AP-CON Aluminum Solid Electrolytic Capacitor
AVEA Series Standard
Standard SMD type
Rated Voltage:2.5~25Vdc
Endurance 2000hrs at 105℃
Suitable for DC-DC converters, voltage regulators and decoupling applications
RoHS Compliant
Specification
Category Temperature Range -55~+105℃
Rated Capacitance Range
15 to 1000 (μF)
Rated Voltage Range
2.5 to 25Vdc
Capacitance Tolerance
±20% (M)
Surge Voltage
Rated voltage X 1.15 (at 105°C) Dissipation Factor
Leakage Current
Shall not exceed values shown in standard ratings.
0.12 max. (at 20°C 120Hz)
(at 20°C after 2 mins.)
105°C, 2000hrs, rated voltage applied
Appearance
No significant damage
Endurance
Capacitance Change
≦ ±20% of the initial value
DF(tanδ)
≦ 150% of the initial specified value
ESR
≦ The initial specified value
60℃, 90 to 95% RH, 1000hrs, No voltage applied
Appearance
Leakage current
Damp Heat (Steady State)
Capacitance Change
DF(tanδ)
ESR
Leakage current
1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a
protective resistor (R=1kΩ) and discharge for 5.5min.
Appearance
Surge Voltage
Capacitance Change
DF(tanδ)
ESR
Leakage current
Dimensions and Marking
Series
Date code
Polarity
Capacitance
marking (-)
Voltage
Size code
0506
0645
0606
0610
0807
0810
ψD±0.5max
(mm)
5.0
6.3
6.3
6.3
8.0
8.0
L
(mm)
5.8
4.3
5.8
9.7
6.8
9.7
α
(mm)
E
(mm)
W±0.2
(mm)
H±0.2
(mm)
C±0.2
(mm)
R
(mm)
P±0.3
(mm)
0.2
0.2
0.2
0.3
0.2
0.3
0.00~0.20
0.00~0.20
0.00~0.20
0.00~0.20
0.00~0.20
0.00~0.20
5.3
6.6
6.6
6.6
8.3
8.3
5.3
6.6
6.6
6.6
8.3
8.3
6
7.3
7.3
7.3
9
9
0.5~0.8
0.5~0.8
0.5~0.8
0.6~0.9
0.8~1.1
0.8~1.1
1.4
2.1
2.1
2.1
2.9
2.9
Product Specifications are subject to change without notice.
Standard Ratings
WV/Vdc
(SV)
2.5
(2.9)
6.3
(7.2)
16
(18.4)
25
(28.8)
Cap Size
(μF) Code
330
330
390
390
560
820
100
220
220
330
560
560
820
1000
47
68
100
100
180
270
270
330
15
22
27
47
0506
0645
0506
0606
0606
0610
0645
0645
0606
0606
0610
0810
0810
0810
0606
0606
0506
0606
0606
0807
0810
0810
0645
0645
0606
0606
Leakage
ESR
Current
(mΩmax/20%,
(μA)
100k to300kHz)
165
700
700
292
700
700
315
700
277
416
705
705
1,033
1,260
376
300
320
320
576
864
864
1,056
300
275
338
235
21
17
10
10
10
10
19
17
15
17
10
10
12
10
25
25
27
24
22
22
16
16
55
45
40
30
Rated Ripple
Current
(mArms/ 105℃
/100kHz)
Part No.
2,670
2,300
3,900
3,900
3,900
4,300
2,300
2,300
3,160
3,390
4,300
4,500
4,700
5,440
2,500
2,440
3,000
2,490
3,300
3,300
4,400
4,700
1,650
2,350
2,100
2,500
2R5AVEA331M0506
2R5AVEA331M0645
2R5AVEA391M0506
2R5AVEA391M0606
2R5AVEA561M0606
2R5AVEA821M0610
6R3AVEA101M0645
6R3AVEA221M0645
6R3AVEA221M0606
6R3AVEA331M0606
6R3AVEA561M0610
6R3AVEA561M0810
6R3AVEA821M0810
6R3AVEA102M0810
160AVEA470M0606
160AVEA680M0606
160AVEA101M0506
160AVEA101M0606
160AVEA181M0606
160AVEA271M0807
160AVEA271M0810
160AVEA331M0810
250AVEA150M0645
250AVEA220M0645
250AVEA270M0606
250AVEA470M0606
很抱歉,暂时无法提供与“6R3AVEA221M0645”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.87966
- 50+0.72414
- 150+0.64638
- 1500+0.50458
- 3000+0.45792
- 4500+0.43460
