UHP252010NF-4R7M
UHP252010NF-4R7M
    TAI-TECH(台庆)
    功率电感 SMD
UHP252010NF-4R7M 数据手册
P1 TAI-TECH Power Inductor UHP252010NF-SERIES ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 14/02/10 新 發 行 楊祥忠 詹偉特 林宜蕰 備 註 www.tai-tech.com.tw P2 TAI-TECH Power Inductor UHP252010NF-SERIES 1. Features 1. This specification applies Low Profile Power Inductors. 2. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension Halogen Pb Halogen-free Pb-free B A D E D C Series A(mm) B(mm) C(mm) D(mm) E(mm) UHP252010NF 2.5 -0.1/+0.2 2.0 -0.1/+0.2 1.0max. 0.85 ref. 0.80 ref. Units: mm 3. Part Numbering UHP 252010 NF A B - C 4R7 M D E A: Series B: Dimension C: Lead Free Material D: Inductance E: Inductance Tolerance 4R7=4.7uH M=±20% 4. Specification TAI-TECH Part Number Test Inductance Tolerance DCR I sat I sat Frequency (uH) (%) (Ω) ±20% (A) typ. (A) Max. (Hz) I rms (A) typ I rms (A) Max. UHP252010NF-R47M 0.47 ±20% 0.1V/1M 0.030 2.85 2.57 2.80 2.50 UHP252010NF-R68 M 0.68 ±20% 0.1V/1M 0.039 2.70 2.45 2.45 2.20 UHP252010NF-1R0 M 1.0 ±20% 0.1V/1M 0.055 2.45 2.05 2.20 1.80 UHP252010NF-1R5 M 1.5 ±20% 0.1V/1M 0.090 1.80 1.70 1.70 1.55 UHP252010NF-2R2M 2.2 ±20% 0.1V/1M 0.114 1.60 1.55 1.55 1.40 UHP252010NF-3R3M 3.3 ±20% 0.1V/1M 0.170 1.30 1.10 1.25 1.10 UHP252010NF-4R7M 4.7 ±20% 0.1V/1M 0.250 1.10 0.95 1.05 0.92 UHP252010NF-6R8M 6.8 ±20% 0.1V/1M 0.370 0.95 0.80 0.85 0.76 UHP252010NF-100M 10 ±20% 0.1V/1M 0.470 0.75 0.65 0.75 0.67 UHP252010NF-150M 15 ±20% 0.1V/1M 0.750 0.55 0.45 0.55 0.50 UHP252010NF-220M 22 ±20% 0.1V/1M 1.120 0.50 0.40 0.50 0.45 Note: Isat:Based on inductance change (△L/L0:≦-30%)@ ambient temp. 25℃ Irms:Based on temperature rise (△T:40℃.)Max www.tai-tech.com.tw P3 TAI-TECH UHP252010NF-R47 1 0.9 Inductance(uH) Inductance(uH) 0.8 0.6 0.4 0 0 0 1 2 DCcurrent(A) 3 4 0 UHP252010NF-1R0 2 1.2 1.8 2.4 DCcurrent(A) 3 UHP252010NF-1R5 2.4 Inductance(uH) Inductance(uH) 0.6 3 1.5 1 0.5 1.8 1.2 0.6 0 0 0 0.5 1 1.5 2 DCcurrent(A) 0 2.5 UHP252010NF-2R2 4 0.5 1 DCcurrent(A) 1.5 2 UHP252010NF-3R3 6 4.5 Inductance(uH) 3 Inductance(uH) 0.6 0.3 0.2 2 3 1.5 1 0 0 0 0.5 1 DCcurrent(A) 1.5 0 2 UHP252010NF-4R7 8 0.3 0.6 0.9 DCcurrent(A) 1.2 1.5 0.8 1 UHP252010NF-6R8 12 9 Inductance(uH) 6 Inductance(uH) UHP252010NF-R68 1.2 4 6 3 2 0 0 0 0.3 0.6 0.9 DCcurrent(A) 1.2 1.5 0 www.tai-tech.com.tw 0.2 0.4 0.6 DCcurrent(A) P4 TAI-TECH UHP252010NF-100 20 15 Inductance(uH) 15 Inductance(uH) UHP252010NF-150 20 10 5 10 5 0 0 0 0.2 0.4 DCcurrent(A) 0.6 0.8 0.45 0.6 0 0.2 0.4 DCcurrent(A) 0.6 0.8 UHP252010NF-220 32 Inductance(uH) 24 16 8 0 0 0.15 0.3 DCcurrent(A) 5. Material No. Description Specification a. Core Ferrite Core b. Coating Epoxy with magnetic powder c Termination Tin Pb Free d Wire Enameled Copper Wire Exposed wire tolerance limit of coating resin part on product side. Size of exposed wire occurring to coating resin is specified below. 1. Width direction(dimension a):Acceptable when a≦w/2 Nonconforming when a>w/2 2. Length direction(dimension b):Dimension b is not specified. 3. The total area of exposed wire occurring to each sides is not greater than 50% of coating resin area, and is acceptable. www.tai-tech.com.tw P5 TAI-TECH 6. Reliability and Test Condition Item Operating Temperature Performance Test Condition -55~+125℃(For products in unopened tape package, less than 40℃) Electrical Performance Test Inductance L Agilent-4291, Agilent-4287 Agilent-4192, Agilent-4285 Q Refer to standard electrical characteristic list SRF Agilent-4291 DC Resistance Agilent-4338 Rated Current Base on temp. rise & △L/L0A≦30%. Saturation DC Current (Isat) will cause L0 to drop approximately △L(%). Temperature Rise Test ΔT 40℃Max Heat Rated Current (Irms) will cause the coil temperature rise approximately △T(℃) without core loss. 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Mechanical Performance Test Appearance:No damage. Inductance:within±10% of initial value Solder Heat Resistance Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Temperature (°C) Time (s) Temperature ramp/immersion and emersion rate 260 ±5 (solder temp) 10 ±1 25mm/s±6 mm/s Number of heat cycles 1 Depth: completely cover the termination Solderability Test Preheat: 150℃,60sec.。 Solder: Sn99.5%-Cu0. 5%。 Temperature: 245±5℃。 Flux for lead free: Rosin. 9.5%。 More than 95% of terminal electrode should be covered with solder. Dip time: 4±1sec。 Depth: completely cover the termination Reliability Test Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Temperature:125±2℃(Bead) Life Test Temperature: 85±2℃(Inductor) Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Step1:-40±2℃ 30±5min Step2:25±2℃ ≦0.5min Thermal shock Appearance:No damage. Step3:105±2℃ 30±5min Inductance:within±10% of initial value Q:Shall not exceed the specification value. Number of cycles: 500 Measured at room fempraturc after placing for 24±2 hrs RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Humidity Resistance Test Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Oscillation Frequency: 10~2K~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration Test www.tai-tech.com.tw P6 TAI-TECH 7. Soldering and Mounting 7-1. Soldering Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for all wave and re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools. 7-1.1 Solder re-flow: Recommended temperature profiles for re-flow soldering in Figure 1. 7-1.2 Soldering Iron(Figure 2): Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a soldering iron must be employed the following precautions are recommended. ‧Preheat circuit and products to 150℃ ‧355℃ tip temperature (max) ‧Never contact the ceramic with the iron tip ‧1.0mm tip diameter (max) Iron Soldering Reflow Soldering PRE-HEATING SOLDERING 20~40s PRE-HEATING NATURAL COOLING TEMPERATURE(°C) ( 217 60~150s 200 150 SOLDERING within 4~5s TP(260° C / 40s max.) ) ‧Use a 20 watt soldering iron with tip diameter of 1.0mm ‧Limit soldering time to 4~5 sec. 60~180s NATURAL COOLING 350 150 Gradual cooling Over 60s 480s max. 25 TIME(sec.) TIME( sec.) Reflow times: 3 times max. Iron Soldering times: 1 times max. Fig.1 Fig.2 7-2. Recommended PC Board Pattern H L L(mm) G(mm) H(mm) 2.6 0.8 2.1 G www.tai-tech.com.tw P7 TAI-TECH 8. Packaging Information 8-1. Reel Dimension Type A(mm) B(mm) C(mm) D(mm) 7”x8mm 8.4±1.0 50 min. 13±0.8 178±2 C B D A 8-2. Tape Dimension / 8mm 7"x8mm 8-2. Tape Dimension / 8mm t P Ao Bo Po:4±0.1 W:8.0±0.1 P2:2±0.05 Series Size UHP 252010 Bo(mm) Ao(mm) Ko(mm) P(mm) 2.85±0.1 2.45±0.1 1.40±0.1 4.0±0.1 t(mm) 0.23±0.05 Ko 8-3. Packaging Quantity Chip size 252010 Chip / Reel 2000 8-4. Tearing Off Force F Top cover tape The force for tearing off cover tape is 15 to 80 grams in the arrow direction under the following conditions. 165° to180° Base tape Room Temp. Room Humidity Room atm Tearing Speed (℃) (%) (hPa) mm/min 5~35 45~85 860~1060 300 Application Notice ‧Storage Conditions To maintain the solderability of terminal electrodes: 1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1. 2. Temperature and humidity conditions: Less than 40℃ and 60% RH. 3. Recommended products should be used within 12 months form the time of delivery. 4. The packaging material should be kept where no chlorine or sulfur exists in the air. ‧Transportation 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. www.tai-tech.com.tw
UHP252010NF-4R7M 价格&库存
很抱歉,暂时无法提供与“UHP252010NF-4R7M”相匹配的价格&库存,您可以联系我们找货
UHP252010NF-4R7M
库存:1530
