SLO1365H220MTT
1. Features
1. Magnetic metal powder inductor.
2. Compact design.
3. High current,low DCR,high efficiency.
4. Very low acoustic noise and very low leakage flux noise.
5. High reliability.
6. 100% Lead(Pb)-Free and RoHS compliant.
2. Dimensions
220
编号
A
B
C
D
E
尺寸(mm)
14.40Max.
12.80 0.30
4.00 0.50
6.50Max.
0 0.15
F
2.50 0.50
3. Recommend Land Pattern Dimensions
A
B
C
4.50
3.40
14.10
Unit : mm
Rev.01
Page 1 of 7
www.Sunltech.com
SLO1365H220MTT
4.Specifications
DCR ( mΩ)
L0
Inductance
Part Number
( µH )
@ (0A)
SLO1365H220MTT
22
Typ.
Max
28
35
NOTES:
1. Idc : DC current (A) that will cause an approximate
Heat Rating Current
Saturation Current
DC Amps. Idc ( A )
DC Amps. Isat ( A )
6
12
△T of 40℃,
2. 2. Isat : DC current (A) that will cause Lo to drop approximately 35%
℃ ambient
4. Operating Temperature Range -55℃ to +125℃
3. All test data is referenced to 25
5. The part temperature (ambient + temp rise) should not exceed 125
℃under the worst operating conditions. Circuit
design,
component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part
temperature.
Part temperature should be verified in the end application.
6. TEST FREQUENCY:100KHz,1.0V
7. TESTING INSTRUMENT L :Agilent4284A,WK4235,CH3302/G LCR METER
CH1320,CH1320S BIAS CURRENT SOURCE
Rdc :CH502BC MICRO OHMMETER
Rev.01
Page 2 of 7
www.Sunltech.com
SLO1365H220MTT
5. TEST REPORT
TEST REPORT
L0A
22uH
±20%
21.38
21.37
20.94
21.11
20.44
19.98
20.13
20.45
20.51
20.71
Specification
Tolerance
1
2
3
4
5
6
7
8
9
10
X
Specification
Tolerance
1
2
3
4
5
6
7
8
9
10
X
Rev.01
Electrical Characteristic
Item
DCR
35mΩ
Max
20.702
A
B
14.4
12.8
Max (mm)
28.9
29.0
29.3
28.9
29.1
29.0
29.0
29.0
29.1
29.0
29.029
External Dimensions
Item
C
6Amps
△T≦40℃
I sat
12Amps
L≧65%
38.6℃
72.58%
I rms
D
F
4.0
6.5
2.5
± 0.3(mm)
± 0.5(mm)
Max (mm)
± 0.5(mm)
14.07
12.75
4.03
6.11
2.61
14.05
12.74
4.03
6.17
2.61
14.05
12.75
4.05
6.22
2.59
14.04
12.74
4.03
6.24
2.59
14.05
12.74
4.04
6.21
2.56
14.06
12.75
4.05
6.19
2.59
14.04
12.74
4.04
6.23
2.56
14.05
12.75
4.05
6.19
2.54
14.06
12.74
4.04
2.58
14.06
12.75
4.05
6.25
6.25
14.053
12.745
4.041
6.206
2.586
Page 3 of 7
2.63
www.Sunltech.com
SLO1365H220MTT
6. INDUCTANCE VS DC CURRENT
7.TEMPERATURE RISE VS DC CURRENT
Rev.01
Page 4 of 7
www.Sunltech.com
SLO1365H220MTT
8. Reliability and Test Condition
Item
Performance
Test Condition
-10~+40℃,50~60%RH (Product without taping)
Operating temperature
-40~+125
Storage temperature
Electrical Performance Test
HP4284A,CH11025,CH3302,CH1320,CH1320S
Inductance
Refer to standard electrical characteristics list.
DCR
CH16502,Agilent33420A Micro-Ohm Meter.
Saturation Current (Isat)
△L30% typical.
Saturation DC Current (Isat) will cause
L0 to drop
L(%)(keep quickly).
Heat Rated Current (Irms)
Heat Rated Current (Irms) will cause the coil
Approximately
△T≦40℃
△T(℃) without core loss.
temperature rise
Reliability Test
Temperature:125±2
Duration:1000±12hrs
High Temperature Exposure
Test
Low Temperature Life Test
Temperature:-40±2
Humidity:85±3%RH.
Temperature:85±2
Duration:1000±12hr
s.
Biased Humidity Test
Condition for 1 cycle
Step1:-40+0 / -2
Thermal shock test
Electric specifications should be satisfied
15±1 min.
Step2:Room temperature within
≦0.2
min.
Step3:+125+2
/ -0
Frequency:
10-2000-10Hz
for15±1min.
20 min.
Amplitude: Parts mounted within 2" from any secure
Vibration test
point. Directions and times: X, Y, Z directions for 20
min.
Reflow test
Reflow test
Solder test
Terminals should be covered by over 95% solder on visual inspection
Solder test
Rev.01
Page 5 of 7
Pre-heat 150 5
Duration 5
minutes
20~40
Temperature 260 5
seconds (IPC/JEDEC J-STD-020C)
After dip into flux dip into
solder 235 5
4 1seconds
Flux
solder for lead free
(ANSI /J-STD-002C Method
B)
www.Sunltech.com
SLO1365H220MTT
9. SOLDERING CONDITION RECOMMENDED
9.1 器件焊接方式:
9.1.1 回流焊焊接方式及推荐炉温曲线
9.1.2 高温耐热性描述(在 265℃的熔融铅料中,停留时间不少于 10 秒,3 次最少,无
质量问题。)
O
9.1.3 返修温度和时间 (温度:400 C;时间:不少于 5 秒。)
9.1.4 焊接次数 (元器件能承受的焊接次数不少于 3 次。)
Rev.01
Page 6 of 7
www.Sunltech.com
SLO1365H220MTT
10. Packaging Information
F
TYPE
A
B
A
B
C
D
E
F
C
D
24mm
330
100
21.0
±0.8
+ 0 .5
13 − 0.2
16±0.3
26.4
E
Q’TY (PCS)
A0
B0
KO
W
P
T
500
14.5±0.1
12.9±0.1
±0.1
6.6±0.1
24.0±0.3
16.0±0.1
.0±0.1
0.40±0.05
101
一卷包装:500Pcs;
①一卷包装
② 小箱装两卷:一共
1000Pcs;
00Pcs;
③ 大箱装三小箱:
大箱装三小箱 一共
3000Pcs.
00Pcs.
Rev.01
Page 7of 7
www.Sunltech.com
很抱歉,暂时无法提供与“SLO1365H220MTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.26160
- 10+2.74320
- 30+2.51640
- 100+2.28960
