PAS3012EF-681K
PAS3012EF-681K
    TAI-TECH(台庆)
    SMD
    功率电感 SMD
PAS3012EF-681K 数据手册
TAI-TECH P1 Telecoil-antennas Inductors PAS3012EF-681K ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 17/08/01 新 發 行 楊祥忠 詹偉特 張展耀 備 註 www.tai-tech.com.tw TAI-TECH P2 Telecoil-antennas Inductor PAS3012EF-681K 1. Features 1. Hearing Aid Compatibility-/ Telecoil -antennas; 2. PAS3012F-series realizes small size and low profile. .3.0x3.0x1.2 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS Halogen Pb Halogen-free Pb-free compliant. 4. Meets the T3/T4 FCC .Requirements (HAC-Act) acc. ANSI C63.19 2. Dimension Series A(mm) B(mm) C(mm) D(mm) E(mm) PAS3012 3.0±0.2 3.0±0.2 1.2 max. 1.0 ref. 1.0 ref. Units: mm 3. Part Numbering PAS 3012 EF A B C - 681 K D E A: Series B: Dimension C: Lead Free Material D: Inductance E: Inductance Tolerance 681=680uH K=±10% 4. Specification Part Number PAS3012EF-681K Inductance Test Frequency SRF RDC(Ω) Rated current (uH) ±10% (KHz) MHz(typ) Max. (mA)Max. 680 10 5.0 22 80 Note: 1. Test frequency : Inductor(L) : 10KHz /0.1V; 2. All test data referenced to 25℃ ambient. 3. Testing Instrument : L/Q: Agilent-4192A, Agilent-16334A ; Irms:CH3302,CH1320 ; SRF: Agilent-4291B ; RDC: Agilent-34420A 4. Rated Current (Irms) will cause the coil temperature rise approximately Δt of 20℃ . www.tai-tech.com.tw TAI-TECH P3 5. Material No. Description Specification a. Core Ferrite Core b. Wire Enameled Copper Wire c Glue Epoxy d Terminal Ag/Ni/Sn 6. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test HP4284A,CH11025,CH3302,CH1320,CH1320S Inductance Refer to standard electrical characteristics list. DCR LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation DC Current (Isat) will cause L0 Saturation Current (Isat) △L≦30% typical. to drop △L(%)(keep quickly). Heat Rated Current (Irms) will cause the coil temperature rise △T(℃) without core loss. Heat Rated Current (Irms) Approximately △T≦40℃ 1.Applied the allowed DC current(keep 1 min.). 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature: 125±2℃(Inductor) Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Load Humidity Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Moisture Resistance Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Vibration www.tai-tech.com.tw Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 TAI-TECH Item P4 Performance Bending Shock Solder ability Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value More than 95% of the terminal electrode should be covered with solder。 Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
PAS3012EF-681K 价格&库存
很抱歉,暂时无法提供与“PAS3012EF-681K”相匹配的价格&库存,您可以联系我们找货
