QUARTZ CRYSTAL UNIT SPECIFCATION
Customer:
Customer P/N:
1. Frequency:
2. Holder type :
3. Frequency tolerance:
4. Equivalent resistance:
5. Storage temperature range:
6. Operable temperature range:
7. Temperature drift:
8. Loading capacitance (CL) :
9. Drive level:
10. Shunt Capacitance:
11. Insulation resistance :
12. Mode of oscillation:
13. Circuit:
14. Shocking :
Variation :
15. Aging:
16. Note:
HELE P/N : X3S024000D81H-X
Date : 2015/07/16
24.000000MHz
HSX321S
+/-20 ppm at 25deg.C +/-3deg.C
60 ohms Max. / SERIES
-40 deg.C To +85 deg.C
-20 deg.C To +70 deg.C
+/-30 ppm
8.0 pF
10uW (100uW Max.)
2.0 pF Max.
More than 500M ohms at DC 100V
Fundamental
Measured in HP/E5100A,S&A 250B
Dropping from 120 cm height 3 times on Concrete floor
Frequency less than +/-5 ppm
Resistance less than +/- 15 ﹪or 2ohms max.
Less than +/- 3 ppm/ Year
*Marking should be printed as following:
Logo, Nominal Frequency, Manufactured year & month
*Nominal frequency = integer only
( ex.
14.31818 MHz
14
*Manufacturing Lot No.
(Y: year) ex. 2000 shall be marked as ‘ 0 ’
Year
2000 2001 2002 2003 2004 2005 2006 2007 2008 2009
2010 2011 2012 2013 2014 2015 2016 2017 2018 2019
Code
2
3
4
5
6
7
8
9
(M: month) ex. June shall be marked as ‘ F ‘
Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov. Dec.
A
B
C
D
E
F
G
H
J
K
L
M
Marking: Laser marking.
HARMONY ELECTRONICS CORP.
很抱歉,暂时无法提供与“X3S024000D81H-X”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.48840
- 10+2.76480
- 30+2.46240
- 100+2.07360
