Cautions and Warnings
Please be noted that this spec is only for reference if you have projects
designed with the product number listed in. If you are looking for new
project design-in, please find BWCU_02 Series specification/datasheet on
Chilisin website. Or you may find our sales contact for more information on
old part number at your convenience. Appreciated your attention and
understanding.
Note: Please be sure to request approval specifications that provide further details of the products.
Kindly note that the content of these specifications are subject to change or may be discontinued
without prior notice. This product may not be designed/used in medical or high risk applications
without Chilisin approval. Please contact our sales department before ordering.
SMD Common Mode Choke - CUW Series
CUW Series For USB 2.0, IEEE1394b, LVDS Applications
A full series of common mode choke is designed for excellent noise
attenuation with compact sizing for use in wide range of applications.
Both standard series and custom designs are available.
Features
Applications
RoHS Compliant
USB line for personal computers and peripheral
Miniature SMD type common mode filter for fully automated assembly IEEE 1394 line for personal computers, DVC, STB
Wide impedance range (30Ω ~ 2200Ω) for noise suppression
LVDS, panel line for liquid display panels, graph card,etc.
Excellent solderability
Product Identification
Packaging: T:Tape and Reel
Shape and Dimensions
Recommended Pattern
CUW10/11/31
CUW21
Dimensions in mm
Dimensions in mm
TYPE
A
B
C
D
E
TYPE
A
B
C
D
CUW10
1.60±0.2
0.80±0.2
1.10±0.2
0.25
0.33
CUW10
0.25
0.75
0.61
2.29
CUW11
1.25±0.2
1.00±0.2
0.8±0.1
0.32
0.33
CUW11
0.36
1.00
0.59
1.75
CUW21
2.05±0.2
1.25±0.2
1.20±0.2
0.50
0.40
CUW21
0.50
1.27
0.80
2.60
CUW31
3.20±0.2
1.60±0.2
1.90±0.2
0.50
0.60
CUW31
0.40
1.60
1.60
3.70
Electrical Characteristics
Part Number
Impedance
Tolerance
(Ω)
Test
Frequency
(MHz)
RDC
Irms
(Ω) Max
(mA) Max
Rated
Withstamd
Insulation
Voltage
Voltage
Resistance
(Vdc)
(Vdc)
(MΩ) Min
CUW10T-250M-N
25
20,25
100
0.077
500
50
125
10
CUW10T-600M-N
60
20,25
100
0.109
500
50
125
10
CUW10T-900M-N
90
20,25
100
0.142
500
50
125
10
CUW10T-121M-N
120
20,25
100
0.160
500
50
125
10
CUW10T-141M-N
140
20,25
100
0.174
500
50
125
10
CUW10T-221M-N
220
20,25
100
0.209
500
50
125
10
Note: When ordering, please specify tolerance code. Tolerance: M=±20% , Y=±25%
Operating temperature range-40℃~105℃(Including self - temperature rise)
rms for 20℃ rise from 25℃ ambient
Measure Equipment:
Z:Agilent HP4287A+Agilent 16197A
RDC:HP4338B or Chroma 16502 (Single Wire Test Value)
Irms:HP4284A+HP42841A/HP4285A+HP42841A
Insulation Resistance:Agilent HP4339B
Test Instruments:HP4287A Material/Impedance Analyzer
Typical Impedance vs. Frequency
1000
COMMON MODE
221
141
IIMPEDANCE(Ω)
100
121
600
900
250
10
221
1
141
250
0.1
1
900
600
121
10
NORMAL MODE
100
FREQUENCY(MHz)
Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these
specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in
medical or high risk applications without Chilisin approval. Please contact our sales department before ordering.
1000
Part Number
Impedance
Tolerance
(Ω)
Test
Frequency
(MHz)
RDC
IDC
(Ω) Max
(mA)
Rated
Withstamd
Insulation
Voltage
Voltage
Resistance
(Vdc)
(Vdc)
(MΩ) Min
CUW11T-250T-N
25
30
100
0.30
400
50
125
100
CUW11T-600M-N
60
0.40
300
50
125
100
CUW11T-670M-N
67
0.25
300
50
125
100
CUW11T-900M-N
90
0.30
250
50
125
100
CUW11T-121M-N
120
0.40
200
50
125
100
CUW11T-161M-N
160
0.43
160
50
125
100
CUW11T-201M-N
200
0.80
120
50
125
100
CUW11T-331Y-N
330
25
100
1.30
100
50
125
100
Note: When ordering, please specify tolerance code. Tolerance: M=±20% , Y=±25% , T=±30%
IDC for Inductance drop 10% from its value without current
Measure Equipment:
RDC:Chroma 16502 (Single Wire Test Value)
IDC:HP4284A+HP42841A/HP4285A+HP42841A
10000
Common Mode
161
IMPEDANCE(Ω)
1000
121
900
670
100
600
10
161
1
121
600
0.1
1
670
10
Normal Mode
900
100
1000
FREQUENCY(MHz)
10000
Rated
Withstamd
Insulation
Voltage
Voltage
Resistance
(Vdc)
(Vdc)
(MΩ) Min
450
50
125
10
0.25
400
50
125
10
0.30
360
50
125
10
100
0.35
330
50
125
10
0.30
400
50
125
10
0.35
350
50
125
10
180
0.35
330
50
125
10
CUW21T-201M-N
200
0.35
330
50
125
10
CUW21T-221M-N
220
0.35
310
50
125
10
CUW21T-261M-N
260
0.40
300
50
125
10
CUW21T-301M-N
300
0.40
290
50
125
10
CUW21T-361M-N
360
0.45
280
50
125
10
CUW21T-371M-N
370
0.45
280
50
125
10
CUW21T-501M-N
500
0.55
170
50
125
10
CUW21T-671M-N
670
0.60
140
50
125
10
CUW21T-901M-N
900
0.60
80
50
125
10
Impedance
Tolerance
(Ω)
CUW21T-300M-N
30
CUW21T-670M-N
67
CUW21T-750M-N
75
CUW21T-900M-N
Test
RDC
IDC
(Ω) Max
(mA)
100
0.20
90
CUW21T-121M-N
120
CUW21T-161M-N
160
CUW21T-181M-N
Part Number
Frequency
(MHz)
Measure Equipment:
Test Instruments:HP4291A Material/Impedance Analyzer
SMD Common Mode Choke – CUW Series
Rated
Withstamd
Insulation
Voltage
Voltage
Resistance
(Vdc)
(Vdc)
(MΩ) Min
370
50
125
10
0.3
370
50
125
10
0.4
340
50
125
10
100
0.4
320
50
125
10
100
0.5
310
50
125
10
0.8
260
50
125
10
1000
1.0
230
50
125
10
2200
1.2
200
50
125
10
Impedance
Tolerance
(Ω)
CUW31T-900M-N
90
CUW31T-121M-N
120
CUW31T-161M-N
160
CUW31T-221M-N
CUW31T-261M-N
Test
RDC
IDC
(Ω) Max
(mA)
100
0.3
220
CUW31T-601M-N
600
CUW31T-102M-N
CUW31T-222M-N
Part Number
Frequency
(MHz)
Measure Equipment:
Packaging Specifications
Tape Dimensions
Reel Dimensions
4.0 ± 0.1
2.0 ± 0.05
1.5 +0.1/-0.0
T
1.75 ± 0.1
F
BB
W
A
K
Trailer
P
O
C
Leader
End
O
End
Blank part (160mm min.)
O
Blank Compartments with Cover Tape
and Leader (330mm min.)
Dimensions in mm
TYPE
Tape Dimensions
Reel Dimensions
Quantity
A
B
T
W
P
F
K
A
B
C
D
PCS / Reel
CUW10
0.95
1.70
0.24
8
4
3.5
1.15
178
60
12
1.5
2000
CUW11
1.15
1.45
0.24
8
4
3.5
1.00
178
60
12
1.5
2000
CUW21
1.50
2.25
0.24
8
4
3.5
1.35
178
60
12
1.5
2000
CUW31
1.76
3.47
0.22
8
4
3.5
2.05
178
60
12
1.5
2000
很抱歉,暂时无法提供与“CUW21T-900M-N”相匹配的价格&库存,您可以联系我们找货
