凯越翔实业
深圳市凯越翔实业
工厂地址:深圳市宝安区观澜人民路蔡发工业城一栋四层
官网:www.kaiyuexiang.com
TEL:0755-89315823
89315866
FAX:0755-89315223
凯越翔实业
石英谐振器规格书
产品名称:
石英晶振谐振器
产品型号:
3225/32.000MHZ
产品参数:
12PF/±10ppm
原厂型号:
K3A320001210
尺寸图:
P.2 3
凯越翔实业技术
董宗全
部:
客 户 确 认 印 栏
认 证 印 章
年
月
负 责 人 印 章
日
年
TEL:0755-89315823
本规格章程连同本页合共 6 页
89315866
月
日
FAX:0755-89315223
凯越翔实业
TEL:0755-89315823
89315866
FAX:0755-89315223
凯越翔实业
1. Frequency:
32.000 MHZ
2. Holder Type:
SMD3.2*2.5
3. Frequency Tolerance:
±10ppm at 25℃±3℃
4. Equivalent Series Resistance:
40ΩMax
5. Storage Temperature Range:
-40℃ ~ + 85℃
6. Operating Temperature Range:
-40℃ ~ +85℃
7. Frequency Characteistics Over Temperatnre: ±10ppm -40℃~+85℃
8. Load Capacitance (CL):
12 PF
9. Drive Level:
100μW Max
10. Shunt Capacitance:
5PF MAX
11. Insulation Resistance:
≥500MΩ Min at 100 V
12. Mode Of Oscllation:
Fundamental
13. Aging:
3ppm/Year
Marking description:
K32.00 MHZ
14. Dimensiors(mm):
16.Structure Illustration
TEL:0755-89315823
89315866
FAX:0755-89315223
凯越翔实业
TEL:0755-89315823
89315866
FAX:0755-89315223
凯越翔实业
Reliability Testing 可靠性测试项目介绍
项目
Vibration
振动
验条件及要求
要求
Endurance condition by a frequency sweep shall be made. The entire
frequency range
from 10HZ to 50HZ and return to 10HZ,shall be transverseb
in 1min. Amplitude(total excursion):1.5mm this motion shall be applied for
a period of 2h each of 3 mutually perpendicular axes(a total of 6h)
振动频率:从 10HZ 到 55HZ,再回到 10HZ 1 倍频程/min 幅度为 1.5mm 3 个相互垂直
(1).FL:+/-5ppm
(2).Rr:+/-15%
的方向各 2 小时
Drop
Form 70cm height 3 times on 3cm hard wooden floor
跌落
从 70cm 高处跌落到 3cm 厚的硬质木板上,重复 3 次
Shock
Peak acceleration:981m/s2
冲击
shocks shall be applied in both direction of 3 mutually perpendicular axes(a
duration of the pulse :6ms three successive
total of 18 shocks)
加速度:981m/s2 时间:6ms 作用在 3 个相互垂直的方向
Damp heat,constant
The unit shall be stored at a temperature of 40℃±2℃with relative humidity
恒定湿热
of 90%to95% for 48h, then it shall be subjected to standard atmospheric
conditions for 1~2h after which measurement shall be made.
在温度:40℃
±2℃、湿度:90%to95%条件下存放 48 小时,然后在标准大气压下放置 1~2 小时
后测试
Cold
低温存储
The unit shall be stored at a temperature of-40℃±5℃ for 48h, then it shall
be subjected to standard atmospheric conditions
在-40℃±5℃下存放 48 小时,然后在标准大气压下放置 1~2 小时后测试
Dry heat
The unit shall be stored at a temperature of 100℃±5℃ for 24h, then it
高温存储
shall be subjected to standard atmospheric conditions
(1).FL:+/-10ppm
(2).Rr:+/-80Ω
100℃±5℃下存放 24 小时,然后在标准大气压下放置 1~2 小时后测试
Aging
The unit shall be stored at a temperature of 85℃±5℃ for 7d then it shall
老化
85℃±5℃下放置 7 天,然后在标准大气压下放置 1~2 小时后测试
The unit shall be subjected to 5 successive change of temperature cycles,
Temperature
each as show in table below,then it shall be subjected to standard
cycling
atmospheric conditions for 1~2h after which measurement shall be made
温度循环
下表给定温度和时间参数的条件下循环 5 次,标准大气压下放置 1~2 小时后测试
TEL:0755-89315823
89315866
在
FAX:0755-89315223
凯越翔实业
1
Temperature
Duration
温度
放置时间
-40℃±3℃
30min(30 分
钟)
2
Standard
atmospheric
conditions
Within 30s
30 秒内
标准大气压
3
100℃±3℃
30min
(30 分
钟)
4
Standard
atmospheric
conditions
Within 30s
30 秒内
标准大气压
Resistance to
soldering heat
耐焊接热
TEL:0755-89315823
89315866
FAX:0755-89315223
凯越翔实业
拟制
成望生
审 核
董宗全
批 准
TEL:0755-89315823
赵庸桓
89315866
FAX:0755-89315223
很抱歉,暂时无法提供与“K3A320001210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46484
- 100+0.37152
- 300+0.32487
- 3000+0.27044
- 6000+0.24246
- 9000+0.22853
