SSW32768KE3CH-I
SSW32768KE3CH-I
    HELE(加高电子)
    SMD3225_4P
    有源晶振 32.768KHz3V~3.6V-10℃~+70℃
SSW32768KE3CH-I 数据手册
SPECIFICATIONS FOR APPROVAL GP SSW32768KE3CH-I Customer Part No.: HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: HSO321S(RTC)/32.768KHz Sample Order No: EOS-D40084-1 OSCILLATOR 2013/04/12 Date: Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. HARMONY ELECTRONICS (SUZHOU) CO.,LTD TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號2樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN TEL:886-2-26588883 FAX:886-2-26588683 Tittle Date TAIWAN FACTORY: 工廠:(831) 高雄市大寮區大發工業區華東路 39 號 No.39, HWA DONG RD., DALLIAO DIST.,DAFA INDUSTRIAL PARK., KAOHSIUNG CITY 831, TAIWAN TEL: (07)787-1555-6 FAX: (07)787-1557 THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源 工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-27309272 / 27309262 FAX: 0755-27309755 SUZHOU FACTORY: 蘇州市相城區黃埭鎮安民路 5 號 NO.5 ANMING ROAD, HUANGDAI TOWN, XIANGCHENG DISTRCT, SUZHOU CITY, JIANGSU PROVINCE TEL:86-512-67592373 FAX:86-512-67592363 Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 1 HSO321S(RTC) SPECIFICATION INDEX Tittle Date ITEM PAGE 1. Type.............................. 3 2. Output Frequency....................... 3 3. Absolute Maximum Ratings................... 3 4. Electric Specifications..................... 3-4 5. Dimensions........................... 5 6. Inside Structure......................... 6 7. Mechanical Performance..................... 6 8. Environment Performance.................... 7 9. Supplement........................... 8-9 10. Taping and Packing....................... 9-11 11. Flow Chart........................... 12 12.Environmental Workload Chemical Substance Components List.. 13 HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 2 1. Type Name: HSO321S(RTC) 2. Output Frequency: 32.768000 KHz 3. Absolute Maximum Ratings: Item Symbol Vdd terminal voltage Vdd Input terminal voltage Vcont Output terminal voltage Vout Output terminal current Iout Storage temp. range Tstr 4. Value -0.5 ~ 4.0 -0.5 ~ Vdd+0.5 -0.5 ~ Vdd+0.5 10 -55 ~ 125 Unit V V V mA deg.C Electric Specifications: Item Symbol Min -25 -10 3.0 Value Typ 25 3.3 Max +25 +70 3.6 Unit Etc Condition Vdd Temp Δf/F Frequency Stability ppm 3.3+/℃ Operating temp. range Topr 0.3V Supply voltage Vdd V Current consumption 1 Idd1 3 mA (#1 pin: open or "H") Current consumption 2 Idd2 0.01 mA (#1 pin: "L" level) Fig1,2 3.3V Symmetry Duty 40 50 60 % 0.1xVdd Low level output voltage Vol V 0.9xVdd High level output voltage Voh V Rise & Fall time Tr & Tf 10 ns Pin #1 options YES Output load C-MOS CL = 15pF (Idd1, Idd2 test at No Load) Low level input current Iil 10 uA High Level input current Iih 10 uA Vddx0.3 Low level input voltage Vil V Vddx0.7 Fig3 3.3V High level input voltage Vih V Output disable time Tplz 150 nsce Output enable time Tpzl 5 msce ppm/year Aging -3 3 F :Output Frequency Δf =Oscillation Frequency – F Frequency Stability is inclusive of 25℃ Tolerance, operating temperature range, input voltage change, Load chang, first of aging , shock and vibration. Moisture Sensitivity Level : Level 1 Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY -10~70 ℃ 25+/-3 ℃ 25+/-3 ℃ Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 3 Fig. 1) Measurement Circuit : CL = Include jig & probe capacitance (Refer to 4) Switch H Open L Out term. Oscillation out Oscillation out High Z Fig. 2) Output Wave Form: Fig. 3) Input Output Condition: Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 4 5. Dimensions: Lot No.: Year : Last digit of the year Year Code 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017 2018 2019 0 1 2 3 4 5 6 7 8 9 Month : Alphabet assign below Month 1 2 3 4 5 6 7 8 9 10 11 12 Code A B C D E F G H J K L M Marking : Laser marking Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 5 6. Inside Structure: Reference drawing (1) Base: Alumina Ceramic (Al2O3) Metalized Pad: W Ni Plating Au Plating (2)IC IC(Si. Al. Ti.) (3) Au Bonding Wire: Au (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) LID: Fe+Ni+Co (6) Adhesive Silver Conductive Silicon Resin The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in this item. 7. Mechanical Performance: 1 Specifications Code Item Test Methods Natural Drop Drop 3 times from the height of 50cm onto min. 30mm thickness hard A wooden board. 2 Vibration Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z A 3 axes, Duration of 2 hours to each axis. 3 Sealing Tightness (1) Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak detector. – Fine Leakage. --- (2) Dipping in the FC-40 at +125 +/-5deg.C for 5 minutes, no gas bubble observed from the inside of the can. 4 Solderability After applying ROSIN Flux, dipping in solder bath at B 245deg.C+/-5deg.C for 3+/-0.5 sec. Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 6 8. Environment Performance: Item 1 Specifications Code Test Methods Humidity Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours. A Back to room temperature first, then in 1~2 hours, the component shall be checked. 2 Storage in Low -40deg.C +/-2deg.C, Duration of 240 hours. Temperature Back to the room temperature first, then in 1~2 hours, the component A shall be checked. 3 Storage in High +85deg.C +/-2deg.C, Duration of 240 hours. Temperature Back to the room temperature first, then in 1~2 hours, the component A shall be checked. 4 -30deg.C +/-2deg.C (30min)  +80deg.C +/-2deg.C (30min) 25 Temperature cycles cycles. Temp. increasing or reducing time need to be within 3 minutes. A Back to the room temperature first, then in 1~2 hours, the component shall be checked. 5 High Temperature +85deg.C +/-2deg.C, +3.3V Vdd Duration of 240 hours. Operation Back to the room temperature first, then in 1~2 hours, the component A shall be checked. Specifications code Specifications A Frequency variation shall be within +/-5ppm and equivalent resistance shall be within the specification after the test B Tittle Date More than 90% of lead shall be covered by new solder. HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 7 9. Supplement: 9.1. Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 9.2.Land Pattern Layout: (Example) 9.3.Solder Iron: (Example) Bit temp.:350deg.C Max. , Time:3sec Max. , Each terminal solder a 1 time Max. 9.4.Mounting: This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering Process. 9.5.Cleaning: Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 8 Cleaning liquid which corrodes Nickel shall not be used. It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 9.6.Handling: HSO321S series is designed to withstand Drop and Vibration, however, the crystal blank might be broken. So, if excess force is given, please check the characteristics before use. HSO321S series has C-MOS circuit inside. Please pay attention to static-electricity as same handling as other C-MOS. devices. 9.7.By-pass Capacitor: It has no by-pass capacitor integrated. We recommend you to use capacitor (like ceramic chip capacitor) 0.01μF in-between Vdd and GND. 9.8.Storage: Please keep away from high temperature and high humidity, which may cause put solderbility. No direct Sunlight, No dew as well. 10. Taping and Packing: 10.1.Emboss Tape Specifications: Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 9 10.2.Reel Specifications: (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 9.3+/-0.3 Outer Width W2 Out Line diameter B 11.3+/-1.0 ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Center Core slit Width Position Spindle diameter Key Ditch Width 10.3.Storage: Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 10 Temperature+40deg.C Max. Humidity 80% Max. 10.4.Quantity on Reel: 3,000 PCS/REEL 10.5.Label: Label is following information: 10.6.Shipping Carton: The size carton box is shown as below. One carton contains 10 reels. In case of less than 10 reels, suitable size of carton will be used. The cushion is filled in the carton box, which material shall be anti-static. 11. Tittle Date Flow Chart: HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 11 Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 12 12. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE D(H)SO321S PERCENTAGE 25.2(mg) ppm WOLFRAM AND ITS COMPOUND(W) 0.21168 53.3434 COBALT AND ITS COMPOUND(Co) 0.96900 244.1880 CHROMIUM AND ITS COMPOUND(Cr) 0.07308 18.4162 SILVER(Ag) 0.15876 40.0075 COPPER(Cu) 0.07812 19.6862 NICKEL AND ITS COMPOUND(Ni) 2.26044 569.6309 MANGANESE AND ITS COMPOUND(Mn) 0.02016 5.0803 MOLYBDENUM AND ITS COMPOUND(Mo) 0.12348 31.1170 SILICON AND ITS COMPOUND(Si) 0.28476 71.7595 ALUMINIUM AND ITS COMPOUND(Al) 7.96320 2006.7264 GOLD(Au) 0.15372 38.7374 IRON(Fe) 3.37176 849.6835 Chemical Substance Components Tittle Date HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 13 REV. DATE REASON No. 0 2013/04/12 NEW Tittle Date CONTENTS - HSO321S(RTC) SPECIFICATION Confirm Check Prepare 2013/04/12 F. S. TSAI C. H. WENG U. F. CHEN HARMONY Country of origin Spec. No. TAIWAN FACTORY Rev. Page SSW32768KE3CH-I ELECTRONICS CORP. 0 14
SSW32768KE3CH-I 价格&库存
很抱歉,暂时无法提供与“SSW32768KE3CH-I”相匹配的价格&库存,您可以联系我们找货
SSW32768KE3CH-I
    • 1+2.53260
    • 10+1.98288
    • 30+1.46448
    • 100+1.44180
    库存:17
