X3S030000BA1H-U
X3S030000BA1H-U
    HELE(加高电子)
    SMD3225_4P
    无源晶振 SMD3225_4P
X3S030000BA1H-U 数据手册
SPECIFICATIONS FOR APPROVAL GP Customer Part No. HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: Sample Order No: EOS-D50413-3 Date: X3S030000BA1H-U CRYSTAL HSX321S / 30.000MHz 2013/06/07 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. HARMONY ELECTRONICS (SUZHOU) CO.,LTD TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號2樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄市大寮區大發工業區華東路 39 號 No.39, HWA DONG RD., DALLIAO DIST.,DAFA INDUSTRIAL PARK., KAOHSIUNG CITY 831, TAIWAN TEL: (07)787-1555-6 FAX: (07)787-1557 THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 Tittle HSX321S SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源 工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-27309272 / 27309262 FAX: 0755-27309755 Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS SUZHOU FACTORY: 蘇州市相城區黃埭鎮安民路 5 號 NO.5 ANMING ROAD, HUANGDAI TOWN, XIANGCHENG DISTRCT, SUZHOU CITY, JIANGSU PROVINCE TEL:86-512-67592373 FAX:86-512-67592363 CORP. 0 1 HSX321S SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION........... 3 2. MARKING & DIMENSIONS................... 4 3. INSIDE STRUCTURE...................... 5 4. EMBOSS CARRIER TAPE&REEL................ a. DIMENSIONS OF CARRIER TAPE............... 6 b. DIMENSIONS OF REEL................... 6-7 c. STORAGE CONDITION................... 7 d. STANDARD PACKING QUANTITY................... 7 e. MATERIAL OF TAPE..................... 7 f. LABEL CONTENTS...................... 7 g. TAPING DIMENSION..................... 8 h. JOINT OF TAPE....................... 8 i. RELEASE STRENGHT OF COVER TAPE............ 8 j. PACKAGE.......................... 9 5. MECHANICAL PERFORMANCE................. 10 6. ENVIRONMENTAL PERFORMANCE............... 11 7. SUPPLEMENT ........................ 12-13 8. FLOW CHART......................... 14 9. Environmental Workload Chemical Substance Components List. 15 10. TEST DATA.......................... Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 30.000000MHz 2. Holder type : HSX321S 3. Frequency tolerance: +/-10 ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 50 ohms Max. / SERIES 5. Storage temperature range: -40 deg.C To +85 deg.C 6. Operable temperature range: -20 deg.C To +70 deg.C 7. Temperature drift: +/-10ppm 8. Loading capacitance (CL) : 10.0 pF 9. Drive level: 10 μW 10. Shunt Capacitance: 2.0 pF Max 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 75 cm height 3 times on firm wood Variation : -20 deg.C To +70 deg.C (100uW Max) Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/-3 ppm/Year 16. Holder HSX321S Seam type 17. Dimensions and marking Refer to page.4 18. Emboss carrier tape & reel Refer to page.6 and page.7 19. Moisture Sensitivity Level Level 1 20. Note: Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 3 2. HSX321S MARKING & DIMENSIONS Chamfer index mark depends on the ceramic base supplier. *Marking should be printed as following: Logo, Nominal Frequency, Manufactured year & month *Nominal frequency = integer only ( ex. 14.31818 MHz  14 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2). Marking : Laser marking. (Table-1) 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 Year 2010 2011 2012 2013 2014 2015 2016 2017 2018 2019 Code 0 1 2 3 4 5 6 7 8 9 (Table-2) Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov. Dec. A B C D E F G H J K L M Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 4 3. INSIDE STRUCTURE ※Reference drawing 1) Base: Alumina Ceramic (Al2O3) Metallized Pad: W Ni Plating Au Plating (2) Lid : Fe- Ni -Co (3) Crystal Enclosure Seal: Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin Adhesive bonding: upper & lower bonding/lower bonding only (6) Electrode (7) PAD Alumina Ceramic : W Ni Plating Au Plating (8) Cover Ring: Fe-Ni-Co Alloy Tittle HSX321S The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in this item. Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 5 4. HSX321S EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 9.3+/-0.3 Outer Width W2 Out Line diameter B 11.3+/-1.0 ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Width Center Core slit Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 3,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material PS Conductive Polyester f.) Label contents Sticks label for every reel. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 8 j.) Package Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 9 5. Mechanical Performance Test Methods 1 Natural Drop 2 Vibration 3 Sealing Tightness 4 Solderability 5 Substrate Bending Drop 3 times from the height of 75cm onto min. 30mm thickness hard wooden board. Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z 3 axes, Duration of 120min. to each direction. Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak detector. – Fine Leakage. After applying ROSIN Flux, dipping in solder bath at 245deg.C+/-5deg.C for 3+/-0.5 sec. Mount a sample on board. Apply Pressure to the center of board until it is bent to 3 mm and hold for 5 ±1 sec Pressure speed :0.5 mm / sec Mount a sample on the circuit board. Apply pressure vertically to the side of specimen attached to the circuit board with the pressure jig. Pressure : 5N for 10+/-1 sec Apply pressure to the center of body with the R0.5 pressure jig. pressure :10N for 10+/-1sec 6 7 Adhesion Body strength Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Specifications Code Item Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. A --B A A A TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS A CORP. 0 10 6. Environment Performance Item 1 2 3 4 Specifications Code Test Methods Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours. Back to room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. +85deg.C +/-2deg.C, Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. -40deg.C +/-2deg.C (30min)  +85deg.C +/-2deg.C (30min) 25 cycles. Back to the room temperature first, then in 1~2 hours, the component shall be checked. Humidity Storage in Low Temperature Storage in High Temperature Temperature cycles A A A A Specifications code Specifications A Frequency variation shall be within +/-5ppm and equivalent resistance shall be within +/-15% or 2Ω B More than 90% of lead shall be covered by new solder. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 11 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. 7.3.Land pattern layout(Example) 7.4.Solder iron (Example) Bit temp.:350℃max.,Time:3sec max. ,Each terminal solder a 1 time max. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 12 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering Process. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity ,which may cause put solderbility. No direct Sunlight, No dew as well. Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 13 8. Flow Chart LID(外 殼 蓋 ) BLANK(晶 片 ) BLANK進 料 檢 查 LID進 料 檢 查 1 Incoming Inspection of LID 4 2 LID洗 淨 5 Cleaning of LID BASE(基 座 ) 6 7 Incoming Inspection of BLANK BASE進 料 檢 查 3 Incoming Inspection of BASE 化學蝕刻 Etching 頻率選別 Sorting of Freq. 蒸著前洗淨 Cleaning before Base Plating 8 微蝕刻 9 基礎蒸著 Flash Etching Base Plating 10 押入接著 11 接著硬化 12 13 14 15 Blank Ass'y Adhesive Curing 接著檢查 Bonding Check 調 整 蒸 著 / ION Partial 23 中 間 檢 查 ($) 氣 密 檢 查 I (AIR) Leak Check I 氣 密 檢 查 II (氦 氣 加 壓 ) Leak Check II (Helium Pressurization) Middle Check 高真空烘烤 High Vacuum Annealing 16 熔 接 Seam Seal 17 強 勵 振 Over Drive 18 REFLOW 19 老 化 Aging 20 22 Partial Adjustment/Ion Partial 24 25 Leak Check II 最 終 檢 查 ($) Final Check 26 TAPING 27 Taping 外 觀 檢 查 28 出貨檢查 印字排盤 Aligning 氣 密 檢 查 II (HE) Check of Taping Outgoing Inspection 21 印 字 +外 觀 檢 查 Marking & Check 29 出貨捆包 Packing to Shipment/stock ($): 特 殊 特 性 (For Special Characteristics) 出 貨 Shipment Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 14 9. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE H(D)SX321S PERCENTAGE 20.5(mg) ppm Si 0.04715 9.6658 Au 0.15785 32.3593 Co & Co Compound 1.21770 249.6285 Mo & Mo Compound 0.04100 8.4050 Ag 0.42640 87.4120 Cu 0.11890 24.3745 Cr & Cr Compound 0.04100 8.4050 Al 5.09630 1044.7415 Mn & Mn Compound 0.02460 5.0430 W & W Compound 0.19885 40.7643 Ni & Ni Compound 3.06680 628.6940 Fe 4.14715 850.1658 Chemical Substance Components Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 15 REV. DATE REASON No. 0 2013/06/07 New CONTENTS Tittle HSX321S Country of origin QUARTZ CRYSTAL SPECIFICATION Date Confirm 2013/06/07 F. S. TSAI Check Prepare Y. W. LEE U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY THAILAND FACTORY CHINA FACTORY Rev. Page X3S030000BA1H-U ELECTRONICS CORP. 0 16
X3S030000BA1H-U 价格&库存
很抱歉,暂时无法提供与“X3S030000BA1H-U”相匹配的价格&库存,您可以联系我们找货
X3S030000BA1H-U
    • 1+2.20839
    • 10+1.74572
    • 30+1.54743
    库存:1
