PCMB063T-R68MS
PCMB063T-R68MS
    CYNTEC(乾坤)
    SMD
    功率电感 SMD
PCMB063T-R68MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : PCMB063T-000 REVISION : A2 PAGE : 1 OF 5 Power Choke Coil PCMB063T type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 3.0mm Low loss realized with low DCR Capable of corresponding high frequency (3MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' A B W B' Code L W T A A’ B B’ H Dimensions (mm) 6.95 ± 0.35 6.6 ± 0.2 2.8 ± 0.2 1.6 ± 0.3 2.0 ± 0.1 3.0 ± 0.3 3.6 ± 0.2 0 ~ +0.15 T  Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown above after confirming and safety. B A C A 3.5 B 3.7 C 8.4 Unit : mm CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : PCMB063T-000 REVISION : A2 PAGE : 2 OF 5 Specifications Part Number PCMB063T-R10MS PCMB063T-R15MS PCMB063T-R20MS PCMB063T-R22MS PCMB063T-R33MS PCMB063T-R36MS PCMB063T-R47MS PCMB063T-R56MS PCMB063T-R68MS PCMB063T-R82MS PCMB063T-1R0MS PCMB063T-1R2MS PCMB063T-1R5MS PCMB063T-2R2MS PCMB063T-2R5MS PCMB063T-3R3MS PCMB063T-4R7MS PCMB063T-5R6MS PCMB063T-6R8MS PCMB063T-8R2MS PCMB063T-100MS L0 Inductance ( µH ) @ (0A) 0.10 0.15 0.20 0.22 0.33 0.36 0.47 0.56 0.68 0.82 1.0 1.2 1.5 2.2 2.5 3.3 4.7 5.6 6.8 8.2 10.0 Rdc ( mΩ) Typical 1.5 1.9 2.4 2.5 3.0 2.6 3.5 4.7 4.5 7.0 8.5 10.0 10.6 18.0 20.0 25.0 32.5 39.0 54.0 54.0 62.0 Maximum 1.7 2.5 3.0 2.8 3.5 3.9 4.1 5.0 5.0 7.5 9.0 12.0 12.1 20.0 22.0 28.0 35.0 42.0 60.0 60.0 68.0 Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Typical Typical 32.5 30.0 24.0 23.0 21.0 20.0 18.0 16.5 16.0 14.0 12.0 10.0 10.0 8.0 7.0 6.5 5.5 5.5 4.5 4.5 4.0 60.0 45.0 41.0 40.0 25.0 26.0 20.0 25.5 17.0 16.0 15.0 20.0 14.0 10.0 14.0 10.0 6.5 6.0 8.0 6.0 5.5 *: If you require another part number please contact with us. **:Inductance Tolerance ± 20% : All test data is referenced to 25℃ ambient. Note 2.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 3.: Isat : DC current (A) that will cause Lo to drop approximately 30% Note 4.: Operating Temperature Range -55℃ to + 125℃ Note 5.: The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case operating Note 1. conditions. Circuit design , component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 6. : The rated current as listed is either the saturation current or the heating current depending on which value is lower. CYNTEC CO., LTD. 乾坤科技股份有限公司 PAGE : 3 OF 5 80 0.10 0.08 60 0.06 40 0.04 INDUCTANCE(µH) 0.02 TEMP RISE ( ) ℃ ℃ 20 0.00 0 10 15 20 25 30 35 40 45 DC BIAS(Amps ) 50 80 60 INDUCTANCE(µH) 0.09 TEMP RISE ( 0.06 ℃) 40 20 0.03 0.00 0 0 5 10 15 20 25 30 DC BIAS(Amps) 35 40 45 PCMB063T-R22MS 0.30 100 100 0.20 60 0.15 40 0.10 INDUCTANCE(µH) ℃ 0.05 0.00 10 15 20 25 30 DC BIAS(Amps ) 35 40 0.40 80 0.32 60 INDUCTANCE(µH) ℃) 40 0.12 ℃ 20 0.06 0.00 0 0 2 4 6 8 ℃ TE MP RISE ( ) 100 0.24 TEMP RISE ( 20 0 5 10 15 20 25 30 35 40 45 80 60 INDUCTANCE(µH) 0.16 TEMP RISE ( ℃) 40 0.00 0 0 3 6 0.80 9 12 15 18 DC BIAS(Amps) 21 24 27 30 100 PCMB063T-R56MS 100 0.30 60 INDUCTANCE(µH) TEMP RISE ( 0.20 ℃) 40 0.10 20 0.00 0 0 3 6 9 12 15 18 DC BIAS(Amps) 21 24 27 ℃ INDUCTANCE(µH) 80 TEMP RISE( ) INDUCTANCE(µH) 0.70 0.40 ℃ 20 0.08 DC BIAS(Amps) PCMB063T-R47MS 100 PCMB063T-R36MS 0.24 10 12 14 16 18 20 22 24 26 28 30 0.50 ℃ DC BIAS(Amps) 0.30 0.18 40 INDUCTANCE(µH) 0.10 45 PCMB063T-R33MS 0.36 0.15 0 INDUCTANCE(µH) 5 60 0.00 0 0 0.20 0.05 20 TEMP RISE ( ) 80 ) ℃ TEMP RISE( ) 80 INDUCT ANCE(µH) 0.25 0.25 ℃ 0.12 55 60 65 PCMB063T-R20MS 0.30 0.15 TEMP RISE( ) 5 100 80 0.60 0.50 60 0.40 40 0.30 INDUCTANCE(µH) 0.20 TEMP RISE ( 20 ℃) 0.10 0 0 5 10 15 20 DC BIAS(Amps) 25 30 ℃ TEMP RISE( ) 0 PCMB063T-R15MS 0.18 TEMP RISE( ) INDUCTANCE (µH) : A2 TEMP RISE( ) 100 0.12 I NDUCTANCE(µH) REVISION TEMP RISE( PCMB063T-R10MS INDUCTANCE(µH) 0.14 INDUCTANCE(µH) : PCMB063T-000 Current Characteristic TEMP RISE( )  DOCUMENT 80 0.75 60 INDUCTANCE(µH) ℃) 40 0.15 20 0.00 9 12 15 DC BIAS(Amps) 18 21 10 12 14 16 18 20 22 24 14 16 18 80 60 40 0.40 INDUCT ANCE(µH) TEMP RISE ( 5 10 DC BIAS(Amps) 20 ℃) 15 20 PCMB063T-2R2MS 2.80 100 100 80 1.20 INDUCT ANCE(µH) 60 TEMP RISE ( ) 40 ℃ 0.90 0.60 ℃ 20 0.30 INDUCTANCE(µH) 2.40 1.50 2 4 3.60 6 8 10 12 14 DC BIAS(Amps) 16 18 20 2.40 60 1.80 40 INDUCTANCE(µH) 0.60 TEMP RISE ( ℃) 20 0 0.00 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 TEMP RISE ( 0.80 18 ℃) 40 0 2 4 3.60 6 8 DC BIAS(Amps) 10 12 14 100 PCMB063T-3R3MS 3.00 ℃ ℃ 20 0 80 1.20 INDUCTANCE(µH) 1.20 0.00 100 3.00 60 1.60 22 PCMB063T-2R5MS 80 2.00 0.40 0 0 ℃ 0 0 20 PCM B063T-1R5MS 100 PCMB063T-1R2MS 0.60 0.00 0.00 INDUCTANCE(µH) 8 0.80 INDUCTANCE(µH) INDUCTANCE( µH) 40 ℃ 0 1.80 6 TEMP RISE( ) ℃) 8 10 12 DC BIAS(Amps) 4 1.00 0.00 6 0 2 1.20 0.20 4 40 ℃ 20 1.40 20 2 ℃) 0.15 0.20 0 TEMP RISE ( 0.00 TEMP RISE( ) INDUCTANCE(µH) 60 TEMP RISE ( 60 0.30 100 0.80 0.40 80 0 80 INDUCTANCE(µH) 100 DC BIAS(Amps) 1.00 0.60 : 4 OF 5 PCMB063T-R82MS 0.45 24 PCMB063T-1R0MS 1.20 PAGE INDUCTANCE(µH) INDUCTANCE(µH) 6 TEMP RISE( ) 3 : A2 0.60 0 0 REVISION TEMP RISE( ) TEMP RISE ( : PCMB063T-000 80 2.40 60 1.80 40 1.20 INDUCTANCE(µH) 0.60 TEMP RISE ( ℃) 20 0 0.00 0 1 2 3 4 5 6 7 8 DC BIAS(Amps) 9 10 11 12 13 ℃ TEMP RISE( ) 0.30 ℃ INDUCTANCE(µH) 0.45 0.90 TEMP RISE( ) INDUCTANCE(µH) 0.60 100 TEMP RISE( ) PCMB063T-R68MS 0.75 DOCUMENT TEMP RISE( ) CYNTEC CO., LTD. 乾坤科技股份有限公司 4.00 3.20 INDUCTANCE( µH) 2.40 T EMP RISE ( ) 60 ℃ 40 1.60 20 INDUCTANCE(µH) ℃ TEMP RISE( ) INDUCTANCE( µH) 80 0.80 0 0 : 5 OF 5 100 80 5.0 60 4.0 INDUCTANCE(µH) 3.0 TEMP RISE ( 2.0 ℃) 40 1 2 3 4 5 6 7 0.0 8 PCMB063T-6R8MS 8.00 0 0 100 1 2 3 4 5 DC BIAS(Amps) 60 4.00 40 3.00 INDUCTANCE(µH) 2.00 TEMP RISE ( 1.00 ℃) 20 2 3 4 5 6 DC BIAS(Amps) 7 8 9 100 10.0 8.0 60 7.0 40 6.0 5.0 INDUCTANCE(µH) 4.0 TEMP RISE ( ℃) 20 3.0 0 2 3 4 DC BIAS(Amps) 5 6 7 ℃ TEMP RISE( ) 80 9.0 1 80 8.00 7.00 60 6.00 INDUCTANCE(µH) 5.00 TEMP RISE ( ℃) 40 4.00 20 0 0 10 PCMB063T-100MS 11.0 100 2.00 0 1 8 3.00 0.00 0 INDUCTANCE(µH) ℃ TEMP RISE( ) 5.00 7 9.00 80 6.00 6 PCMB063T-8R2MS 10.00 7.00 ℃ 20 DC BIAS(Amps) INDUCTANCE(µH) PAGE 1.0 0.00 INDUCTANCE(µH) : A2 6.0 4.80 0 REVISION PCMB063T-5R6MS 7.0 100 : PCMB063T-000 1 2 3 4 DC BIAS(Amps) 5 6 7 ℃ TEMP RISE( ) PCMB063T-4R7MS 5.60 DOCUMENT TEMP RISE( ) CYNTEC CO., LTD. 乾坤科技股份有限公司
PCMB063T-R68MS 价格&库存
很抱歉,暂时无法提供与“PCMB063T-R68MS”相匹配的价格&库存,您可以联系我们找货
