X3S026000BZ1HZ-HU
X3S026000BZ1HZ-HU
    HELE(加高电子)
    SMD3225_4P
    无源晶振 SMD3225_4P
X3S026000BZ1HZ-HU 数据手册
PRELIMINARY SPECIFICATIONS GP Customer Part No.: Application For: HELE. Part No: MT6236 X3S026000BZ1HZ-HU Products: Accepted Model: Type & Freq.: Sample Order No: Date: CRYSTAL HSX321S / 26.000MHz 2010/07/22 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號 2 樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN (R.O.C.) TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄縣大寮鄉大發工業區華東路 39 號 NO. 39, HWA DONG RD., TA FA IND. DIST., TA LIAO KAOHSIUNG HSIEN 831, TAIWAN, R.O.C. TEL: (07)787-1555-6 FAX: (07)787-1557 Tittle HSX321S THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-7309272 / 7309262 FAX: 0755-7309755 TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 1 HSX321S SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION........... 3 2. MARKING & DIMENSIONS................... 4 3. INSIDE STRUCTURE...................... 5 4. EMBOSS CARRIER TAPE&REEL................ a. DIMENSIONS OF CARRIER TAPE............... 6 b. DIMENSIONS OF REEL................... 6-7 c. STORAGE CONDITION................... 7 d. STANDARD PACKING QUANTITY................... 7 e. MATERIAL OF TAPE..................... 7 f. LABEL CONTENTS...................... 7 g. TAPING DIMENSION..................... 8 h. JOINT OF TAPE....................... 8 i. RELEASE STRENGHT OF COVER TAPE............ 8 j. PACKAGE.......................... 9 5. MECHANICAL PERFORMANCE................. 10 6. ENVIRONMENTAL PERFORMANCE............... 10 7. SUPPLEMENT ........................ 11-12 8. FLOW CHART......................... 13 9. Environmental Workload Chemical Substance Components List. 14 10. TEST DATA.......................... Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 26.000000MHz 2. Holder type : HSX321S 3. Frequency tolerance: +/-10 ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 50 ohms Max. / SERIES 5. Storage temperature range: -40 deg.C To +85 deg.C 6. Operable temperature range: -20 deg.C To +70 deg.C 7. Temperature drift: +/-10ppm 8. Loading capacitance (CL) : 12.0 pF -104 Hz 9. Drive level: 10 uW +/- 2 uW (100uW Max) 10. Shunt Capacitance: 2.0 pF Max 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 50 cm height 3 times on firm wood Variation : -20 deg.C To +70 deg.C Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/- 5 ppm/Year 16. Holder HSX321S Seam type 17. Dimensions and marking Refer to page.4 18. Emboss carrier tape & reel Refer to page.6 and page.7 19. Note: Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 3 2. HSX321S MARKING & DIMENSIONS *Marking should be printed as following: Logo, Nominal Frequency, Manufactured year & month *Nominal frequency = integer only ( ex. 14.31818 MHz Æ 14 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2). Marking : Laser marking. (Table-1) 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 Year 2010 2011 2012 2013 2014 2015 2016 2017 2018 2019 Code 0 1 2 3 4 5 6 7 8 9 (Table-2) Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov. Dec. A B C D E F G H J K L M Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 4 3. INSIDE STRUCTURE ※Reference drawing (1) Base: Alumina Ceramic (Al2O3) Metallized Pad: W Ni Plating Au Plating Supplier: Kyocera NTK (2) Lid : Fe- Ni -Co (3) Crystal Enclosure Seal: Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin Adhesive bonding: upper & lower bonding/lower bonding only (6) PAD Alumina Ceramic (W. Ni. Au) (7) Kovaring: Fe-Ni-Co Alloy Tittle HSX321S The use prohibition chemistry substance of Table 1 of DHE-0204-1 (QA-QM-08) is not included in this item. Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 5 4. HSX321S EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 12.8+/-0.3 Outer Width W2 Out Line diameter B 15.5+/-1.0 ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Width Center Core slit Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 3,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material PS Conductive Polyester f.) Label contents .The type of product .Our specification No. .Your Part No. .Lot No. .Nominal Frequency .Quantity .Our Company Name Sticks label for every reel. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 8 j.) Package Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 9 5. Mechanical Performance Specifications Code Item Test Methods 1 Natural Drop 2 Vibration 3 Sealing Tightness 4 Solderability Drop 3 times from the height of 50cm onto min. 30mm thickness hard wooden board. Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z 3 axes, Duration of 2 hours to each axis. Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak detector. – Fine Leakage. After applying ROSIN Flux, dipping in solder bath at 245deg.C+/-5deg.C for 3+/-0.5 sec. 6. 2 3 4 A --B Environment Performance Item 1 A Specifications Code Test Methods Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours. Back to room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. +85deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C (30min) ↔ +85deg.C +/-2deg.C (30min) 25 cycles. Back to the room temperature first, then in 1~2 hours, the component shall be checked. Humidity Storage in Low Temperature Storage in High Temperature Temperature cycles A A A A Specifications code Specifications A Frequency variation shall be within +/-5ppm and equivalent resistance shall be within the specification after the test B More than 90% of lead shall be covered by new solder. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 10 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 7.3.Land pattern layout(Example) 7.4.Solder iron (Example) Bit temp.:350℃max.,Time:3sec max. ,Each terminal solder a 1 time max. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 11 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering Process. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity ,which may cause put solderbility. No direct Sunlight, No dew as well. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 12 8. Flow Chart LID(外 殼 蓋 ) BLANK(晶 片 ) LID進 料 檢 查 1 2 Incoming Inspection of LID LID洗 淨 Cleaning of LID BASE(基 座 ) BLANK進 料 檢 查 5 6 7 BASE進 料 檢 查 3 Incoming Inspection of BLANK 化學蝕刻 Incoming Inspection of BASE BASE洗 淨 4 Etching Cleaning of BASE 頻率選別 Freq. Sorting 蒸著前洗淨 8 9 10 11 12 13 14 15 Cleaning before Base Plating 微蝕刻 Flash Etching 基 礎 蒸 著 ($) Base Plating 押入接著 Blank Ass'y 接著硬化 Adhesive Curing 接 著 檢 查 ($) Bonding Check 25 26 調整蒸著 Partial Plating 27 熔 接 Seam Seal 20 REFLOW 30 23 Check of Temp. Characteristics Tapping Marking & Check Country of origin QUARTZ CRYSTAL SPECIFICATION Prepare C. L. WANG U. F. CHEN Check of Tapping 出貨檢查 Outgoing Inspection REFLOW (C) Spec. No. 出 貨 Shipment TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS 出貨捆包 Outgoing Packing to Shipment/Stock 印 字 +外 觀 Tittle HSX321S Tapping外 觀 檢 查 CF檢 查 (C) 35 HARMONY Final Check 溫 特 檢 查 (C) 34 2010/07/22 F. S. TSAI REFLOW (C) 最 終 檢 查 ($) 31 Check of CF Check Final Check 老 化 Aging 22 Confirm 最 終 檢 查 ($)(C) Appearance Check 33 Date Leak Check II 29 Se am前 外 觀 檢 查 (C) 強 勵 振 Over Driver 24 氣 密 檢 查 II(HE)($) 28 32 ($): 特 殊 特 性 (For Special Characteristics) (C): 指 定 製 程 (Specific Assignment) Leak Check II (Helium Pressurization) Annealing in High Vacuum 19 21 氣 密 檢 查 II(氦 氣 加 壓 ) Middle Check 17 18 Leak Check I 中 間 檢 查 ($) 高真空烘烤 16 氣 密 檢 查 I (AIR)($) CORP. 0 13 9. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE H(D)SX321S PERCENTAGE 20.5(mg) ppm Si 0.04715 9.6658 Au 0.15785 32.3593 Co & Co Compound 1.21770 249.6285 Mo & Mo Compound 0.04100 8.4050 Ag 0.42640 87.4120 Cu 0.11890 24.3745 Cr & Cr Compound 0.04100 8.4050 Al 5.09630 1044.7415 Mn & Mn Compound 0.02460 5.0430 W & W Compound 0.19885 40.7643 Ni & Ni Compound 3.06680 628.6940 Fe 4.14715 850.1658 Chemical Substance Components Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 14 REV. No. DATE REASON 0 2010/07/22 New CONTENTS Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2010/07/22 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Rev. Page X3S026000BZ1HZ-HU ELECTRONICS CORP. 0 15 EXCEL EXPORT PRINTOUT FORMAT Run Name: Run Date : 19-07-2010 2:12 pm S&A 250B: 9.40 Report: 4.60 Description: 25999896 Reference Fr: (Using Measured FL) Power: 10.00 uW Into 20.0 ohms PL: No Load CL: 12.00 pF Crystal First Failure FR Hz FL Hz FL ppm High Limit Low Limit 1 2 3 4 5 6 7 8 9 PPM 20 PASS PASS PASS PASS PASS PASS PASS PASS PASS 25996027 25996010 25996007 25996023 25996133 25996111 25996374 25996475 25996404 25999631 25999674 25999666 25999881 25999926 25999893 26000075 26000164 26000087 -10.17 -8.56 -8.86 -0.59 1.15 -0.13 6.88 10.33 7.33 RR Ohms C0 pF 50 2.00 12.76 10.81 11.30 13.54 12.32 11.30 13.02 10.30 11.41 1.12 1.15 1.12 1.12 1.12 1.11 1.12 1.14 1.17 HSX321S 25.999896MHZ TEMP -FREQ.(-40 ~ 125 ℃)200uW Ω 35 10 30 5 25 0 20 -5 15 -10 10 -15 5 -20 ℃ C0/C1 L mH TS ppm/pF Q k 3.60 3.66 3.65 3.85 3.78 3.77 3.69 3.69 3.69 310.99 314.09 305.97 292.04 296.39 293.87 302.22 309.85 316.95 10.42 10.23 10.27 9.74 9.91 9.94 10.15 10.16 10.16 10.45 10.59 10.61 11.17 10.99 10.97 10.73 10.67 10.64 133.45 154.47 148.41 117.48 131.31 143.71 127.38 161.17 145.48 RLD2 DLD2 FDLD Ohms Ohms ppm 13.26 10.77 11.37 13.51 12.28 11.27 12.99 10.26 11.39 0.83 0.35 0.39 0.27 0.24 0.31 0.28 0.35 0.33 1.00 1.10 0.98 0.81 0.89 1.03 0.91 1.08 1.00 HSX321S 25.999896MHZ TEMP -RR.(-40 ~ 125 ℃)200uW 40 15 -40 -30 -20 -10 0 C1 fF 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 0 -40 -30 -20 -10 ℃ 0 10 20 30 40 50 60 70 80 90 100 110 120
X3S026000BZ1HZ-HU 价格&库存
很抱歉,暂时无法提供与“X3S026000BZ1HZ-HU”相匹配的价格&库存,您可以联系我们找货
X3S026000BZ1HZ-HU
    • 1+2.16076
    • 10+1.71494
    • 30+1.52388
    库存:32
