8.6) 12 (13.8) 16 (18.4) Cap (μF) Size Code 330 470 470 560 680 820 1000 1500 500 680 820 470 560 680 820 330 470 560 680 820 1000 1000 1500 2200 2500 05X8 05X8 06X8 06X8 06X8 06X8 06A0 08A2 05X8 06X8 06A1 06A0 06A0 06A1 06A1 06X8 06A1 06A1 08A2 08A2 08A6 10A2 10A6 10B0 10B0 ESR Leakage (mΩmax/20%, Current 100k (μA) to300kHz) 500 592 592 705 857 1,033 1,260 1,890 750 1,020 1,230 1,128 1,344 1,632 1,968 1,056 1,505 1,792 2,176 2,624 3,200 3,200 4,800 7,040 8,000 Product Specifications are subject to change without notice. 8 8 8 8 8 8 8 7 12 12 10 12 12 18 15 20 16 20 10 10 10 12 10 8 8 Rated Ripple Current (mArms/ 105℃ /100kHz) Part No. 4,050 4,050 4,700 4,700 4,700 4,700 4,700 6,100 3,500 4,780 5,200 3,900 3,900 3,900 4,000 2,800 4,000 3,500 5,230 5,230 6,100 5,400 6,600 8,100 8,100 6R3AREP331M05X8 6R3AREP471M05X8 6R3AREP471M06X8 6R3AREP561M06X8 6R3AREP681M06X8 6R3AREP821M06X8 6R3AREP102M06A0 6R3AREP152M08A2 7R5AREP501M05X8 7R5AREP681M06X8 7R5AREP821M06A1 120AREP471M06A0 120AREP561M06A0 120AREP681M06A1 120AREP821M06A1 160AREP331M06X8 160AREP471M06A1 160AREP561M06A1 160AREP681M08A2 160AREP821M08A2 160AREP102M08A6 160AREP102M10A2 160AREP152M10A6 160AREP222M10B0 160AREP252M10B0
6R3AREP391M05X8E14P00 价格&库存
很抱歉,暂时无法提供与“6R3AREP391M05X8E14P00”相匹配的价格&库存,您可以联系我们找货
