WA06X5101FTL
WA06X5101FTL
    WALSIN(华新科)
    RA_0603X4
    排阻/电阻网络 0603x4 5.1kΩ ±1% 100mW ±100ppm/℃
WA06X5101FTL 数据手册
Approval sheet WA04, WA06 ±1%, ±5%, Convex Type & Concave Type General purpose chip resistors array Size 0402x2 (4p2R) Size 0402x4, 0603x4 (8p4R) Size 0602x8 (16p8R) *Contents in this sheet are subject to change without prior notice. Page 1 of 9 ASC_WA04/06_V15 Oct.2010 Approval sheet FEATURE 1. Small size and light weight 2. Reduced size of final equipment 3. Lower surface mounted assembly costs 4. Higher component and equipment reliability 5. RoHS compliant and lead free products. APPLICATION • Consumer electrical equipment • EDP, Computer application • Telecom DESCRIPTION The resistors array is constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is Tin (lead free) alloy. Fig 1. Consctruction of a Chip-R array (convex Type) Page 2 of 9 Fig 2. Consctruction of a Chip-R array (concave Type) ASC_WA04/06_V15 Oct.2010 Approval sheet QUICK REFERENCE DATA Item Series No. Size Resistance Tolerance Resistance Range TCR (ppm/°C) 10Ω ≤ R ≤ 1MΩ R1MΩ Max. dissipation at Tamb=70°C Max. Operation Voltage (DC or RMS) Max. overload voltage Climatic category WA04Y(Convex) 0402x2 (1005x2) General Specification WA06X(Convex) 0603x4 (1608x4) WA04X(Convex) 0402x4 (1005x4) ±5% ±1% ±5% ±1% ±5% 3Ω ~ 1MΩ, Jumper 10Ω ~ 1MΩ 3Ω ~ 1MΩ Jumper 10Ω ~ 1MΩ ≤ ± 300 ≤ ± 400 ≤ ± 200 - ≤ ± 200 -300~+500 ≤ ±100 - WA06W(Convex) 0602x8 (1605x8) ±1% WA06T(Concave) 0603x4 (1608x4) ±5% ±1% ±5% 1Ω ~ 10MΩ 10Ω ~ 100KΩ, 10Ω ~ 100KΩ 10Ω ~ 1MΩ, 10Ω ~ 1MΩ, Jumper, Jumper Jumper, ≤ ±200 -300~+500 ≤ ±200 - ≤ ± 200 - ≤ ± 200 - ≤ ± 200 - 1/16 W 1/16 W 1/10 W 1/16 W 1/10 W 25V 50V 50V 50V 50V 50V 100V 100V 100V 100V 55/155/56 55/155/56 55/155/56 Note : 1. Climatic category refer to IEC 60068 2. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 3. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. DIMENSIONS (unit : mm) WA04Y L 1.00 ± 0.10 W 1.00 ± 0.10 T 0.35 ± 0.10 P 0.65 ± 0.10 A 0.34 ± 0.10 Ta 0.20 ± 0.15 Tb 0.25 ± 0.17 W P Ta T Tb A L Page 3 of 9 ASC_WA04/06_V15 Oct.2010 Approval sheet WA04X WA06X L 2.00 ± 0.10 3.20 ± 0.10 W 1.00 ± 0.10 1.60 ± 0.10 T 0.45 ± 0.10 0.50 ± 0.10 P 0.50 ± 0.05 0.80 ± 0.10 A 0.40 ± 0.10 0.60 ± 0.10 B 0.20 ± 0.10 0.30 ± 0.10 C 0.30 ± 0.05 0.40 ± 0.10 G 0.25 ± 0.10 0.30 ± 0.20 WA06W L 4.00 ± 0.20 W 1.60 ± 0.15 T 0.45 ± 0.10 B 0.30 ± 0.20 G 0.30 ± 0.20 D 0.20 ± 0.10 P 0.50 ± 0.20 H1 0.40 ± 0.20 H2 0.30 ± 0.10 WA06T Page 4 of 9 L 3.20+0.20/-0.10 W 1.60+0.20/-0.10 T 0.60 ± 0.10 P 0.80 ± 0.10 A 0.60 ± 0.15 B 0.35 ± 0.15 C 0.50 ± 0.15 G 0.50 ± 0.15 ASC_WA04/06_V15 Oct.2010 Approval sheet MARKING 3-digits marking for E24 series 1% ,5% products Each resistor is marked with a three digits code on the protective coating to designate the nominal resistance value. For values up to 9.1 the R is used as a decimal point. For values of 10.0 or greater the first 2 digits apply to the resistance value and third indicate the number of zeros to follow. Example RESISTANCE 4.7Ω 10Ω 100Ω 6800Ω 47000Ω 3-digits marking 4R7 100 101 682 473 No marking for WA04Y chip resistors array and E96 series resistance. FUNCTIONAL DESCRIPTION Product characterization Standard values of nominal resistance are taken from the E24 series for resistors with a tolerance of ±5%, The values of the E24 series are in accordance with “IEC publication 60063” Standard values of nominal resistance are taken from the E24/E96 series for resistors with a tolerance of ±1%, The values of the E24/E96 series are in accordance with “IEC publication 60063” Derating The power that the resistor can dissipate depends on the operating temperature; see Fig.3. Figure 3 Maximum dissipation in percentage of rated power as a function of the ambient temperature CONSTRUCTION R1=R2=R3=R4 Page 5 of 9 ASC_WA04/06_V15 Oct.2010 Approval sheet MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 4. Fig 4. Infrared soldering profile for Chip Resistors array Page 6 of 9 ASC_WA04/06_V15 Oct.2010 Approval sheet TEST AND REQUIREMENTS(JIS C 5201-1 : 1998) Essentially all tests are carried out according to the schedule of IEC publication 115-8, category LCT/UCT/56(rated temperature range : Lower Category Temperature, Upper Category Temperature; damp heat, long term, 56 days). The testing also meets the requirements specified by EIA, EIAJ and JIS. The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical robustness testing procedure for electronic components" and under standard atmospheric conditions according to IEC 60068-1, subclause 5.3. Unless otherwise specified, the following value supplied : Temperature: 15°C to 35°C. Relative humidity: 45% to 75%. Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar). All soldering tests are performed with midly activated flux. TEST REQUIREMENT Resistor PROCEDURE DC resistance Clause 4.5 DC resistance values measured at the test voltages specified below : Within the specified
WA06X5101FTL 价格&库存
很抱歉,暂时无法提供与“WA06X5101FTL”相匹配的价格&库存,您可以联系我们找货
