MPCA-0630-R68-M
MPCA-0630-R68-M
    MAZO(玛冀)
    SMD,7x6.6mm
    功率电感 SMD
MPCA-0630-R68-M 数据手册
Kun Shan MAZO tech Co., Ltd Page : 1 / 10 昆山瑪冀電子有限公司 High Current, Power Inductors MPCA-0630-XXX-M Power Choke Applications • Voltage Regulator Module (VRM) • Multi-phase regulators • Point-of-load modules • Smart phone POL modules • SSD modules Description • Notebook regulators • Halogen Free • Battery power systems • 125°C maximum total temperature operation • Graphics cards •7.3x6.8x 3.0mm maximum surface mount package • Data networking and storage systems • Powder iron core material Environmental Data • Magnetically shielded, low EMI •Storage temperature range: -55°C to +125 °C • High current carrying capacity, Low core losses •Operating temperature range: -55°C to +125°C • Frequency range up to 5MHz (ambient plus self-temperature rise) • RoHS compliant •Solder reflow temperature: J-STD-020D compliant Description MPCA-0630-1R5-M 1.5μH ±20 % Model Inductance Value Inductance Tolerance Global Part Number M P C A Product Series 0 6 3 Dimensions 0 1 R Inductance 5 M Value Tol. Kun Shan MAZO tech Co., Ltd Page : 2 / 10 昆山瑪冀電子有限公司 Part No. Inductance DC Resistance Heating Rating Current Saturation Current L0 (μH) DCR (mΩ) Idc (A) Isat (A) ±20 %, 100 kHz, 1V TYP. MAX. TYP. TYP. MPCA-0630-R10-M 0.1 0.9 1.2 32.0 56.0 MPCA-0630-R22-M 0.22 2.5 3.0 24.0 34.0 MPCA-0630-R24-M 0.24 2.6 3.1 23.0 26.0 MPCA-0630-R33-M 0.33 3.0 3.5 21.0 25.0 MPCA-0630-R47-M 0.47 3.5 4.1 18.0 20.0 MPCA-0630-R56-M 0.56 3.9 4.5 16.5 18.0 MPCA-0630-R68-M 0.68 4.8 5.3 16.0 17.0 MPCA-0630-R82-M 0.82 5.4 6.0 14.0 16.0 MPCA-0630-1R0-M 1.0 6.7 7.4 12.0 15.0 MPCA-0630-1R5-M 1.5 10.6 12.1 12.0 14.0 MPCA-0630-2R2-M 2.2 13.5 15.0 9.5 10.0 MPCA-0630-3R3-M 3.3 18.0 22.0 8.5 9.5 MPCA-0630-4R7-M 4.7 28.0 33.0 6.0 6.5 MPCA-0630-5R6-M 5.6 37.0 42.0 5.0 6.0 MPCA-0630-6R8-M 6.8 42.5 48.0 5.0 6.0 MPCA-0630-8R2-M 8.2 54.0 60.0 5.0 6.0 MPCA-0630-100-M 10.0 62.0 67.0 4.5 5.5 MPCA-0630-150-M 15.0 104.0 115.0 3.0 4.5 MPCA-0630-220-M 22.0 180.0 200.0 2.3 3.0 MPCA-0630-330-M 33.0 280.0 310.0 2.0 2.5 Notes 1. All test data is referenced to 25 °C ambient 2. Operating temperature range - 55 °C to + 125 °C 3. Idc(A):DC current (A) that will cause an approximate ΔT of 40 °C(reference ambient temperature is 25 °C) 4. Isat(A):DC current (A) that will cause L0 to drop approximately 30 % 5. The part temperature (ambient + temp rise) should not exceed 125 °C under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. Kun Shan MAZO tech Co., Ltd Page : 3 / 10 昆山瑪冀電子有限公司 •Dimensions-mm •Marking The inductor is marked with a 3-digit code Example - -1.5→1R5 Note:Using Ink for marking Kun Shan MAZO tech Co., Ltd Page : 4 / 10 昆山瑪冀電子有限公司 Performance Graphs Test Instruments Test Condition Temperature: 26 ± 3℃ Wayne kerr 3260B/G LCR Meter Humidity: < 70% RH Wayne kerr 3265B Bias Current Source Frequency: 100 KHz, 1.0V MPCA-0630-R10-M MPCA-0630-R22-M 80 0.176 TEMP RISE(℃) 60 INDUCTANCE(μH) 0.04 40 0.02 20 0 0 0 10 20 30 40 50 80 TEMP RISE(℃) 0.132 60 INDUCTANCE(μH) 0.088 40 0.044 20 0 60 0 0 5 10 15 20 25 30 35 40 45 50 DC BIAS(Amps) DC BIAS(Amps) MPCA-0630-R33-M 100 0.192 80 0.264 80 TEMP RISE(℃) 0.144 60 INDUCTANCE(μH) 0.096 40 0.048 20 0 0 0 5 TEMP RISE(℃) 0.198 60 INDUCTANCE(μH) 0.132 40 0.066 20 0 10 15 20 25 30 35 40 45 0 0 5 10 DC BIAS(Amps) 80 0.448 60 INDUCTANCE(μH) 0.188 40 0.094 20 0 0 0 3 6 9 12 15 18 21 24 27 30 DC BIAS(Amps) INDUCTANCE(μH) 0.56 TEMP RISE(℃) 0.282 20 25 30 35 40 MPCA-0630-R56-M 100 TEMP RISE(℃) INDUCTANCE(μH) 0.376 15 DC BIAS(Amps) MPCA-0630-R47-M 0.47 TEMP RISE(℃) 0.33 INDUCTANCE(μH) 100 TEMP RISE(℃) INDUCTANCE(μH) MPCA-0630-R24-M 0.24 100 80 TEMP RISE(℃) 0.336 60 INDUCTANCE(μH) 0.224 40 0.112 20 0 0 0 3 6 9 12 15 18 21 24 27 30 DC BIAS(Amps) TEMP RISE(℃) 0.06 100 TEMP RISE(℃) 0.22 INDUCTANCE(μH) 0.08 100 TEMP RISE(℃) INDUCTANCE(μH) 0.1 Kun Shan MAZO tech Co., Ltd Page : 5 / 10 昆山瑪冀電子有限公司 MPCA-0630-R82-M 0.544 80 0.656 TEMP RISE(℃) 0.408 60 INDUCTANCE(μH) 0.272 40 0.136 20 0 60 INDUCTANCE(μH) 0.328 40 0.164 20 0 0 9 12 15 18 21 24 27 30 3 6 MPCA-0630-1R0-M 1.5 80 1.2 TEMP RISE(℃) 0.6 60 INDUCTANCE(μH) 0.4 40 0.2 20 0 INDUCTANCE(μH) 100 TEMP RISE(℃) INDUCTANCE(μH) 0.8 0 4 6 0.9 60 INDUCTANCE(μH) 0.6 40 0.3 20 0 0 0 2 4 6 8 10 12 14 16 18 20 22 24 DC BIAS(Amps) MPCA-0630-3R3-M 3.3 80 2.64 TEMP RISE(℃) 1.32 60 INDUCTANCE(μH) 0.88 40 0.44 20 0 0 8 10 12 DC BIAS(Amps) 14 16 INDUCTANCE(μH) 100 TEMP RISE(℃) INDUCTANCE(μH) 1.76 6 24 80 MPCA-0630-2R2-M 4 21 TEMP RISE(℃) 8 10 12 14 16 18 20 2.2 2 18 100 DC BIAS(Amps) 0 15 MPCA-0630-1R5-M 1 2 12 DC BIAS(Amps) DC BIAS(Amps) 0 9 TEMP RISE(℃) 6 0.492 100 80 TEMP RISE(℃) 1.98 60 INDUCTANCE(μH) 1.32 40 0.66 20 0 0 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 TEMP RISE(℃) 3 80 TEMP RISE(℃) 0 0 0 100 TEMP RISE(℃) 0.82 INDUCTANCE(μH) 100 TEMP RISE(℃) INDUCTANCE(μH) MPCA-0630-R68-M 0.68 Kun Shan MAZO tech Co., Ltd Page : 6 / 10 昆山瑪冀電子有限公司 5.6 3.76 80 4.48 TEMP RISE(℃) 2.82 60 INDUCTANCE(μH) 1.88 40 0.94 20 0 0 MPCA-0630-5R6-M 80 TEMP RISE(℃) 3.36 20 0 0 0 1 2 3 MPCA-0630-6R8-M 4.08 6.56 60 INDUCTANCE(μH) 2.72 40 1.36 20 0 0 6 7 8 80 4.92 60 INDUCTANCE(μH) 3.28 40 1.64 20 0 0 0 1 2 3 80 12 6 60 INDUCTANCE(μH) 4 40 2 20 0 0 5 6 DC BIAS(Amps) 7 8 9 INDUCTANCE(μH) 15 TEMP RISE(℃) INDUCTANCE(μH) 100 TEMP RISE(℃) 4 5 6 7 8 9 10 MPCA-0630-150-M 8 3 4 DC BIAS(Amps) MPCA-0630-100-M 2 9 TEMP RISE(℃) 9 10 10 1 8 100 DC BIAS(Amps) 0 7 100 80 TEMP RISE(℃) 9 60 INDUCTANCE(μH) 6 40 3 20 0 0 0 1 2 3 4 5 DC BIAS(Amps) 6 7 8 TEMP RISE(℃) 5 6 TEMP RISE(℃) 80 INDUCTANCE(μH) 8.2 TEMP RISE(℃) INDUCTANCE(μH) 100 TEMP RISE(℃) 4 5 MPCA-0630-8R2-M 5.44 3 4 DC BIAS(Amps) 6.8 2 40 1.12 DC BIAS(Amps) 1 60 INDUCTANCE(μH) 2.24 0 1 2 3 4 5 6 7 8 9 10 11 0 100 TEMP RISE(℃) 100 INDUCTANCE(μH) 4.7 TEMP RISE(℃) INDUCTANCE(μH) MPCA-0630-4R7-M Kun Shan MAZO tech Co., Ltd Page : 7 / 10 昆山瑪冀電子有限公司 MPCA-0630-220-M MPCA-0630-330-M 80 TEMP RISE(℃) 13.2 60 INDUCTANCE(μH) 8.8 40 4.4 20 0 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 DC BIAS(Amps) INDUCTANCE(μH) 17.6 33 100 26.4 80 TEMP RISE(℃) 19.8 60 INDUCTANCE(μH) 13.2 40 6.6 20 0 0 0 0.5 1 1.5 2 2.5 DC BIAS(Amps) 3 3.5 4 TEMP RISE(℃) 100 TEMP RISE(℃) INDUCTANCE(μH) 22 Kun Shan MAZO tech Co., Ltd Page : 8 / 10 昆山瑪冀電子有限公司 Mechanical Reliability Item Solderability Specification and Requirement Test Method The surface of terminal immersed shall Solder heat proof: be minimum of 95% covered with a new 1. Preheating: 160 ± 10 ℃ coating of solder 2. Retention time: 245 ± 5 ℃ for 2 ± 0.5 seconds 1. Vibration frequency: Inductance change: Within ± 10% Vibration Without mechanical damage such as break (10 Hz to 55 Hz to 10Hz) in 60 seconds as a period 2. Vibration time: Period cycled for 2 hours in each of 3 mutual perpendicular directions. 3. Amplitude: 1.5 mm max. 1. Peak value: 100 G Shock Inductance change: Within ±10% Without 2. Duration of pulse: 11ms mechanical damage such as break 3. 3 times in each positive and negative direction of 3 mutual perpendicular directions Endurance Reliability Item Specification and Requirement Test Method 1. Repeat 100 cycles as follow: (-55 ± 2 ℃; 30 ± 3 min) Thermal Shock Inductance change: Within ± 10% Without distinct damage in appearance →(Room temp., 5 min) → (+125 ± 2 ℃, 30 ± 3 min) → (Room temp., 5 min) 2. Recovery: 48 + 4 / -0 hours of recovery under the standard condition after the test. High Temperature Resistance Inductance change: Within ± 10% Without distinct damage in appearance 1. Environment condition: 85 ± 2 ℃ Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours 1. Environment condition: 60 ± 2 ℃ Humidity Resistance Inductance change: Within ± 10% Humidity: 90–95% Without distinct damage in appearance Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours Low Temperature Store High Temperature Store Inductance change: Within ± 10% Store temperature: Without distinct damage in appearance -55 ± 2 ℃,1000 + 4 / -0 hours Inductance change: Within ± 10% Store temperature: Without distinct damage in appearance +125 ± 2 ℃,1000 + 4 / -0 hours Kun Shan MAZO tech Co., Ltd Page : 9 / 10 昆山瑪冀電子有限公司 Tape Packaging Dimensions Reel Dimensions A0 B0 K0 t 7.2±0.10 7.5±0.10 3.6±0.15 0.31±0.05 Kun Shan MAZO tech Co., Ltd Page : 10 / 10 昆山瑪冀電子有限公司 • Peel force of top cover tape The peel speed shall be about 300mm/minute The peel force of top cover tape shall be between 0.1 to 1.3 N • Numbers of taping 1500pieces/reel • Label making The following items shall be marked on the production and shipping Label on the reel • Production Labe • Part No • Description • Quantity • Produce No • Taping No • Shipping Label (1)*Customer's name (2)*Customer's part No (3)Manufacturer's part No (4)Manufacturer's name (5) Manufacturer's country
MPCA-0630-R68-M 价格&库存
很抱歉,暂时无法提供与“MPCA-0630-R68-M”相匹配的价格&库存,您可以联系我们找货
