C3D3A805KB02C00
C3D3A805KB02C00
    FARATRONIC(法拉)
    插件,P=27.5mm
    薄膜电容 径向
C3D3A805KB02C00 数据手册
RoHS Compliant SPECIFICATION FOR APPROVAL File No.: Q/FRK 0.GS.E.C3D-C13 Product Name DC-Link Capacitor for PCB Product Type: C3D Product Code Customer Customer Code Issue Date Approved by Customer Xiamen Faratronic Co. Ltd. Drafted Checked Approved 厦门法拉电子股份有限公司 Xiamen Faratronic Co. Ltd. 地址: 中国厦门市海沧区新园路 99 号 Add: No.99 Xinyuan Road, Haicang District, Xiamen, China TEL: FAX: Mail: Http: Export business 0086-592-6208609 6208608 0086-592-6208557 Vivian@faratronic.com.cn Donny@faratronic.com.cn james@faratronic.com.cn www.faratronic.com.cn HK office : Faratronic (HK) Co. Ltd. 0852-2898 9168 0852-2898 9683 hkoffice@faratronic.com.hk kolin@faratronic.com.hk www.faratronic.com *.The specification are the property of Xiamen Faratronic Co.Ltd and shall not be copied or used as commercial purposes without permission. Page 1 of 15 C3D Version history Current version Date Author Page 2 of 15 Change description C3D DC-Link Capacitor for PCB ■ Outline Drawing 2 Pins 4 Pins Square-bottom Arc-bottom ■ Features ● Metallized polypropylene structure. ● Excellent electric property. ● Plastic case (UL94 V-0), Filled with resin. ● High performance DC filtering applications (i.e. transducers, Industrial and high-end power supplies and solar inverters) ■ Safety Approvals ● TUV Rheinland ● UL ■ EN 61071:2007,EN 61881-1:2011, 450Vdc ~ 3200Vdc,0.56F~220F,-40/85℃ Certificate No.:R 50266108 UL 810 (construction only),Max. 5000Vdc,90℃ File No.: E256238, CCN: CZDS2 Specifications Reference Standard GB/T 17702 (IEC 61071) Climatic Category 40/85/56 Operating temperature (case) -40℃~105℃ (+85℃ to +105℃: decreasing factor 1.35% per ℃ for UN, 85℃) UN, 85℃ 500Vdc,600Vdc,800Vdc,900Vdc,1 000Vdc,1 100Vdc,1 200Vdc Capacitance Tolerance J (5), K (10) Voltage Proof 1.5UN (10s) Insulation Resistance(IR×CN) 10 000s Self Inductance (Ls) 1nH per mm of lead spacing Maximum peak current Î(A) Expected lifetime Î=C·dV/dt 100 000h @ UN , Θhs =70℃ (20℃, 100V, 1min) Page 3 of 15 C3D ■ Part number code system The 18 digits part number is formed as follow: 1 C 2 3 3 D 4 5 6 7 8 9 10 Digit 1 to 3 Series code C3D Digit 4 to 5 D.C. rated voltage 2H=500V 11 12 13 14 15 16 17 18 1U=600V 3A=1 000V 2K=800V 1M=1 100V 1X=900V 3L=1 200V Digit 6 to 8 Rated capacitance value for example: 256=25×106pF=25.0μF Digit 9 Capacitance tolerance J=±5% Digit 10 Pitch B=27.5 mm C=30.0 mm F=37.5 mm M=52.5 mm Digit 11 Internal use K=±10% Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use ■ Table 1 lead form and packaging code Digit 12 Digit 13 and Digit 14 Code Explanation Code Explanation 0 Two pins (bulk) C0 38 Standard lead length 5.5mm lead length 3.8mm 1 2 3 4 A B C D Our pins (bulk) b=10.0mm Four pins (bulk) b=12.7mm Four pins (bulk) b=20.0mm Four pins (bulk) b=15.0mm four pins(bulk) b=20.3mm four pins(bulk) b=10.2mm four pins(bulk) b=5.1mm four pins(bulk) b=15.2mm Page 4 of 15 Digit 15 Code 0 2 Explanation Length tolerance ±1.0mm Length tolerance ±0.5mm C3D ■ Technical data(mm) UN,85℃ : 500Vdc CN (F) W ±1.0 H ±1.0 tanδ×(10-4) T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 0.8 65 10 100 ESR @10kHz (mΩ) 8.5 0.8 65 10 100 7.5 0.8 65 10 100 Imax (A) Part number 5.0 C3D2H505+B00+++*** 6.5 C3D2H106+B00+++*** 5.0 10.0 C3D2H226+B00+++*** 5.0 32.0 20.0 11.0 27.5 10.0 32.0 24.5 15.0 27.5 22.0 32.0 37.0 22.0 27.5 - 30.0 42.0 40.0 20.0 37.5 10.2 1.0 30 15 150 8.0 12.5 C3D2H306+F0B+++*** 35.0 42.0 36.0 24.0 37.5 10.2 1.0 30 15 150 8.0 13.5 C3D2H356+F0B+++*** 40.0 41.5 37.5 27.5 37.5 10.2 1.0 30 15 150 5.0 14.5 C3D2H406+F0B+++*** 50.0 41.0 43.0 28.0 37.5 12.7 1.2 30 15 150 4.0 16.0 C3D2H506+F02+++*** 50.0 42.0 45.0 30.0 37.5 20.3 1.2 30 15 150 4.0 16.0 C3D2H506+F0A+++*** 60.0 42.0 45.0 30.0 37.5 20.3 1.2 30 15 150 3.0 16.5 C3D2H606+F0A+++*** 75.0 57.0 43.5 29.5 52.5 12.7 1.2 15 35 350 5.5 16.0 C3D2H756+M02+++*** 75.0 57.0 43.5 29.5 52.5 20.3 1.2 15 35 350 5.5 16.0 C3D2H756+M0A+++*** 80.0 57.0 43.5 29.5 52.5 20.3 1.2 15 35 350 5.0 16.5 C3D2H806+M0A+++*** 100.0 57.0 50.0 35.0 52.5 20.3 1.2 15 35 350 4.0 18.0 C3D2H107+M0A+++*** 110.0 57.0 50.0 35.0 52.5 20.3 1.2 15 35 350 4.0 19.0 C3D2H117+M0A+++*** UN,85℃ : 600Vdc CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 2.0 32.0 18.0 9.0 27.5 0.8 65 11 100 ESR @10kHz (mΩ) 47.8 3.0 32.0 20.0 11.0 27.5 0.8 65 11 100 4.0 32.0 20.0 11.0 27.5 0.8 65 11 100 5.0 32.0 22.0 13.0 27.5 0.8 65 11 6.0 32.0 24.5 15.0 27.5 0.8 65 7.0 32.0 24.5 15.0 27.5 0.8 65 8.0 32.0 28.0 14.0 27.5 0.8 tanδ×(10-4) Imax (A) Part number 2.8 C3D1U205+B00+++*** 31.8 4.1 C3D1U305+B00+++*** 23.9 5.5 C3D1U405+B00+++*** 100 19.1 6.9 C3D1U505+B00+++*** 11 100 18.6 7.1 C3D1U605+B00+++*** 11 100 15.9 8.3 C3D1U705+B00+++*** 65 11 100 13.9 9.5 C3D1U805+B00+++*** 0.8 65 11 100 12.4 10.7 C3D1U905+B00+++*** 0.8 65 11 100 11.1 11.0 C3D1U106+B00+++*** 0.8 65 11 100 10.8 12.0 C3D1U126+B00+++*** 9.0 32.0 30.0 16.0 27.5 10.0 32.0 30.0 16.0 27.5 12.0 32.0 33.0 18.0 27.5 15.0 32.0 37.0 22.0 27.5 - 0.8 65 11 100 9.0 12.0 C3D1U156+B00+++*** 15.0 32.0 37.0 22.0 27.5 10.2 0.8 65 11 100 7.4 16.5 C3D1U156+B0B+++*** 18.0 32.0 37.0 22.0 27.5 - 0.8 65 11 100 8.0 12.0 C3D1U186+B00+++*** 18.0 32.0 37.0 22.0 27.5 12.7 0.8 65 11 100 6.2 17.0 C3D1U186+B02+++*** 10.0 41.0 30.0 16.0 37.5 30 20 175 19.5 6.2 C3D1U106+F00+++*** 41.0 30.0 16.0 37.5 1.0 30 20 175 16.3 7.4 C3D1U126+F00+++*** 15.0 41.0 33.5 18.5 37.5 - 1.0 12.0 1.0 30 20 175 C3D1U156+F00+++*** 42.0 40.0 20.0 37.5 10.2 1.0 30 20 175 13.0 9.8 9.2 20.0 12.3 C3D1U206+F0B+++*** 22.0 42.0 40.0 20.0 37.5 10.2 1.0 30 20 175 8.9 13.5 C3D1U226+F0B+++*** 25.0 42.0 40.0 20.0 37.5 10.2 1.0 30 20 175 7.8 15.4 C3D1U256+F0B+++*** 30.0 42.0 44.0 24.0 37.5 12.7 1.0 30 20 175 42.0 45.0 30.0 37.5 12.7 1.2 30 20 175 18.5 20.1 C3D1U306+F02+++*** 35.0 6.5 6.0 35.0 42.0 45.0 30.0 37.5 20.3 1.2 30 20 175 6.0 20.1 C3D1U356+F0A+++*** 40.0 42.0 45.0 30.0 37.5 12.7 1.2 30 20 175 5.2 23.0 C3D1U406+F02+++*** 40.0 42.0 45.0 30.0 37.5 20.3 1.2 30 20 175 5.2 23.0 C3D1U406+F0A+++*** Page 5 of 15 C3D1U356+F02+++*** C3D ■ Technical data(mm) UN,85℃ : 600Vdc 175 ESR @10kHz (mΩ) 4.6 25.8 C3D1U456+F02+++*** 175 4.6 25.8 C3D1U456+F0A+++*** tanδ×(10-4) CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 45.0 42.0 50.0 35.0 37.5 12.7 1.2 30 20 45.0 42.0 50.0 35.0 37.5 20.3 1.2 30 20 Imax (A) Part number 50.0 42.0 50.0 35.0 37.5 20.3 1.2 30 20 175 4.2 28.7 C3D1U506+F0A+++*** ★50.0 42.0 46.0 35.0 37.5 20.3 1.2 30 20 175 4.2 28.7 C3D1U506+FAA+++*** 55.0 42.0 50.0 35.0 37.5 20.3 1.2 30 20 175 3.8 31.6 C3D1U556+F0A+++*** 60.0 42.0 55.0 40.0 37.5 20.3 1.2 30 20 175 3.5 34.5 C3D1U606+F0A+++*** 65.0 42.0 55.0 40.0 37.5 20.3 1.2 30 20 175 3.2 35.0 C3D1U656+F0A+++*** 70.0 42.0 55.0 40.0 37.5 20.3 1.2 30 20 175 3.0 35.0 C3D1U706+F0A+++*** 75.0 42.0 60.0 45.0 37.5 20.3 1.2 30 20 175 2.8 35.0 C3D1U756+F0A+++*** 80.0 42.0 60.0 45.0 37.5 20.3 1.2 30 20 175 2.6 35.0 C3D1U806+F0A+++*** 85.0 42.0 60.0 45.0 37.5 20.3 1.2 30 20 175 2.5 35.0 C3D1U856+F0A+++*** 40.0 57.0 45.0 25.0 52.5 12.7 1.2 15 36 350 9.8 12.3 C3D1U406+M02+++*** 45.0 57.0 45.0 25.0 52.5 12.7 1.2 15 36 350 8.7 13.8 C3D1U456+M02+++*** 50.0 57.0 45.0 25.0 52.5 12.7 1.2 15 36 350 7.8 15.4 C3D1U506+M02+++*** 55.0 57.0 43.5 29.5 52.5 12.7 1.2 15 36 350 7.1 16.9 C3D1U556+M02+++*** 55.0 57.0 43.5 29.5 52.5 20.3 1.2 15 36 350 7.1 16.9 C3D1U556+M0A+++*** 60.0 57.0 43.5 29.5 52.5 12.7 1.2 15 36 350 6.5 18.5 C3D1U606+M02+++*** 60.0 57.0 43.5 29.5 52.5 20.3 1.2 15 36 350 6.5 18.5 C3D1U606+M0A+++*** 65.0 57.0 50.0 35.0 52.5 12.7 1.2 15 36 350 6.0 20.0 C3D1U656+M02+++*** 65.0 57.0 50.0 35.0 52.5 20.3 1.2 15 36 350 6.0 20.0 C3D1U656+M0A+++*** 70.0 57.0 50.0 35.0 52.5 20.3 1.2 15 36 350 5.6 21.5 C3D1U706+M0A+++*** 75.0 57.0 50.0 35.0 52.5 20.3 1.2 15 36 350 5.2 23.1 C3D1U756+M0A+++*** 80.0 57.0 50.0 35.0 52.5 20.3 1.2 15 36 350 C3D1U806+M0A+++*** 57.0 55.0 45.0 52.5 20.3 1.2 15 36 350 4.9 4.8 24.6 85.0 25.1 C3D1U856+M0A+++*** 90.0 57.0 55.0 45.0 52.5 20.3 1.2 15 36 350 4.6 25.8 C3D1U906+M0A+++*** 95.0 57.0 55.0 45.0 52.5 20.3 1.2 15 36 350 4.4 27.3 C3D1U956+M0A+++** 100.0 57.0 55.0 45.0 52.5 20.3 1.2 15 36 350 4.2 28.7 C3D1U107+M0A+++*** 110.0 57.0 55.0 45.0 52.5 20.3 1.2 15 36 350 3.8 31.6 C3D1U117+M0A+++*** 120.0 57.0 65.0 45.0 52.5 20.3 1.2 15 36 350 3.5 34.5 C3D1U127+M0A+++*** 130.0 57.0 65.0 45.0 52.5 20.3 1.2 15 36 350 3.2 35.0 C3D1U137+M0A+++*** 140.0 57.0 65.0 45.0 52.5 20.3 1.2 15 36 350 3.0 35.0 C3D1U147+M0A+++*** UN,85℃ : 800Vdc tanδ×(10-4) T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 18.0 9.0 27.5 - 0.8 65 10 95 ESR @10kHz (mΩ) 45.4 20.0 11.0 27.5 - 0.8 65 10 95 30.3 32.0 30.0 16.0 27.5 - 0.8 65 10 95 32.0 25.0 13.0 27.5 - 0.8 65 10 95 5.0 32.0 24.5 15.0 27.5 - 0.8 65 10 6.0 32.0 30.0 16.0 27.5 - 0.8 65 7.0 32.0 30.0 16.0 27.5 - 0.8 8.0 32.0 33.0 18.0 27.5 - 0.8 9.0 32.0 33.0 18.0 27.5 - 10.0 32.0 37.0 22.0 27.5 - CN (F) W ±1.0 H ±1.0 2.0 32.0 3.0 32.0 3.3 4.0 Imax (A) Part number 2.9 C3D2K205+B00+++*** 4.4 C3D2K305+B00+++*** 18.8 7.0 C3D2K335+B00+++*** 22.7 5.8 C3D2K405+B00+++*** 95 18.2 7.3 C3D2K505+B00+++*** 10 95 15.1 8.7 C3D2K605+B00+++*** 65 10 95 13.0 10.2 C3D2K705+B00+++*** 65 10 95 12.5 10.5 C3D2K805+B00+++*** 0.8 65 10 95 11.1 11.8 C3D2K905+B00+++*** 0.8 65 10 95 11.0 12.0 C3D2K106+B00+++*** Page 6 of 15 C3D ■ Technical data(mm) UN,85℃ : 800Vdc tanδ×(10-4) Imax (A) Part number 95 ESR @10kHz (mΩ) 9.1 14.5 C3D2K106+B0B+++*** 10 95 10.0 12.0 C3D2K116+B00+++*** 10 95 8.3 16.0 C3D2K116+B0B+++*** 65 10 95 9.3 12.0 C3D2K126+B00+++*** 0.8 65 10 95 7.6 16.0 C3D2K126+B0B+++*** 0.8 65 10 95 8.8 12.0 C3D2K136+B00+++*** 12.7 0.8 65 10 95 8.1 16.2 C3D2K136+B02+++*** 27.5 - 0.8 65 10 95 8.2 12.0 C3D2K146+B00+++*** 27.5 12.7 0.8 65 10 95 7.6 16.5 C3D2K146+B02+++*** 16.0 37.5 1.0 30 18 160 22.3 5.4 C3D2K805+F00+++*** 1.0 30 18 160 19.8 6.1 C3D2K905+F00+++*** 1.0 30 18 160 17.8 6.7 C3D2K106+F00+++*** 1.0 30 18 160 14.9 8.1 C3D2K126+F00+++*** CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 10.0 32.0 37.0 22.0 27.5 10.2 0.8 65 10 11.0 32.0 37.0 22.0 27.5 - 0.8 65 11.0 32.0 37.0 22.0 27.5 10.2 0.8 65 12.0 32.0 37.0 22.0 27.5 - 0.8 12.0 32.0 37.0 22.0 27.5 10.2 13.0 32.0 37.0 22.0 27.5 - 13.0 32.0 37.0 22.0 27.5 14.0 32.0 37.0 22.0 14.0 32.0 37.0 22.0 8.0 41.0 30.0 9.0 41.0 30.0 16.0 37.5 10.0 41.0 33.5 18.5 37.5 12.0 41.0 33.5 18.5 37.5 - 15.0 42.0 40.0 20.0 37.5 10.2 1.0 30 18 160 11.9 10.1 C3D2K156+F0B+++*** 20.0 42.0 44.0 24.0 37.5 12.7 1.0 30 18 160 8.9 13.5 C3D2K206+F02+++*** 25.0 42.0 44.0 24.0 37.5 12.7 1.0 30 18 160 7.1 16.8 C3D2K256+F02+++*** 30.0 42.0 45.0 30.0 37.5 12.7 1.2 30 18 160 5.9 20.2 C3D2K306+F02+++*** 30.0 42.0 45.0 30.0 37.5 20.3 18 160 50.0 35.0 37.5 20.3 30 18 160 5.9 5.5 20.2 22.0 C3D2K306+F0A+++*** 42.0 1.2 1.2 30 35.0 20.3 1.2 30 18 160 4.8 25.1 C3D2K406+F0A+++*** 40.0 42.0 50.0 35.0 37.5 C3D2K356+F0A+++*** 45.0 42.0 55.0 40.0 37.5 20.3 1.2 30 18 160 4.2 28.3 C3D2K456+F0A+++*** 50.0 42.0 55.0 40.0 37.5 20.3 1.2 30 18 160 3.8 31.4 C3D2K506+F0A+++*** 20.3 1.2 30 18 160 3.5 34.5 C3D2K556+F0A+++*** 55.0 42.0 60.0 45.0 37.5 ★60.0 42.0 60.0 45.0 37.5 20.3 1.2 30 18 160 3.2 35.0 C3D2K606+F0A+++*** ★65.0 42.0 60.0 45.0 37.5 20.3 1.2 30 18 160 2.9 35.0 C3D2K656+F0A+++*** 25.0 57.0 45.0 25.0 52.5 12.7 1.2 15 33 320 14.3 8.4 C3D2K256+M02+++*** 30.0 57.0 45.0 25.0 52.5 12.7 1.2 15 33 320 11.9 10.1 C3D2K306+M02+++*** ★35.0 57.0 45.0 25.0 52.5 12.7 1.2 15 33 320 10.2 11.8 C3D2K356+M02+++*** 40.0 57.0 43.5 29.5 52.5 12.7 1.2 15 33 320 8.9 13.5 C3D2K406+M02+++*** 40.0 57.0 43.5 29.5 52.5 20.3 1.2 15 33 320 8.9 13.5 C3D2K406+M0A+++*** 45.0 57.0 43.5 29.5 52.5 12.7 1.2 15 33 320 7.9 15.1 C3D2K456+M02+++*** 45.0 57.0 43.5 29.5 52.5 20.3 1.2 15 33 320 7.9 15.1 C3D2K456+M0A+++*** 50.0 57.0 50.0 35.0 52.5 12.7 1.2 15 33 320 7.1 16.8 C3D2K506+M02+++*** 50.0 57.0 50.0 35.0 52.5 20.3 1.2 15 33 320 7.1 16.8 C3D2K506+M0A+++*** 55.0 57.0 50.0 35.0 52.5 20.3 1.2 15 33 320 6.5 18.5 C3D2K556+M0A+++*** 60.0 57.0 50.0 35.0 52.5 20.3 1.2 15 33 320 5.9 20.2 C3D2K606+M0A+++*** 65.0 57.0 55.0 45.0 52.5 20.3 1.2 15 33 320 5.5 21.9 C3D2K656+M0A+++*** 70.0 57.0 55.0 45.0 52.5 20.3 1.2 15 33 320 5.1 23.6 C3D2K706+M0A+++*** 75.0 57.0 55.0 45.0 52.5 20.3 1.2 15 33 320 4.8 25.2 C3D2K756+M0A+++*** 80.0 57.0 55.0 45.0 52.5 20.3 1.2 15 33 320 4.6 25.9 C3D2K806+M0A+++*** 85.0 57.0 55.0 45.0 52.5 20.3 1.2 15 33 320 4.5 26.7 C3D2K856+M0A+++*** 90.0 57.0 55.0 45.0 52.5 20.3 1.2 15 33 320 4.2 28.3 C3D2K906+M0A+++*** 95.0 57.0 65.0 45.0 52.5 20.3 1.2 15 33 320 4.0 29.8 C3D2K956+M0A+++*** 100.0 57.0 65.0 45.0 52.5 20.3 1.2 15 33 320 3.8 31.4 C3D2K107+M0A+++*** 110.0 57.0 65.0 45.0 52.5 20.3 1.2 15 33 320 3.5 34.5 C3D2K117+M0A+++*** Page 7 of 15 C3D ■ Technical data(mm) U N,85℃ : 900Vdc tanδ×(10-4) CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 1.0 2.0 3.0 32.0 32.0 32.0 18.0 20.0 22.0 9.0 11.0 13.0 27.5 27.5 27.5 0.8 0.8 0.8 70 70 70 9 9 9 90 90 90 4.0 5.0 6.0 32.0 32.0 32.0 24.5 30.0 33.0 15.0 16.0 18.0 27.5 27.5 27.5 0.8 0.8 0.8 70 70 70 9 9 9 90 90 90 7.0 32.0 33.0 18.0 27.5 0.8 70 9 8.0 8.0 32.0 32.0 37.0 37.0 22.0 22.0 27.5 27.5 - ESR @10kHz (mΩ) 86.0 43.0 28.7 0.8 0.8 70 70 9.0 9.0 10.0 32.0 32.0 32.0 37.0 37.0 37.0 22.0 22.0 22.0 27.5 27.5 27.5 12.7 - 0.8 0.8 0.8 70 70 70 10.0 32.0 37.0 22.0 27.5 12.7 0.8 70 9 4.7 5.0 6.0 7.0 8.0 10.0 41.0 41.0 41.0 41.0 41.0 42.0 26.0 30.0 30.0 30.0 33.0 40.0 15.0 16.0 16.0 16.0 18.0 20.0 37.5 37.5 37.5 37.5 37.5 37.5 10.2 1.0 1.0 1.0 1.0 1.0 1.0 35 35 35 35 35 35 17 17 17 17 17 17 12.0 15.0 18.0 20.0 25.0 25.0 41.0 42.0 42.0 42.0 42.0 42.0 37.0 44.0 44.0 44.0 45.0 45.0 22.0 24.0 24.0 24.0 30.0 30.0 37.5 37.5 37.5 37.5 37.5 37.5 10.2 12.7 12.7 12.7 12.7 20.3 1.0 1.0 1.0 1.0 1.2 1.2 35 35 35 35 35 35 17 17 17 17 17 17 30.0 35.0 40.0 42.0 42.0 42.0 50.0 55.0 55.0 35.0 40.0 40.0 37.5 37.5 37.5 20.3 20.3 20.3 1.2 1.2 1.2 35 35 35 45.0 50.0 42.0 42.0 60.0 60.0 45.0 45.0 37.5 37.5 20.3 20.3 1.2 1.2 15.0 20.0 25.0 57.0 57.0 57.0 45.0 45.0 45.0 25.0 25.0 25.0 52.5 52.5 52.5 10.2 12.7 12.7 30.0 30.0 35.0 57.0 57.0 57.0 43.5 43.5 43.5 29.5 29.5 29.5 52.5 52.5 52.5 35.0 40.0 45.0 50.0 57.0 57.0 57.0 57.0 43.5 50.0 50.0 50.0 29.5 35.0 35.0 35.0 55.0 60.0 65.0 70.0 75.0 57.0 57.0 57.0 57.0 57.0 55.0 55.0 55.0 65.0 65.0 80.0 85.0 57.0 57.0 65.0 65.0 Imax (A) Part number 1.5 3.1 4.6 C3D1X105+B00+++*** C3D1X205+B00+++*** C3D1X305+B00+++*** 21.5 17.2 18.0 6.1 7.7 6.9 C3D1X405+B00+++*** C3D1X505+B00+++*** C3D1X605+B00+++*** 90 13.0 10.2 C3D1X705+B00+++*** 9 9 90 90 11.5 10.7 11.4 12.3 C3D1X805+B00+++*** C3D1X805+B0B+++*** 9 9 9 90 90 90 10.4 9.6 12.0 12.0 13.8 12.2 C3D1X905+B00+++*** C3D1X905+B02+++*** C3D1X106+B00+++*** 90 8.6 15.4 C3D1X106+B02+++*** 150 150 150 150 150 150 35.6 33.4 27.9 23.9 20.9 16.7 3.4 3.6 4.3 5.0 5.7 7.2 C3D1X475+F00+++*** C3D1X505+F00+++*** C3D1X605+F00+++*** C3D1X705+F00+++*** C3D1X805+F00+++*** C3D1X106+F0B+++*** 150 150 150 150 150 150 13.9 11.1 9.3 8.4 6.7 6.7 8.6 10.8 12.9 14.4 17.9 17.9 C3D1X126+F0B+++*** C3D1X156+F02+++*** C3D1X186+F02+++*** C3D1X206+F02+++*** C3D1X256+F02+++*** C3D1X256+F0A+++*** 17 17 17 150 150 150 5.6 5.1 4.5 21.5 23.4 26.8 C3D1X306+F0A+++*** C3D1X356+F0A+++*** C3D1X406+F0A+++*** 35 35 17 17 150 150 4.0 3.6 30.1 33.5 C3D1X456+F0A+++*** C3D1X506+F0A+++*** 1.2 1.2 1.2 15 15 15 31 31 31 300 300 300 22.3 16.7 13.4 5.4 7.2 9.0 C3D1X156+M0B+++*** C3D1X206+M02+++*** C3D1X256+M02+++*** 12.7 20.3 12.7 1.2 1.2 1.2 15 15 15 31 31 31 300 300 300 11.1 11.1 9.6 10.8 10.8 12.6 C3D1X306+M02+++*** C3D1X306+M0A+++*** C3D1X356+M02+++*** 52.5 52.5 52.5 52.5 20.3 20.3 20.3 20.3 1.2 1.2 1.2 1.2 15 15 15 15 31 31 31 31 300 300 300 300 9.6 8.4 7.4 6.7 12.6 14.4 16.1 17.9 C3D1X356+M0A+++*** C3D1X406+M0A+++*** C3D1X456+M0A+++*** C3D1X506+M0A+++*** 45.0 45.0 45.0 45.0 45.0 52.5 52.5 52.5 52.5 52.5 20.3 20.3 20.3 20.3 20.3 1.2 1.2 1.2 1.2 1.2 15 15 15 15 15 31 31 31 31 31 300 300 300 300 300 6.1 5.6 5.1 4.8 4.7 19.7 21.5 23.3 25.1 25.7 C3D1X556+M0A+++*** C3D1X606+M0A+++*** C3D1X656+M0A+++*** C3D1X706+M0A+++*** C3D1X756+M0A+++*** 45.0 45.0 52.5 52.5 20.3 20.3 1.2 1.2 15 15 31 31 300 300 4.5 4.2 26.8 28.5 C3D1X806+M0A+++*** C3D1X856+M0A+++*** 10.2 - Page 8 of 15 C3D ■ Technical data(mm) U N,85℃ : 1 000Vdc 10kHz ESR @10kHz (mΩ) Imax (A) Part number 8 80 76.4 1.7 C3D3A105+B00+++*** 75 8 80 38.2 3.5 C3D3A205+B00+++*** 0.8 75 8 80 25.5 5.2 C3D3A305+B00+++*** 0.8 75 8 80 19.1 6.9 C3D3A405+B00+++*** 0.8 75 8 80 15.3 8.6 C3D3A505+B00+++*** 0.8 75 8 80 14.9 8.9 C3D3A605+B00+++*** 0.8 75 8 80 14.5 9.4 C3D3A705+B00+++*** 12.7 0.8 75 8 80 11.4 11.6 C3D3A705+B02+++*** - 0.8 75 8 80 13.0 10.8 C3D3A805+B00+++*** 27.5 12.7 0.8 75 8 80 10.0 13.3 C3D3A805+B02+++*** 16.0 37.5 1.0 37 15 140 31.2 3.8 C3D3A505+F00+++*** 30.0 16.0 37.5 1.0 37 15 140 26.0 4.6 C3D3A605+F00+++*** 41.0 33.0 18.0 37.5 1.0 37 15 140 22.3 5.4 C3D3A705+F00+++*** 8.0 41.0 33.0 18.0 37.5 1.0 37 15 140 19.5 6.2 C3D3A805+F00+++*** 10.0 42.0 40.0 20.0 37.5 - 1.0 37 15 140 15.6 6.7 C3D3A106+F00+++*** 10.0 42.0 40.0 20.0 37.5 10.2 1.0 37 15 140 15.6 7.7 C3D3A106+F0B+++*** 12.0 41.0 37.0 22.0 37.5 12.7 1.0 37 15 140 13.0 9.2 C3D3A126+F02+++*** 12.0 41.0 37.0 22.0 37.5 - 1.0 37 15 140 15.0 8.0 C3D3A126+F00+++*** 15.0 42.0 44.0 24.0 37.5 12.7 1.0 37 15 140 10.4 11.5 C3D3A156+F02+++*** 18.0 42.0 45.0 30.0 37.5 12.7 1.2 37 15 140 8.7 13.8 C3D3A186+F02+++*** 18.0 42.0 45.0 30.0 37.5 20.3 1.2 37 15 140 8.7 13.8 C3D3A186+F0A+++*** 20.0 42.0 45.0 30.0 37.5 12.7 1.2 37 15 140 7.8 15.4 C3D3A206+F02+++*** 20.0 42.0 45.0 30.0 37.5 20.3 1.2 37 15 140 7.8 15.4 C3D3A206+F0A+++*** 25.0 42.0 50.0 35.0 37.5 20.3 1.2 37 15 140 6.2 19.2 C3D3A256+F0A+++*** 30.0 42.0 55.0 40.0 37.5 20.3 1.2 37 15 140 5.2 23.1 C3D3A306+F0A+++*** 35.0 42.0 55.0 40.0 37.5 20.3 1.2 37 15 140 4.8 25.1 C3D3A356+F0A+++*** 40.0 42.0 60.0 45.0 37.5 20.3 1.2 37 15 140 4.2 28.7 C3D3A406+F0A+++*** 15.0 57.0 45.0 25.0 52.5 12.7 1.2 17 28 280 20.8 5.8 C3D3A156+M02+++*** 20.0 57.0 45.0 25.0 52.5 12.7 1.2 17 28 280 15.6 7.7 C3D3A206+M02+++*** 25.0 57.0 45.0 25.0 52.5 12.7 1.2 17 28 280 12.5 9.6 C3D3A256+M02+++*** 30.0 57.0 43.5 29.5 52.5 12.7 1.2 17 28 280 10.4 11.5 C3D3A306KM02+++*** 30.0 57.0 43.5 29.5 52.5 20.3 1.2 17 28 280 10.4 11.5 C3D3A306KM0A+++*** 30.0 57.0 45.0 30.0 52.5 12.7 1.2 17 28 280 10.4 11.5 C3D3A306JM02+++*** 30.0 57.0 45.0 30.0 52.5 20.3 1.2 17 28 280 10.4 11.5 C3D3A306JM0A+++*** 35.0 57.0 50.0 35.0 52.5 20.3 1.2 17 28 280 8.9 13.5 C3D3A356+M0A+++*** 40.0 57.0 50.0 35.0 52.5 20.3 1.2 17 28 280 7.8 15.4 C3D3A406+M0A+++*** 45.0 57.0 55.0 45.0 52.5 20.3 1.2 17 28 280 6.9 17.3 C3D3A456+M0A+++*** 50.0 57.0 55.0 45.0 52.5 20.3 1.2 17 28 280 6.2 19.2 C3D3A506+M0A+++*** 55.0 57.0 55.0 45.0 52.5 20.3 1.2 17 28 280 5.7 21.1 C3D3A556+M0A+++*** 60.0 57.0 65.0 45.0 52.5 20.3 1.2 17 28 280 5.2 23.1 C3D3A606+M0A+++*** 65.0 57.0 65.0 45.0 52.5 20.3 1.2 17 28 280 4.8 25.0 C3D3A656+M0A+++*** 70.0 57.0 65.0 45.0 52.5 20.3 1.2 17 28 280 4.5 26.9 C3D3A706+M0A+++*** tanδ×(10-4) CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 1.0 32.0 18.0 9.0 27.5 0.8 75 2.0 32.0 22.0 13.0 27.5 0.8 3.0 32.0 24.5 15.0 27.5 4.0 32.0 30.0 16.0 27.5 5.0 32.0 33.0 18.0 27.5 6.0 32.0 33.0 18.0 27.5 7.0 32.0 37.0 22.0 27.5 - 7.0 32.0 37.0 22.0 27.5 8.0 32.0 37.0 22.0 27.5 8.0 32.0 37.0 22.0 5.0 41.0 30.0 6.0 41.0 7.0 Page 9 of 15 C3D ■ Technical data(mm) U N,85℃ : 1 100Vdc 10kHz ESR @10kHz (mΩ) Imax (A) Part number 8 70 80.0 1.7 C3D1M684+B00+++*** 80 8 70 59.4 2.2 C3D1M105+B00+++*** 0.8 80 8 70 55.7 2.4 C3D1M155+B00+++*** - 0.8 80 8 70 27.9 4.7 C3D1M205JB00+++*** 27.5 - 0.8 80 8 70 27.9 4.7 C3D1M205KB00+++*** 16.0 27.5 - 0.8 80 8 70 20.4 6.5 C3D1M305+B00+++*** 33.0 18.0 27.5 - 0.8 80 8 70 15.3 8.6 C3D1M405+B00+++*** 32.0 37.0 22.0 27.5 - 0.8 80 8 70 14.0 9.8 C3D1M505+B00+++*** 5.0 32.0 37.0 22.0 27.5 10.2 0.8 80 8 70 12.3 10.8 C3D1M505+B0B+++*** 6.0 32.0 37.0 22.0 27.5 - 0.8 80 8 70 12.3 10.8 C3D1M605+B00+++*** 6.0 32.0 37.0 22.0 27.5 10.2 0.8 80 8 70 10.2 12.9 C3D1M605+B0B+++*** 3.0 41.0 30.0 16.0 37.5 - 1.0 40 15 130 48.3 2.5 C3D1M305+F00+++*** 4.0 41.0 30.0 16.0 37.5 - 1.0 40 15 130 36.2 3.3 C3D1M405+F00+++*** 4.7 41.0 33.5 18.5 37.5 - 1.0 40 15 130 30.8 3.9 C3D1M475+F00+++*** 5.0 41.0 33.5 18.5 37.5 - 1.0 40 15 130 29.0 4.1 C3D1M505+F00+++*** 6.0 41.0 33.5 18.5 37.5 - 1.0 40 15 130 24.2 5.0 C3D1M605+F00+++*** 7.0 42.0 40.0 20.0 37.5 10.2 1.0 40 15 130 20.7 5.8 C3D1M705+F0B+++*** 8.0 41.0 37.0 22.0 37.5 10.2 1.0 40 15 130 18.1 6.6 C3D1M805+F0B+++*** 9.0 41.0 37.0 22.0 37.5 12.7 1.0 40 15 130 16.1 7.5 C3D1M905+F02+++*** 10.0 42.0 44.0 24.0 37.5 12.7 1.0 40 15 130 14.5 8.3 C3D1M106+F02+++*** 12.0 42.0 44.0 24.0 37.5 12.7 1.0 40 15 130 12.1 9.9 C3D1M126+F02+++*** 12.0 42.0 44.0 24.0 37.5 - 1.0 40 15 130 14.0 8.6 C3D1M126+F00+++*** 15.0 42.0 45.0 30.0 37.5 12.7 1.2 40 15 130 9.7 12.4 C3D1M156+F02+++*** 15.0 42.0 45.0 30.0 37.5 20.3 1.2 40 15 130 9.7 12.4 C3D1M156+F0A+++*** 18.0 42.0 50.0 35.0 37.5 20.3 1.2 40 15 130 8.1 14.9 C3D1M186+F0A+++*** 20.0 42.0 50.0 35.0 37.5 20.3 1.2 40 15 130 7.2 16.6 C3D1M206+F0A+++*** 25.0 42.0 55.0 40.0 37.5 20.3 1.2 40 15 130 5.8 20.7 C3D1M256+F0A+++*** 30.0 42.0 60.0 45.0 37.5 20.3 1.2 40 15 130 4.8 24.8 C3D1M306+F0A+++*** ★15.0 57.0 45.0 25.0 52.5 12.7 1.2 20 27 260 19.3 6.2 C3D1M156+M02+++*** 20.0 57.0 43.5 29.5 52.5 12.7 1.2 20 27 260 14.5 8.3 C3D1M206+M02+++*** 20.0 57.0 43.5 29.5 52.5 20.3 1.2 20 27 260 14.5 8.3 C3D1M206+M0A+++*** 25.0 57.0 50.0 35.0 52.5 20.3 1.2 20 27 260 11.6 10.4 C3D1M256+M0A+++*** 30.0 57.0 50.0 35.0 52.5 20.3 1.2 20 27 260 9.7 12.4 C3D1M306+M0A+++*** 35.0 57.0 55.0 45.0 52.5 20.3 1.2 20 27 260 8.4 14.3 C3D1M356+M0A+++*** 40.0 57.0 55.0 45.0 52.5 20.3 1.2 20 27 260 7.8 15.5 C3D1M406+M0A+++*** 45.0 57.0 55.0 45.0 52.5 20.3 1.2 20 27 260 6.9 17.4 C3D1M456+M0A+++*** 50.0 57.0 65.0 45.0 52.5 20.3 1.2 20 27 260 6.2 19.3 C3D1M506+M0A+++*** 55.0 57.0 65.0 45.0 52.5 20.3 1.2 20 27 260 5.6 21.3 C3D1M556+M0A+++*** tanδ×(10-4) CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 0.68 32.0 20.0 11.0 27.5 - 0.8 80 1.0 32.0 20.0 11.0 27.5 - 0.8 1.5 32.0 22.0 13.0 27.5 - 2.0 32.0 25.0 13.0 27.5 ★2.0 32.0 25.0 13.0 3.0 32.0 30.0 4.0 32.0 5.0 Page 10 of 15 C3D ■ Technical data(mm) U N,85℃ : 1 200Vdc tanδ×(10-4) CN (F) W ±1.0 H ±1.0 T ±1.0 P ±0.5 b ±0.5 d ±0.05 dV/dt (V/μs) 1kHz 10kHz 1.0 32.0 20.0 11.0 27.5 0.8 90 7 55 2.0 32.0 24.5 15.0 27.5 0.8 90 7 55 3.0 32.0 30.0 16.0 27.5 0.8 90 7 55 4.0 32.0 33.0 18.0 27.5 0.8 90 7 5.0 32.0 37.0 22.0 27.5 - ESR @10kHz (mΩ) 39.5 0.8 90 5.0 32.0 37.0 22.0 27.5 10.2 0.8 90 3.0 41.0 30.0 16.0 37.5 1.0 4.0 41.0 30.0 16.0 37.5 5.0 41.0 33.5 18.5 37.5 6.0 42.0 40.0 20.0 37.5 - 7.0 41.0 37.0 22.0 37.5 8.0 42.0 44.0 24.0 37.5 9.0 42.0 44.0 24.0 10.0 42.0 44.0 12.0 42.0 12.0 42.0 15.0 Imax (A) Part number 3.5 C3D3L105+B00+++*** 26.3 5.0 C3D3L205+B00+++*** 17.5 7.5 C3D3L305+B00+++*** 55 13.9 9.5 C3D3L405+B00+++*** 7 55 12.7 10.4 C3D3L505+B00+++*** 7 55 11.1 11.8 C3D3L505+B0B+++*** 45 13 100 37.2 3.2 C3D3L305+F00+++*** 1.0 45 13 100 27.9 4.3 C3D3L405+F00+++*** 1.0 45 13 100 22.3 5.4 C3D3L505+F00+++*** 1.0 45 13 100 18.6 6.5 C3D3L605+F00+++*** 10.2 1.0 45 13 100 15.9 7.5 C3D3L705+F0B+++*** 12.7 1.0 45 13 100 13.9 8.6 C3D3L805+F02+++*** 37.5 12.7 1.0 45 13 100 12.4 9.7 C3D3L905+F02+++*** 24.0 37.5 12.7 1.0 45 13 100 11.1 10.8 C3D3L106+F02+++*** 45.0 30.0 37.5 12.7 1.2 45 13 100 9.3 12.9 C3D3L126+F02+++*** 45.0 30.0 37.5 20.3 1.2 45 13 100 9.3 12.9 C3D3L126+F0A+++*** 42.0 50.0 35.0 37.5 20.3 1.2 45 13 100 7.4 16.1 C3D3L156+F0A+++*** 18.0 42.0 50.0 35.0 37.5 20.3 1.2 45 13 100 6.6 18.1 C3D3L186+F0A+++*** 20.0 42.0 55.0 40.0 37.5 20.3 1.2 45 13 100 6.0 20.1 C3D3L206+F0A+++*** 25.0 42.0 60.0 45.0 37.5 20.3 1.2 45 13 100 4.8 25.1 C3D3L256+F0A+++*** 12.0 57.0 45.0 25.0 52.5 12.7 1.2 23 24 200 19.9 6.0 C3D3L126+M02+++*** 15.0 57.0 45.0 25.0 52.5 12.7 1.2 23 24 200 15.9 7.5 C3D3L156+M02+++*** 20.0 57.0 43.5 29.5 52.5 12.7 1.2 23 24 200 11.9 10.0 C3D3L206KM02+++*** 20.0 57.0 43.5 29.5 52.5 20.3 1.2 23 24 200 11.9 10.0 C3D3L206KM0A+++*** 20.0 57.0 45.0 30.0 52.5 12.7 1.2 23 24 200 11.9 10.0 C3D3L206JM02+++*** 20.0 57.0 45.0 30.0 52.5 20.3 1.2 23 24 200 11.9 10.0 C3D3L206JM0A+++*** 25.0 57.0 50.0 35.0 52.5 20.3 1.2 23 24 200 9.6 12.6 C3D3L256+M0A+++*** 30.0 57.0 55.0 45.0 52.5 20.3 1.2 23 24 200 8.0 15.1 C3D3L306+M0A+++*** 35.0 57.0 55.0 45.0 52.5 20.3 1.2 23 24 200 6.8 17.6 C3D3L356+M0A+++*** 40.0 57.0 65.0 45.0 52.5 20.3 1.2 23 24 200 6.0 20.1 C3D3L406+M0A+++*** 45.0 57.0 65.0 45.0 52.5 20.3 1.2 23 24 200 5.3 22.6 C3D3L456+M0A+++*** Note: 1. “+”=capacitance tolerance code K=±10%, J=±5% 2. “+++”= lead form and packaging code 3. “***”= Internal use 4. When the b=10.0mm, the digit 12 is “1”; When the b=20.0mm, the digit 12 is “2”; When the b=15.0mm, the digit 12 is “4”; 5. “Imax”=Maximum r.m.s current at 10kHz, Θamb=70℃, △Θcase=15.0℃. 6. “★” = Arc-bottom of the outer shell. Page 11 of 15 C3D ■ Typical waveforms These capacitors are only suitable for DC applications. It means the voltage applied to the capacitors must be unidirectional ripple voltage. Note: ●The peak voltage(UP+) shall not be greater then the rated DC voltage(U N). ●The peak-to-peak ripple voltage(UP-P) shall not be greater then 0.3× (UN). ●The maximum component surface temperature rise must be lower than 15℃. ■ Measuring the component temperature Note: ●The temperature is measured in unloaded (Tamb) and maximum loaded condition (T c) ●The temperature rise is given by △T = Tc - Tamb ●To avoid thermal radiation or convection, the capacitor must be tested in a closed area from air circulation ■ Over voltages according to IEC 61071: 1.1 UN 30% of on-load-dur. 1.15 UN 30min/day 1.2 UN 5min/day 1.3 UN 1.5 UN 1min/day 100ms every time, 1000 times during the whole life of the capacitor ■ Lifetime expectancy (typical curve) Page 12 of 15 C3D ■ No. Test Method And Performance Item 5.14.2 External inspection Initial measurements Performance Legible marking and finish as specified Dimensions: see specific drawing Capacitance at 1kHz tg at 10kHz Testing Method IEC 61071 Check for finish, marking and overall dimensions Tensile Ua1 Wire diameter 1 5.14.1.1 Robustness of terminations d ≤0.8mm 0.8 mmd ≤1.2mm There shall be no visible damage Bending Ub1 Wire diameter load 10N 20N load d≤0.8 mm 5N 0.8 mmd≤1.2 mm 10N 4×90°, duration 2s to 3s 5.14.1.6 Resistance to soldering heat There shall be no visible damage. Final measurements |C/C|≤0.5%(relative to the initial value) Increase of tg: 0.005 Initial measurements Capacitance at 1kHz tg at 10kHz 5.14.3.1 Vibration There shall be no evidence damage 5.14.3.1 Impacts There shall be no evidence damage 2 Final measurements Initial measurements 3 f=10 Hz to 55Hz a=±0.35mm Test duration per axis = 10 frequency cycles (3 axes offset from each other by 90C), 1 octave/min, the total times are 135min for 3 axes. 1 000times, Acceleration: 390m/s2 Pulse duration: 6ms |C/C|≤0.5%(relative to the initial value) Increase of tg: 0.005 Capacitance at 1kHz tg at 10kHz Test voltage: 1.1UNDC Number of discharges: 5 Time lapse every 2 min (10min total) Within 5 min after the surge discharge test, the capacitor shall be subjected to a voltage test between terminals: 1.5UNDC, 60s 5.9 Surge discharge test Final measurements Solder temperature: 260˚C5˚C Immersion time: 10s1s |C/C|≤1.0% (relative to the initial value) tg: 1.2×tg0(the initial tg)+0.0001 Page 13 of 15 C3D No. Item Initial measurements Testing Method IEC 61071 Performance Capacitance at 1kHz tg at 10kHz Voltage: 1.5U Duration: 10s If fewer than five clearing occur during this time, the voltage shall be increased slowly until five clearings have occurred since the start of the test or until the voltage has reached 2.5UNDC If fewer than five clearings have occurred when the voltage has reached 2.5UNDC, for a time of 10s,the test shall be finished. NDC 4 5.11 Self-healing Initial measurements 5 6 7 5.13.1Change of temperature |C/C|≤0.5% (relative to the initial value) tg: 1.1×tg0(the initial tg)+0.0001 Capacitance at 1kHz tg at 10kHz There shall be no evidence of deterioration Final measurements |C/C|≤2.0%(relative to the initial value) Increase of tg:0.015 Initial measurements Capacitance at 1kHz tg at 10kHz Test: Na A=-40˚C,B=+85˚C 5 cycles, Duration: t=30min 5.13.2Damp heat, steady state There shall be no evidence of deterioration. Temperature: 40˚C 2˚C Humidity: 933 %RH Duration: 56 days 5.5.1 Voltage test between terminals There shall be no puncturing or flashover. permanent 1.5U , 60s 5.6.1 Voltage test between terminals and case There shall be no puncturing or flashover. permanent NDC Final measurements |C/C|≤2.0%(relative to the initial value) Increase of tg:0.015 Initial measurements Capacitance at 1kHz tg at 10kHz 5.10.1Thermal stability test Final measurements Throughout the last 6h, the temperature of the case near of the top rise shall not increase by more than 1˚C |C/C|≤2.0%(relative to the initial value) tg:1.2×tg0(the initial tg)+0.015 Page 14 of 15 2 000VAC, 10s Temperature: ambient temperature Test current: 1.1Irms Test frequency: 10kHz Test time: 48h During the last 6h, the temperature of the case near of the top rise shall be measured per 1.5h. C3D No. Item Initial measurements Performance Testing Method IEC 61071 Capacitance at 1kHz tg at 10kHz Measuring procedure: (1) 1.3U , 85℃, 500h NDC 8 (2) Charging and discharging: Times: 1 000 dv/dt: according to the technical data 5.15 Endurance (3) 1.3U , 85℃, 500h NDC Final measurements |C/C|≤3.0%(relative to the initial value) Increase of tg:0.015 Page 15 of 15
C3D3A805KB02C00 价格&库存
很抱歉,暂时无法提供与“C3D3A805KB02C00”相匹配的价格&库存,您可以联系我们找货
