Form No.: QF-1274
Edition: 2
RoHS & Halogen Free & REACH Compliance.
SPECIFICATION FOR APPROVAL
Customer:
各廠家
Customer P/N:
Drawing No:
Quantity:
Chilisin P/N:
Pcs.
Date :
2018/06/19
MPB252012T-4R7M-NA2
SPECIFICATION
ACCEPTED BY:
COMPONENT
ENGINEER
ELECTRICAL
ENGINEER
MECHANICAL
ENGINEER
APPROVED
REJECTED
奇力新電子股份有限公司
Chilisin Electronics Corp
No. 29, Alley 301, Tehhsin Rd.,
Hukou,Hsinchu 303, Taiwan
TEL +886-3- 599-2646
FAX +886-3- 599-9176
E-mail sales@chilisin.com.tw
http //www.chilisin.com.tw
奇力新電子(
奇力新電子(河南)
河南)有限公司
Chilisin Electronics (Henan) Co., Ltd.
XiuWu Xian, industry gathering area
JiaoZuo, Henan China
Postal Code:454350
TEL:+86-391-717-0682
FAX:+86-391-717-0666
Drawn by
陳瑞揚 ryan.chen
東莞奇力新電子有限公司
Chilisin Electronics (Dongguan) Co., Ltd.
No. 78, Puxing Rd., Yuliangwei Administration Area,
Qingxi Town, Dongguan City, Guangdong,China
TEL +86-769-8773-0251~3
FAX +86-769-8773-0232
E-mail cect@chilisin.com.tw
蘇州奇益新電子有限公司
SUZHOU QI YIXIN Electronics Co., Ltd.
No.143,Song Shan Rd., Suzhou New District,
Suzhou,China
Postal Code:215129
TEL:+86-512-6841-2350
FAX:+86-512-6841-2356
E-mail suzhou@chilisin.com.tw
Checked by
ling
溫美玲
Approved by
陳瑞揚 ryan.chen
YG18601014
MPB252010T Series Specification
1 Scope: This specification applies to Multilayer power inductors
2 Part Numbering:
3 Rating:
Operating Temperature: -55℃ ~ 125℃(Including self - temperature rise)
Storage Temperature: -55℃ ~ 125℃(after PCB)
-5℃~40℃,Humidity 40%~70%(before PCB)
4 Marking:
5 Standard Testing Condition
Temperature
Humidity
Unless otherwise specified
Ordinary Temperature(15 to 35 )
Ordinary Humidity(25 to 85% RH)
In case of doubt
20 to 30
50 to 80 %RH
6 Configuration and Dimensions:
7 Electrical Characteristics:
Inductance
(uH)
Test Freq.
RDC
(Ω)±30%
Isat
(mA)Max.
Irms
(mA)Max.
Tolerance
MPB252012T-R47□-NA2
0.47
3MHz,200mV
0.04
1500
1800
20,30
MPB252012T-1R0□-NA2
1
3MHz,200mV
0.05
950
1600
20,30
MPB252012T-1R5□-NA2
1.5
3MHz,200mV
0.07
900
1400
20,30
MPB252012T-2R2□-NA2
2.2
3MHz,200mV
0.1
700
1200
20,30
MPB252012T-3R3□-NA2
3.3
3MHz,200mV
0.12
500
1100
20,30
MPB252012T-4R7□-NA2
4.7
3MHz,200mV
0.14
350
1000
20,30
MPB252012T-6R8□-NA2
6.8
3MHz,200mV
0.16
250
900
20,30
Part No.
NOTE: □-tolerance M=±20% / T=±30%
1.Operating temperature range
2.Isat for Inductance drop 30% from its value without current.
℃ temperature rise from 25℃ ambient with current.
3.Irms for a 40
8 MPB252012T Series
8.1 Construction:
8.2 Material List:
7 Reliability Of Ferrite Multilayer power inductors
1-1.Mechanical Performance
No
Item
1-1-1 Flexure Strength
Test Method
Specification
The forces applied on the right Test device shall be soldered on the substrate
conditions must not damage Substrate Dimension: 100x40x1.6mm
the terminal electrode and the Deflection: 2.0mm
ferrite
Keeping Time: 30sec
1-1-2 Vibration
Oscillation Frequency: 10 to 55 to 10Hz for 1min
Amplitude: 1.5mm
Time: 2hrs for each axis (X, Y & Z), total 6hrs
1-1-3 Resistance to Soldering Heat Appearance: No damage
Pre-heating: 150 , 1min
More than 75% of the terminal.Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free)
electrode should be covered Solder Temperature: 260±5
with solder.
Immersion Time: 10±1sec
Inductance: within ±20% of
initial value
1-1-4 Solder ability
The electrodes shall be at
least 95% covered with new Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free)
solder coating
Solder Temperature: 245±5
Immersion Time: 4±1sec
1-1-5 Terminal Strength Test
No split termination
Chip
F
Test device shall be soldered on the substrate,
then apply a force in the direction of the arrow.
Force : 5N
Keeping Time: 10±1sec
Mounting Pad
1-2.Environmental Performance
No
Item
1-2-1 Temperature Cycle
1-2-2 Humidity Resistance
1-2-3 High
Temperature Resistance
1-2-4 Low
Specification
Inductance:within±20% of
initial value
Test Method
One cycle:
Time (min)
Step
Temperature ( )
1
-55±3
30
2
25±2
3
3
125±3
30
4
25±2
3
Total: 100cycles
Measured after exposure in the room condition for 24hrs
Temperature: 40±2
Relative Humidity: 90 ~ 95% / Time: 1000hrs
Temperature: 125±3
Relative Humidity: 0% / Time: 1000hrs
Temperature: -55±3
9 Packaging:
Chilisin P/N: MPB252012T-4R7M-NA2
9.1 Packaging -Cover Tape
L
RDC Isat
A
B
(uH)
(Ω) (mA)Max. m/m m/m
4.7±20%
0.14±30%
350
2.5±0.22.0±0.2
3MHz
200mV
5.14
5.15
5.14
5.15
5.11
5.15
3.1
5.14
5.14
5.12
0.114
0.111
0.115
0.114
0.114
0.114
0.12
0.115
0.11
0.114
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
2.48
2.48
2.48
2.48
2.49
2.48
2.48
2.49
2.49
2.48
9.3 Reel Dimensions
L: Agilent E4991A+16197A
RDC: HP4338B
Isat : E4980A+42841A
Irms: Chroma DC Power Suppy 62006P-100-25
1.98
1.98
1.98
1.99
1.98
1.98
1.99
1.99
1.98
1.98
C
m/m
D
m/m
1.2Max.
0.6±0.2
1.15
1.15
1.15
1.15
1.15
1.16
1.15
1.16
1.16
1.16
0.45
0.43
0.44
0.43
0.44
0.44
0.43
0.45
0.44
0.44
11 Packaging:
11.4 Tape Dimensions in mm
The force for tearing off cover tape is 10 to 100 grams in the arrow direction.
12 Recommended Land Pattern:
13 Note:
1. Please make sure that your product has been evaluated and confirmed against your specifications
when our product is mounted to your product.
2. Do not knock nor drop.
3. All the items and parameters in this product specification have been prescribed on the premise that
our product is used for the purpose,under the condition and in the environment agreed upon between
you and us. You are requested not to use our product deviating from such agreement.
4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950)
5. The moisture sensitivity level (MSL) of products is classified as level 1.
14 Graph:
很抱歉,暂时无法提供与“MPB252010T-4R7M-N2”相匹配的价格&库存,您可以联系我们找货
