PCMB104T-R22MS
PCMB104T-R22MS
    CYNTEC(乾坤)
    SMD
    功率电感 SMD
PCMB104T-R22MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : PCMB104T-000 REVISION : A5 PAGE : 1 OF 5 Power Choke Coil PCMB104T type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 4.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' Dimensions (mm) A B Code R15 / R22 / R36 / R39 R45 / R47 / R56 / R68 1R0 / 1R5 L W B' H  T 1R8 / 2R0 / 2R2 / 3R3 / 4R7 5R6 / 6R8 / 8R2 / 100 / 150 220 / 330 / 470 / 680 11.15 ± 0.35 10.85 ± 0.35 W 10 ± 0.3 T 3.8 ± 0.2 A 2.0 ± 0.5 A’ 2.5 ± 0.1 B 3.0 ± 0.5 B’ 5.0 ± 0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown above after confirming and safety. B A C A 4.1 B 5.4 C 13.6 Unit : mm CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : PCMB104T-000 REVISION : A5 PAGE : 2 OF 5 Specifications Part Number PCMB104T-R15MS PCMB104T-R22MS PCMB104T-R36MT PCMB104T-R39MT PCMB104T-R45MS PCMB104T-R47MS PCMB104T-R56MT PCMB104T-R68MS PCMB104T-1R0MT PCMB104T-1R5MS PCMB104T-1R8MS PCMB104T-2R0MS PCMB104T-2R2MS PCMB104T-3R3MS PCMB104T-4R7MS PCMB104T-5R6MS PCMB104T-6RR8MS PCMB104T-8R2MS PCMB104T-100MS PCMB104T-150MS PCMB104T-220MS PCMB104T-330MS PCMB104T-470MS PCMB104T-680MS L0 Inductance ( µH ) @ (0A) 0.15 0.22 0.36 0.39 0.45 0.47 0.56 0.68 1.0 1.5 1.8 2.0 2.2 3.3 4.7 5.6 6.8 8.2 10.0 15.0 22.0 33.0 47.0 68.0 Rdc ( mΩ) Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Typical Maximum Typical Typical 0.5 0.9 1.05 1.1 1.1 1.53 1.6 2.1 3.0 3.8 4.5 5.2 6.0 10.8 17.0 20.0 22.5 25.0 27.0 40.0 60.0 85.0 130.0 178.0 0.65 1.0 1.2 1.2 1.3 1.68 1.8 2.4 3.3 4.2 5.0 5.8 7.0 11.8 20.0 23.0 25.0 27.0 30.0 45.0 66.0 92.0 145.0 195.0 40.0 35.0 30.0 31.0 25.0 30.0 25.0 23.0 18.0 16.0 15.0 14.0 12.0 10.0 8.5 8.0 7.0 6.0 7.5 6.25 5.0 4.4 3.3 2.3 75.0 60.0 50.0 45.0 27.0 40.0 33.0 30.0 28.0 32.0 15.0 14.0 18.0 16.0 15.0 14.0 12.0 9.0 8.5 7.0 5.5 5.0 3.5 3.0 :If you require another part number please contact with us. **:Inductance Tolerance ± 20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 3.: Isat : DC current (A) that will cause Lo to drop approximately 30% Note 4.: Operating Temperature Range -55℃ to + 125℃ Note 5.: The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case * operating conditions. Circuit design , component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 6. : The rated current as listed is either the saturation current or the heating current depending on which value is lower. CYNTEC CO., LTD. 乾坤科技股份有限公司  : A5 PAGE : 3 OF 5 100 PCMB104T-R22MS TEMP RISE ( ℃) 40 0.06 60 0.16 0.12 40 0.08 INDUCTANCE(µH) 0.04 TEMP RISE ( 20 0.03 0 0 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 DC BIAS(Amps) DC BIAS(Amps) PCM B104T-R36MT 0.50 ℃ 0.32 60 IND UCTANCE(µH ) 0.24 TEM P RISE ( 0.16 ℃) 40 0.08 0.00 0 5 10 15 20 25 30 35 40 45 TEM P RISE( ) 80 INDUCTANCE(µH) 100 0.40 0.40 80 0.30 60 INDUCTANCE(µH) 0.20 20 0.10 0 0.00 50 TEMP RISE ( 0 5 10 15 ℃ I NDU CTAN CE(µH) 0.20 40 ℃ TEMP RIS E ( ) 0.10 TEMP RISE( 60 0.30 20 0.00 15 20 25 DC BIAS(Amps) 30 35 PCMB104T-R47MS 0.56 0.40 60 0.32 INDUCTANCE(µH) 0.24 TEMP.RISE( ℃) 40 0.16 20 0.08 0.00 0 0 5 10 15 20 25 30 DC BIAS(Amps) 35 40 45 50 80 0.30 40 0.20 IND UCTANCE(µH ) 20 ℃ 0 5 10 0.84 15 20 25 30 DC BIAS(Amps) 35 40 45 100 PCMB104T-R68MS 0.70 ℃ ℃ TEM P RISE ( ) 0 80 100 0.00 100 0.48 45 60 40 INDUCTANCE(µH) 10 TEMP RISE( ) 5 40 0.40 0.10 0 0 35 0.50 IND UCTANCE(µH ) 80 20 25 30 DC BIAS(Amps) PCM B104T-R56MT 0.60 ) 0.40 40 20 0 100 ℃) ℃ ) PCM B104T-R45MS 100 PCMB104T-R39MT DC BIAS(Amps) 0.50 20 0.00 0A 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 0.48 ℃) ℃ TEMP RISE( ) 0.09 80 0.20 TEMP RISE( ) 60 INDUCTANCE(µH) ℃ TEM P RISE( 80 0.12 INDUCTANCE(µH) 0.24 TEMP RISE( ) INDUCTANCE(µH) 0.28 100 0.00 IN DUCTAN CE(µ H) REVISION 80 0.56 60 0.42 40 0.28 INDUCTANCE(µH) 0.14 TEMP RISE ( ℃) 20 0.00 0 0 5 10 15 20 25 30 DC BIAS(Amps) 35 40 45 50 ℃ TEMP RISE( ) PCMB104T-R15MS 0.15 INDU CTA NCE(µH) : PCMB104T-000 Current Characteristic 0.18 INDUCTANCE(µH) DOCUMENT CYNTEC CO., LTD. 乾坤科技股份有限公司 60 0.60 40 INDUCTANCE(µH) TEMP RISE ( ℃) 0.00 0 5 10 15 20 DC BIAS(Amps) 25 30 80 40 0.80 0 0.40 IN DUCTAN CE(µ H) ℃ 20 TEMP RISE ( ) 0 0 5 10 15 20 25 DC BIAS(Amps) 30 35 40 100 PCMB104T-2R2MS 60 INDUCTANCE(µH) 0.90 TEMP RISE ( ℃) 40 0.60 0 5 10 15 DC BIAS(Amps) 20 80 1.60 60 INDUCTANCE(µH) 1.20 TEMP RISE ( 0.80 20 0.40 0 0.00 40 ℃ 0 2 4 6 8 10 12 14 16 DC BIAS(Amps) 18 20 22 24 PCMB104T-3R3MS 4.00 100 ℃) 20 0 25 PCMB104T-1R8MS 2.10 ℃ TEMP RISE( ) 1.50 INDUCTANCE(µH) 2.00 1.20 ℃ ) 1.00 0.60 100 80 1.50 60 1.20 0.90 INDUCTANCE(µH) 0.60 TEMP RISE ( 40 ℃) ℃ 20 0.30 80 3.00 2.50 INDUCTANCE(µH) 2.00 TEMP RISE ( 60 ℃) 40 1.50 1.00 ℃ TEMP RISE( ) 1.80 INDUCTANCE(µH) 3.50 TEMP RISE( ) 20 0.50 0 0 5 10 15 DC BIAS(Amps) 20 PCMB104T-4R7MS 6.00 80 4.00 60 3.00 40 INDUCTANCE(µH) TEMP.RISE( 1.00 ℃) 20 0.00 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 18 20 0 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 18 20 PCMB104T-5R6MS 6.00 100 5.00 2.00 0.00 25 100 5.00 ℃ 80 4.00 60 3.00 40 2.00 INDUCTANCE(µH) 1.00 TEMP RISE ( ℃) 12 14 20 0 0.00 0 2 4 6 8 10 DC BIAS(Amps) 16 ℃ TEMP RISE( ) 0.00 INDUCTANCE(µH) INDUCTANCE(µH) 100 60 20 80 0.00 INDUCTANCE(µH) PCM B104T-1R5MS 2.40 0.30 INDUCTANCE(µH) : 4 OF 5 100 1.80 0 PAGE 1.20 35 PCMB104T-2R0MS 2.10 : A5 TEMP RISE( ) 0.20 ℃ IND UCTANCE(µH ) 0.80 REVISION 1.40 TEMP RISE( ) 80 TEMP RISE( ) INDUCTANCE(µH) 1.00 0.40 1.60 100 : PCMB104T-000 TEM P RISE( PCMB104T-1R0MT 1.20 DOCUMENT CYNTEC CO., LTD. 乾坤科技股份有限公司 INDUCTANCE(µH) TEMP RISE ( ℃) 20 0.00 8 10 12 DC BIAS(Amps) 14 16 80 8.0 60 INDUCTANCE(µH) TEMP.RISE( ℃) 40 4.0 0 0.0 10 PCMB104T-220MS INDUCTANCE(µH) 60 ℃) 10.0 40 5.0 20 0.0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 ℃ 80 INDUCTANCE(µH) 24.0 TEMP.RISE( ) 60 ℃ 40 16.0 20 8.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 4.0 4.5 5.0 1 2 3 4 5 6 7 8 DC BIAS(Amps) 9 10 11 12 13 PCMB104T-150MS 100 15.0 80 12.0 60 INDUCTANCE(µH) ℃ 9.0 TEMP.RISE( ) 6.0 40 ℃ 20 3.0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 10 PCMB104T-330MS 100 30.0 80 24.0 60 INDUCTANCE(µH) 18.0 ℃ 40 TEMP.RISE( ) 12.0 ℃ 20 6.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 DC BIAS(Amps) 40.0 32.0 20 0.0 100 48.0 ℃) ℃ 0 9 PCMB104T-470MS 56.0 TEMP. RISE( 36.0 0 0 1.8 0 80 TEMP.RISE( INDUCT ANCE(µH) 0.0 100 20.0 15.0 40 3.6 12 PCMB104T-680MS 90.0 ℃ INDUCTANCE(µH) INDUCTANCE(µH) 6 8 DC BIAS(Amps) INDUCTANCE(µH) 4 TEMP RISE( ) 2 25.0 INDUCTANCE(µH) ℃ 20 2.0 0 5.4 18.0 100 10.0 6.0 60 0 18 PCMB104T-100MS 12.0 INDUCTANCE(µH) 6 INDUCTANCE(µH) 4 TEMP RISE( ) 2 80 7.2 0.0 0 0 100 100 75.0 80 60.0 60 INDUCTANCE(µH) 45.0 TEMP.RISE( ℃) 40 30.0 20 15.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 DC BIAS(Amps) 3.0 3.5 4.0 ℃ TEMP. RISE( ) 2.00 : 5 OF 5 TEMP RISE( ) 40 PAGE TEMP RISE( ) 4.00 : A5 9.0 INDUCTANCE(µH) 60 ℃ REVISION PCMB104T-8R2MS 10.8 TEMP RISE( ) 80 6.00 : PCMB104T-000 TEMP RISE( ) 100 PCMB104T-6R8MS TEMP RISE( ) INDUCTANCE(µH) 8.00 DOCUMENT
PCMB104T-R22MS 价格&库存
很抱歉,暂时无法提供与“PCMB104T-R22MS”相匹配的价格&库存,您可以联系我们找货
