200CE33FS+D
200CE33FS+D
    SUNCON
    SMD,D12.5xL13.5mm
    贴片铝电解电容 AEC_D12.5X13.5MM_SM
200CE33FS+D 数据手册
Aluminum Electrolytic Type / Surface Mount Type CE-FE CE-LD CE-FSS CE-FS 160 to 400V, 105℃ 1,000 to 2,000hours Non solvent proof ■ Specifications Items Condition Rated voltage (V) − 160 200 250 400 Surge voltage (V) Room temperature 200 250 300 450 120Hz/20℃ Dissipation Factor(tan δ) tanδ (max)120Hz/20℃ μA/after 2minutes (max) Leakage current (LC) CE-GA CE-LS CE-LF [ φD≤10 ] Polarity (Cathode) 8D 10 200 F CE-FN 6 6 6 10 φ8 : 1,000hours, φ10 to φ16 : 2,000hours △C/C Within ±25% of the initial value tanδ Less than 200% of the specified value LC Less than the specified value 8DT 47 200 F (Unit : mm) D±0.5 W Lot No. Series Symbol Rated Voltage L Lot No. Indicated Only φD=16 pressure relief vent L±0.3 W±0.2 H±0.2 C±0.2 R P 8 10.5 8.3 8.3 9.0 0.7∼1.0 3.2 10 10.5 10.3 10.3 11.0 1.0∼1.4 4.6 12.5 13.5±0.5 12.8 12.8 13.5 1.0∼1.4 4.6 16 16.5±0.5 16.3 16.3 17.3 1.7∼2.1 7.0 R (+) (P)reference size Rated Capacitance Series Symbol Rated Voltage ■ Size, Rated Ripple Current V μF 160 200 250 400 2.2 8×10.5 25 3.3 8×10.5 31 10×10.5 36 4.7 8×10.5 37 10×10.5 38 6.8 8×10.5 44 12.5×13.5 47 10 8×10.5 57 10×10.5 64 10×10.5 64 12.5×13.5 57 22 12.5×13.5 112 12.5×13.5 112 12.5×13.5 112 16×16.5 115 33 12.5×13.5 137 12.5×13.5 137 16×16.5 150 47 16×16.5 180 16×16.5 180 16×16.5 180 68 16×16.5 215 16×16.5 215 82 16×16.5 235 Please refer to page 14 for ripple current frequency coefficients. ■ Part number Case size:φDxL(mm) 16×16.5:CE-FST FS Rated ripple current mArms(120Hz, 105℃) FST 200 CE 10 FS 200 CE 47 FS T Series code Rated capacitance Type code Rated voltage 44 3 6 Rated Capacitance Polarity (Cathode) CE-PF CE-JX 3 Test 0.3max [ φD≥12.5 ] CE-PS CE-NP 0.02CV +25 3 ■ Marking, Dimensions CE-PH CE-TH CV > 1000 Endurance CE-LH(High Voltage) CE-PC 0.25 0.03CV +15 105℃ rated voltage applied (With the rated ripple current) CE-LH CE-LL CV ≤ 1000 Impedance ratio at Iow temperature φD CE-LX M : ±20 0.20 Based on the value at −25℃ Z/Z20℃ 120Hz, +20℃ −40℃ Z/Z20℃ CE-KX CE-ZC −40 to +105 Capacitance tolerance (%) CE-AX CE-ZX − Category temperature range (℃) CE-FS(High Voltage) CE-FH Specifications C CE-BS CE-BSS ● High Voltage Series (P) CE-BD ● 105℃ Standard H Aluminum Electrolytic Capacitors Surface Mount Type CE-BE CE-FS RoHS compliance Sn plating terminal option Series code Rated capacitance Type code Rated voltage
200CE33FS+D 价格&库存
很抱歉,暂时无法提供与“200CE33FS+D”相匹配的价格&库存,您可以联系我们找货
200CE33FS+D
    • 1+4.09320
    • 10+4.02840
    • 30+3.97440
    • 100+3.93120
