C42Q2105K9SC320
C42Q2105K9SC320
    FARATRONIC(法拉)
    插件,P=22.5mm
    安规电容 径向 305V
C42Q2105K9SC320 数据手册
 MKP62 Metallized polypropylene film interference suppression capacitor(Class X2, 305Vac/275Vac) ■ Outline Drawing 4pins W±0.4, H±0.4, T±0.4 Square-bottom 4pins W±0.4, H±0.4, T±0.4 4pins Arc-bottom ■ Features ●Metallized polypropylene structure ●Withstanding overvoltage stressing ● Excellent active and passive flame resistant abilities ● Used in across-the-line, interference suppression circuit. ■ Safety Approvals ● CQC IEC 60384-14:2013, X2, 305Vac/275Vac, 0.0010F50.0F, 40/110/56/B Certificate No.: CQC03001002875 ● ENEC-VDE EN 60384-14:2013,X2, 305Vac/275Vac, 0.0010F50.0F, 40/110/56/B Certificate No.: 40000358 ● UL-CUL ● KC UL 60384-14:2009 , CSA E60384-14:09 , X2, 305Vac/275Vac, 0.0010F50.0F, 40/110/56/B File No.: E186600, CCN: FOWX2/8 K60384-14(2006-12) , X2, 305Vac/275Vac, 0.0010F3.0F, 40/110/56/B Certificate No.: SU03060-12001A/12002/12003/12004  MKP62 ■ Specifications Class Climatic Category / Passive Flammability Category Temperature Range Operating Rated Voltage (UR) Maximum continuous DC voltage Capacitance Range Capacitance Tolerance Voltage Proof Insulation Resistance Dissipation Factor Class X2 40/110/56/B -40℃ ~ +110℃ 305Vac/275Vac,50/60Hz 630Vdc 0.0010F~25.0F 10(K), 20(M) Between Terminals 4.3UR(dc), 2s Between Terminals To Case R≥15 000M , CN≤0.33F RCN≥5 000s, CN0.33F 0.0010F≤CN0.010F 0.010F≤CN0.47F 0.47F≤CN≤1.0F 1.0FCN≤10.0F 10.0FCN≤50.0F 2 120Vac, 1min (20℃, 100V ,1min) ≤2010-4(1kHz,20℃) ≤1010-4(1kHz,20℃) ≤2010-4(1kHz,20℃) ≤3010-4(1kHz,20℃) ≤4010-4(1kHz,20℃) ≤2010-4(10kHz,20℃) ≤2010-4(10kHz,20℃) ≤4010-4(10kHz,20℃) -------------------------  MKP62 ■ Part number system The 18 digits part number is formed as follow: 1 2 3 C 4 2 4 Digit 1 to 3 5 6 7 8 9 10 11 1 2 1 3 14 1 5 1 6 1 7 1 8 Series code C42=MKP62 Digit 4 to 5 A.C. rated voltage Q2=305V P2=275V Digit 6 to 8 Rated capacitance value For example : 103=10×103 pF= 0.01μF Digit 9 Capacitance tolerance K=±10%, M=±20% Digit 10 Pitch 3=7.5mm B=27.5mm Digit 11 4=10.0mm 6=15.0mm F=37.5mm 9=22.5mm M=52.5mm Internal use Digit 12 to 15 Lead form and packaging code Digit 16 to 18 Internal use Table1 Lead form and packaging code Digit 12 code A C explanation ammo-pack straight lead “C” in the figure above D Insulated stranded leads E Insulated solid leads M Insulated stranded leads Box with mounting foot T P1=20.3mm±0.5mm Digit 13 code 3 4 6 explanation F=7.5mm F=10.0mm F=15.0mm Digit 14 code 0 explanation Straight code 1 5 code explanation 00 45 35 32 C5 K0 K2 L0 standard lead length (18mm~26mm) lead length 4.5mm lead length 3.5mm lead length 3.2mm 35mm 100mm 120mm 200mm Note 1:This length includes the stripping parts. Note 2:Normally, for P≥27.5 Caps can choice Insulated leads. 45 Digit 15 0 2 Length tolerance ±0.5mm or standard length Length tolerance ±0.3mm 1 Length tolerance -5 mm~0 mm 2 Length tolerance 0 mm~+5 mm 3 Length tolerance 0 mm~+10mm 4 Length tolerance ±5 mm lead length 4.5mm 0 3 P1=20mm±0.5mm 55 lead length 5.5mm explanation each cap. among two consecutive holes P3=12.7mm,H=18.5mm (For P=7.5mm) P3=25.4mm;H=18.5mm (For pitch=10/15mm) (Detail parameter refer to page 11) Length tolerance standard length ±0.5mm or  MKP62 ■ Dimensions(mm) 305Vac/275Vac# 305Vac/275Vac# 305Vac/275Vac# CN (F) 0.0010 0.0012 0.0015 0.0018 0.0022 0.0027 0.0033 0.0039 0.0047 0.0056 0.0068 0.0082 0.010 0.012 0.015 0.018 0.022 0.027 0.033 0.039 0.047 0.056 0.068 0.0047 0.0056 0.0068 0.0082 0.010 0.012 0.015 0.018 0.022 0.027 0.033 0.039 0.047 0.056 0.068 0.082 0.10M 0.10K 0.12 0.15 0.18 0.22M W 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 H 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 11.0 11.0 11.0 12.0 12.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 11.0 11.0 11.0 11.0 12.0 13.0 13.0 14.0 14.0 T 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.0 5.0 5.0 6.0 6.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.0 5.0 5.0 5.0 6.0 7.0 7.0 8.0 8.0 P 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 d 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 Part number C42Q2102-30****+++ C42Q2122-30****+++ C42Q2152-30****+++ C42Q2182-30****+++ C42Q2222-30****+++ C42Q2272-30****+++ C42Q2332-30****+++ C42Q2392-30****+++ C42Q2472-30****+++ C42Q2562-30****+++ C42Q2682-30****+++ C42Q2822-30****+++ C42Q2103-30****+++ C42Q2123-30****+++ C42Q2153-30****+++ C42Q2183-30****+++ C42Q2223-3S****+++ C42Q2273-3S****+++ C42Q2333-3S****+++ C42Q2393-3S****+++ C42Q2473-3S****+++ C42Q2563-3S****+++ C42Q2683-3S****+++ C42Q2472-40****+++ C42Q2562-40****+++ C42Q2682-40****+++ C42Q2822-40****+++ C42Q2103-40****+++ C42Q2123-40****+++ C42Q2153-40****+++ C42Q2183-40****+++ C42Q2223-40****+++ C42Q2273-40****+++ C42Q2333-4S****+++ C42Q2393-4S****+++ C42Q2473-4S****+++ C42Q2563-4S****+++ C42Q2683-4S****+++ C42Q2823-4S****+++ C42Q2104M4S****+++ C42Q2104K4S****+++ C42Q2124-4S****+++ C42Q2154-4S****+++ C42Q2184-4S****+++ C42Q2224M4S****+++ CN (F) 0.022 0.027 0.033 0.039 0.047 0.056 0.068 0.082 0.10M 0.10 0.12 0.15M 0.15K 0.18 0.22M 0.22K 0.22K 0.22K 0.27 0.33M 0.33K 0.33M 0.33M 0.33K 0.33 0.39 0.47M 0.47M 0.47K 0.56 0.60 0.68 0.82M 0.15 0.18 0.22 0.27 0.33 0.39 0.47M 0.47K 0.56 0.60 0.68 0.82 W 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 H 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 11.0 11.0 11.0 12.0 12.0 12.0 13.5 12.0 13.5 13.5 13.5 14.0 12.5 17.5 18.5 12.0 14.5 14.5 18.5 16.0 16.0 19.0 19.0 19.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 16.0 16.0 17.0 17.0 18.5 T 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 6.0 6.0 6.0 6.0 7.0 7.5 7.5 7.5 8.0 9.0 6.0 7.5 13.0 8.5 8.5 7.5 10.0 10.0 11.0 11.0 11.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 7.0 7.0 8.5 8.5 10.0 P 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 d 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.8 0.8 0.6 0.6 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 Part number C42Q2223-6A****+++ C42Q2273-6A****+++ C42Q2333-6A****+++ C42Q2393-6A****+++ C42Q2473-6A****+++ C42Q2563-6A****+++ C42Q2683-6A****+++ C42Q2823-6A****+++ C42Q2104M6A****+++ C42Q2104-6S****+++ C42Q2124-6S****+++ C42Q2154M6S****+++ C42Q2154K6S****+++ C42Q2184-6S****+++ C42Q2224M6S****+++ C42Q2224K6B****+++ C42Q2224K6C****+++ C42Q2224K6S****+++ C42Q2274-6S****+++ C42Q2334M6S****+++ C42Q2334K6S****+++ C42Q2334M6A****+++ C42Q2334M6B****+++ C42Q2334K6A****+++ C42Q2334-6C****+++ C42Q2394-6S****+++ C42Q2474M6S****+++ C42Q2474M6A****+++ C42Q2474K6S****+++ C42Q2564-6A****+++ C42Q2604-6S****+++ C42Q2684-6S****+++ C42Q2824M6S****+++ C42Q2154-90****+++ C42Q2184-90****+++ C42Q2224-9S****+++ C42Q2274-9S****+++ C42Q2334-9S****+++ C42Q2394-9S****+++ C42Q2474M9S****+++ C42Q2474K9S****+++ C42Q2564-9S****+++ C42Q2604-9S****+++ C42Q2684-9S****+++ C42Q2824-9S****+++ CN (F) 0.39 0.47 0.56 0.68 0.82 1.0 1.0 1.2 1.5 1.8 2.2M 2.2K ★2.2 2.7 3.3 3.3M 3.3K ★3.3M ★3.3K 3.9 3.9 4.7M ★4.7M 4.7K 4.7 5.6 6.8M 1.5 1.8 2.2 2.2 2.7 3.3 3.3 3.3 3.9 4.7M 4.7K 4.7 5.6 6.8 6.8 8.2 10.0M 10.0K W 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 32.0 41.0 41.0 41.0 42.0 41.0 41.0 42.0 42.0 41.0 42.0 41.0 41.0 41.0 41.0 42.0 41.0 41.0 41.0 H 18.0 18.0 18.0 18.0 18.0 18.0 12.0 20.0 20.0 22.0 22.0 25.0 16.0 28.0 30.0 24.5 28.0 16.0 18.5 29.0 33.0 33.0 18.5 33.0 30.0 37.0 37.0 22.0 22.0 24.0 15.0 24.0 26.0 28.0 15.0 30.0 19.0 20.0 30.0 33.5 33.5 24.0 37.0 37.0 41.0 T 9.0 9.0 9.0 9.0 9.0 9.0 18.0 11.0 11.0 13.0 13.0 13.0 22.0 14.0 16.0 15.0 17.0 27.5 31.0 19.0 18.0 18.0 31.0 18.0 21.0 22.0 22.0 11.0 11.0 13.0 24.0 13.0 15.0 14.0 24.0 16.0 24.0 26.0 16.0 18.5 18.5 32.0 22.0 22.0 26.0 P 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5 d 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 Part number C42Q2394-B0****+++ C42Q2474-B0****+++ C42Q2564-B0****+++ C42Q2684-B0****+++ C42Q2824-BS****+++ C42Q2105-BS****+++ C42Q2105-BC****+++ C42Q2125-BS****+++ C42Q2155-BS****+++ C42Q2185-BS****+++ C42Q2225MBS****+++ C42Q2225KBS****+++ C42Q2225-BC****+++ C42Q2275-BS****+++ C42Q2335-BA****+++ C42Q2335MBB****+++ C42Q2335KBB****+++ C42Q2335MBC****+++ C42Q2335KBC****+++ C42Q2395-BA****+++ C42Q2395-BS****+++ C42Q2475MBS****+++ C42Q2475MBC****+++ C42Q2475KBA****+++ C42Q2475-BB****+++ C42Q2565-BS****+++ C42Q2685MBS****+++ C42Q2155-FS****+++ C42Q2185-FS****+++ C42Q2225-FS****+++ C42Q2225-FC****+++ C42Q2275-FS****+++ C42Q2335-FA****+++ C42Q2335-FS****+++ C42Q2335-FC****+++ C42Q2395-FS****+++ C42Q2475MFC****+++ C42Q2475KFC****+++ C42Q2475-FS****+++ C42Q2565-FS****+++ C42Q2685-FS****+++ C42Q2685-FC****+++ C42Q2825-FS****+++ C42Q2106MFS****+++ C42Q2106KFS****+++ 0.010 0.012 0.015 0.018 17.5 17.5 17.5 17.5 9.5 9.5 9.5 9.5 5.0 5.0 5.0 5.0 15.0 15.0 15.0 15.0 0.6 0.6 0.6 0.6 C42Q2103-6A****+++ C42Q2123-6A****+++ C42Q2153-6A****+++ C42Q2183-6A****+++ 1.0 1.2 1.5M 1.5K 1.8 2.2 2.2 26.5 26.5 26.5 26.5 26.5 26.5 26.5 18.5 20.0 20.0 22.0 24.5 24.5 29.5 10.0 11.0 11.0 12.0 15.5 15.5 14.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 0.8 0.8 0.8 0.8 0.8 0.8 0.8 C42Q2105-9S****+++ 10.0K C42Q2125-9S****+++ 12.0 C42Q2155M9S****+++ 15.0 C42Q2155K9S****+++ 20.0 C42Q2185-9S****+++ 20.0 C42Q2225-9S****+++ 20.0 C42Q2225-9A****+++ 25.0 41.5 41.0 42.0 42.0 57.0 57.0 57.0 37.5 43.0 45.0 57.5 45.0 30.0 50.0 27.5 28.0 30.0 30.0 30.0 44.0 35.0 37.5 37.5 37.5 37.5 52.5 52.5 52.5 1.0 1.0 1.0 1.0 1.2 1.2 1.2 C42Q2106KFA****+++ C42Q2126-FS****+++ C42Q2156-FS****+++ C42Q2206-FS****+++ C42Q2206-MST***+++ C42Q2206-MCT***+++ C42Q2256-MST***+++ Note: 1. “-”=capacitance tolerance code, M=±20%, K=±10% 2. “****”=lead form and packaging mode code (refer to table 1) 3. “#”when the rated voltage is 275Vac, the digit 4~5 is P2. 4. Not for use in series with the mains, the capacitors for series with the mains please refer to A.C. Capacitors for Capacitive Divider. 5. “★” = Arc bottom of the outer shell.  MKP62 ■ Maximum permissible voltage change per unit of time Rated Voltage (Vac) P=7.5mm P=10mm P=15mm P=22.5mm P=27.5mm P=37.5mm P=52.5mm 305 500 500 400 200 150 100 50 dV/dt(V/us) at 440 Vdc Note: 1. Rated voltage pulse slope (dV/dt)R at rated voltage. 2. If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR/U. ■ Impedance Vs. Frequency TYPICAL GRAPHS Z=f(f) Typical values ■ Quality ensuring test (before shipment): Inspection item(each batch) Inspection level (GB/T 2828.1, ISO2859-1) IL AQL II 1.5 II 0.25 S-3 2.5 Appearance inspection Dimensions Capacitance Tangent of the loss angle Dielectric strength Insulation resistance Solderability  MKP62 ■ Test Method And Performance No. Item 1 4.5 Solderability 2 4.3 Terminal strength 3 4.4 Resistance to solder heat 4 Test Method (IEC 60384-14) Performance 4.20 Solvent resistance of the marking 4.2 Initial measurement 4.6 Rapid change of temperature Good quality of tinning Solder temperature: 245˚C 5˚C Immersion time: 2.0s0.5s There shall be no visible damage Tense: 0.50d≤0.80, 10N 0.80d≤1.25, 20N Bend: 0.50d≤0.80, 5N 0.80d≤1.25, 10N The terminals shall be bent 2 times in each direction There shall be no visible damage C/C 5(relative to the initial value) Solder temperature:260˚C5˚C Immersion time: 10s1s The marking shall be legible Solvent: Industrial isopropanol. Solvent temperature:23˚C±5˚C Dipping time: 5min0.5min Condition: scrub Scrub material: absorbent cotton Reverting time: No Capacitance, Tg There shall be no evidence of deterioration. 4.7 Vibration There shall be no evidence of deterioration. 4.8 Bump There shall be no evidence of deterioration. 5 Final measurement TA=-40˚C, TB =+110˚C Duration: t=30min 5 cycles Amplitude 0.75mm or acceleration 100m/s2 (whichever is the smaller severity), f: 10Hz to 500Hz.Three directions, 2h for each direction, total 6h. 4 000 times, Acceleration: 400m/s2, Pulse duration, 6ms There shall be no visible damage C/C5(relative to the initial value) Initial measurement +110℃, 16h Dry heat Damp heat, Cyclic Test Db, Severity: b, the first cycle -40℃, 2h Cold 6 4.11 Climate sequence Damp heat, cyclic other Final measurement Test Db, Severity b, the other cycles There shall be no visible damage, legible marking C/C5(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) Dielectric strength : there shall be no permanent breakdown or flashover I.R.:  50 of the rated value  MKP62 No. 7 8 Item Performance 4.12 Damp heat steady state There shall be no visible damage, legible marking C/C 5(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) Dielectric strength : there shall be no permanent breakdown or flashover I.R.:  50 of the rated value 4.13 Impulse voltage There are three or more waveforms which indicate that no self-heating breakdown have occurred when it is monitored by the monitor Test Method (IEC 60384-14) Temperature: 40˚C 2˚C Humidity: 933RH Duration: 56 days Each individual capacitor shall be subjected to 24 impulses of the same polarity (when any three successive impulses are shown by the monitor to have a wave form indicating that no self-healing breakdown have taken place the impulses can be stopped), the time between impulses shall not be less than 10S, and the peak value of the voltage impulse: 2.5kV(suitable for CN 1F; When CN1F, the capacitor can endure pulse voltage value is 2.5 / CN kV) 9 4.14 Endurance There shall be no visible damage, legible marking C/C10(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) Dielectric strength : There shall be no breakdown or flashover I.R. :  50 of the rated value +110˚C, 1.25URVa.c., 1 000h The voltage shall be subjected to 1000Vrms for 0.1s every one hour during test. Times: 10 000 Duration of charging: 0.5s Duration of discharging: 0.5s 10 11 4.15 Charging and discharging 4.17 Passive flammability C/C 10(relative to the initial value) Increase of tg: CN1F: 0.008 (10kHz) CN1F: 0.005 (1kHz) I.R.:  50 of the rated value The flaming time of each capacitor shall not go beyond 10s after it is taken apart from the flame. Drop of each capacitor caused by flame shall not fire the tissue below. Charging voltage: 2 UR Vd.c. Charging resistance: 220/CN() or the current ≤1.0A (whichever is the minor) Discharging resistance: 2UR R () dU CN  dt CN: Capacitance (F) dU/dt(V/us) : 100V/s Ref.item 4.17 Needle flame test The category of flammability: B Expose time: 1 time Capacitor Volume Exposing time 250
C42Q2105K9SC320 价格&库存
很抱歉,暂时无法提供与“C42Q2105K9SC320”相匹配的价格&库存,您可以联系我们找货
C42Q2105K9SC320
  • 1+2.08760
  • 10+1.78320
  • 30+1.54890
  • 100+1.41420
  • 600+1.34690
库存:95
