CRYSTAL UNIT
YSX1612SL
Small Size
Applications
Features
‧SmartWearable
TWS IOT
Communication.
‧Dimensions:1.60 x 1.20 x 0.35 mm.
‧High precision and high frequency stability.
‧Standard Frequency:24~60MHz
‧Excellent heat resistance and environmental
characteristics.
Specifications
Standard Frequency
24~60 MHz
Vibration Mode
AT Fundamental
Load Capacitance
8pF,9pF,12pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
±20ppm,or specify
-20~+70℃, -40~+85℃,or specify
Operating Temperature
-40~+85℃, or specify
Storage Temperature
Shunt Capacitance
3 pF Max.
Level of Drive
100 μWMax.
Aging (at 25 ℃ )
±2ppm/year Max.
Equivalent Series Resistance(ESR)
Fundamental
32 ~ 40 MHz
41 ~ 60 MHz
150 Ω Max.
100 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
1.60±0.10
Marking
To p V i e w
2
0 . 7 5 0.30
0. 75
0.60
0.30
0.20
2
Bo t t o m Vi e w
2
0.60
0.50
4
1
To p Vi e w C r y st a l C o n n e c t i o n
S i de Vi ew
1
3
GND
0.3 5 ± 0 . 05
1
4
GND
1. 2 ± 0. 10
3
4
3
To p Vi e w S u g g e s t e d L a y o u t
www.yxc.hk
第1页共2页
CRYSTAL UNIT
YSX1612SL
Small Size
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-1612
180±2.0
8.0±0.3
1.85±0.1
1.90±0.1
4.0±0.1
0.45±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X161226MLB4SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.65000
- 100+1.32000
- 750+1.17700
- 1500+1.11100
- 3000+1.05710
- 国内价格
- 5+1.95567
- 50+1.52021
- 150+1.33359
- 500+1.10074
- 3000+0.99706
- 6000+0.93485
