PHC0412-1R0M-T
PHC0412-1R0M-T
    EMTEK(兆欣)
    SMD
    功率电感 SMD
PHC0412-1R0M-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: T-0653-010M 新弘智 DATE: Aug.7,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: PHC0412-Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/8 SPEC. No. PRODUCT SPECIFICATION T-0653-010M 1. Scope This specification applies High Current Power Inductors PHC0412-Series to be delivered to user. 2. Product Identification PHC 0412 - 1R5 □ - T (1) (2) (3) (4) (5) (1) Product name (2) Shapes and dimensions (3) Inductance 1R5: 1.5μH (4) Tolerance(%) M: ±20% (5) Taping Type T: Taping, None:Bulk 3. Shapes and Dimensions A: B: C: D: E: Drawn by 4.45±0.25 mm 4.06±0.25 mm 1.2 Max. mm 2.0±0.3 mm 0.76±0.3 mm Checked by Approved by 2/8 SPEC. No. PRODUCT SPECIFICATION T-0653-010M 4. Schematics and Land Patterns A B C 4.95 mm 2.35 mm 1.65 mm Saturation Current DC Amps. Isat(A) Typ. 5. Electrical Characterisitics 5-1 Electrical Spec. Customer Part Number EMTEK Part No. Inductance uH Tol. (100KHz/0.5V) Typ. Max. Heat Rating Current DC Amps.Idc(A) Typ. Rdc (mΩ) PHC0412-R10□-T 0.10 M 9.0 11.0 10.0 15.0 PHC0412-R22□-T 0.22 M 15.0 18.0 7.0 10.0 PHC0412-R24□-T 0.24 M 11.0 15.0 7.50 11.5 PHC0412-R33□-T 0.33 M 17.0 19.0 6.50 8.4 PHC0412-R36□-T 0.36 M 18.0 20.0 6.40 7.8 PHC0412-R47□-T 0.47 M 19.0 21.0 6.00 6.8 PHC0412-R68□-T 0.68 M 32.0 36.0 4.50 6.0 PHC0412-1R0□-T 1.0 M 43.0 47.0 4.20 5.2 PHC0412-1R2□-T 1.2 M 43.0 55.0 4.00 5.1 PHC0412-1R5□-T 1.5 M 68.0 75.0 3.25 4.0 PHC0412-2R2□-T 2.2 M 79.4 83.5 2.75 3.5 Inductance Tolerance:M=±20% , N=±30% 1.All test data is referenced to 25℃ ambient. 2. Idc : DC current (A) that will cause an approximate △T of 40℃ 3. Isat : DC current (A) that will cause Lo to drop approximately 30% 4.Operating Temperature Range -40℃ to + 125℃ 5. The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case operating conditions. Circuit design , component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. 6.The rated current as listed is either the saturation current or the heating current depending on which value is lower. 7. TEST FREQUENCY:100KHz,0.5V TESTING INSTRUMENT L:Agilent/HP4284A Precision LCR Meter. Rdc:Chroma Millohmmeter16502 or equivalent. 3/8 SPEC. No. PRODUCT SPECIFICATION 5-2 Typical Electrical Curve:Inductance VS Isat , Irms VS TEMP. PHC0412-R24M-T 100 0.30 0.25 0.20 L(uH) 60 0.15 40 0.10 L(uH) 0.05 20 ΔT(℃) 0.00 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 DC CURRENT(A) PHC0412-R36M-T 0.40 100 L(uH) 60 0.20 40 0.10 20 L(uH) ΔT(℃) 0 0.00 0 1 2 3 4 5 6 7 8 9 DC CURRENT(A) 10 11 12 13 14 TEMPERATURE(℃) 80 0.30 TEMPERATURE(℃) 80 T-0653-010M 4/8 SPEC. No. PRODUCT SPECIFICATION 5-2 Typical Electrical Curve:Inductance VS Isat , Irms VS TEMP. T-0653-010M 5/8 PRODUCT SPECIFICATION SPEC. NO. T-0653-010M 6. Reliability Test Item Solderability Specifications The metalized area must have 90% minimum solder coverage. Test conditions Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag solder) at 255°C ±5°C. Resistance to There must be no case deformation or Inductors shall be reflowed onto a PC board using soldering heat change in dimensions. 96.5 Sn/3.5 Ag solder paste. Inductance must not change more Solder process shall be at a maximum temperature than the stated tolerance. of 260°C. For 96.5 Sn/3.5 Ag solder paste:>217°C for 90 seconds High temperature There must be no case deformation or Inductors shall be subjected to temperature 125±2℃ change in dimensions. for 100 hours. resistance Inductance must not change more Measure the test items after leaving the inductors at than the stated tolerance. room temperature and humidity for 2 hours. Static Humidity Inductors must not have a shorted or Inductors shall be subjected to temperature 85±2℃ openwinding. and 90 to 95%RH. for 100 hours. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. Low temperature resistance There must be no case deformation or Inductors shall be subjected to temperature change in dimensions. -40±2℃ for 100 hours. Inductance must not change more Measure the test items after leaving the inductors than the stated tolerance. at room temperature and humidity for 1 to 2 hours. Temperaure cycle Change from an initial value Inductance: within ±10% The specimen shalll be subjected to 10 continuous cycles of temperature change of -40℃ for 30 min and 125℃ for 30 min with the transit period of 3 min or less. Then it shall be stabilized under standard atmospheric conditions for 1 hr before measurement. Measurement shall be made within 2 hr. 6/8 SPEC. NO. PRODUCT SPECIFICATION T-0653-010M 7. Packaging The packaging must be done not to receive any damage during transporting and storing. 7-1 Tape dimensions Ko P1 P0 P Bo W Ao t ( Dimensions in mm; Tolerance:±0.1) Symbol W P P0 P1 Ao Bo Ko t Dimension 12 8 4 2 4.55 4.75 1.5 0.25±0.05 7-2 Reel dimensions D Symbol C B A ( Dimensions in mm ) T A B 180 C 13 D 16 E 13.2 E 7-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 60 7/8 SPEC. NO. PRODUCT SPECIFICATION T-0653-010M 7-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Leader. Blank (25 pitches) Chip Blank (25 pitches) 7-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 7-6 Packing Quantity φ180 mm reel type : 1,000 pcs./reel 8/8 SPEC. NO. PRODUCT SPECIFICATION T-0653-010M 8. Recommended Reflow Pattern 8-1 Recommended Reflow Pattern Reflow : until two times 10sec. Min. 255℃ 217℃ Natural cooling 150sec. Max. 150℃ 60sec. Min. 8-2 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the Ceramic body outside of terminal electrode. 5 seconds max. at 260℃. 9. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 10. Others 10-1 Operating temperature range : Ferrite Series :-40~+125℃ 10-2 Storage condition : Temperature 20°~25℃﹐Relative Humidity 40%~60% 10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
PHC0412-1R0M-T 价格&库存
很抱歉,暂时无法提供与“PHC0412-1R0M-T”相匹配的价格&库存,您可以联系我们找货
