49SAT040000201080
49SAT040000201080
    JGHC(晶光华)
    HC-49S/SMD
    无源晶振 4MHz ±10ppm 20pF -20℃~+70℃
49SAT040000201080 数据手册
www.0755crystal.com 【深圳市晶光华电子有限公司】        External dimensions: 11.5 x 4.8 x 4.2mm. Frequency range: 3.579545MHz ~ 64MHz. Surface mount type crystal units. A great number of standard frequencies. High frequency pullability and low equivalent series resistance. Highly mass production capability. Applications: PC, STB, LCDM and Cable Modem. Electrical Specifications Item / Type 49S SMD Frequency Range 3.2 ~ 50 MHz Frequency Tolerance (at 25 ℃ ) ± 20ppm, or specify Frequency Stability Over Operating Temperature Range ± 20ppm, or specify Operating Temperature Range - 20 ~ +70 ℃, or specify Shunt Capacitance (C0) 7 pF Max. Drive Level 1 ~ 500 uW (50 uW typical) Load Capacitance Series, 9 pF 12 pF 16 pF, 18 pF, 20 pF, 22 pF, or specify Aging (at 25 ℃ ) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Equivalent Series Resistance Item / Type 49S SMD 3.2 ~ 3.686 MHz 300 Ω Max 20 ~ 30 MHz 40 Ω Max. 3.686 ~ 5 MHz 120 Ω Max 30 ~ 50 MHz 30 Ω Max. 5 ~ 10 MHz 70 Ω Max 10 ~ 14 MHz 60 Ω Max. 14 ~ 20 MHz 50 Ω Max. Dimensions
49SAT040000201080 价格&库存
很抱歉,暂时无法提供与“49SAT040000201080”相匹配的价格&库存,您可以联系我们找货
49SAT040000201080
  • 5+0.47460
  • 50+0.37818
  • 150+0.32997
  • 1000+0.27942
  • 2000+0.25046
  • 5000+0.23601
库存:406
