MHP201612-R47M
MHP201612-R47M
    ME-TECH(美台高科)
    功率电感 SMD
MHP201612-R47M 数据手册
High Current Molding Power Inductors MHP Series FEATURES      Low profile, high current power supplies. Low loss realized with low DCR. Ultra low buzz noise, due to composite construction. Frequency up to 5MHz. Available for automatic mounting in tape and real package. APPLICATIONS  Excellent for power line DC-DC conversion application used in power switching, personal computer and other handheld electronic equipment. PRODUCT IDENTIFICATION MHP – 2520 12 –100 – M Inductance Tolerance (K:10% ; M:20% ; N:30%) Inductance Value 4R7:4.7uH; 100: 10uH; 101:100uH Thickness Product dimensions Series name SHAPES AND DIMENSIONS Item A B C D E H I J MHP201610 2.0±0.2 1.6±0.2 1.0 Max 0.5±0.2 1.44 0.9 1.6 2.3 MHP201612 2.0±0.2 1.6±0.2 1.2 Max 0.5±0.2 1.44 0.9 1.6 2.3 MHP252010 2.5±0.2 2.0±0.2 1.0 Max 0.6±0.2 1.84 1.2 2.0 2.8 MHP252012 2.5±0.2 2.0±0.2 1.2 Max 0.6±0.2 1.84 1.2 2.0 2.8 Note: Beyond the above specification also could satisfy the special requirement Rev.A2 Rev.A2 High Current Molding Power Inductors MHP Series ELECTRICAL CHARACTERISTICS I Inductance Part N No. Tolerance e L DC CR I sat I rms (m m) (A) (A) (uH) (±%) Typ Max MHP201610--R24M 0.24 20 20 MHP201610 --R33M 0.33 20 MHP201610 --R47M 0.47 MHP201610 --1R0M Max Typ Max Typ 24 4.8 4.3 4.0 4 3.5 5 29 36 4.2 3.7 3.4 3 3.0 0 20 36 46 3.56 3.2 2.7 2 2.4 43 1.0 20 63 75 2.8 2.4 2.1 2 1.9 9 MHP201610 --1R5M 1.5 20 105 137 2.2 2.0 1.8 1 1.6 6 MHP201610 --2R2M 2.2 20 174 197 1.95 1.75 1.6 1 1.4 4 MHP201612 --R24M 0.24 20 17 21 5.3 4.8 4.5 4 4.0 0 MHP201612 --R33M 0.33 20 27 33 4.6 4.0 3.9 3 3.5 5 MHP201612 --R47M 0.47 20 30 36 3.9 3.5 3.5 3 3.1 1 MHP201612 --1R0M 1.0 20 60 72 2.9 2.6 2.4 2 2.2 2 MHP201612 --1R5M 1.5 20 86 112 2.4 2.16 1.9 1 1.7 7 MHP201612 --2R2M 2.2 20 146 186 2.1 1.7 1.5 1 1.3 35 MHP252010 --R33M 0.33 20 19 26 5.3 4.77 4.4 4 4.0 0 MHP252010 --R47M 0.47 20 28 41 4.5 4.05 3.5 3 3.1 1 MHP252010 --R68M 0.68 20 31 45 4.3 3.6 3.3 3 3.0 0 MHP252010 --1R0M 1.0 20 58 65 3.55 3.2 2.8 2 2.5 52 MHP252010 --1R5M 1.5 20 76 95 3.0 2.7 2.2 2 1.9 98 MHP252010 --2R2M 2.2 20 104 113 2.6 2.34 1.8 1 1.6 62 MHP252012 -R33M 0.33 20 15 17 5.80 5.22 5.5 4.95 MHP252012 -R47M 0.47 20 23 28 5.0 4.5 4.5 4 4.0 0 MHP252012 -1R0M - 1.0 20 48 55 3.8 3.3 3.1 3 2.7 7 MHP252012 -1R5M - 1.5 20 61 70 2.9 2.61 2 2.7 2.4 43 105 2.5 2.2 2 2.3 2.0 0 20 92 2.2 MHP252012 -2R2M If you require another part number please contact with us. If you require another part number please contact with us. Note 1: Referenced ambient temperature 20 . Note 1: Referenced ambient temperature 20 . Note 2: Test Condition :1MHz ,1.0 Vrms. Note 2: Test Condition :1MHz ,1.0 Vrms. Note 3: I sat (Typ) : DC current A that will cause L0 to drop approximately 30% Note 3: I sat (Typ) : DC current A that will cause L0 to drop approximately 30% I sat (Max) : DC current A that will cause L0 to drop 30% Max I sat (Max) : DC current A that will cause L0 to drop 30% Max I rms (Typ) : DC current A I rms (Typ) : DC current A I rms (Max) : DC current A Max I rms (Max) : DC current A Max Note 4: Operating temperature range includes self-temperature rise. Storage Temperature Range:-40°C to+125°C Note 4: Operating temperature range includes self-temperature rise. Note 5: The rated current as listed is either the saturation current or the heating current depending on which value is Note 5: The rated current as listed is either the saturation current or the heating current depending on which value is lower. lower. Note: Beyond the above specification also could satisfy the special requirement High Current Molding Power Inductors MHP Series pical perfo ormance curves :  Typ MHP P201610-1R0M MHP201610-R22M MHP P201612-1R0M MH HP201610-1R5 5M M MHP201610-R3 33M MH HP201612-1R5 5M MHP201610-2 2R2M MHP201610-R47M MHP201612-2 2R2M Rev.A2 High Current Molding Power Inductors MHP Series pical perfo ormance curves :  Typ MHP 252010-R33M MH HP252010-R47M MHP252010-R R68M MHP252010-1R0M MH HP252010-1R5M MHP252010-2 2R2M M HP252012-R33M M MHP252012-1R R5M MHP P252012-R47M MHP252012-2R2M MHP252012-1R0 M 0M Rev.A2 High Current Molding Power Inductors MHP Series RELIABILITY TEST Rev.A2 High Current Molding Power Inductors MHP Series Note: Beyond the above specification also could satisfy the special requirement Rev.A2 High Current Molding Power Inductors MHP Series Rev.A2 Packaging SIZE A0 B0 E F f P P1 P2 W T K0 MHP201610 2.65 2.23 5.50 1.75 1. 50 4.00 4.00 2.00 8.00 0.25 1.30 MHP201612 2.65 2.23 5.50 1.75 1. 50 4.00 4.00 2.00 8.00 0.25 1.50 MHP252010 2.73 2.23 5.50 1.75 1. 50 4.00 4.00 2.00 8.00 0.25 1.30 MHP252012 2.73 2.23 5.50 1.75 1. 50 4.00 4.00 2.00 8.00 0.25 1.50 SIZE A B C D Reel/PCS MHP2016 330 100 13 12.5 3000 MHP2520 330 100 13 12.5 3000 Note: Beyond the above specification also could satisfy the special requirement
MHP201612-R47M 价格&库存
很抱歉,暂时无法提供与“MHP201612-R47M”相匹配的价格&库存,您可以联系我们找货
