X2R026000BZ1HZ-DEHPZ
    HELE(加高电子)
    SMD2520_4P
    无源晶振 SMD2520_4P
X2R026000BZ1HZ-DEHPZ 数据手册
PRELIMINARY SPECIFICATIONS GP Customer Part No.: HELE. Part No: X2R026000BZ1HZ-DEHPZ Application For: Products: Accepted Model: Type & Freq.: HSX221SR / 26.000MHz Sample Order No: Date: CRYSTAL 2014/02/21 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. HARMONY ELECTRONICS (SUZHOU) CO.,LTD TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號2樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄市大寮區大發工業區華東路 39 號 No.39, HWA DONG RD., DALLIAO DIST.,DAFA INDUSTRIAL PARK., KAOHSIUNG CITY 831, TAIWAN TEL: (07)787-1555-6 FAX: (07)787-1557 THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源 工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-27309272 / 27309262 FAX: 0755-27309755 Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS SUZHOU FACTORY: 蘇州市相城區黃埭鎮安民路 5 號 NO.5 ANMING ROAD, HUANGDAI TOWN, XIANGCHENG DISTRCT, SUZHOU CITY, JIANGSU PROVINCE TEL:86-512-67592373 FAX:86-512-67592363 CORP. 1 1 HSX221SR SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION............ 3-4 2. MARKING & DIMENSIONS................... 5 3. INSIDE STRUCTURE...................... 6 4. EMBOSS CARRIER TAPE&REEL................ a. DIMENSIONS OF CARRIER TAPE............... 7 b. DIMENSIONS OF REEL.................... 7-8 c. STORAGE CONDITION.................... 8 d. STANDARD PACKING QUANTITY............... 8 e. MATERIAL OF TAPE..................... 8 f. LABEL CONTENTS...................... 8 g. TAPING DIMENSION..................... 9 h. JOINT OF TAPE....................... 9 i. RELEASE STRENGHT OF COVER TAPE............ 9 j. PACKAGE........................... 10 5. MECHANICAL ENDURANCE.................. 10 6. ENVIRONMENTAL ENDURANCE................ 11 7. SUPPLEMENT......................... 12-13 8. Flow Chart........................... 14 Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 26.000000MHz 2. Holder type : HSX221SR 3. Frequency tolerance: +/-10 ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 30 ohms Max. / SERIES 5. Storage temperature range: -40 deg.C To +85 deg.C 6. Operable temperature range: -30 deg.C To +85 deg.C 7. Temperature drift: +/-10ppm 8. Loading capacitance (CL) : 7.0 pF 9. Drive level: 10 μW 10. Shunt Capacitance: 2.0 pF 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 120 cm height 3 times on Concrete floor Variation : -25 deg.C To +85deg.C (100uW Max) Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. +/- 1ppm max. first year +/- 1.5ppm max. second year +/- 2.5ppm max. after 5 years +/- 5ppm max. after 10 years 15. Aging: 16. Holder HSX221SR Seam type 17.Dimensions and marking Refer to page.4 18. Emboss carrier tape & reel Refer to page.6 and page.7 19. Moisture Sensitivity Level Level 1 20.Note: Spurious mode series resistance within: 0.5K ohms(Min) +/-1 MHz Tuning sensitivity (TS) : 28+/-10% ppm/pF DLD Spec. : 10nW ~ 100uW, step ratio is √10 DLD2 : 2.5 ohm Max. DLDH2 : 1.5 ohm Max. FDLD : 2 ppm Max. FDLDH : 0.7 ppm Max. Country of origin TAIWAN FACTORY Tittle HSX221SR THAILAND FACTORY QUARTZ CRYSTAL SPECIFICATION CHINA FACTORY Confirm Check Prepare Date Spec. No. Rev. Page 2014/02/21 F. S. TSAI Y. W. LEE HARMONY U. F. CHEN X2R026000BZ1HZ-DEHPZ ELECTRONICS CORP. 1 3 ▪ S curve (fL) 3rd order curve fitting coefficient requirement over operation temperature under per 2 ℃ test [f (T) = C3*(T-T0)^3 + C2*(T-T0)^2 + C1*(T-T0) + C0 ; T0 = 25 ℃] – 1st order coefficient : -0.1 ~ -0.35 – 2nd order coefficient : -0.0005 ~ -0.0012 – 3rd order coefficient : 0.000087 ~ 0.00011 ▪ Freq. slope error between measured S curve (fL) data and 3rd order curve fitting data over operation temperature under per 2 ℃ test – -10 ℃ ~ 60 ℃ : ±0.05ppm – -30 ℃ ~ 85 ℃ : ±0.1ppm ▪ Freq. perturbation : within ± 0.5 ppm – Residual error from the freq. vs. temperature curve fit 3rd order. Min. of 1 freq. reading per 2 degree C over operation temperature ▪ Full cycle temperature hysteresis : 0.5ppm Max. – Difference in freq. measurement at any temperature when undergoing a thermal cycle over the entire operation temperature range from -40℃ to 85℃ for per 2 degree test ▪ Small cycle temperature hysteresis : 0.05ppm Max. – Difference in freq. measurement at any temperature when undergoing a thermal cycle of a temperature range of 5℃ for per 1 degree test Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 4 2. HSX221SR MARKING & DIMENSIONS UNIT: mm TOLERANCE: +/-0.15 *Marking should be printed as following: Logo, Nominal Frequency, Manufactured year & month *Nominal frequency = integer only ( ex. 14.31818 MHz  14 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2). Marking : Laser marking. (Table-1) Year 2000 2010 0 Code 2001 2011 1 2002 2012 2 2003 2013 3 2004 2014 4 2005 2015 5 2006 2016 6 2007 2017 7 2008 2018 8 2009 2019 9 (Table-2) Jan. A Feb. B Mar. C Apr. D May. E Jun. F Jul. G Aug. H Sep. J Oct. K Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. Nov. L Dec. M TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 5 3. INSIDE STRUCTURE ※Reference drawing (1) Base: Alumina Ceramic (Al2O3) Metallized Pad: Ni Plating Au Plating (2) Lid : Fe- Ni -Co (3) Crystal Enclosure Seal: Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin (6) PAD Alumina Ceramic (Ni. Au) (7) Cover Ring: Fe-Ni-Co Alloy (8) Thermistor: Resistance : 100KΩ±1% The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in this item. B-constant : 4250K±1% (9) Electrode Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 6 4. HSX221SR EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 7 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 9.3+/-0.3 Outer Width W2 Out Line diameter B 11.3+/-1.0 ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Width Center Core slit Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 3,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material PS Conductive Polyester f.) Label contents Sticks label for every reel. Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 8 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 9 j.) Package Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 10 5. Mechanical Performance Item Test Methods Specifications Code 1 2 Natural Drop Vibration A 3 Sealing Tightness 4 Solderability Dropping from 120 cm height 3 times on Concrete floor Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z 3 axes, Duration of 2 hours to each axis. Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak detector. – Fine Leakage. After applying ROSIN Flux, dipping in solder bath at 245deg.C+/-5deg.C for 3+/-0.5 sec. 6. 2 3 4 B Specifications Code Test Methods Humidity Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours. Back to room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. +85deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C (30min)  +85deg.C +/-2deg.C (30min) 25 cycles. Back to the room temperature first, then in 1~2 hours, the component shall be checked. Storage in Low Temperature Storage in High Temperature Temperature cycles A A A A Specifications code Specifications A Frequency variation shall be within +/-5ppm and equivalent resistance shall be within the specification after the test More than 90% of lead shall be covered by new solder. B Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date --- Environment Performance Item 1 A Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 11 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 7.3.Land pattern layout(Example) 7.4.Solder iron (Example) Bit temp.:350℃max.,Time:3sec max. ,Each terminal solder a 1 time max. Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 12 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering Process. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity ,which may cause put solderbility. No direct Sunlight, No dew as well. Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 13 8. Flow Chart Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 14 REV. \ No. DATE REASON 0 1 2012/12/17 2014/02/21 New CONTENTS 新增 page4. 20.Note: ▪ S curve (fL) 3rd order curve fitting coefficient requirement over operation temperature under per 2 ℃ test [f (T) = C3*(T-T0)^3 + C2*(T-T0)^2 + C1*(T-T0) + C0 ; T0 = 25 ℃] – 1st order coefficient : -0.1 ~ -0.35 – 2nd order coefficient : -0.0005 ~ -0.0012 – 3rd order coefficient : 0.000087 ~ 0.00011 ▪ Freq. slope error between measured S curve (fL) data and 3rd order curve fitting data over operation temperature under per 2 ℃ test – -10 ℃ ~ 60 ℃ : ±0.05ppm – -30 ℃ ~ 85 ℃ : ±0.1ppm ▪ Freq. perturbation : within ± 0.5 ppm – Residual error from the freq. vs. temperature curve fit 3rd order. Min. of 1 freq. reading per 2 degree C over operation temperature ▪ Full cycle temperature hysteresis : 0.5ppm Max. – Difference in freq. measurement at any temperature when undergoing a thermal cycle over the entire operation temperature range from -40℃ to 85℃ for per 2 degree test ▪ Small cycle temperature hysteresis : 0.05ppm Max. – Difference in freq. measurement at any temperature when undergoing a thermal cycle of a temperature range of 5℃ for per 1 degree test Country of origin Tittle HSX221SR QUARTZ CRYSTAL SPECIFICATION Date Confirm 2014/02/21 F. S. TSAI Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page Check Prepare Y. W. LEE U. F. CHEN X2R026000BZ1HZ-DEHPZ HARMONY ELECTRONICS CORP. 1 15
X2R026000BZ1HZ-DEHPZ 价格&库存
很抱歉,暂时无法提供与“X2R026000BZ1HZ-DEHPZ”相匹配的价格&库存,您可以联系我们找货
    • 1+0.56512
    • 10+0.29903
    • 30+0.13285
    • 100+0.11208
    库存:43
