CC1206GRNPO0BN222
CC1206GRNPO0BN222
    YAGEO(国巨)
    贴片电容(MLCC) 1206 2.2nF ±2% 100V C0G(NP0)
CC1206GRNPO0BN222 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Mid-voltage NP0/X7R 100 V TO 630 V 0.47 pF to 2.2 µF Product Specification – July 13, 2018 V.21 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP This specification describes Midvoltage NP0/X7R series chip capacitors with lead-free terminations. CTC & 12NC APPLICATIONS PCs, Hard disk, Game PCs Power supplies LCD panel ADSL, Modem FEATURES Supplied in tape on reel Nickel-barrier end termination RoHS compliant Halogen Free compliant 2 18 All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) CC XXXX X X XXX X (1) (2) (3) (4) (5) B X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216) / 1210 (3225) 1808 (4520) / 1812 (4532) (2) TOLERANCE B = ± 0.1 pF C = ± 0.25 pF D = ± 0.5 pF F = ± 1% G = ± 2% J = ± 5% K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch C = Bulk case (4) TC MATERIAL NPO X7R (5) RATED VOLTAGE 0 = 100 V A = 200 V Y = 250 V B = 500 V Z = 630 V (6) PROCESS N = NP0 B = Class 2 MLCC (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 3 18 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION Table 1 For outlines see fig. 2 OUTLINES TYPE L1 (mm) W (mm) T (MM) L2 / L3 (mm) L4 (mm) min. max. min. 0201 0.6 ± 0.03 0.3± 0.03 0.3± 0.03 0.10 0.20 0.20 0402 1.0 ± 0.05 0.5 ± 0.05 0.5 ± 0.05 0.15 0.30 0.40 0603 1.6 ± 0.10 0.8 ± 0.10 0.8 ± 0.10 0.20 0.60 0.40 0805 2.0 ± 0.20 1.25 ± 0.20 0.25 0.75 0.70 For dimension see Table 1 0.6 ± 0.10 0.85 ± 0.10 1.25 ± 0.20 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.6 ± 0.10 1206 3.2 ± 0.30 1.6 ± 0.20 0.85 ± 0.10 1.25 ± 0.20 0.25 0.75 1.40 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 1.6 ± 0.20 3.2 ± 0.30 1.6 ± 0.30 3.2 ± 0.30 2.5 ± 0.20 1.6 ± 0.30 0.85 ± 0.10 1210 1.25 ± 0.20 2.0 ± 0.20 1808 4.5 ± 0.40 2.0 ± 0.30 1.25 ± 0.20 0.85 ± 0.10 1812 4.5 ± 0.40 3.2 ± 0.30 1.25 ± 0.20 1.6 ± 0.20 www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0201 to 0805 0201 0402 0603 CAP. Mid-voltage NP0/X7R 100 V to 630 V 4 18 0805 100V 100V 100 V 200 V 250 V 100 V 200 V 250 V 500 V 630V 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.22 pF 0.47 pF 0.56 pF 0.68 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0603 to 0805 (continued) 0402 0603 CAP. 100 V 100 V 200 V Mid-voltage NP0/X7R 100 V to 630 V 5 18 0805 250 V 100 V 200 V 250 V 500 V 630 V 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF 0.8± 0.1 0.5± 0.05 0.8± 0.1 0.6± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 0.85± 0.1 1.8 nF 2.2 nF 1.25± 0.2 2.7 nF 1.25± 0.2 3.3 nF 3.9 nF 4.7 nF 1.25± 0.2 5.6 nF 6.8 nF 8.2 nF 10 nF 12 nF 15 nF 18 nF 22 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 1206 to 1210 1206 CAP. 100 V 200 V 250 V 0.6± 0.1 0.6± 0.1 0.6± 0.1 Mid-voltage NP0/X7R 100 V to 630 V 6 18 1210 500 V 630 V 0.6± 0.1 1.25± 0.2 100 V 200 V 250 V 500 V 630 V 0.47 pF 0.56 pF 0.68 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 82 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 5 Sizes from 1206 to 1210 (continued) 1206 CAP. 100 V 200 V 250 V 500 V 0.6± 0.1 0.6± 0.1 0.6± 0.1 Mid-voltage NP0/X7R 100 V to 630 V 7 18 1210 630 V 100 V 200 V 250 V 500 V 630 V 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 1.25± 0.2 390 pF 470 pF 560 pF 1.25± 0.2 0.6± 0.1 680 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 820 pF 1.0 nF 1.2 nF 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.5 nF 1.8 nF 2.2 nF 1.25± 0.2 2.7 nF 3.3 nF 3.9 nF 4.7 nF 0.85± 0.1 5.6 nF 6.8 nF 8.2 nF 10 nF 1.25± 0.2 12 nF 15 nF 18 nF 1.6± 0.2 22 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 8 18 100 V to 630 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 6 Sizes 1812 1812 CAP. 100 V 200 V 250 V 500 V 630V 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 1.25± 0.2 330 pF 390 pF 470 pF 1.25± 0.2 560 pF 680 pF 820 pF 1 nF 1.2 nF 1.25± 0.2 1.5 nF 1.25± 0.2 1.8 nF 2.2 nF 2.7 nF 1.25± 0.2 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 12 nF 15 nF 18 nF 22 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR X7R Table 7 Sizes from 0402 to 0805 0402 0603 CAP. 100 V 100 V 250 V Mid-voltage NP0/X7R 9 18 100 V to 630 V 0805 100 V 200 V 250 V 500 V 630 V 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1.0 nF 0.5± 0.05 1.5 nF 0.6± 0.1 2.2 nF 3.3 nF 0.8± 0.1 0.8± 0.1 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 33 nF 47 nF 68 nF 100 nF 1.25± 0.2 150 nF 220 nF 330 nF 470 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For special ordering code, please contact local sales force before order 4. For product with 5% tolerance, please contact local sales force before order www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR X7R Table 8 Sizes from 1206 to 1210 1206 CAP. 100 V 200 V 250 V 0.85± 0.1 0.85± 0.1 500 V Mid-voltage NP0/X7R 100 V to 630 V 10 18 1210 630 V 100 V 200 V 250 V 0.85± 0.1 0.85± 0.1 500 V 630V 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1.0 nF 1.5 nF 2.2 nF 3.3 nF 1.25± 0.2 1.25± 0.2 0.85± 0.1 4.7 nF 6.8 nF 1.25± 0.2 10 nF 15 nF 22 nF 33 nF 1.25± 0.2 47 nF 1.25± 0.2 1.6± 0.2 1.6± 0.2 1.6± 0.2 68 nF 100 nF 150 nF 1.25± 0.2 1.25± 0.2 1.6± 0.2 470 nF 1.25± 0.2 1.6± 0.2 220 nF 330 nF 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.6± 0.2 680 nF 1 µF 1.6± 0.2 2.2 µF 1.6± 0.3 2.0± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before order www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR X7R Table 9 Sizes from 1808 to 1812 1808 CAP. 100 V 200 V 250 V 500 V Mid-voltage NP0/X7R 100 V to 630 V 11 18 1812 100 V 200 V 250 V 0.85± 0.1 0.85± 0.1 500 V 630 V 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1.0 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 0.85± 0.1 10 nF 15 nF 22 nF 1.35± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 33 nF 1.6± 0.2 47 nF 68 nF 100 nF 150 nF 220 nF 1.25± 0.2 1.25± 0.2 1.6± 0.2 1.6± 0.2 1.6± 0.2 1.25± 0.2 330 nF 470 nF 680 nF 1.6± 0.2 1 µF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before order www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 12 18 THICKNESS CLASSES AND PACKING QUANTITY Table 10 SIZE CODE Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister THICKNESS CLASSIFICATION TAPE WIDTH QUANTITY PER REEL 0201 0.3 ± 0.03 mm 8 mm 15,000 --- 50,000 --- --- 0402 0.5 ± 0.05 mm 8 mm 10,000 --- 50,000 --- 50,000 0603 0.8 ± 0.1 mm 8 mm 4,000 --- 15,000 --- 15,000 0.6 ± 0.1 mm 8 mm 4,000 --- 20,000 --- 10,000 0.8 / 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- 8,000 1.25 ± 0.2 mm 8 mm --- 3,000 --- 10,000 5,000 0805 1206 QUANTITY PER BULK CASE 0.6 ± 0.1 mm 8 mm 4,000 --- 20,000 --- --- 0.8 / 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- --- 1.00 / 1.15 ± 0.1 mm 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm 8 mm --- 3,000 --- 10,000 --- 1.6 ± 0.15 mm 8 mm --- 2,500 --- 10,000 --- 1210 1.6 ± 0.2 mm 8 mm --- 2,000 --- 8,000 --- 0.6 / 0.7 ± 0.1 mm 8 mm --- 4,000 --- 15,000 --- 0.85 ± 0.1 mm 8 mm --- 4,000 --- 10,000 --- 1.15 ± 0.1 mm 8 mm --- 3,000 --- 10,000 --- 1.15 ± 0.15 mm 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm 8 mm --- 3,000 --- --- --- 1.5 ± 0.1 mm 8 mm --- 2,000 --- --- --- 1.6 / 1.9 ± 0.2 mm 8 mm --- 2,000 --- --- --- 2.0 ± 0.2 mm 8 mm --- 2,000 1,000 --- --- --- 2.5 ± 0.2 mm 8 mm --- 1,000 500 --- --- --- 1.15 ± 0.15 mm 12 mm --- 3,000 --- --- --- 1.25 ± 0.2 mm 12 mm --- 3,000 --- --- --- 1.35 ± 0.15 mm 12 mm --- 2,000 --- --- --- 1.5 ± 0.1 mm 12 mm --- 2,000 --- --- --- 1.6 ± 0.2 mm 12 mm --- 2,000 --- 8,000 --- 2.0 ± 0.2 mm 12 mm --- 2,000 --- --- --- 0.6 / 0.85 ± 0.1 mm 12 mm --- 2,000 --- --- --- 1.15 ± 0.1 mm 12 mm --- 1,000 --- --- --- 1.15 ± 0.15 mm 12 mm --- 1,000 --- --- --- 1.25 ± 0.2 mm 12 mm --- 1,000 --- --- --- 1.35 ± 0.15 mm 12 mm --- 1,000 --- --- --- 1.5 ± 0.1 mm 12 mm --- 1,000 --- --- --- 1.6 ± 0.2 mm 12 mm --- 1,000 --- --- --- 2.0 ± 0.2 mm 12 mm --- 1,000 --- --- --- 2.5 ± 0.2 mm 12 mm --- 500 --- --- --- 1808 1812 www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 13 18 100 V to 630 V ELECTRICAL CHARACTERISTICS NP0/X7R DIELECTRIC CAPACITORS; NISN TERMINATIONS Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1: - Temperature: 15 °C to 35 °C Relative humidity: 25% to 75% Air pressure: 86 kPa to 106 kPa Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. Table 11 VALUE DESCRIPTION Capacitance range 0.47 pF to 2.2 µF Capacitance tolerance NP0 C < 10 pF ± 0.25 pF, ± 0.5 pF C ≥ 10 pF ±2%, ± 5%, ± 10% X7R ± 5% (1), ± 10%, ± 20% Dissipation factor (D.F.) NP0 C < 30 pF ≤ 1 / ( 400 + 20C ) C ≥ 30 pF ≤ 0.1 % X7R Exception ≤ 2.5 % X7R/0603/100V, 12nF ≤ C ≤ 100nF, X7R/1206/2.2uF/100V ≤ 5% X7R/1206/100V/1uF; X7R/1210/100V/1uF and 2.2uF; ≤ 3.5% Insulation resistance after 1 minute at Ur (DC) Rins ≥ 10 GΩ or Rins × C ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient): NP0 ± 30 ppm/°C X7R ± 15% Operating temperature range: NP0/X7R –55 °C to +125 °C NOTE 1. Capacitance tolerance ±5% doesn't available for X7R full product range, please contact local sales force before order www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors SOLDERING RECOMMENDATION Table 12 SIZE SOLDERING 0201 METHOD Reflow Reflow only Reflow/Wave Mid-voltage NP0/X7R 14 18 100 V to 630 V 0402 0603 0805 1206 ≥ 1210 > 100 nF > 1.0 µF > 2.2 µF > 2.2 µF Reflow only ≤ 100 nF ≤ 1.0 µF ≤ 2.2 µF ≤ 2.2 µF --- TESTS AND REQUIREMENTS Table 12 Test procedures and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Mounting IEC 60384- 4.3 21/22 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual Inspection and Dimension Check 4.4 Any applicable method using × 10 magnification In accordance with specification Capacitance 4.5.1 Class 1: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C Within specified tolerance f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Class 2: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C Dissipation Factor (D.F.) 4.5.2 Class 1: f = 1 MHz for C ≤ 1 nF , measuring at voltage 1 Vrms at 20 °C In accordance with specification f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Class 2: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C Insulation Resistance 4.5.3 Ur ≤ 500 V: At Ur for 1 minute In accordance with specification Ur > 500 V: At 500 V for 1 minute www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Temperature coefficient 4.6 Mid-voltage PROCEDURE NP0/X7R 100 V to 630 V 15 18 REQUIREMENTS Capacitance shall be measured by the steps shown Class1: in the following table. ∆ C/C: ± 30ppm The capacitance change should be measured after 5 min at each specified temperature stage. Class2: X7R: ∆ C/C: ±15% Temperature(℃) Step Y5V: ∆ C/C: 22~-82% a 25± 2 Lower temperature± 3℃ b Class2: X7R/X5R: ∆ C/C: ±15% c 25± 2 Y5V: ∆ C/C: 22~-82% Upper Temperature± 2℃ d e 25± 2 (1) Class I Temperature Coefficient shall be calculated from the formula as below C2 - C1 106 [ppm/℃] Temp, Coefficient = C1 xΔT C1: Capacitance at step c C2: Capacitance at 125℃ ∆T: 100℃(=125℃-25℃) (2) Class II Capacitance Change shall be calculated from the formula as below C2 - C1 ∆C = x 100% C1 C1: Capacitance at step c C2: Capacitance at step b or d Adhesion Bending Strength IEC 6038421/22 4.7 A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate Force size ≥ 0603: 5N 4.8 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 5 mm ∆C/C Class 1: NP0: within ± 1% or 0.5 pF, whichever is greater Class2: X7R: ± 10% www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Resistance to Soldering Heat 4.9 Mid-voltage NP0/X7R 100 V to 630 V 16 18 PROCEDURE REQUIREMENTS Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute Class 1: NP0: within ± 0.5% or 0.5 pF, whichever is greater ∆C/C Preheating: for size >1206: 100 °C to 120 Class2: °C for 1 minute and 170 °C to 200 °C for 1 X7R: ± 10% minute D.F. within initial specified value Solder bath temperature: 260 ± 5 °C Dipping time: 10 ± 0.5 seconds Rins within initial specified value Recovery time: 24 ± 2 hours Solderability 4.10 Preheated the temperature of 80 °C to 140 °C and maintained for 30 seconds to 60 seconds. The solder should cover over 95% of the critical area of each termination 1. Temperature: 235± 5°C / Dipping time: 2 ± 0.5 s 2. Temperature: 245± 5°C / Dipping time: 3 ± 0.5 s (lead free) Depth of immersion: 10mm Rapid Change of Temperature IEC 6038421/22 4.11 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature 5 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature Recovery time 24 ± 2 hours No visual damage ∆C/C Class 1: NP0: within ± 1% or 1 pF, whichever is greater Class2: X7R: ± 15% D.F. meet initial specified value Rins meet initial specified value www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Damp Heat 4.13 Mid-voltage REQUIREMENTS 3. Preconditioning, class 2 only: No visual damage after recovery 4. Initial measure: Spec: refer initial spec C, D, IR 500 ± 12 hours at 40 ± 2 °C; 90 to 95% R.H. Class 1: NP0: within ± 2% or 1 pF, whichever is greater Class2: X7R: ≥ 25 V: ≤ 5% 7. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. 1. Preconditioning, class 2 only: Rins Class 1: NP0: ≥ 2,500 MΩ or Rins x Cr ≥ 25s whichever is less Class2: X7R: ≥ 500 MΩ or Rins x Cr ≥ 25s whichever is less No visual damage 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer initial spec C, D, IR 3. Endurance test: Temperature: NP0/X7R: 125 °C Specified stress voltage applied for 1,000 hours: 4. High voltage series follows with below stress condition: Voltage NPO X7R ≤ 100V 2.0 x Ur 2.0 x Ur 200/250V 1.5 x Ur 1.5 x Ur 500/630V 1.3 x Ur 1.2 x Ur ≥ 1KV 1.2 x Ur 1.1 x Ur 5. Recovery time: 24 ± 2 hours 6. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. 4.6 ∆C/C Class 1: NP0: ≤ 2 x specified value Class 1: 6 to 24 hours Class 2: 24 ± 2 hours Voltage Proof 18 D.F. 6. Recovery: 4.14 17 Class2: X7R: ± 15% 5. Damp heat test: IEC 6038421/22 100 V to 630 V PROCEDURE 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp Endurance NP0/X7R Specified stress voltage applied for 1~5 seconds Ur ≤ 100 V: series applied 2.5 Ur 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) Ur > 500 V: 1.3 Ur Ur ≥ 1000 V: 1.2 Ur Charge/Discharge current is less than 50 mA ∆C/C Class1: NP0: within ± 2% or 1 pF, whichever is greater Class2: X7R: ± 15% D.F. Class1: NP0: ≤ 2 x specified value Class2: X7R: ≥ 25 V: ≤ 5% Rins Class1: NP0: ≥ 4,000 MΩ or Rins x Cr ≥ 40s whichever is less Class2: X7R: ≥ 1,000 MΩ or Rins x Cr ≥ 50s whichever is less No breakdown or flashover www.yageo.com Jul. 13, 2018 V.21 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 630 V 18 18 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 21 - - Add NPO/0402/120pF to 1nF/100V, NPO/0603/1.2nF to 1.5nF/100V, NPO/1206/1.8nF/630V, NPO/1210/12nF to 22nF/100V Jul. 13, 2018 - Add X7R/0805/33nF to 47nF/200 to 250V Version 20 Sep. 14, 2017 - - Dimension outlines updated Version 19 Mar 7, 2017 - - 0805 L4 spec updated Version 18 Dec 9, 2016 - - Soldering recommendation update Version 17 Aug 16, 2016 - - Capacitance range & thickness update Version 16 Apr. 16, 2015 - - Capacitance range & thickness Version 15 Apr. 16, 2015 - - Electrical characteristics update Version 14 Sep. 25, 2014 - - Electrical characteristics update Version 13 Apr. 21, 2014 - - Electrical characteristics update Version 12 Dec. 12, 2013 - - Electrical characteristics update Version 11 Jun. 17, 2013 - - Test method and procedure updated Version 10 Nov 22, 2012 - - Test method and procedure updated Version 9 Feb 02, 2012 - - Test method and procedure updated Version 8 Apr 22, 2011 - - NP0 0402 100V added Version 7 Mar 01, 2011 - - Dimension updated Version 6 Sep 30, 2010 - - Update the thickness of 0805 100V Version 5 Sep 28, 2010 - - Product range updated - Thickness classes and packing quantity table updated Version 4 Jun 17, 2010 - - Update the dimension of 0805, 1206 and 1812 Version 3 Mar 25, 2010 - - Product range update Version 2 Mar 15, 2010 - - Product range update Version 1 Oct 30, 2009 - - Change to dual brand datasheet that describe Mid-voltage NP0/X7R series with RoHS compliant - Replace the "100V to 630V" part of pdf files: UP-NP0X7R_MV_100-to500V_0, UY-NP0X7R_MV_100-to-500V_0, NP0_16V-to-100V_6, NP0_50-to-500V_10, X7R_16-to-500V_9 and X7R_16V-to-100V_9 - Define global part number - Description of "Halogen Free compliant" added - Test method and procedure updated Version 0 Sep 08, 2005 - - New www.yageo.com Jul. 13, 2018 V.21
CC1206GRNPO0BN222 AI解析
物料型号:国巨(YAGEO)和飞荣达(Phicomp)品牌的中电压多层陶瓷电容器。
器件简介:这些电容器是表面贴装的陶瓷多层电容器,具有高电压和高电容密度的特点,适用于多种电子设备。
引脚分配:电容器由两个端部终止,内电极连接到这两个端部,并最终被镀锡层覆盖。
参数特性: - 电容范围:0.47pF至2.2µF - 额定电压:100V至630V - 温度系数(NP0):±30ppm/°C - 耗散因数(NPO):对于C<30pF,≤1/(400+20C);对于C≥30pF,≤0.1% - 绝缘电阻:在Ur下1分钟后,Rins≥10GΩ或RinsxC>500秒,取较小值
功能详解:这些电容器具有高稳定性和低损耗特性,适用于需要高电容电压特性的应用。
应用信息:适用于个人电脑、硬盘、游戏电脑电源、液晶面板、ADSL、调制解调器等。
封装信息:提供多种尺寸,包括0201、0402、0603、0805、1206、1210、1808和1812等,以及不同的封装风格,如带纸/聚乙烯胶带的卷轴、气泡膜卷轴等。
*介绍内容由AI识别生成
CC1206GRNPO0BN222 价格&库存
很抱歉,暂时无法提供与“CC1206GRNPO0BN222”相匹配的价格&库存,您可以联系我们找货
CC1206GRNPO0BN222
    • 10+0.37579
    • 100+0.30931
    • 300+0.27606
    • 1000+0.25113
    库存:1605
