RLP25JEER030
RLP25JEER030
    TA-I(大毅)
    电流采样电阻 2512
RLP25JEER030 数据手册
High Power Current Sensing Resistors RLP Series ( Halogen-Free ) AEC-Q 200-Ver D qualified Document No TRLP-250S008F Issued date 2016/10/11 page 1/6 1. Scope: This specification applied to the products of current sensing resistor of metal foil for Lead-Free RLP series manufactured by TA-I TECHNOLOGY CO.,LTD. 2. Type Designation: RLP Item 25 Series No. F Resistance tolerance E Packaging 25:2512 F:±1% E: Embossed Tape (6432) C Power rating R010 Resistance C=1W e.g : G:±2% D=1.5W R010=10mΩ J:±5% E=2W R100=100mΩ G=3W R500=500mΩ 3. Construction and Dimension : 3.1 Construction: Over-Coat Ni / Sn Plating Metal Alloy Plate 3.2 Dimension: Unit : mm Style L W C T Material 2.0±0.2(≦4mΩ) RLP25 6.4±0.2 3.2±0.2 Strip: Alloy 0.7 ±0.20 Over Coating:Polymer 0.9±0.2(R>4mΩ) Compound UL-94V-0 grade TA-I TECHNOLOGY CO., LTD Document No TRLP-250S008F Issued date 2016/10/11 page 2/6 High Power Current Sensing Resistors RLP Series ( Halogen-Free ) AEC-Q 200-Ver D qualified 4. Features: Type RLP25 Power Rating Resistance Value Operation Temperature Range Temperature Coefficient of Resistance Tolerance Insulation Resistance Maximum Working Current (A) 1 mΩ<R≦100mΩ(1W、1.5 W、2 W、3W) 100 mΩ<R≦500mΩ(1W、1.5 W、2 W) 1mΩ<R≦500mΩ -55℃~+170℃ ±50ppm/℃ ±1%,±2%,±5% 100 Meg Ohms Minimum (P/R)1/2 Note:2&3watts total Solder pad and trace size of 300mm 5. Reliability Tests : Test Items Temperature Coefficient of Resistance High Temperature Exposure(Storage) Low temperature operation Temperature Cycling Short time overload Biased Humidity Operation life Resistance to Soldering Heat Mechanical Shock Resistance to vibration Board Flex Flammability Reference IEC60115-1 4.8 MIL-STD202 Method 108 IEC60115-1 4.23.4 JESD22 Method JA-104 IEC60115-1 4.13 Condition of Test Test Limits +25 ~ 125℃ Refer 4.0 T=125℃,1000hrs,Measurement at 24hrs after test conclusion. < ±1% -55 °C for 45 min < ±0.5% 1000Cycle (-55℃ to 125 ℃),Measurement at 24hrs after test conclusion. < ±0.5% 5 X rated power for 5s < ±0.5% MIL-STD202 Method 103 MIL-STD202 Method 108 10% Rated voltage at 85 ℃,RH:85% ,1000Hrs, Measurement < ±0.5% at 24hrs after test conclusion. IEC60115-1 4.18 T=260+/-5℃ solder,10+/-1 sec dwell < ±0.5% MIL-STD202 Method 213 MIL-STD202 Method 204 AEC-Q200005 UL-94 1000 h at +70 °C, 1.5 h “ON”, 0.5 h “OFF” < ±1% 100g's , Normal duration is 6ms , half < ±0.5% sine shock pulse 5g's for 20min.12cycles, 10-2000Hz 0.004 4.0 2.1 4.1 R≦0.004 4.0 3.1 1.3 Unit: mm TA-I TECHNOLOGY CO., LTD High Power Current Sensing Resistors RLP Series ( Halogen-Free ) AEC-Q 200-Ver D qualified Document No TRLP-250S008F Issued date 2016/10/11 page 4/6 7. Number of Package: 4000 Pieces / package 8. Label: Date Code Series QTY: 4000 PCS T019C0071H LOT NO: Resistance R010 FEE 0308 RLP25FEE Tolerance Package Power Rating 9. Taping Packing Emboss Type RLP25 A 3.6±0.2 B 6.9±0.2 W 12.±0.2 F 5.5±0.05 E 1.75±0.1 P1 4.0±0.1 P2 2.0±0.05 P0 D0 t 4.0±0.05 ψ1.5 (+0.1/-0) 1.2±0.15 TA-I TECHNOLOGY CO., LTD High Power Current Sensing Resistors RLP Series ( Halogen-Free ) AEC-Q 200-Ver D qualified Document No TRLP-250S008F Issued date 2016/10/11 page 5/6 10. Reel Specification Series ψA ψB ψC W T 13.0±1.0 15.4±2.0 +0 RLP 25 60 ±1.0 180 13.0±1.0 -3 11. Peeling Strength of Top Cover Tape Test Condition: 0.1 to 0.7 N at a peel-off speed of 300 mm / min. top cover tape pull 300 mm/min 10 ~15 standard pulling force: 0.1 ~ 0.7 N carrier tape 12. Storage Conditions: Temperature: 5℃~35℃,Humidity:40%~75% 13. Shelf Life: 2 years from manufacturing date. TA-I TECHNOLOGY CO., LTD High Power Current Sensing Resistors RLP Series ( Halogen-Free ) AEC-Q 200-Ver D qualified Document No TRLP-250S008F Issued date 2016/10/11 page 6/6 14. Recommend IR – Reflow profile: (solder: Sn96.5 / Ag3 / Cu0.5) Peak : 260 5 ℃ , 5 sec 0 Pre – heat zone : 150 to 180 ℃, 90±30 sec Soldering zone : 230℃ or higher , 30±10 sec Iron Solder:350±10℃ , 3+1/-0 sec 15. ECN Engineering Change Notice: The customer will be informed with ECN if there is significant modification on the characteristics and materials described in approval sheet. 16. Manufacturing Country & City : TA-I TECHNOLOGY CO., LTD. ( Taiwan– Tao Yuan ) Tel: (+886) 3-3246169 Fax : (+886) 3-3246167 Associated companies : (1)TA-I TECHNOLOGY ( SU ZHOU ) CO., LTD. ( China – Su Zhou) Tel :(+86) 512-63457879 Fax : (+86) 512-63457869 (2) TA-I TECHNOLOGY ELECTRONIC (DONGGUAN ) CO., LTD. ( China –Dongguan ) Tel : (+86) 769-8339-4790〜3 Fax : (+86) 769-8339-4794 (3) FORTUNE TASK RESISTOR FACTORY Tel : (+86) 769-8339-4790〜3 ( China – Dongguan ) Fax : (+86) 769-8339-4794 (4) TAI OHM ELECTRONICS ( M ) SDN. BHD. ( Malaysia – Penang ) Tel :(+60) 4- 3900480 Fax : (+60) 4-3901481 (5) P.T.TAI ELECTRONIC Indonesia ( Indonesia – Jakarta ) Tel :(+62) 21-44820254 Fax : (+62) 21-44820256 TA-I TECHNOLOGY CO., LTD
