C1005X7R102KGT
C1005X7R102KGT
    DARFON(达方)
    贴片电容(MLCC) 0402
C1005X7R102KGT 数据手册
MLCC CONTENT (MLCC) E STANDARD NUMBER ................................................................................................................................................................ 3 STRUCTURE ................................................................................................................................................................................ 4 GENERAL PURPOSE .................................................................................................................................................................... 5  CLASS I: TEMPERATURE COMPENSATING TYPE ............................................................................................................................ 6  CLASS II: HIGH DIELECTRIC CONSTANT TYPE ............................................................................................................................. 15  X5R Series .................................................................................................................................................................. 15  X6S Series .................................................................................................................................................................. 22  X6T Series .................................................................................................................................................................. 24  X7R Series .................................................................................................................................................................. 25  X7S Series .................................................................................................................................................................. 37  X7T Series .................................................................................................................................................................. 38  X7U Series.................................................................................................................................................................. 40  X8R Series .................................................................................................................................................................. 41  TEST SPEC. ........................................................................................................................................................................ 42 PACKAGE .................................................................................................................................................................................. 46 OTHERS .................................................................................................................................................................................... 50 E Standard Number E3  1.0  E6  E12  2.2  1.0  1.0  1.5  1.2  1.5  4.7  2.2  1.8  2.2  3.3  2.7  3.3  4.7  3.9  4.7  6.8  5.6  6.8  8.2  E24  1.0  1.1  1.2  1.3  1.5  1.6  1.8  2.0  2.2  2.4  2.7  3.0  3.3  3.6  3.9  4.3  4.7  5.1  5.6  6.2  6.8  7.5  8.2  9.1    3  Rev. 202204 MLCC  ORDERING CODE ........................................................................................................................................................................ 4 Structure Class I: CaZrO3  Class II: BaTiO3    Ordering Code C 1005 NP0 101 J G T S △     PRODUCT CODE  C    =    MLCC  SIZE in mm (EIA CODE, in inch)   0402(01005)      0603(0201)      1005 (0402)      1608 (0603)    3216 (1206)        3225(1210)        4520 (1808)  4520 (1808) 4532 (1812)  2012 (0805)    T. C.  NP0: 0 ± 30ppm/℃    -55℃  to +125℃           X5R: ±15%      -55℃  to +85℃  X7R: ±15%    X7S:±22%    X7T: +22%/-33 33%    X7U: +22%/-56%      -55℃  to +125℃  X6S: ±22%   X6T: +22%/-33%    -55℃   to +105℃          CAPACITANCE CODE  Examples:  Expressed in pico-farads and identified by a three farads and identified by a three-digit number.    First two digits represent significant figures.    Last digit specifies the number of zeros.  (Use 9 for 1.0 through 9.9pF;  Use 8 for 0.20 0 through 0.99pF)        Code  Cap (pF)  478  0.47  229  2.2  101  100  102  1000  TOLERANCE CODE  A: ± 0.05pF    J: ±5%  B: ± 0.1pF  K: ±10%  C: ± 0.25pF     M: ±20%      D: ± 0.5pF      F: ±1%  G: ±2%  N: 35V        G: 50V    Q: 2KV        R: 3KV  H: 100V  S: 4KV  VOLTAGE CODE  B: 4V  C: 6.3V  D: 10V    E: 16V   J: 200V  K: 250V  L: 500V  M: 630V   F: 25V    P: 1KV  PACKAGING CODE  T: Paper tape reel Ø180mm (7”)    N: Paper tape reel Ø250mm (10”)    A: Paper tape reel Ø330mm (13”)    W: Special Packing              P: Embossed tape reel Ø180mm (7”)    D: Embossed tape reel Ø250mm (10”)  E: Embossed tape reel Ø330mm (13”)    Application Code  S: Standard     Q: High Q/Low ESR  F: Microwave Microwave A: Automotive Infotainment with AEC-Q200  Thickness Code  Code Thick(mm) Code Thick (mm) Code Thick (mm) (blank) Code Standard Thick    Thick (mm) M 0.70 0.70  G 1.25  S 1.90   Z 0.20  D 0.80 0.80  H 1.50  -- --   A 0.30  E 0.85 0.85  L 1.60  -- --   Q 0.45  I 0.95 0.95  N 2.00  -- --   B 0.50  J 1.00 1.00  P 2.50  -- --   C 0.60  F 1.15 1.15  R 3.20  -- --       4 General Purpose   Standard External Dimensions External Dimensions      MLCC    General Purpose      TYPE Size (EIA Size) C0603  (0201)  C1005  (0402)  C1608  (0603)  C2012  (0805)  C3216  (1206)  C3225  (1210)  Dimension (mm) Kind L (Length) W (Width) Standard Standard  Special (1) (1)  Special (2) (2)  Standard Standard  Special (1) Special (1)  Special (2) Special (2)  Special (3) Special (3)  Special (4 4)  Standard Standard  Special (1) Special (1)  Special (2) Special (2)  Special (3 Special (3)  Standard Standard  Special (1) Special (1)  Standard Standard  Special (1) Special (1)  Special (2) Special (2)  Standard Standard  Special (1) Special (1)  0.6 ± 0.03  0.6 ± 0.05  0.6 ± 0.09  1.0 ± 0.05  1.0 ± 0.10  1.0 ± 0.15  1.0 ± 0.20  1.0 ± 0.30  1.6 ± 0.10  1.6 ± 0.15  1.6 ± 0.20  1.6 ± 0.25  2.0 ± 0.15  2.0 ± 0.20  3.2 ± 0.15  3.2 ± 0.20  3.2 ± 0.30  3.2 ± 0.30  3.2 ± 0.30  0.30 ± 0.03  0.30 ± 0.05  0.30 ± 0.09  0.50 ± 0.05  0.50 ± 0.10  0.50 ± 0.15  0.50 ± 0.20  0.50 ± 0.30  0.80 ± 0.10  0.80 ± 0.15  0.80 ± 0.20  0.80 ± 0.25  1.25 ± 0.15  1.25 ± 0.20  1.60 ±0.15  1.60 ±0.20  1.60 ±0.30  2.50 ± 0.20  2.50 ± 0.30  T (Max.) 0.33  0.35  0.39  0.55  0.60  0.65  0.70  0.80  0.90  0.95  1.00  1.05  1.45  1.45  1.80  1.90  1.90  2.80  2.80  g (Min) 0.15  A (Min/Max) 0.10 / 0.20 0.10 / 0.20  0.10  0.10 / 0.25  0.30  0.15 / 0.35 0.15 / 0.35  0.50  0.25 / 0.65 0.25 / 0.65  0.70  0.25 / 0.75 0.25 / 0.75  1.50  0.25 / 0.75 0.25 / 0.75  1.50  0.3 / 0.90 0.3 / 0.90      For special parts, please see the “Part Number & Characteristic” see the “Part Number & Characteristic” for detail specification.      5   Rev. 202204   Class I: Temperature Compensating Type     Feature   Application 1.  2.  3.  4.  5.  6.  7.  1.  2.  3.  Ultra-stable  Tight tolerance available  Low ESR (Frequency is within 800MHz)  Good frequency performance  No aging of capacitance  RoHS compliant  Halogen Free  LC and RC tuned circuit  Filtering  Timing      Part Number & Characteristic   C0603NP0_S Series (EIA0201)  RV DARFON P/N DARFON P/N 2 Measuring Condition 50V C0603NP0208□ GTS C0603NP0308□ GTS C0603NP0408□ GTS C0603NP0508□ GTS C0603NP0608□ GTS C0603NP0708□ GTS C0603NP0758□ GTS C0603NP0808□ GTS C0603NP0908□ GTS C0603NP0109□ GTS C0603NP0119□ GTS C0603NP0129□ GTS C0603NP0139□ GTS C0603NP0159□ GTS C0603NP0169□ GTS C0603NP0189□ GTS C0603NP0209□ GTS C0603NP0229□ GTS C0603NP0249□ GTS C0603NP0279□ GTS C0603NP0309□ GTS C0603NP0339□ GTS C0603NP0359□ GTS C0603NP0369□ GTS C0603NP0399□ GTS C0603NP0409□ GTS C0603NP0439□ GTS C0603NP0479□ GTS C0603NP0509□ GTS C0603NP0519□ GTS C0603NP0569□ GTS C0603NP0609□ GTS C0603NP0629□ GTS C0603NP0689□ GTS C0603NP0709□ GTS C0603NP0759□ GTS C0603NP0809□ GTS C0603NP0829□ GTS C0603NP0909□ GTS C0603NP0919□ GTS C0603NP0100□ GTS C0603NP0120□ GTS C0603NP0150□ GTS C0603NP0180□ GTS C0603NP0200□ GTS C0603NP0220□ GTS C0603NP0240JGTS C0603NP0270□ GTS C0603NP0300□ GTS C0603NP0330□ GTS C0603NP0360□ GTS C0603NP0390□ GTS C0603NP0430JGTS C0603NP0470□ GTS C0603NP0510□ GTS C0603NP0560□ GTS C0603NP0620□ GTS C0603NP0680□ GTS C0603NP0750□ GTS C0603NP0208□ GT C0603NP0308□ GT C0603NP0408□ GT C0603NP0508□ GT C0603NP0608□ GT C0603NP0708□ GT C0603NP0758□ GT C0603NP0808□ GT C0603NP0908□ GT C0603NP0109□ GT C0603NP0119□ GT C0603NP0129□ GT C0603NP0139□ GT C0603NP0159□ GT C0603NP0169□ GT C0603NP0189□ GT C0603NP0209□ GT C0603NP0229□ GT C0603NP0249□ GT C0603NP0279□ GT C0603NP0309□ GT C0603NP0339□ GT C0603NP0359□ GT C0603NP0369□ GT C0603NP0399□ GT C0603NP0409□ GT C0603NP0439□ GT C0603NP0479□ GT C0603NP0509□ GT C0603NP0519□ GT C0603NP0569□ GT C0603NP0609□ GT C0603NP0629□ GT C0603NP0689□ GT C0603NP0709□ GT C0603NP0759□ GT C0603NP0809□ GT C0603NP0829□ GT C0603NP0909□ GT C0603NP0919□ GT C0603NP0100□ GT C0603NP0120□ GT C0603NP0150□ GT C0603NP0180□ GT C0603NP0200□ GT C0603NP0220□ GT C0603NP0240JGT C0603NP0270□ GT C0603NP0300□ GT C0603NP0330□ GT C0603NP0360□ GT C0603NP0390□ GT C0603NP0430JGT C0603NP0470□ GT C0603NP0510□ GT C0603NP0560□ GT C0603NP0620□ GT C0603NP0680□ GT C0603NP0750□ GT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 0.20 pF 0.30 pF 0.40 pF 0.50 pF 0.60 pF 0.70 pF 0.75 pF 0.80 pF 0.90 pF 1.0 pF 1.1 pF 1.2 pF 1.3 pF 1.5 pF 1.6 pF 1.8 pF 2.0 pF 2.2 pF 2.4 pF 2.7 pF 3.0 pF 3.3 pF 3.5 pF 3.6 pF 3.9 pF 4.0 pF 4.3 pF 4.7 pF 5.0 pF 5.1 pF 5.6 pF 6.0 pF 6.2 pF 6.8 pF 7.0 pF 7.5 pF 8.0 pF 8.2 pF 9.0 pF 9.1 pF 10 pF 12 pF 15 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 36 pF 39 pF 43 pF 47 pF 51 pF 56 pF 62 pF 68 pF 75 pF Available Tolerance Thick. (mm) ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2% ±5%,±2%,±1% ±5% ±5%,±2%,±1% ±5%,±2% ±5%,±2%,±1% ±5%,±2% ±5%,±2%,±1% ±5%,±2% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 6 Tolerance(mm) L/W ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 Thick. ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 DF (max.) Standard Packing 0.25% 0.25% 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.18% 0.17% 0.17% 0.17% 0.16% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Paper,15Kpcs 25V   DARFON P/N 2 Measuring Condition C0603NP0820□ GTS C0603NP0101□ GTS C0603NP0121□ GTS C0603NP0151□ GTS C0603NP0181□ GTS C0603NP0201JGTS C0603NP0221□ GTS C0603NP0271JGTS C0603NP0331JGTS C0603NP0391JGTS C0603NP0471JGTS C0603NP0208□ FTS C0603NP0308□ FTS C0603NP0408□ FTS C0603NP0508□ FTS C0603NP0608□ FTS C0603NP0708□ FTS C0603NP0758□ FTS C0603NP0808□ FTS C0603NP0908□ FTS C0603NP0109□ FTS C0603NP0129□ FTS C0603NP0139□ FTS C0603NP0149□ FTS C0603NP0159□ FTS C0603NP0169□ FTS C0603NP0179□ FTS C0603NP0189□ FTS C0603NP0199□ FTS C0603NP0209□ FTS C0603NP0229□ FTS C0603NP0249□ FTS C0603NP0279□ FTS C0603NP0309□ FTS C0603NP0339□ FTS C0603NP0359□ FTS C0603NP0369□ FTS C0603NP0399□ FTS C0603NP0409□ FTS C0603NP0439□ FTS C0603NP0479□ FTS C0603NP0509□ FTS C0603NP0519□ FTS C0603NP0569□ FTS C0603NP0609□ FTS C0603NP0629□ FTS C0603NP0689□ FTS C0603NP0709□ FTS C0603NP0759□ FTS C0603NP0809□ FTS C0603NP0829□ FTS C0603NP0909□ FTS C0603NP0919□ FTS C0603NP0100□ FTS C0603NP0120□ FTS C0603NP0150□ FTS C0603NP0160□ FTS C0603NP0180□ FTS C0603NP0200□ FTS C0603NP0220□ FTS C0603NP0240□ FTS C0603NP0270□ FTS C0603NP0300□ FTS C0603NP0330□ FTS C0603NP0390□ FTS C0603NP0470□ FTS C0603NP0560□ FTS C0603NP0680□ FTS C0603NP0820□ FTS C0603NP0101□ FTS C0603NP0121JFTS C0603NP0151JFTS C0603NP0181JFTS C0603NP0221JFTS C0603NP0271JFTS C0603NP0331□ FTS C0603NP0391JFTS C0603NP0471□ FTS C0603NP0820□ GT C0603NP0101□ GT C0603NP0121□ GT C0603NP0151□ GT C0603NP0181□ GT C0603NP0201JGT C0603NP0221□ GT C0603NP0271JGT C0603NP0331JGT C0603NP0391JGT C0603NP0471JGT C0603NP0208□ FT C0603NP0308□ FT C0603NP0408□ FT C0603NP0508□ FT C0603NP0608□ FT C0603NP0708□ FT C0603NP0758□ FT C0603NP0808□ FT C0603NP0908□ FT C0603NP0109□ FT C0603NP0129□ FT C0603NP0139□ FT C0603NP0149□ FT C0603NP0159□ FT C0603NP0169□ FT C0603NP0179□ FT C0603NP0189□ FT C0603NP0199□ FT C0603NP0209□ FT C0603NP0229□ FT C0603NP0249□ FT C0603NP0279□ FT C0603NP0309□ FT C0603NP0339□ FT C0603NP0359□ FT C0603NP0369□ FT C0603NP0399□ FT C0603NP0409□ FT C0603NP0439□ FT C0603NP0479□ FT C0603NP0509□ FT C0603NP0519□ FT C0603NP0569□ FT C0603NP0609□ FT C0603NP0629□ FT C0603NP0689□ FT C0603NP0709□ FT C0603NP0759□ FT C0603NP0809□ FT C0603NP0829□ FT C0603NP0909□ FT C0603NP0919□ FT C0603NP0100□ FT C0603NP0120□ FT C0603NP0150□ FT C0603NP0160□ FT C0603NP0180□ FT C0603NP0200□ FT C0603NP0220□ FT C0603NP0240□ FT C0603NP0270□ FT C0603NP0300□ FT C0603NP0330□ FT C0603NP0390□ FT C0603NP0470□ FT C0603NP0560□ FT C0603NP0680□ FT C0603NP0820□ FT C0603NP0101□ FT C0603NP0121JFT C0603NP0151JFT C0603NP0181JFT C0603NP0221JFT C0603NP0271JFT C0603NP0331□ FT C0603NP0391JFT C0603NP0471□ FT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 82 pF 100 pF 120 pF 150 pF 180 pF 200 pF 220 pF 270 pF 330 pF 390 pF 470 pF 0.20 pF 0.30 pF 0.40 pF 0.50 pF 0.60 pF 0.70 pF 0.75 pF 0.80 pF 0.90 pF 1.0 pF 1.2 pF 1.3 pF 1.4 pF 1.5 pF 1.6 pF 1.7 pF 1.8 pF 1.9 pF 2.0 pF 2.2 pF 2.4 pF 2.7 pF 3.0 pF 3.3 pF 3.5 pF 3.6 pF 3.9 pF 4.0 pF 4.3 pF 4.7 pF 5.0 pF 5.1 pF 5.6 pF 6.0 pF 6.2 pF 6.8 pF 7.0 pF 7.5 pF 8.0 pF 8.2 pF 9.0 pF 9.1 pF 10 pF 12 pF 15 pF 16 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF Available Tolerance Thick. (mm) ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2% ±5%,±2% ±5%,±2% ±5% ±5%,±2% ±5% ±5% ±5% ±5% ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5% ±5% ±5% ±5% ±5% ±5%,±2% ±5% ±5%,±2%,±1% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 7  Tolerance(mm) L/W ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 Thick. ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 DF (max.) 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.25% 0.25% 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.18% 0.17% 0.17% 0.17% 0.16% 0.14% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Standard Packing Paper,15Kpcs MLCC  50V DARFON P/N General Purpose  RV Paper,15Kpcs Rev. 202204 RV 25V 16V 10V DARFON P/N DARFON P/N 2 Measuring Condition C0603NP0561JFTS C0603NP0681JFTS C0603NP0102JFTS C0603NP0279□ ETS C0603NP0330□ ETS C0603NP0201JETS C0603NP0221JETS C0603NP0330□ DTS C0603NP0561JFT C0603NP0681JFT C0603NP0102JFT C0603NP0279□ ET C0603NP0330□ ET C0603NP0201JET C0603NP0221JET C0603NP0330□ DT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 560 pF 680 pF 1.0 nF 2.7 pF 33 pF 200 pF 220 pF 33 pF Available Tolerance Thick. (mm) ±5% ±5% ±5% ±0.25pF,±0.1pF ±5%,±2%,±1% ±5% ±5% ±5%,±2%,±1% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 8 Tolerance(mm) L/W ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 Thick. ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 DF (max.) 0.10% 0.10% 0.10% 0.22% 0.10% 0.10% 0.10% 0.10% Standard Packing Paper,15Kpcs Paper,15Kpcs Paper,15Kpcs   C1005NP0_S Series (EIA0402)  DARFON P/N 2 Measuring Condition 50V C1005NP0208□ GTS C1005NP0308□ GTS C1005NP0408□ GTS C1005NP0508□ GTS C1005NP0608□ GTS C1005NP0688□ GTS C1005NP0708□ GTS C1005NP0808□ GTS C1005NP0828□ GTS C1005NP0908□ GTS C1005NP0109□ GTS C1005NP0129□ GTS C1005NP0139□ GTS C1005NP0159□ GTS C1005NP0169□ GTS C1005NP0189□ GTS C1005NP0209□ GTS C1005NP0229□ GTS C1005NP0249□ GTS C1005NP0259□ GTS C1005NP0279□ GTS C1005NP0309□ GTS C1005NP0339□ GTS C1005NP0359□ GTS C1005NP0369□ GTS C1005NP0399□ GTS C1005NP0409□ GTS C1005NP0439□ GTS C1005NP0479□ GTS C1005NP0509□ GTS C1005NP0519□ GTS C1005NP0569□ GTS C1005NP0609□ GTS C1005NP0629□ GTS C1005NP0689□ GTS C1005NP0709□ GTS C1005NP0759□ GTS C1005NP0809□ GTS C1005NP0829□ GTS C1005NP0909□ GTS C1005NP0919□ GTS C1005NP0100□ GTS C1005NP0110□ GTS C1005NP0120□ GTS C1005NP0130□ GTS C1005NP0150□ GTS C1005NP0160□ GTS C1005NP0180□ GTS C1005NP0200□ GTS C1005NP0220□ GTS C1005NP0240□ GTS C1005NP0270□ GTS C1005NP0300□ GTS C1005NP0330□ GTS C1005NP0360□ GTS C1005NP0390□ GTS C1005NP0430□ GTS C1005NP0470□ GTS C1005NP0510□ GTS C1005NP0560□ GTS C1005NP0620□ GTS C1005NP0680□ GTS C1005NP0750□ GTS C1005NP0820□ GTS C1005NP0910□ GTS C1005NP0101□ GTS C1005NP0121□ GTS C1005NP0131JGTS C1005NP0151□ GTS C1005NP0181□ GTS C1005NP0201□ GTS C1005NP0221□ GTS C1005NP0208□ GT C1005NP0308□ GT C1005NP0408□ GT C1005NP0508□ GT C1005NP0608□ GT C1005NP0688□ GT C1005NP0708□ GT C1005NP0808□ GT C1005NP0828□ GT C1005NP0908□ GT C1005NP0109□ GT C1005NP0129□ GT C1005NP0139□ GT C1005NP0159□ GT C1005NP0169□ GT C1005NP0189□ GT C1005NP0209□ GT C1005NP0229□ GT C1005NP0249□ GT C1005NP0259□ GT C1005NP0279□ GT C1005NP0309□ GT C1005NP0339□ GT C1005NP0359□ GT C1005NP0369□ GT C1005NP0399□ GT C1005NP0409□ GT C1005NP0439□ GT C1005NP0479□ GT C1005NP0509□ GT C1005NP0519□ GT C1005NP0569□ GT C1005NP0609□ GT C1005NP0629□ GT C1005NP0689□ GT C1005NP0709□ GT C1005NP0759□ GT C1005NP0809□ GT C1005NP0829□ GT C1005NP0909□ GT C1005NP0919□ GT C1005NP0100□ GT C1005NP0110□ GT C1005NP0120□ GT C1005NP0130□ GT C1005NP0150□ GT C1005NP0160□ GT C1005NP0180□ GT C1005NP0200□ GT C1005NP0220□ GT C1005NP0240□ GT C1005NP0270□ GT C1005NP0300□ GT C1005NP0330□ GT C1005NP0360□ GT C1005NP0390□ GT C1005NP0430□ GT C1005NP0470□ GT C1005NP0510□ GT C1005NP0560□ GT C1005NP0620□ GT C1005NP0680□ GT C1005NP0750□ GT C1005NP0820□ GT C1005NP0910□ GT C1005NP0101□ GT C1005NP0121□ GT C1005NP0131JGT C1005NP0151□ GT C1005NP0181□ GT C1005NP0201□ GT C1005NP0221□ GT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 0.20 pF 0.30 pF 0.40 pF 0.50 pF 0.60 pF 0.68 pF 0.70 pF 0.80 pF 0.82 pF 0.90 pF 1.0 pF 1.2 pF 1.3 pF 1.5 pF 1.6 pF 1.8 pF 2.0 pF 2.2 pF 2.4 pF 2.5 pF 2.7 pF 3.0 pF 3.3 pF 3.5 pF 3.6 pF 3.9 pF 4.0 pF 4.3 pF 4.7 pF 5.0 pF 5.1 pF 5.6 pF 6.0 pF 6.2 pF 6.8 pF 7.0 pF 7.5 pF 8.0 pF 8.2 pF 9.0 pF 9.1 pF 10 pF 11 pF 12 pF 13 pF 15 pF 16 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 36 pF 39 pF 43 pF 47 pF 51 pF 56 pF 62 pF 68 pF 75 pF 82 pF 91 pF 100 pF 120 pF 130 pF 150 pF 180 pF 200 pF 220 pF Available Tolerance Thick. (mm) ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.5pF,±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.5pF,±0.25pF,±0.1pF,±0.05pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2% ±5%,±2%,±1% ±5%,±2%,±1% ±10%,±5%,±2%,±1% ±5%,±2%,±1% ±10% ,±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±10% ,±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±10% ,±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±10% ,±5%,±2%,±1% ±10% ,±5%,±2%,±1% ±5% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) Standard Packing 0.25% 0.25% 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.18% 0.17% 0.17% 0.17% 0.16% 0.16% 0.15% 0.14% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Paper, 10Kpcs MLCC  DARFON P/N General Purpose  RV     □ Tolerance Code: A=±0.05 pF, B=±0.1pF, C=±0.25pF ,D=±0.5pF, F=±1%, G=±2%, J=±5%; Special tolerance on the request.    9  Rev. 202204 RV 50V 25V 16V 10V DARFON P/N DARFON P/N 2 Measuring Condition C1005NP0271□ GTS C1005NP0301□ GTS C1005NP0331□ GTS C1005NP0391□ GTS C1005NP0471□ GTS C1005NP0561□ GTS C1005NP0681□ GTS C1005NP0751JGTS C1005NP0821□ GTS C1005NP0102□ GTS C1005NP0152JGTS C1005NP0208□ FTS C1005NP0308□ FTS C1005NP0508□ FTS C1005NP0169BFTS C1005NP0689□ FTS C1005NP0100JFTS C1005NP0120□ FTS C1005NP0160JFTS C1005NP0180KFTS C1005NP0220JFTS C1005NP0240JFTS C1005NP0270JFTS C1005NP0330□ FTS C1005NP0470JFTS C1005NP0560JFTS C1005NP0101JFTS C1005NP0201JFTS C1005NP0221□ FTS C1005NP0271JFTS C1005NP0331JFTS C1005NP0471JFTS C1005NP0561JFTS C1005NP0102JFTS C1005NP0152JFTS C1005NP0182JFTS C1005NP0222JFTS C1005NP0109BETS C1005NP0129BETS C1005NP0209BETS C1005NP0100JETS C1005NP0150□ ETS C1005NP0220FETS C1005NP0300JETS C1005NP0470□ ETS C1005NP0101JETS C1005NP0331□ ETS C1005NP0471JETS C1005NP0102JETS C1005NP0220□ DTS C1005NP0271□ GT C1005NP0301□ GT C1005NP0331□ GT C1005NP0391□ GT C1005NP0471□ GT C1005NP0561□ GT C1005NP0681□ GT C1005NP0751JGT C1005NP0821□ GT C1005NP0102□ GT C1005NP0152JGT C1005NP0208□ FT C1005NP0308□ FT C1005NP0508□ FT C1005NP0169BFT C1005NP0689□ FT C1005NP0100JFT C1005NP0120□ FT C1005NP0160JFT C1005NP0180KFT C1005NP0220JFT C1005NP0240JFT C1005NP0270JFT C1005NP0330□ FT C1005NP0470JFT C1005NP0560JFT C1005NP0101JFT C1005NP0201JFT C1005NP0221□ FT C1005NP0271JFT C1005NP0331JFT C1005NP0471JFT C1005NP0561JFT C1005NP0102JFT C1005NP0152JFT C1005NP0182JFT C1005NP0222JFT C1005NP0109BET C1005NP0129BET C1005NP0209BET C1005NP0100JET C1005NP0150□ ET C1005NP0220FET C1005NP0300JET C1005NP0470□ ET C1005NP0101JET C1005NP0331□ ET C1005NP0471JET C1005NP0102JET C1005NP0220□ DT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 270 pF 300 pF 330 pF 390 pF 470 pF 560 pF 680 pF 750 pF 820 pF 1.0 nF 1.5 nF 0.2 pF 0.3 pF 0.5 pF 1.6 pF 6.8 pF 10 pF 12 pF 16 pF 18 pF 22 pF 24 pF 27 pF 33 pF 47 pF 56 pF 100 pF 200 pF 220 pF 270 pF 330 pF 470 pF 560 pF 1.0 nF 1.5 nF 1.8 nF 2.2 nF 1.0 pF 1.2 pF 2.0 pF 10 pF 15 pF 22 pF 30 pF 47 pF 100 pF 330 pF 470 pF 1.0 nF 22 pF Available Tolerance Thick. (mm) ±5%,±2%,±1% ±5%,±2% ±5%,±2% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2% ±5%,±2%,±1% ±5% ±5%,±2% ±5%,±2%,±1% ±5% ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5% ±5%,±2%,±1% ±5% ±10% ±5% ±5% ±5% ±10% ,±5% ±5% ±5% ±5% ±5% ±10% ,±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±0.1pF ±0.1pF ±0.1pF ±5% ±5%,±2%,±1% ±1% ±5% ±5%,±2%,±1% ±5% ±5%,±2% ±5% ±5% ±5%,±2%,±1% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50                             10 Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.25% 0.25% 0.24% 0.23% 0.19% 0.17% 0.16% 0.14% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.24% 0.24% 0.23% 0.17% 0.14% 0.12% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.12% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs     C1608NP0_S Series (EIA0603)  50V   C1608NP0308□ C1608NP0478□ C1608NP0508□ C1608NP0568□ C1608NP0688□ C1608NP0758□ C1608NP0828□ C1608NP0109□ C1608NP0129□ C1608NP0159□ C1608NP0189□ C1608NP0209□ C1608NP0229□ C1608NP0249□ C1608NP0279□ C1608NP0309□ C1608NP0339□ C1608NP0399□ C1608NP0409□ C1608NP0479□ C1608NP0509□ C1608NP0569□ C1608NP0609□ C1608NP0629□ C1608NP0689□ C1608NP0709□ C1608NP0809□ C1608NP0829□ C1608NP0909□ C1608NP0100□ C1608NP0110□ C1608NP0120□ C1608NP0150□ C1608NP0160□ C1608NP0180□ C1608NP0200□ C1608NP0220□ C1608NP0240□ C1608NP0270□ C1608NP0300□ C1608NP0330□ C1608NP0360□ C1608NP0390□ C1608NP0430□ C1608NP0470□ C1608NP0560□ C1608NP0620□ C1608NP0680□ C1608NP0750□ C1608NP0820□ C1608NP0910□ C1608NP0101□ C1608NP0121□ C1608NP0151□ C1608NP0181□ C1608NP0201□ C1608NP0221□ GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS GTS DARFON P/N 2 C1608NP0308□ C1608NP0478□ C1608NP0508□ C1608NP0568□ C1608NP0688□ C1608NP0758□ C1608NP0828□ C1608NP0109□ C1608NP0129□ C1608NP0159□ C1608NP0189□ C1608NP0209□ C1608NP0229□ C1608NP0249□ C1608NP0279□ C1608NP0309□ C1608NP0339□ C1608NP0399□ C1608NP0409□ C1608NP0479□ C1608NP0509□ C1608NP0569□ C1608NP0609□ C1608NP0629□ C1608NP0689□ C1608NP0709□ C1608NP0809□ C1608NP0829□ C1608NP0909□ C1608NP0100□ C1608NP0110□ C1608NP0120□ C1608NP0150□ C1608NP0160□ C1608NP0180□ C1608NP0200□ C1608NP0220□ C1608NP0240□ C1608NP0270□ C1608NP0300□ C1608NP0330□ C1608NP0360□ C1608NP0390□ C1608NP0430□ C1608NP0470□ C1608NP0560□ C1608NP0620□ C1608NP0680□ C1608NP0750□ C1608NP0820□ C1608NP0910□ C1608NP0101□ C1608NP0121□ C1608NP0151□ C1608NP0181□ C1608NP0201□ C1608NP0221□ GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT GT Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 0.30 pF 0.47 pF 0.50 pF 0.56 pF 0.68 pF 0.75 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.0 pF 2.2 pF 2.4 pF 2.7 pF 3.0 pF 3.3 pF 3.9 pF 4.0 pF 4.7 pF 5.0 pF 5.6 pF 6.0 pF 6.2 pF 6.8 pF 7.0 pF 8.0 pF 8.2 pF 9.0 pF 10 pF 11 pF 12 pF 15 pF 16 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 36 pF 39 pF 43 pF 47 pF 56 pF 62 pF 68 pF 75 pF 82 pF 91 pF 100 pF 120 pF 150 pF 180 pF 200 pF 220 pF Available Tolerance Thick. (mm) ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 11  Tolerance(mm) L/W ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 DF (max.) Standard Packing 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.17% 0.17% 0.16% 0.16% 0.14% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Paper, 4Kpcs MLCC  DARFON P/N General Purpose  RV   Rev. 202204 RV 50V 25V 16V 10V DARFON P/N DARFON P/N 2 Measuring Condition C1608NP0271□ GTS C1608NP0331□ GTS C1608NP0391□ GTS C1608NP0431JGTS C1608NP0471□ GTS C1608NP0561□ GTS C1608NP0681□ GTS C1608NP0821□ GTS C1608NP0102□ GTS C1608NP0122JGTS C1608NP0152□ GTS C1608NP0182JGTS C1608NP0222JGTS C1608NP0272JGTS C1608NP0332JGTS C1608NP0392JGTS C1608NP0472JGTS C1608NP0562JGTS C1608NP0682JGTS C1608NP0822JGTS C1608NP0103JGTS C1608NP0279CFTS C1608NP0309CFTS C1608NP0609DFTS C1608NP0220JFTS C1608NP0470JFTS C1608NP0101□ FTS C1608NP0121□ FTS C1608NP0471□ FTS C1608NP0102JFTS C1608NP0152JFTS C1608NP0222JFTS C1608NP0682JFTS C1608NP0822JFTS C1608NP0103JFTS C1608NP0180□ ETS C1608NP0300JETS C1608NP0152JETS C1608NP0222JETS C1608NP0272JETS C1608NP0332JETS C1608NP0822JETS C1608NP0101□ DTS C1608NP0271□ GT C1608NP0331□ GT C1608NP0391□ GT C1608NP0431JGT C1608NP0471□ GT C1608NP0561□ GT C1608NP0681□ GT C1608NP0821□ GT C1608NP0102□ GT C1608NP0122JGT C1608NP0152□ GT C1608NP0182JGT C1608NP0222JGT C1608NP0272JGT C1608NP0332JGT C1608NP0392JGT C1608NP0472JGT C1608NP0562JGT C1608NP0682JGT C1608NP0822JGT C1608NP0103JGT C1608NP0279CFT C1608NP0309CFT C1608NP0609DFT C1608NP0220JFT C1608NP0470JFT C1608NP0101□ FT C1608NP0121□ FT C1608NP0471□ FT C1608NP0102JFT C1608NP0152JFT C1608NP0222JFT C1608NP0682JFT C1608NP0822JFT C1608NP0103JFT C1608NP0180□ ET C1608NP0300JET C1608NP0152JET C1608NP0222JET C1608NP0272JET C1608NP0332JET C1608NP0822JET C1608NP0101□ DT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz Capacitance Value Unit 270 pF 330 pF 390 pF 430 pF 470 pF 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 2.7 nF 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 2.7 pF 3.0 pF 6.0 pF 22 pF 47 pF 100 pF 120 pF 470 pF 1.0 nF 1.5 nF 2.2 nF 6.8 nF 8.2 nF 10 nF 18 pF 30 pF 1.5 nF 2.2 nF 2.7 nF 3.3 nF 8.2 nF 100 pF Available Tolerance Thick. (mm) ±5%,±2% ±5%,±2% ±5%,±2% ±5% ±5%,±2%,±1% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2%,±1% ±5% ±5%,±2% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±0.25pF ±0.25pF ±0.5pF ±5% ±5% ±10%,±5% ±10%,±5% ±10%,±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5%,±2%,±1% ±5% ±5% ±5% ±5% ±5% ±5% ±10%,±5% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80                                 □ Tolerance Code: F=±1%, G=±2%, J=±5%; Special tolerance on the request.  12 Tolerance(mm) L/W ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 DF (max.) 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.22% 0.22% 0.19% 0.12% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.13% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs     C2012NP0_S Series (EIA0805)  50V 25V 16V   DARFON P/N 2 C2012NP0100□ GTS C2012NP0120□ GTS C2012NP0150□ GTS C2012NP0180□ GTS C2012NP0200□ GTS C2012NP0220□ GTS C2012NP0270□ GTS C2012NP0300□ GTS C2012NP0330□ GTS C2012NP0360□ GTS C2012NP0390□ GTS C2012NP0470□ GTS C2012NP0560□ GTS C2012NP0680□ GTS C2012NP0820□ GTS C2012NP0101□ GTS C2012NP0121JGTS C2012NP0151JGTS C2012NP0181JGTS C2012NP0201JGTS C2012NP0221□ GTS C2012NP0271JGTS C2012NP0331JGTS C2012NP0391JGTS C2012NP0471JGTS C2012NP0471JGTSE C2012NP0561JGTS C2012NP0681JGTS C2012NP0821JGTS C2012NP0102JGTS C2012NP0122JGTS C2012NP0152JGTS C2012NP0182JGTS C2012NP0222JGTS C2012NP0272JGTS C2012NP0272JGPS C2012NP0332JGTS C2012NP0332JGPS C2012NP0392JGTS C2012NP0392JGPS C2012NP0472JGTS C2012NP0472JGPS C2012NP0562JGPS C2012NP0682JGPS C2012NP0822JGPS C2012NP0103JGTS C2012NP0103□ GPS C2012NP0223JGPS C2012NP0222JFTS C2012NP0100JETS C2012NP0270□ ETS C2012NP0332JEPS C2012NP0100□ GT C2012NP0120□ GT C2012NP0150□ GT C2012NP0180□ GT C2012NP0200□ GT C2012NP0220□ GT C2012NP0270□ GT C2012NP0300□ GT C2012NP0330□ GT C2012NP0360□ GT C2012NP0390□ GT C2012NP0470□ GT C2012NP0560□ GT C2012NP0680□ GT C2012NP0820□ GT C2012NP0101□ GT C2012NP0121JGT C2012NP0151JGT C2012NP0181JGT C2012NP0201JGT C2012NP0221□ GT C2012NP0271JGT C2012NP0331JGT C2012NP0391JGT C2012NP0471JGT C2012NP0561JGT C2012NP0681JGT C2012NP0821JGT C2012NP0102JGT C2012NP0122JGT C2012NP0152JGT C2012NP0182JGT C2012NP0222JGT C2012NP0272JGT C2012NP0272JGP C2012NP0332JGT C2012NP0332JGP C2012NP0392JGT C2012NP0392JGP C2012NP0472JGT C2012NP0472JGP C2012NP0562JGP C2012NP0682JGP C2012NP0822JGP C2012NP0103JGT C2012NP0103□ GP C2012NP0223JGP C2012NP0222JFT C2012NP0100JET C2012NP0270□ ET C2012NP0332JEP Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz 1V, 1MHz 1V, 1kHz Capacitance Value Unit 10 pF 12 pF 15 pF 18 pF 20 pF 22 pF 27 pF 30 pF 33 pF 36 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 120 pF 150 pF 180 pF 200 pF 220 pF 270 pF 330 pF 390 pF 470 pF 470 pF 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 2.7 nF 2.7 nF 3.3 nF 3.3 nF 3.9 nF 3.9 nF 4.7 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 10 nF 22 nF 2.2 nF 10 pF 27 pF 3.3 nF Available Tolerance Thick. (mm) ±10%,±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±10%,±5% ±5%,±2% ±5%,±2% ±5%,±2%,±1% ±5% ±5% ±5% ±5% ±5%,±2%,±1% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5%,±2%,±1% ±5% ±5% ±5% ±5%,±2% ±5% 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.85 0.60 0.60 0.60 0.60 0.85 0.85 0.85 0.85 0.85 1.25 0.85 1.25 0.85 1.25 0.85 1.25 1.25 1.25 1.25 0.85 1.25 1.25 0.85 0.60 0.60 1.25 13  Tolerance(mm) L/W ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 Thick. ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 DF (max.) Standard Packing 0.17% 0.16% 0.14% 0.13% 0.13% 0.12% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Paper, 4Kpcs 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Embossed, 3Kpcs 0.10% Paper, 4Kpcs 0.10% Embossed, 3Kpcs 0.10% Paper, 4Kpcs 0.10% Embossed, 3Kpcs 0.10% Paper, 4Kpcs 0.10% Embossed, 3Kpcs 0.10% Embossed, 3Kpcs 0.10% Embossed, 3Kpcs 0.10% Embossed, 3Kpcs 0.10% Paper, 4Kpcs 0.10% Emobssed,3Kpcs 0.10% 0.10% Paper, 4Kpcs 0.17% Paper, 4Kpcs 0.11% 0.10% Embossed, 3Kpcs Rev. 202204 MLCC  DARFON P/N General Purpose  RV     C3216NP0_S Series (EIA1206)  RV 50V 25V 16V DARFON P/N DARFON P/N 2 Measuring Condition C3216NP0100JGTS C3216NP0220JGTS C3216NP0101JGTS C3216NP0221JGTS C3216NP0822JGPS C3216NP0103JGPS C3216NP0123JGPS C3216NP0153JGPS C3216NP0183JGPS C3216NP0223JGPS C3216NP0273JGPS C3216NP0333JGPS C3216NP0393JGPS C3216NP0104JGPS C3216NP0104JFPS C3216NP0123JEPS C3216NP0153JEPS C3216NP0183JEPS C3216NP0223JEPS C3216NP0273JEPS C3216NP0333JEPS C3216NP0393JEPS C3216NP0100JGT C3216NP0220JGT C3216NP0101JGT C3216NP0221JGT C3216NP0822JGP C3216NP0103JGP C3216NP0123JGP C3216NP0153JGP C3216NP0183JGP C3216NP0223JGP C3216NP0273JGP C3216NP0333JGP C3216NP0393JGP C3216NP0104JGP C3216NP0104JFP C3216NP0123JEP C3216NP0153JEP C3216NP0183JEP C3216NP0223JEP C3216NP0273JEP C3216NP0333JEP C3216NP0393JEP 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz Capacitance Value Unit 10 pF 22 pF 100 pF 220 pF 8.2 nF 10 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF 100 nF 100 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF Available Tolerance Thick. (mm) ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% 0.80 0.80 0.80 0.80 1.25 1.25 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 14 Tolerance(mm) L/W ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.20 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 DF (max.) 0.17% 0.12% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Standard Packing Paper,4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs 1.  2.  3.  4.  High volumetric efficiency  High insulation resistance  RoHS compliant  Halogen Free  1.  2.  3.  4.  5.  6.  Blocking  Coupling  Timing  Bypassing  Frequency discriminating    Flittering  MLCC    Feature   Class II: High Dielectric Constant Type   Application   Part Number & Characteristic   X5R Series    C0603X5R Series(EIA0201)  50V 35V 25V 16V 10V   DARFON P/N DARFON P/N 2 Measuring Condition C0603X5R331KGTS C0603X5R102□ GTS C0603X5R103KGTS C0603X5R104KGTS C0603X5R104KNTS C0603X5R101KFTS C0603X5R151KFTS C0603X5R221KFTS C0603X5R102□ FTS C0603X5R222KFTS C0603X5R472KFTS C0603X5R682KFTS C0603X5R103□ FTS C0603X5R153□ FTS C0603X5R183□ FTS C0603X5R223□ FTS C0603X5R273□ FTS C0603X5R333□ FTS C0603X5R393□ FTS C0603X5R473□ FTS C0603X5R563□ FTS C0603X5R683□ FTS C0603X5R823□ FTS C0603X5R104□ FTS C0603X5R224□ FTS C0603X5R334□ FTS C0603X5R474□ FTS C0603X5R102□ ETS C0603X5R222KETS C0603X5R332KETS C0603X5R472KETS C0603X5R103□ ETS C0603X5R153□ ETS C0603X5R223□ ETS C0603X5R273□ ETS C0603X5R333□ ETS C0603X5R473□ ETS C0603X5R683□ ETS C0603X5R104□ ETS C0603X5R224□ ETS C0603X5R334□ ETS C0603X5R474□ ETS C0603X5R105METS C0603X5R222□ DTS C0603X5R332□ DTS C0603X5R472□ DTS C0603X5R562□ DTS C0603X5R682□ DTS C0603X5R822□ DTS C0603X5R103□ DTS C0603X5R153□ DTS C0603X5R223□ DTS C0603X5R333□ DTS C0603X5R473□ DTS C0603X5R563□ DTS C0603X5R683□ DTS C0603X5R823□ DTS C0603X5R104□ DTS C0603X5R224□ DTS C0603X5R334□ DTS C0603X5R474□ DTS C0603X5R331KGT C0603X5R102□ GT C0603X5R103KGT C0603X5R104KGT C0603X5R104KNT C0603X5R101KFT C0603X5R151KFT C0603X5R221KFT C0603X5R102□ FT C0603X5R222KFT C0603X5R472KFT C0603X5R682KFT C0603X5R103□ FT C0603X5R153□ FT C0603X5R183□ FT C0603X5R223□ FT C0603X5R273□ FT C0603X5R333□ FT C0603X5R393□ FT C0603X5R473□ FT C0603X5R563□ FT C0603X5R683□ FT C0603X5R823□ FT C0603X5R104□ FT C0603X5R224□ FT C0603X5R334□ FT C0603X5R474□ FT C0603X5R102□ ET C0603X5R222KET C0603X5R332KET C0603X5R472KET C0603X5R103□ ET C0603X5R153□ ET C0603X5R223□ ET C0603X5R273□ ET C0603X5R333□ ET C0603X5R473□ ET C0603X5R683□ ET C0603X5R104□ ET C0603X5R224□ ET C0603X5R334□ ET C0603X5R474□ ET C0603X5R105MET C0603X5R222□ DT C0603X5R332□ DT C0603X5R472□ DT C0603X5R562□ DT C0603X5R682□ DT C0603X5R822□ DT C0603X5R103□ DT C0603X5R153□ DT C0603X5R223□ DT C0603X5R333□ DT C0603X5R473□ DT C0603X5R563□ DT C0603X5R683□ DT C0603X5R823□ DT C0603X5R104□ DT C0603X5R224□ DT C0603X5R334□ DT C0603X5R474□ DT 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Value Unit 330 pF 1.0 nF 10 nF 100 nF 100 nF 100 pF 150 pF 220 pF 1.0 nF 2.2 nF 4.7 nF 6.8 nF 10 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF 47 nF 56 nF 68 nF 82 nF 100 nF 220 nF 330 nF 470 nF 1.0 nF 2.2 nF 3.3 nF 4.7 nF 10 nF 15 nF 22 nF 27 nF 33 nF 47 nF 68 nF 100 nF 220 nF 330 nF 470 nF 1.0 uF 2.2 nF 3.3 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 15 nF 22 nF 33 nF 47 nF 56 nF 68 nF 82 nF 100 nF 220 nF 330 nF 470 nF Available Tolerance Thick. (mm) ±10% ±10% , ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% , ±20% ±10% ±10% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ±10%  ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20%  ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 15  Tolerance(mm) L/W ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.09 ± 0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.05 ±0.09 ±0.09 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.03 ± 0.05 ±0.09 ±0.09 Thick. ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.09 ± 0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.05 ±0.09 ±0.09 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.03 ± 0.05 ±0.09 ±0.09 DF (max.) 5.0% 5.0% 5.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% Standard Packing Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Test Spec. (I) (I) (II)* (II)* (II) (I) (I) (I) (I) (I) (I) (I) (II)* (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* Rev. 202204 General Purpose  RV   RV 10V 6.3V 4V 2.5V DARFON P/N DARFON P/N 2 C0603X5R105□ DTS C0603X5R225MDTS C0603X5R222□ CTS C0603X5R332□ CTS C0603X5R472□ CTS C0603X5R562□ CTS C0603X5R682□ CTS C0603X5R822□ CTS C0603X5R103□ CTS C0603X5R153□ CTS C0603X5R223□ CTS C0603X5R333□ CTS C0603X5R473□ CTS C0603X5R563□ CTS C0603X5R683□ CTS C0603X5R823□ CTS C0603X5R104□ CTS C0603X5R224□ CTS C0603X5R334□ CTS C0603X5R474□ CTS C0603X5R105□ CTS C0603X5R225MCTS C0603X5R475MCTSB C0603X5R473□ BTS C0603X5R474□ BTS C0603X5R105□ BTS C0603X5R225MBTS C0603X5R475MBTSB C0603X5R475MTTSB C0603X5R105□ DT C0603X5R225MDT C0603X5R222□ CT C0603X5R332□ CT C0603X5R472□ CT C0603X5R562□ CT C0603X5R682□ CT C0603X5R822□ CT C0603X5R103□ CT C0603X5R153□ CT C0603X5R223□ CT C0603X5R333□ CT C0603X5R473□ CT C0603X5R563□ CT C0603X5R683□ CT C0603X5R823□ CT C0603X5R104□ CT C0603X5R224□ CT C0603X5R334□ CT C0603X5R474□ CT C0603X5R105□ CT C0603X5R225MCT C0603X5R473□ BT C0603X5R474□ BT C0603X5R105□ BT C0603X5R225MBT Measuring Condition 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz Capacitance Value Unit 1.0 uF 2.2 uF 2.2 nF 3.3 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 15 nF 22 nF 33 nF 47 nF 56 nF 68 nF 82 nF 100 nF 220 nF 330 nF 470 nF 1.0 uF 2.2 uF 4.7 uF 47 nF 470 nF 1.0 uF 2.2 uF 4.7 uF 4.7 uF Available Tolerance Thick. (mm) ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20%  ±20%  ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20%  ±20%  ±20%  ±20% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.50 0.30 0.30 0.30 0.30 0.50 0.50 Tolerance(mm) L/W ±0.09 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.05 ±0.09 ±0.05 ±0.09 ±0.09 ± 0.03 ±0.09 ±0.05 ±0.09 ±0.09 ±0.09 Thick. ±0.09 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.05 ±0.09 ±0.05 ±0.09 ±0.05 ± 0.03 ±0.09 ±0.05 ±0.09 ±0.05 ±0.05 □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  16 DF (max.) 12.5% 15.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 20.0% 20.0% 10.0% 12.5% 10.0% 20.0% 20.0% 20.0% Standard Packing Paper, 15Kpcs Paper, 15Kpcs Paper, 10Kpcs Paper, 15Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (II)* (II)* (II) (II)* (II)* (II)* (II)* (II)* 50V 35V 25V 16V 10V 6.3V   DARFON P/N DARFON P/N 2 Measuring Condition C1005X5R102KGTS C1005X5R682KGTS C1005X5R103KGTS C1005X5R183KGTS C1005X5R223KGTS C1005X5R333KGTS C1005X5R473KGTS C1005X5R104□ GTS C1005X5R224KGTS C1005X5R334□ GTS C1005X5R474□ GTS C1005X5R105□ GTS C1005X5R105□ NTS C1005X5R225□ NTS C1005X5R103KFTS C1005X5R223□ FTS C1005X5R333KFTS C1005X5R473KFTS C1005X5R683KFTS C1005X5R104□ FTS C1005X5R224□ FTS C1005X5R334□ FTS C1005X5R394□ FTS C1005X5R474□ FTS C1005X5R564□ FTS C1005X5R684□ FTS C1005X5R105□ FTS C1005X5R225□ FTS C1005X5R475MFTS C1005X5R102KETS C1005X5R153□ ETS C1005X5R223□ ETS C1005X5R273□ ETS C1005X5R333□ ETS C1005X5R393KETS C1005X5R473□ ETS C1005X5R563□ ETS C1005X5R683□ ETS C1005X5R823□ ETS C1005X5R104□ ETS C1005X5R124□ ETS C1005X5R154□ ETS C1005X5R184□ ETS C1005X5R224□ ETS C1005X5R334□ ETS C1005X5R474□ ETS C1005X5R564□ ETS C1005X5R684□ ETS C1005X5R105□ ETS C1005X5R225□ ETS C1005X5R475METS C1005X5R102□ DTS C1005X5R103KDTS C1005X5R153□ DTS C1005X5R223□ DTS C1005X5R333□ DTS C1005X5R473□ DTS C1005X5R563□ DTS C1005X5R683□ DTS C1005X5R823□ DTS C1005X5R104□ DTS C1005X5R124□ DTS C1005X5R154□ DTS C1005X5R184□ DTS C1005X5R224□ DTS C1005X5R334□ DTS C1005X5R394□ DTS C1005X5R474□ DTS C1005X5R684□ DTS C1005X5R105□ DTS C1005X5R225□ DTS C1005X5R475□ DTS C1005X5R106MDTS C1005X5R226MDTS C1005X5R223KCTS C1005X5R473KCTS C1005X5R104□ CTS C1005X5R102KGT C1005X5R682KGT C1005X5R103KGT C1005X5R183KGT C1005X5R223KGT C1005X5R333KGT C1005X5R473KGT C1005X5R104□ GT C1005X5R224KGT C1005X5R334□ GT C1005X5R474□ GT C1005X5R105□ GT C1005X5R105□ NT C1005X5R225□ NT C1005X5R103KFT C1005X5R223□ FT C1005X5R333KFT C1005X5R473KFT C1005X5R683KFT C1005X5R104□ FT C1005X5R224□ FT C1005X5R334□ FT C1005X5R394□ FT C1005X5R474□ FT C1005X5R564□ FT C1005X5R684□ FT C1005X5R105□ FT C1005X5R225□ FT C1005X5R475MFT C1005X5R102KET C1005X5R153□ ET C1005X5R223□ ET C1005X5R273□ ET C1005X5R333□ ET C1005X5R393KET C1005X5R473□ ET C1005X5R563□ ET C1005X5R683□ ET C1005X5R823□ ET C1005X5R104□ ET C1005X5R124□ ET C1005X5R154□ ET C1005X5R184□ ET C1005X5R224□ ET C1005X5R334□ ET C1005X5R474□ ET C1005X5R564□ ET C1005X5R684□ ET C1005X5R105□ ET C1005X5R225□ ET C1005X5R475MET C1005X5R102□ DT C1005X5R103KDT C1005X5R153□ DT C1005X5R223□ DT C1005X5R333□ DT C1005X5R473□ DT C1005X5R563□ DT C1005X5R683□ DT C1005X5R823□ DT C1005X5R104□ DT C1005X5R124□ DT C1005X5R154□ DT C1005X5R184□ DT C1005X5R224□ DT C1005X5R334□ DT C1005X5R394□ DT C1005X5R474□ DT C1005X5R684□ DT C1005X5R105□ DT C1005X5R225□ DT C1005X5R475□ DT C1005X5R106MDT C1005X5R226MDT C1005X5R223KCT C1005X5R473KCT C1005X5R104□ CT 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Available Tolerance Value Unit 1.0 nF ±10% 6.8 nF ±10% 10 nF ±10% 18 nF ±10% 22 nF ±10% 33 nF ±10% 47 nF ±10% 100 nF ±5% ,±10% ,±20% 220 nF ±10% 330 nF ±10% , ±20% 470 nF ±10% , ±20% 1.0 uF ±10% , ±20% 1.0 uF ±10% , ±20% 2.2 uF ±10% , ±20% 10 nF ±10% 22 nF ±10% , ±20% 33 nF ±10% 47 nF ±10% 68 nF ±10% 100 nF ±10% , ±20% 220 nF ±10% , ±20% 330 nF ±10% , ±20% 390 nF ±10% , ±20% 470 nF ±10% , ±20% 560 nF ±10% , ±20% 680 nF ±10% , ±20% 1.0 uF ±10% , ±20% 2.2 uF ±10% , ±20% 4.7 uF  ±20% 1.0 nF ±10% 15 nF ±10% , ±20% 22 nF ±10% , ±20% 27 nF ±10% , ±20% 33 nF ±10% , ±20% 39 nF ±10% 47 nF ±10% , ±20% 56 nF ±10% , ±20% 68 nF ±10% , ±20% 82 nF ±10% , ±20% 100 nF ±10% , ±20% 120 nF ±10% , ±20% 150 nF ±10% , ±20% 180 nF ±10% , ±20% 220 nF ±10% , ±20% 330 nF ±10% , ±20% 470 nF ±10% , ±20% 560 nF ±10% , ±20% 680 nF ±10% , ±20% 1.0 uF ±10% , ±20% 2.2 uF ±10% , ±20% 4.7 uF ±20% 1.0 nF ±10% , ±20% 10 nF ±10% 15 nF ±10% , ±20% 22 nF ±10% , ±20% 33 nF ±10% , ±20% 47 nF ±10% , ±20% 56 nF ±10% , ±20% 68 nF ±10% , ±20% 82 nF ±10% , ±20% 100 nF ±10% , ±20% 120 nF ±10% , ±20% 150 nF ±10% , ±20% 180 nF ±10% , ±20% 220 nF ±10% , ±20% 330 nF ±10% , ±20% 390 nF ±10% , ±20% 470 nF ±10% , ±20% 680 nF ±10% , ±20% 1.0 uF ±10% , ±20% 2.2 uF ±10% , ±20% 4.7 uF ±10% , ±20% 10 uF ±20% 22 uF ±20% 22 nF ±10% 47 nF ±10% 100 nF ±10% , ±20% 17  Thick. (mm) 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.20 ±0.10 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.20 ±0.10 ±0.10 ±0.10 ±0.20 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.05 ±0.05 ±0.05 ±0.20 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.20 ±0.15 ±0.20 ±0.30 ±0.05 ±0.05 ±0.05 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.20 ±0.10 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.20 ±0.10 ±0.10 ±0.10 ±0.20 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.05 ±0.05 ±0.05 ±0.20 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.20 ±0.15 ±0.20 ±0.30 ±0.05 ±0.05 ±0.05 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 7.5% 7.5% 7.5% 10.0% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 5.0% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 20.0% 7.5% 7.5% 10.0% Standard Packing  Paper, 10Kpcs  Paper, 10Kpcs  Paper, 10Kpcs  Paper, 10Kpcs  Paper, 10Kpcs  Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (II) (II) (II)* (II)* (II)* (II)* (II)* (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (I) (I) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (I) (I) (I) Rev. 202204 MLCC  RV   General Purpose    C1005X5R Series (EIA0402) RV 6.3V 4V DARFON P/N C1005X5R224□ CTS C1005X5R334□ CTS C1005X5R474□ CTS C1005X5R684□ CTS C1005X5R105MCTSA C1005X5R105□ CTS C1005X5R225MCTSA C1005X5R225□ CTS C1005X5R475MCTSA C1005X5R475□ CTS C1005X5R106MCTS C1005X5R226MCTS C1005X5R105□ BTS C1005X5R225□ BTS C1005X5R225MBTSA C1005X5R475□ BTS C1005X5R106MBTS C1005X5R226MBTS DARFON P/N 2 C1005X5R224□ C1005X5R334□ C1005X5R474□ C1005X5R684□ CT CT CT CT C1005X5R105□ CT C1005X5R225□ CT C1005X5R475□ CT C1005X5R106MCT C1005X5R226MCT C1005X5R105□ BT C1005X5R225□ BT C1005X5R475□ BT C1005X5R106MBT C1005X5R226MBT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz Capacitance Value Unit 220 nF 330 nF 470 nF 680 nF 1.0 uF 1.0 uF 2.2 uF 2.2 uF 4.7 uF 4.7 uF 10 uF 22 uF 1.0 uF 2.2 uF 2.2 uF 4.7 uF 10 uF 22 uF Available Tolerance Thick. (mm) ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% 0.50 0.50 0.50 0.50 0.30 0.50 0.30 0.50 0.30 0.50 0.50 0.50 0.50 0.50 0.30 0.50 0.50 0.50 Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.20 ±0.20 ±0.15 ±0.20 ±0.20 ±0.05 ±0.20 ±0.05 ±0.15 ±0.20 ±0.20 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.03 ±0.05 ±0.03 ±0.20 ±0.03 ±0.15 ±0.20 ±0.20 ±0.05 ±0.20 ±0.03 ±0.15 ±0.20 ±0.20 □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  18 DF (max.) 10.0% 10.0% 10.0% 10.0% 12.5% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 15.0% 15.0% 10.0% 10.0% 10.0% 15.0% 15.0% Standard Packing  Paper, 10Kpcs  Paper, 15Kpcs  Paper, 10Kpcs  Paper, 15Kpcs  Paper, 10Kpcs  Paper, 15Kpcs  Paper, 10Kpcs  Paper, 10Kpcs  Paper, 15Kpcs  Paper, 10Kpcs Test Spec. (II) (II) (II) (II) (II)* (II) (II)* (II)* (II)* (II)* (II) (II)* (II) (II) (II) (II) (II) (II)*   C1608X5R Series (EIA0603)  35V 25V 16V 10V 6.3V 4V DARFON P/N 2 C1608X5R102KGTS C1608X5R103KGTS C1608X5R333KGTS C1608X5R104□ GTS C1608X5R224□ GTS C1608X5R474□ GTS C1608X5R105□ GTS C1608X5R225□ GTS C1608X5R105□ NTS C1608X5R225□ NTS C1608X5R475□ NTS C1608X5R106MNTS C1608X5R104□ FTS C1608X5R224□ FTS C1608X5R334KFTS C1608X5R474□ FTS C1608X5R684KFTS C1608X5R105□ FTS C1608X5R105□ FTSB C1608X5R225□ FTS C1608X5R335□ FTS C1608X5R475□ FTS C1608X5R106MFTS C1608X5R104□ ETS C1608X5R224□ ETS C1608X5R334□ ETS C1608X5R474□ ETS C1608X5R684□ ETS C1608X5R105□ ETS C1608X5R105□ ETSB C1608X5R225□ ETS C1608X5R335□ ETS C1608X5R475□ ETS C1608X5R106□ ETS C1608X5R104□ DTS C1608X5R224□ DTS C1608X5R334□ DTS C1608X5R474□ DTS C1608X5R684□ DTS C1608X5R105□ DTS C1608X5R105□ DTSB C1608X5R225□ DTS C1608X5R225□ DTSB C1608X5R335□ DTS C1608X5R475□ DTS C1608X5R475□ DTSB C1608X5R106□ DTS C1608X5R226MDTS C1608X5R226MDWS C1608X5R104□ CTS C1608X5R105□ CTS C1608X5R225□ CTS C1608X5R475□ CTS C1608X5R106MCTSB C1608X5R106□ CTS C1608X5R226MCTS C1608X5R476MCTS C1608X5R106MBTS C1608X5R226MBTS C1608X5R476MBTS C1608X5R102KGT C1608X5R103KGT C1608X5R333KGT C1608X5R104□ GT C1608X5R224□ GT C1608X5R474□ GT C1608X5R105□ GT C1608X5R225□ GT C1608X5R105□ NT C1608X5R225□ NT C1608X5R475□ NT C1608X5R106MNT C1608X5R104□ FT C1608X5R224□ FT C1608X5R334KFT C1608X5R474□ FT C1608X5R684KFT C1608X5R105□ FT C1608X5R225□ FT C1608X5R335□ FT C1608X5R475□ FT C1608X5R106MFT C1608X5R104□ ET C1608X5R224□ ET C1608X5R334□ ET C1608X5R474□ ET C1608X5R684□ ET C1608X5R105□ ET C1608X5R225□ C1608X5R335□ C1608X5R475□ C1608X5R106□ C1608X5R104□ C1608X5R224□ C1608X5R334□ C1608X5R474□ C1608X5R684□ C1608X5R105□ ET ET ET ET DT DT DT DT DT DT C1608X5R225□ DT C1608X5R335□ DT C1608X5R475□ DT C1608X5R106□ DT C1608X5R226MDT C1608X5R226MDW C1608X5R104□ CT C1608X5R105□ CT C1608X5R225□ CT C1608X5R475□ CT C1608X5R106□ CT C1608X5R226MCT C1608X5R476MCT C1608X5R106MBT C1608X5R226MBT C1608X5R476MBT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz Capacitance Value Unit 1.0 nF 10 nF 33 nF 100 nF 220 nF 470 nF 1.0 uF 2.2 uF 1.0 uF 2.2 uF 4.7 uF 10 uF 100 nF 220 nF 330 nF 470 nF 680 nF 1.0 uF 1.0 uF 2.2 uF 3.3 uF 4.7 uF 10 uF 100 nF 220 nF 330 nF 470 nF 680 nF 1.0 uF 1.0 uF 2.2 uF 3.3 uF 4.7 uF 10 uF 100 nF 220 nF 330 nF 470 nF 680 nF 1.0 uF 1.0 uF 2.2 uF 2.2 uF 3.3 uF 4.7 uF 4.7 uF 10 uF 22 uF 22 uF 100 nF 1.0 uF 2.2 uF 4.7 uF 10 uF 10 uF 22 uF 47 uF 10 uF 22 uF 47 uF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% ±10% , ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ,±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% ±20% ±20% ±20% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.50 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.10 ±0.15 ±0.10 ±0.15 ±0.15 ±0.10 ±0.15 ±0.20 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.10 ±0.15 ±0.15 ±0.20 ±0.20 ±0.25 ±0.20 ±0.10 ±0.10 ±0.15 ±0.15 ±0.10 ±0.15 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 Thick. ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.10 ±0.15 ±0.10 ±0.15 ±0.15 +0/-0.10 ±0.15 ±0.20 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0/-0.10 ±0.15 ±0.15 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0/-0.10 ±0.15 +0/-0.10 ±0.15 ±0.15 ±0.05 ±0.20 ±0.25 ±0.20 ±0.10 ±0.10 ±0.15 ±0.15 ±0.10 ±0.15 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 7.5% 5.0% 7.5% 10.0% 12.5% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 3.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 10.0% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 15.0% 12.5% 10.0% 10.0% 12.5% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Embossed, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (I) (I) (I) (II) (II) (II) (II)* (II) (II) (II) (II) (I) (I) (I) (II) (II) (II) (II) (II) (II)* (II)* (II)* (I) (I) (I) (I) (I) (II) (II) (II) (II)* (II) (II) (II) (II)* (II)* (II)* (I) (II) (II) (II) (II)* (II)* (II)* (II)* (II) (II)* (II)*             □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    19  Rev. 202204 MLCC  50V DARFON P/N General Purpose  RV     C2012X5R Series (EIA0805)  RV 50V 35V 25V 16V 10V 6.3V 4V DARFON P/N DARFON P/N 2 Measuring Condition C2012X5R224KGTS C2012X5R105□ GTS C2012X5R105□ GPS C2012X5R225□ GTS C2012X5R225□ GPS C2012X5R475□ GPS C2012X5R106□ GPS C2012X5R106□ NPS C2012X5R226MNWS C2012X5R474□ FPS C2012X5R105□ FTS C2012X5R105□ FPS C2012X5R225□ FTS C2012X5R225□ FPS C2012X5R475□ FTS C2012X5R475□ FPS C2012X5R106□ FTS C2012X5R106□ FPS C2012X5R226MFPS C2012X5R226MFWS C2012X5R105□ ETS C2012X5R105□ EPS C2012X5R225□ EPS C2012X5R335□ EPS C2012X5R475□ ETS C2012X5R475□ EPS C2012X5R106□ ETS C2012X5R106□ EPS C2012X5R226METS C2012X5R226□ EPS C2012X5R105□ DPS C2012X5R225□ DTS C2012X5R225□ DPS C2012X5R335□ DPS C2012X5R475□ DPS C2012X5R106□ DTS C2012X5R106□ DPS C2012X5R226MDTS C2012X5R226MDPS C2012X5R476MDPS C2012X5R225KCTS C2012X5R225□ CPS C2012X5R335□ CPS C2012X5R475□ CPS C2012X5R106□ CTS C2012X5R106□ CPS C2012X5R226MCTS C2012X5R226□ CPS C2012X5R476MCTS C2012X5R476MCPS C2012X5R107MCPS C2012X5R226MBPS C2012X5R476MBPS C2012X5R107MBPS C2012X5R224KGT C2012X5R105□ GT C2012X5R105□ GP C2012X5R225□ GT C2012X5R225□ GP C2012X5R475□ GP C2012X5R106□ GP C2012X5R106□ NP C2012X5R226MNW C2012X5R474□ FP C2012X5R105□ FT C2012X5R105□ FP C2012X5R225□ FT C2012X5R225□ FP C2012X5R475□ FT C2012X5R475□ FP C2012X5R106□ FT C2012X5R106□ FP C2012X5R226MFP C2012X5R226MFW C2012X5R105□ ET C2012X5R105□ EP C2012X5R225□ EP C2012X5R335□ EP C2012X5R475□ ET C2012X5R475□ EP C2012X5R106□ ET C2012X5R106□ EP C2012X5R226MET C2012X5R226□ EP C2012X5R105□ DP C2012X5R225□ DT C2012X5R225□ DP C2012X5R335□ DP C2012X5R475□ DP C2012X5R106□ DT C2012X5R106□ DP C2012X5R226MDT C2012X5R226MDP C2012X5R476MDP C2012X5R225KCT C2012X5R225□ CP C2012X5R335□ CP C2012X5R475□ CP C2012X5R106□ CT C2012X5R106□ CP C2012X5R226MCT C2012X5R226□ CP C2012X5R476MCT C2012X5R476MCP C2012X5R107MCP C2012X5R226MBP C2012X5R476MBP C2012X5R107MBP 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz Capacitance Value Unit 220 nF 1.0 uF 1.0 uF 2.2 uF 2.2 uF 4.7 uF 10 uF 10 uF 22 uF 470 nF 1.0 uF 1.0 uF 2.2 uF 2.2 uF 4.7 uF 4.7 uF 10 uF 10 uF 22 uF 22 uF 1.0 uF 1.0 uF 2.2 uF 3.3 uF 4.7 uF 4.7 uF 10 uF 10 uF 22 uF 22 uF 1.0 uF 2.2 uF 2.2 uF 3.3 uF 4.7 uF 10 uF 10 uF 22 uF 22 uF 47 uF 2.2 uF 2.2 uF 3.3 uF 4.7 uF 10 uF 10 uF 22 uF 22 uF 47 uF 47 uF 100 uF 22 uF 47 uF 100 uF Available Tolerance Thick. (mm) ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20%  ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% ±20%  ±20% ±20% ±20% 0.85 0.85 1.25 0.85 1.25 1.25 1.25 1.25 1.25 1.25 0.85 1.25 0.85 1.25 0.85 1.25 0.85 1.25 1.25 1.25 0.85 1.25 1.25 1.25 0.85 1.25 0.85 1.25 0.85 1.25 1.25 0.85 1.25 1.25 1.25 0.85 1.25 0.85 1.25 1.25 0.85 1.25 1.25 1.25 0.85 1.25 0.85 1.25 0.85 1.25 1.25 1.25 1.25 1.25 Tolerance(mm) L/W ±0.15 ±0.15 ±0.15 ±0.20 ±0.15/±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.15/±0.20 ±0.15 ±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.15 ±0.15 ±0.15/±0.20 ±0.20 ±0.20 ±0.15/±0.20 ±0.15 ±0.15/±0.20 ±0.20 ±0.20 ±0.15/±0.20 ±0.15 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.20 ±0.20 ±0.15 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.15 ±0.15 ±0.20 ±0.20 ±0.20 ±0.15 ±0.20 ±0.20 Thick. ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.20 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 ±0.20 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.15 ±0.20 ±0.20                   □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  20 DF (max.) 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 15.0% 15.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 10.0% 10.0% 15.0% Standard Packing Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs  Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Test Spec. (II) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (I) (II) (I) (II) (II) (II)* (II) (II)* (II)* (II)* (II)* (II) (I) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (II) (II) (II) (I) (II) (II) (II) (II) (II)* (II)* (II)* (II) (II)* (II)*   50V 35V 25V 16V 10V 6.3V 4V DARFON P/N DARFON P/N 2 C3216X5R105KGPS C3216X5R225□ GTS C3216X5R225KGPS C3216X5R475□ GTS C3216X5R475□ GPS C3216X5R106□ GPS C3216X5R225□ NPS C3216X5R106□ NTS C3216X5R106□ NPS C3216X5R105KFTSE C3216X5R105KFPSL C3216X5R225□ FPS C3216X5R475□ FPS C3216X5R106□ FPS C3216X5R226MFTSE C3216X5R226□ FPSL C3216X5R476MFPSL C3216X5R225□ EPS C3216X5R475□ EPS C3216X5R106□ EPS C3216X5R226□ EPS C3216X5R476MEPS C3216X5R225□ DPS C3216X5R475□ DPS C3216X5R106□ DPS C3216X5R226□ DPS C3216X5R476□ DPS C3216X5R106KCPS C3216X5R226□ CPS C3216X5R476MCPS C3216X5R107MCPS C3216X5R226□ BPS C3216X5R476MBPS C3216X5R107MBPS C3216X5R227MBPSL C3216X5R105KGP C3216X5R225□ GT C3216X5R225KGP C3216X5R475□ GT C3216X5R475□ GP C3216X5R106□ GP C3216X5R225□ NP C3216X5R106□ NT C3216X5R106□ NP C3216X5R105KFP C3216X5R225□ FP C3216X5R475□ FP C3216X5R106□ FP C3216X5R226MFT C3216X5R226□ FP C3216X5R476MFP C3216X5R225□ EP C3216X5R475□ EP C3216X5R106□ EP C3216X5R226□ EP C3216X5R476MEP C3216X5R225□ DP C3216X5R475□ DP C3216X5R106□ DP C3216X5R226□ DP C3216X5R476□ DP C3216X5R106KCP C3216X5R226□ CP C3216X5R476MCP C3216X5R107MCP C3216X5R226□ BP C3216X5R476MBP C3216X5R107MBP C3216X5R227MBP Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz Capacitance Value Unit 1.0 uF 2.2 uF 2.2 uF 4.7 uF 4.7 uF 10 uF 2.2 uF 10 uF 10 uF 1.0 uF 1.0 uF 2.2 uF 4.7 uF 10 uF 22 uF 22 uF 47 uF 2.2 uF 4.7 uF 10 uF 22 uF 47 uF 2.2 uF 4.7 uF 10 uF 22 uF 47 uF 10 uF 22 uF 47 uF 100 uF 22 uF 47 uF 100 uF 220 uF Available Tolerance Thick. (mm) ±10% ±10% , ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ±10% , ±20% ±20% ±20% ±10% , ±20% ±20% ±20% ±20% 1.60 0.85 1.60 0.85 1.60 1.60 1.60 0.85 1.60 0.85 1.60 1.60 1.60 1.60 0.85 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 Available Tolerance Thick. (mm) ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20%  ±20% 2.50 2.50 2.00 2.00 2.50 2.00 2.00 2.50 2.50 2.50 2.50 2.00 2.50 2.50 2.50 2.50 2.50 2.50 Available Tolerance Thick. (mm) ±10% 1.60 Tolerance(mm) L/W ±0.30 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.15 ±0.20 ±0.15 ±0.30 ±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.30 ±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.30 ±0.30 ±0.30/±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.30 ±0.30 Thick. ±0.30 ±0.10 ±0.20 ±0.10 ±0.30 ±0.20 ±0.30 ±0.10 ±0.30 ±0.10 ±0.30 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 DF (max.) Standard Packing Test Spec. 3.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 3.5% 3.5% 5.0% 5.0% 10.0% 10.0% 10.0% 15.0% 5.0% 5.0% 10.0% 10.0% 10.0% 7.5% 7.5% 10.0% 10.0% 10.0% 15.0% 15.0% 10.0% 15.0% 15.0% 15.0% 15.0% 15.0% Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Paper, 4Kpcs (I) (II) (II) (II) (II) (II) (II) (II)* (II) (I) (I) (I) (II) (II) (II)* (II)* (II)* (I) (II) (II) (II) (II) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) DF (max.) Standard Packing Test Spec. 5.0% 5.0% 10.0% 10.0% 10.0% 5.0% 5.0% 15.0% 10.0% 15.0% 10.0% 5.0% 10.0% 10.0% 10.0% 10.0% 15.0% 15.0% Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 2Kpcs Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 2Kpcs Embossed,0.5Kpcs Embossed, 1Kpcs (II) (I) (I) (I) (II) (I) (I) (II) (II) (II) (II) (I) (II) (II) (II) (II) (II) (II) DF (max.) Standard Packing Test Spec. 10.0% Embossed, 1Kpcs (II)* Embossed, 2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed,2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs General Purpose  RV MLCC    C3216X5R Series (EIA1206)        C3225X5R Series (EIA1210)  RV DARFON P/N DARFON P/N 2 Measuring Condition 50V 35V C3225X5R106□ GPS C3225X5R106□ NPS C3225X5R475□ FWS C3225X5R106□ FPS C3225X5R226□ FPS C3225X5R475□ EWS C3225X5R106□ EPS C3225X5R226□ EWS C3225X5R226□ EPS C3225X5R476□ EPS C3225X5R107MEPS C3225X5R106KDPS C3225X5R226□ DPS C3225X5R476□ DPS C3225X5R107MDPS C3225X5R226□ CPS C3225X5R476□ CPS C3225X5R107MCPS C3225X5R106□ GP C3225X5R106□ NP C3225X5R475□ FW C3225X5R106□ FP C3225X5R226□ FP C3225X5R475□ EW C3225X5R106□ EP C3225X5R226□ EW C3225X5R226□ EP C3225X5R476□ EP C3225X5R107MEP C3225X5R106KDP C3225X5R226□ DP C3225X5R476□ DP C3225X5R107MDP C3225X5R226□ CP C3225X5R476□ CP C3225X5R107MCP 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 25V 16V 10V 6.3V Capacitance Value Unit 10 uF 10 uF 4.7 uF 10 uF 22 uF 4.7 uF 10 uF 22 uF 22 uF 47 uF 100 uF 10 uF 22 uF 47 uF 100 uF 22 uF 47 uF 100 uF Tolerance(mm) L/W ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30 Thick. ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.30 Embossed, 1Kpcs Embossed, 2Kpcs Embossed, 1Kpcs Embossed, 1Kpcs       C4532X5R Series (EIA1812)  RV DARFON P/N DARFON P/N 2 Measuring Condition 50V C4532X5R225KGPS C4532X5R225KGP 1V , 1kHz Capacitance Value Unit 2.2 uF Tolerance(mm) L/W ±0.30 Thick. ±0.20     □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.;  (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    21  Rev. 202204     X6S Series    C0603X6S Series (EIA0201)  RV DARFON P/N C0603X6S103KFTS C0603X6S104□ FTS C0603X6S103KETS 16V C0603X6S104□ ETS C0603X6S473□ DTS C0603X6S104KDTS 10V C0603X6S224□ DTS C0603X6S105MDTS C0603X6S103□ CTS C0603X6S153KCTS C0603X6S333□ CTS C0603X6S473□ CTS 6.3V C0603X6S104□ CTS C0603X6S224□ CTS C0603X6S474MCTS C0603X6S105MCTS C0603X6S104□ BTS C0603X6S224□ BTS 4V C0603X6S474MBTS C0603X6S105MBTS 25V DARFON P/N 2 C0603X6S103KFT C0603X6S104□ FT C0603X6S103KET C0603X6S104□ ET C0603X6S473□ DT C0603X6S104KDT C0603X6S224□ DT C0603X6S105MDT C0603X6S103□ CT C0603X6S153KCT C0603X6S333□ CT C0603X6S473□ CT C0603X6S104□ CT C0603X6S224□ CT C0603X6S474MCT C0603X6S105MCT C0603X6S104□ BT C0603X6S224□ BT C0603X6S474MBT C0603X6S105MBT Measuring Capacitance Condition Value Unit  1V , 1kHz 10 nF  1V , 1kHz 100 nF  1V , 1kHz 10 nF  1V , 1kHz 100 nF  1V , 1kHz 47 nF  1V , 1kHz 100 nF  1V , 1kHz 220 nF  1V , 1kHz 1.0 uF  1V , 1kHz 10 nF  1V , 1kHz 15 nF  1V , 1kHz 33 nF  1V , 1kHz 47 nF  1V , 1kHz 100 nF   0.5V , 1kHz 220 nF  1V , 1kHz 470 nF   0.5V , 1kHz 1.0 uF  1V , 1kHz 100 nF   0.5V , 1kHz 220 nF  1V , 1kHz 470 nF   0.5V , 1kHz 1.0 uF Available Tolerance Thick. (mm) ±10% ±10%, ±20% ±10% ±10%, ±20% ±10%, ±20% ±10% ±10%, ±20% ±20% ±10%, ±20% ±10% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±20% ±20% ±10%, ±20% ±10%, ±20% ±20% ±20% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 Available Tolerance Thick. (mm) ±10% ±10% ±10%, ±20% ±10%, ±20% ±10% ±10% ±10% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10%, ±20%  ±20% ±10% ±10% ±10% ±10%, ±20% ±10%, ±20% ±20% ±20% ±10% ±10%, ±20% ±10%, ±20% ±20% ±20% ±20% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 Tolerance(mm) L/W ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.05 ± 0.03 ± 0.09 ± 0.03 ± 0.05 ± 0.05 ± 0.05 ± 0.05 ± 0.03 ± 0.09 ± 0.09 ± 0.05 ± 0.03 ± 0.05 ± 0.09 Thick. ±0.03 ±0.03 ± 0.03 ±0.05 ± 0.03 ±0.05 ±0.03 ±0.09 ±0.03 ±0.05 ±0.05 ±0.05 ±0.05 ±0.03 ± 0.09 ± 0.09 ±0.05 ±0.03 ±0.05 ± 0.09 DF (max.) 5% 10% 5% 10% 5% 10% 10% 10% 5% 10% 10% 10% 10% 10% 10% 10% 10% 10% 10% 10% Standard Packing Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Test Spec. (I) (II)* (I) (II)* (I) (II) (II)* (II)* (I) (II) (II) (II) (II)* (II)* (II)* (II)* (II) (II) (II)* (II)*     C1005X6S Series (EIA0402)    RV DARFON P/N C1005X6S104KFTS C1005X6S224KFTS 25V C1005X6S105□ FTS C1005X6S225□ FTS C1005X6S104KETS C1005X6S224KETS C1005X6S334KETS 16V C1005X6S474□ ETS C1005X6S105□ ETS C1005X6S225□ ETS C1005X6S105□ DTS 10V C1005X6S225□ DTS C1005X6S475MDTS C1005X6S224KCTS C1005X6S334KCTS C1005X6S684KCTS 6.3V C1005X6S105□ CTS C1005X6S225□ CTS C1005X6S475MCTS C1005X6S106MCTS C1005X6S334KBTS C1005X6S105□ BTS 4V C1005X6S225□ BTS C1005X6S106MBTS C1005X6S226MBTS 2.5V C1005X6S226MTTS DARFON P/N 2 C1005X6S104KFT C1005X6S224KFT C1005X6S105□ FT C1005X6S225□ FT C1005X6S104KET C1005X6S224KET C1005X6S334KET C1005X6S474□ ET C1005X6S105□ ET C1005X6S225□ ET C1005X6S105□ DT C1005X6S225□ DT C1005X6S475MDT C1005X6S224KCT C1005X6S334KCT C1005X6S684KCT C1005X6S105□ CT C1005X6S225□ CT C1005X6S475MCT C1005X6S106MCT C1005X6S334KBT C1005X6S105□ BT C1005X6S225□ BT C1005X6S106MBT C1005X6S226MBT C1005X6S226MTT Measuring Capacitance Condition Value Unit 1V , 1kHz 100  nF  1V , 1kHz 220  nF  0.5V , 1kHz 1.0 uF  1V , 1kHz 2.2 uF  1V , 1kHz 100  nF   1V , 1kHz 220 nF  1V , 1kHz 330 nF  1V , 1kHz 470 nF  1V , 1kHz 1.0 uF  1V , 1kHz 2.2 uF  1V , 1kHz 1.0 uF  1V , 1kHz 2.2 uF  1V , 1kHz 4.7 uF  1V , 1kHz 220 nF  1V , 1kHz 330 nF  1V , 1kHz 680 nF  1V , 1kHz 1.0 uF  0.5V , 1kHz 2.2 uF  0.5V , 1kHz 4.7 uF  0.5V , 1kHz 10 uF  1V , 1kHz 330 nF  1V , 1kHz 1.0 uF  0.5V , 1kHz 2.2 uF  0.5V , 1kHz 10 uF  0.5V , 120Hz 22 uF  0.5V , 120Hz 22 uF Tolerance(mm) L/W ±0.05 ±0.10 ±0.10 ±0.20 ±0.05 ±0.10 ±0.10 ±0.10 ±0.10 ±0.20 ±0.05 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.05 ±0.15 ±0.15 ±0.20 ±0.10 ±0.05 ±0.15 ±0.20 ±0.30 ±0.30 Thick. ±0.05 ±0.10 ±0.10 ±0.20 ±0.05 ±0.10 ±0.10 ±0.10 ±0.10 ±0.20 ±0.05 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.05 ±0.15 ±0.15 ±0.20 ±0.10 ±0.05 ±0.15 ±0.20 ±0.30 ±0.30 DF (max.)           □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  22 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 12.5% 10.0% 12.5% 12.5% 10.0% 10.0% 12.5% 12.5% 12.5% 12.5% 10.0% 10.0% 10.0% 10.0% 12.5% 10.0% 20.0% 20.0% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (II) (II) (II)* (II)* (II) (II) (II)* (II)* (II)* (II) (II)* (II)* (II) (II) (II)* (II)* (II)* (II)* (II)* (II)* (II) (II)* (II)* (II)* (II)* (II)*     C1608X6S Series (EIA0603)  C1608X6S105KFTS C1608X6S225KFTS C1608X6S475□ FTS C1608X6S105KETS C1608X6S225□ ETS 16V C1608X6S475□ ETS C1608X6S106METS C1608X6S225KDTS 10V C1608X6S475□ DTS C1608X6S106MDTS C1608X6S225□ CTS C1608X6S475□ CTS 6.3V C1608X6S106MCTS C1608X6S226MCTS C1608X6S475□ BTS C1608X6S106MBTS 4V C1608X6S226MBTS C1608X6S476MBTS 2.5V C1608X6S476MTTS 25V DARFON P/N 2 C1608X6S105KFT C1608X6S225KFT C1608X6S475□ FT C1608X6S105KET C1608X6S225□ ET C1608X6S475□ ET C1608X6S106MET C1608X6S225KDT C1608X6S475□ DT C1608X6S106MDT C1608X6S225□ CT C1608X6S475□ CT C1608X6S106MCT C1608X6S226MCT C1608X6S475□ BT C1608X6S106MBT C1608X6S226MBT C1608X6S476MBT C1608X6S476MTT Measuring Capacitance Condition Value Unit 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF  1V , 1kHz 1.0 uF  1V , 1kHz 2.2 uF  1V , 1kHz 4.7 uF  1V , 1kHz 10 uF  1V , 1kHz 2.2 uF  1V , 1kHz 4.7 uF  1V , 1kHz 10 uF  1V , 1kHz 2.2 uF  1V , 1kHz 4.7 uF  1V , 1kHz 10 uF  0.5V , 120Hz 22 uF  1V , 1kHz 4.7 uF  1V , 1kHz 10 uF  0.5V , 120Hz 22 uF  0.5V , 120Hz 47 uF  0.5V , 120Hz 47 uF Available Tolerance Thick. (mm) ±10% ±10% ±10%,±20% ±10% ±10%,±20% ±10%,±20% ±20% ±10% ±10%,±20% ±20% ±10%,±20% ±10%,±20% ±20% ±20% ±10%,±20% ±20% ±20% ±20% ±20% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W ±0.15 ±0.20 ±0.20 ±0.15 ±0.10 ±0.20 ±0.20 ±0.10 ±0.15 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 ±0.20 ±0.20 Thick. ±0.15 ±0.20 ±0.20 ±0.15 ±0.10 ±0.20 ±0.20 ±0.10 ±0.15 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 ±0.20 ±0.20 DF (max.) 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 15.0% Standard Packing Test Spec. Paper, 4Kpcs (II) (II)* (II)* (II) (II)* (II)* (II) (II) (II) (II) (II)* (II)* (II)* (II)* (II)* (II)* (II)* (II)* (II)* DF (max.) Standard Packing Test Spec. 2.5% 10.0% 10.0% 12.5% 12.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% Paper, 4Kpcs Embossed, 3Kpcs (I) (II) (II)* (II)* (II)* (II) (II)* (II)* (II) (II)* (II)* (II)* (II) (II) (II)* (II)* DF (max.) Standard Packing Test Spec. 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% Embossed, 2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Embossed, 2Kpcs (II)* (II) (II) (II) (II) (II) (II) (II) (II) (II) DF (max.) Standard Packing Test Spec. 10.0% Embossed, 1Kpcs (II) Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs MLCC  DARFON P/N     C2012X6S Series (EIA0805)  RV DARFON P/N C2012X6S104KGTS C2012X6S475KGPS C2012X6S225KFPS 25V C2012X6S475KFPS C2012X6S106□ FPS C2012X6S106KEPS 16V C2012X6S226MEPS C2012X6S106KDPS 10V C2012X6S226MDPS C2012X6S106□ CPS 6.3V C2012X6S226MCPS C2012X6S476MCPS C2012X6S106□ BPS C2012X6S226MBPS 4V C2012X6S476MBPS C2012X6S107MBPS 50V DARFON P/N 2 C2012X6S104KGT C2012X6S475KGP C2012X6S225KFP C2012X6S475KFP C2012X6S106□ FP C2012X6S106KEP C2012X6S226MEP C2012X6S106KDP C2012X6S226MDP C2012X6S106□ CP C2012X6S226MCP C2012X6S476MCP C2012X6S106□ BP C2012X6S226MBP C2012X6S476MBP C2012X6S107MBP Measuring Capacitance Available Condition Value Unit Tolerance 1V , 1kHz 100 nF ±10% 1V , 1kHz 4.7 uF ±10% 1V , 1kHz 2.2 uF ±10% 1V , 1kHz 4.7 uF ±10%  0.5V , 1kHz 10 uF ±10%, ±20% 1V , 1kHz 10 uF ±10%  0.5V , 120Hz 22 uF ±20% 1V , 1kHz 10 uF ±10%  0.5V , 120Hz 22 uF ±20% 1V , 1kHz 10 uF ±10%, ±20% 0.5V , 120Hz 22 uF ±20%  0.5V , 120Hz 47 uF ±20% 1V , 1kHz 10 uF ±10%, ±20%  0.5V , 120Hz 22 uF ±20%  0.5V , 120Hz 47 uF ±20%  0.5V , 120Hz 100 uF ±20% Thick. (mm) 0.80 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 Tolerance(mm) L/W ±0.15 ±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.20 ±0.15/±0.20 ±0.20 ±0.20 ±0.20 Thick. ±0.10 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs     C3216X6S Series (EIA1206)  RV DARFON P/N 35V C3216X6S106KNPS C3216X6S106KFPS 25V C3216X6S226□ FPS 16V C3216X6S226□ EPS C3216X6S226MDPS 10V C3216X6S476MDPS 6.3V C3216X6S476MCPS C3216X6S226MBTS 4V C3216X6S476MBPS C3216X6S107MBPS DARFON P/N 2 C3216X6S106KNP C3216X6S106KFP C3216X6S226□ FP C3216X6S226□ EP C3216X6S226MDP C3216X6S476MDP C3216X6S476MCP C3216X6S226MBT C3216X6S476MBP C3216X6S107MBP Measuring Capacitance Available Condition Value Unit Tolerance  1V , 1kHz 10 uF ±10%  1V , 1kHz 10 uF ±10%  0.5V , 120Hz 22 uF ±10%, ±20%  0.5V , 120Hz 22 uF ±10%, ±20%  0.5V , 120Hz 22 uF ±20%  0.5V , 120Hz 47 uF ±20%  0.5V , 120Hz 47 uF ±20%  0.5V , 120Hz 22 uF ±20%  0.5V , 120Hz 47 uF ±20%  0.5V , 120Hz 100 uF ±20% Thick. (mm) 1.60 1.60 1.60 1.60 1.60 1.60 1.60 0.85 1.60 1.60 Tolerance(mm) L/W ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.20 Thick. ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.10 ±0.30 ±0.20 Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs     C3225X6S Series (EIA1210)  RV DARFON P/N 6.3V C3225X6S107MCPS DARFON P/N 2 C3225X6S107MCP Measuring Capacitance Condition Value Unit  0.5V , 120Hz 100 uF Available Tolerance Thick. (mm) ±20% 2.50 Tolerance(mm) L/W ±0.30 Thick. ±0.30       □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.;  (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    23  Rev. 202204   General Purpose  RV   X6T Series    C1005X6T Series (EIA0402)  RV DARFON P/N DARFON P/N 2 Measuring Condition 10V 6.3V C1005X6T475MDTS C1005X6T475MCTS C1005X6S475MDT C1005X6T475MCT  1V , 1kHz 0.5V , 1kHz Capacitance Value 4.7 4.7 Unit uF uF Available Tolerance Thick. (mm)  ±20% ±20% 0.50 0.50 Available Tolerance Thick. (mm) ±20% 1.60 Tolerance(mm) L/W ±0.20 ±0.15 Thick. ±0.20 ±0.15 DF (max.) Standard Packing Test Spec. 10.0% 10.0% Paper, 10Kpcs Paper, 10Kpcs (II)* (II)* DF (max.) Standard Packing Test Spec. 15.0% Embossed, 2Kpcs (II)*     C3216X6T Series (EIA1206)    RV DARFON P/N DARFON P/N 2 6.3V C3216X6T107MCPS C3216X7T107MCP Measuring Condition Capacitance Value 0.5V , 120Hz 100 Unit uF Tolerance(mm) L/W ±0.30 Thick. ±0.30                                                           □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.;  (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  24     X7R Series    C0603X7R Series(EIA0201)  50V 25V 16V DARFON P/N 2 C0603X7R101□ GTS C0603X7R121KGTS C0603X7R151□ GTS C0603X7R181KGTS C0603X7R221□ GTS C0603X7R271KGTS C0603X7R331KGTS C0603X7R391KGTS C0603X7R471KGTS C0603X7R561KGTS C0603X7R681□ GTS C0603X7R821KGTS C0603X7R102KGTS C0603X7R122KGTS C0603X7R152KGTS C0603X7R182KGTS C0603X7R222KGTS C0603X7R332KGTS C0603X7R472KGTS C0603X7R682KGTS C0603X7R103KGTS C0603X7R101KFTS C0603X7R121KFTS C0603X7R151KFTS C0603X7R181KFTS C0603X7R221□ FTS C0603X7R271KFTS C0603X7R331KFTS C0603X7R391KFTS C0603X7R471□ FTS C0603X7R561KFTS C0603X7R681KFTS C0603X7R821□ FTS C0603X7R102□ FTS C0603X7R122KFTS C0603X7R152KFTS C0603X7R182KFTS C0603X7R222KFTS C0603X7R332KFTS C0603X7R472KFTS C0603X7R682KFTS C0603X7R103□ FTS C0603X7R101KETS C0603X7R121KETS C0603X7R181KETS C0603X7R201□ ETS C0603X7R221KETS C0603X7R271KETS C0603X7R331□ ETS C0603X7R471KETS C0603X7R561KETS C0603X7R681□ ETS C0603X7R821□ ETS C0603X7R102□ ETS C0603X7R152□ ETS C0603X7R182KETS C0603X7R222KETS C0603X7R272□ ETS C0603X7R332KETS C0603X7R392KETS C0603X7R472KETS C0603X7R562KETS C0603X7R682KETS C0603X7R822KETS C0603X7R103□ ETS C0603X7R223KETS C0603X7R333KETS C0603X7R473KETS C0603X7R104□ ETS C0603X7R101□ GT C0603X7R121KGT C0603X7R151□ GT C0603X7R181KGT C0603X7R221□ GT C0603X7R271KGT C0603X7R331KGT C0603X7R391KGT C0603X7R471KGT C0603X7R561KGT C0603X7R681□ GT C0603X7R821KGT C0603X7R102KGT C0603X7R122KGT C0603X7R152KGT C0603X7R182KGT C0603X7R222KGT C0603X7R332KGT C0603X7R472KGT C0603X7R682KGT C0603X7R103KGT C0603X7R101KFT C0603X7R121KFT C0603X7R151KFT C0603X7R181KFT C0603X7R221□ FT C0603X7R271KFT C0603X7R331KFT C0603X7R391KFT C0603X7R471□ FT C0603X7R561KFT C0603X7R681KFT C0603X7R821□ FT C0603X7R102□ FT C0603X7R122KFT C0603X7R152KFT C0603X7R182KFT C0603X7R222KFT C0603X7R332KFT C0603X7R472KFT C0603X7R682KFT C0603X7R103□ FT C0603X7R101KET C0603X7R121KET C0603X7R181KET C0603X7R201□ ET C0603X7R221KET C0603X7R271KET C0603X7R331□ ET C0603X7R471KET C0603X7R561KET C0603X7R681□ ET C0603X7R821□ ET C0603X7R102□ ET C0603X7R152□ ET C0603X7R182KET C0603X7R222KET C0603X7R272□ ET C0603X7R332KET C0603X7R392KET C0603X7R472KET C0603X7R562KET C0603X7R682KET C0603X7R822KET C0603X7R103□ ET C0603X7R223KET C0603X7R333KET C0603X7R473KET C0603X7R104□ ET Measuring Capacitance Condition Value Unit 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 3.3 nF 1V , 1kHz 4.7 nF 1V , 1kHz 6.8 nF 1V , 1kHz 10 nF 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 3.3 nF 1V , 1kHz 4.7 nF 1V , 1kHz 6.8 nF 1V , 1kHz 10 nF 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 180 pF 1V , 1kHz 200 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 22 nF 1V , 1kHz 33 nF 1V , 1kHz 47 nF 1V , 1kHz 100 nF Available Tolerance Thick. (mm)  ±5%,±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10%  ±5%,±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10% ±10% ±10%  ±5%,±10% ±10% ±10%  ±5%,±10% ±10% ±10%  ±5%,±10%  ±5%,±10%  ±5%,±10%  ±5%,±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10%, ±20% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 Tolerance(mm) L/W ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 Thick. ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 DF (max.) 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 5.0% 5.0% 5.0% 5.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 5.0% 5.0% 5.0% 5.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10% Standard Packing Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II)*       25  Rev. 202204 MLCC  DARFON P/N General Purpose  RV     RV 10V 6.3V DARFON P/N DARFON P/N 2 C0603X7R221□ DTS C0603X7R102KDTS C0603X7R182KDTS C0603X7R222KDTS C0603X7R272□ DTS C0603X7R332KDTS C0603X7R392KDTS C0603X7R472KDTS C0603X7R562KDTS C0603X7R682KDTS C0603X7R822KDTS C0603X7R103□ DTS C0603X7R473KDTS C0603X7R104□ DTS C0603X7R222KCTS C0603X7R332KCTS C0603X7R103KCTS C0603X7R153KCTS C0603X7R333KCTS C0603X7R104KCTS C0603X7R224KCTS C0603X7R221□ DT C0603X7R102KDT C0603X7R182KDT C0603X7R222KDT C0603X7R272□ DT C0603X7R332KDT C0603X7R392KDT C0603X7R472KDT C0603X7R562KDT C0603X7R682KDT C0603X7R822KDT C0603X7R103□ DT C0603X7R473KDT C0603X7R104□ DT C0603X7R222KCT C0603X7R332KCT C0603X7R103KCT C0603X7R153KCT C0603X7R333KCT C0603X7R104KCT C0603X7R224KCT Measuring Capacitance Condition Value Unit 1V , 1kHz 220 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 47 nF 1V , 1kHz 100 nF 1V , 1kHz 2.2 nF 1V , 1kHz 3.3 nF 1V , 1kHz 10 nF 1V , 1kHz 15 nF 1V , 1kHz 33 nF 1V , 1kHz 100 nF 1V , 1kHz 220 nF Available Tolerance Thick. (mm)  ±5%,±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10%, ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 Tolerance(mm) L/W ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.05 ± 0.05 ± 0.05 Thick. ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.03 ± 0.03 ± 0.03 ± 0.05 ± 0.05 ± 0.05 ± 0.05                                                   □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  26 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10% 5.0% 5.0% 5.0% 10% 10% 10% 12.5% Standard Packing Paper, 15Kpcs Paper, 15Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (I) (I) (I) (II) (II) (II)  (II)*     C1005X7R Series (EIA0402)  50V 35V 25V   DARFON P/N 2 C1005X7R101□ GTS C1005X7R121KGTS C1005X7R151KGTS C1005X7R181KGTS C1005X7R201KGTS C1005X7R221KGTS C1005X7R271□ GTS C1005X7R301KGTS C1005X7R331□ GTS C1005X7R391□ GTS C1005X7R471□ GTS C1005X7R561KGTS C1005X7R681□ GTS C1005X7R751KGTS C1005X7R821KGTS C1005X7R102□ GTS C1005X7R122□ GTS C1005X7R152KGTS C1005X7R182KGTS C1005X7R222□ GTS C1005X7R272□ GTS C1005X7R332□ GTS C1005X7R392KGTS C1005X7R472□ GTS C1005X7R562□ GTS C1005X7R682□ GTS C1005X7R822KGTS C1005X7R103□ GTS C1005X7R123KGTS C1005X7R153KGTS C1005X7R183KGTS C1005X7R223□ GTS C1005X7R333KGTS C1005X7R393KGTS C1005X7R473KGTS C1005X7R683KGTS C1005X7R104□ GTS C1005X7R473KNTS C1005X7R101KFTS C1005X7R121KFTS C1005X7R151KFTS C1005X7R181KFTS C1005X7R221KFTS C1005X7R271KFTS C1005X7R331KFTS C1005X7R391KFTS C1005X7R471KFTS C1005X7R561KFTS C1005X7R681KFTS C1005X7R821KFTS C1005X7R102□ FTS C1005X7R122KFTS C1005X7R152KFTS C1005X7R182KFTS C1005X7R222KFTS C1005X7R272KFTS C1005X7R332□ FTS C1005X7R392KFTS C1005X7R472□ FTS C1005X7R562KFTS C1005X7R682KFTS C1005X7R822KFTS C1005X7R103□ FTS C1005X7R123KFTS C1005X7R153□ FTS C1005X7R183KFTS C1005X7R223□ FTS C1005X7R273□ FTS C1005X7R333KFTS C1005X7R393KFTS C1005X7R473□ FTS C1005X7R563KFTS C1005X7R683KFTS C1005X7R104□ FTS C1005X7R224KFTS C1005X7R101□ GT C1005X7R121KGT C1005X7R151KGT C1005X7R181KGT C1005X7R201KGT C1005X7R221KGT C1005X7R271□ GT C1005X7R301KGT C1005X7R331□ GT C1005X7R391□ GT C1005X7R471□ GT C1005X7R561KGT C1005X7R681□ GT C1005X7R751KGT C1005X7R821KGT C1005X7R102□ GT C1005X7R122□ GT C1005X7R152KGT C1005X7R182KGT C1005X7R222□ GT C1005X7R272□ GT C1005X7R332□ GT C1005X7R392KGT C1005X7R472□ GT C1005X7R562□ GT C1005X7R682□ GT C1005X7R822KGT C1005X7R103□ GT C1005X7R123KGT C1005X7R153KGT C1005X7R183KGT C1005X7R223□ GT C1005X7R333KGT C1005X7R393KGT C1005X7R473KGT C1005X7R683KGT C1005X7R104□ GT C1005X7R473KNT C1005X7R101KFT C1005X7R121KFT C1005X7R151KFT C1005X7R181KFT C1005X7R221KFT C1005X7R271KFT C1005X7R331KFT C1005X7R391KFT C1005X7R471KFT C1005X7R561KFT C1005X7R681KFT C1005X7R821KFT C1005X7R102□ FT C1005X7R122KFT C1005X7R152KFT C1005X7R182KFT C1005X7R222KFT C1005X7R272KFT C1005X7R332□ FT C1005X7R392KFT C1005X7R472□ FT C1005X7R562KFT C1005X7R682KFT C1005X7R822KFT C1005X7R103□ FT C1005X7R123KFT C1005X7R153□ FT C1005X7R183KFT C1005X7R223□ FT C1005X7R273□ FT C1005X7R333KFT C1005X7R393KFT C1005X7R473□ FT C1005X7R563KFT C1005X7R683KFT C1005X7R104□ FT C1005X7R224KFT Measuring Capacitance Condition Value Unit 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 200 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 300 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 750 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 68 nF 1V , 1kHz 100 nF 1V , 1kHz 47 nF 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 100 nF 1V , 1kHz 220 nF Available Tolerance Thick. (mm)  ±5%,±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10%  ±5%,±10%  ±5%,±10%  ±5%,±10% ±10%  ±5%,±10% ±10% ±10%  ±5%,±10%, ±20%  ±5%,±10% ±10% ±10%  ±5%,±10%  ±5%,±10%  ±5%,±10% ±10%  ±5%,±10%  ±5%,±10%  ±5%,±10% ±10%  ±5%,±10%, ±20% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10% ±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10%, ±20% ±10% ±10%  ±5%,±10% ±10% ±10% ±10%, ±20% ±10% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 27  Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 DF (max.) 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 10.0% 10.0% 10.0% 10.0% 10.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 10.0% 10.0% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) Rev. 202204 MLCC  DARFON P/N General Purpose  RV   RV 16V 10V DARFON P/N DARFON P/N 2 C1005X7R101KETS C1005X7R121KETS C1005X7R151KETS C1005X7R181KETS C1005X7R221□ ETS C1005X7R271KETS C1005X7R331KETS C1005X7R391KETS C1005X7R471KETS C1005X7R561KETS C1005X7R681KETS C1005X7R821KETS C1005X7R102□ ETS C1005X7R122KETS C1005X7R152□ ETS C1005X7R182KETS C1005X7R222□ ETS C1005X7R272KETS C1005X7R332KETS C1005X7R392KETS C1005X7R472KETS C1005X7R562KETS C1005X7R682KETS C1005X7R822KETS C1005X7R103□ ETS C1005X7R123KETS C1005X7R153KETS C1005X7R183KETS C1005X7R223KETS C1005X7R273KETS C1005X7R333□ ETS C1005X7R393KETS C1005X7R473□ ETS C1005X7R563KETS C1005X7R683KETS C1005X7R823KETS C1005X7R104□ ETS C1005X7R154KETS C1005X7R224□ ETS C1005X7R334KETS C1005X7R474KETS C1005X7R105KETS C1005X7R101KDTS C1005X7R121KDTS C1005X7R151KDTS C1005X7R181KDTS C1005X7R221KDTS C1005X7R271KDTS C1005X7R331KDTS C1005X7R391KDTS C1005X7R471KDTS C1005X7R561KDTS C1005X7R681KDTS C1005X7R821KDTS C1005X7R102KDTS C1005X7R122KDTS C1005X7R152KDTS C1005X7R182KDTS C1005X7R222KDTS C1005X7R272KDTS C1005X7R332KDTS C1005X7R392KDTS C1005X7R472KDTS C1005X7R562KDTS C1005X7R682KDTS C1005X7R822KDTS C1005X7R103KDTS C1005X7R123KDTS C1005X7R153KDTS C1005X7R183KDTS C1005X7R223KDTS C1005X7R273KDTS C1005X7R333KDTS C1005X7R393KDTS C1005X7R473KDTS C1005X7R101KET C1005X7R121KET C1005X7R151KET C1005X7R181KET C1005X7R221□ ET C1005X7R271KET C1005X7R331KET C1005X7R391KET C1005X7R471KET C1005X7R561KET C1005X7R681KET C1005X7R821KET C1005X7R102□ ET C1005X7R122KET C1005X7R152□ ET C1005X7R182KET C1005X7R222□ ET C1005X7R272KET C1005X7R332KET C1005X7R392KET C1005X7R472KET C1005X7R562KET C1005X7R682KET C1005X7R822KET C1005X7R103□ ET C1005X7R123KET C1005X7R153KET C1005X7R183KET C1005X7R223KET C1005X7R273KET C1005X7R333□ ET C1005X7R393KET C1005X7R473□ ET C1005X7R563KET C1005X7R683KET C1005X7R823KET C1005X7R104□ ET C1005X7R154KET C1005X7R224□ ET C1005X7R334KET C1005X7R474KET C1005X7R105KET C1005X7R101KDT C1005X7R121KDT C1005X7R151KDT C1005X7R181KDT C1005X7R221KDT C1005X7R271KDT C1005X7R331KDT C1005X7R391KDT C1005X7R471KDT C1005X7R561KDT C1005X7R681KDT C1005X7R821KDT C1005X7R102KDT C1005X7R122KDT C1005X7R152KDT C1005X7R182KDT C1005X7R222KDT C1005X7R272KDT C1005X7R332KDT C1005X7R392KDT C1005X7R472KDT C1005X7R562KDT C1005X7R682KDT C1005X7R822KDT C1005X7R103KDT C1005X7R123KDT C1005X7R153KDT C1005X7R183KDT C1005X7R223KDT C1005X7R273KDT C1005X7R333KDT C1005X7R393KDT C1005X7R473KDT Measuring Capacitance Condition Value Unit 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 150 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%, ±10%,±20% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10%,±20% ±10% ±10% ±10% ±5%, ±10%,±20% ±10% ±10%,±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50   28 Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 12.5% 12.5% 12.5% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II)* (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I)   6.3V DARFON P/N 2 C1005X7R563KDTS C1005X7R683KDTS C1005X7R823KDTS C1005X7R104□ DTS C1005X7R224KDTS C1005X7R334KDTS C1005X7R474KDTS C1005X7R684KDTS C1005X7R105KDTS C1005X7R103KCTS C1005X7R223KCTS C1005X7R473KCTS C1005X7R683KCTS C1005X7R104□ CTS C1005X7R224KCTS C1005X7R334KCTS C1005X7R474□ CTS C1005X7R105□ CTS C1005X7R563KDT C1005X7R683KDT C1005X7R823KDT C1005X7R104□ DT C1005X7R224KDT C1005X7R334KDT C1005X7R474KDT C1005X7R684KDT C1005X7R105KDT C1005X7R103KCT C1005X7R223KCT C1005X7R473KCT C1005X7R683KCT C1005X7R104□ CT C1005X7R224KCT C1005X7R334KCT C1005X7R474□ CT C1005X7R105□ CT Measuring Capacitance Condition Value Unit 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 10 nF 1V , 1kHz 22 nF 1V , 1kHz 47 nF 1V , 1kHz 68 nF 1V , 1kHz 100 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF Available Tolerance Thick. (mm) ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10%, ±20% ±10%, ±20% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 Tolerance(mm) L/W ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.05 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.10 ±0.05 DF (max.) 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 12.5% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (II) (II) (II) (II)* (II)* (I) (I) (I) (I) (I) (II) (II) (II) (II)*                                                       □ Tolerance Code: J=±5%, K=±10%, M=±20%; Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    29  Rev. 202204 MLCC  10V DARFON P/N   General Purpose  RV   C1608X7R Series (EIA0603)  RV 50V 35V 25V DARFON P/N DARFON P/N 2 C1608X7R101KGTS C1608X7R121KGTS C1608X7R151KGTS C1608X7R181KGTS C1608X7R221KGTS C1608X7R271KGTS C1608X7R331KGTS C1608X7R391KGTS C1608X7R471□ GTS C1608X7R561KGTS C1608X7R681KGTS C1608X7R821KGTS C1608X7R102□ GTS C1608X7R122□ GTS C1608X7R152□ GTS C1608X7R182KGTS C1608X7R202KGTS C1608X7R222KGTS C1608X7R272KGTS C1608X7R332□ GTS C1608X7R392KGTS C1608X7R472□ GTS C1608X7R562KGTS C1608X7R682□ GTS C1608X7R822KGTS C1608X7R103□ GTS C1608X7R123KGTS C1608X7R153KGTS C1608X7R183□ GTS C1608X7R223KGTS C1608X7R273KGTS C1608X7R333KGTS C1608X7R393KGTS C1608X7R473KGTS C1608X7R563KGTS C1608X7R683KGTS C1608X7R823KGTS C1608X7R104□ GTS C1608X7R154KGTS C1608X7R224□ GTS C1608X7R334KGTS C1608X7R474KGTS C1608X7R105KGTS C1608X7R474KNTS C1608X7R105KNTS C1608X7R101KFTS C1608X7R121KFTS C1608X7R151KFTS C1608X7R181KFTS C1608X7R221KFTS C1608X7R271KFTS C1608X7R331KFTS C1608X7R391KFTS C1608X7R471KFTS C1608X7R561KFTS C1608X7R681KFTS C1608X7R821KFTS C1608X7R102KFTS C1608X7R122KFTS C1608X7R152KFTS C1608X7R182KFTS C1608X7R222KFTS C1608X7R272KFTS C1608X7R332KFTS C1608X7R392KFTS C1608X7R472KFTS C1608X7R101KGT C1608X7R121KGT C1608X7R151KGT C1608X7R181KGT C1608X7R221KGT C1608X7R271KGT C1608X7R331KGT C1608X7R391KGT C1608X7R471□ GT C1608X7R561KGT C1608X7R681KGT C1608X7R821KGT C1608X7R102□ GT C1608X7R122□ GT C1608X7R152□ GT C1608X7R182KGT C1608X7R202KGT C1608X7R222KGT C1608X7R272KGT C1608X7R332□ GT C1608X7R392KGT C1608X7R472□ GT C1608X7R562KGT C1608X7R682□ GT C1608X7R822KGT C1608X7R103□ GT C1608X7R123KGT C1608X7R153KGT C1608X7R183□ GT C1608X7R223KGT C1608X7R273KGT C1608X7R333KGT C1608X7R393KGT C1608X7R473KGT C1608X7R563KGT C1608X7R683KGT C1608X7R823KGT C1608X7R104□ GT C1608X7R154KGT C1608X7R224□ GT C1608X7R334KGT C1608X7R474KGT C1608X7R105KGT C1608X7R474KNT C1608X7R105KNT C1608X7R101KFT C1608X7R121KFT C1608X7R151KFT C1608X7R181KFT C1608X7R221KFT C1608X7R271KFT C1608X7R331KFT C1608X7R391KFT C1608X7R471KFT C1608X7R561KFT C1608X7R681KFT C1608X7R821KFT C1608X7R102KFT C1608X7R122KFT C1608X7R152KFT C1608X7R182KFT C1608X7R222KFT C1608X7R272KFT C1608X7R332KFT C1608X7R392KFT C1608X7R472KFT Measuring Capacitance Condition Value Unit 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.0 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 150 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%,±20% ±10% ±10% ±10%  ±5%,±10%  ±5%,±10%  ±5%,±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10%  ±5%,±10% ±10%  ±5%,±10%,±20% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10%,±20% ±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 30 Tolerance(mm) L/W ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 DF (max.) 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 3.5% 10.0% 10.0% 10.0% 10.0% 10.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% Standard Packing  Paper, 4Kpcs  Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) 25V 16V DARFON P/N 2 C1608X7R562KFTS C1608X7R682KFTS C1608X7R822KFTS C1608X7R103□ FTS C1608X7R123KFTS C1608X7R153KFTS C1608X7R183KFTS C1608X7R223□ FTS C1608X7R273□ FTS C1608X7R333KFTS C1608X7R393KFTS C1608X7R473KFTS C1608X7R563KFTS C1608X7R683KFTS C1608X7R823KFTS C1608X7R104□ FTS C1608X7R124KFTS C1608X7R154KFTS C1608X7R184KFTS C1608X7R224□ FTS C1608X7R334KFTS C1608X7R394KFTS C1608X7R474□ FTS C1608X7R564KFTS C1608X7R105KFTS C1608X7R225KFTS C1608X7R101KETS C1608X7R121KETS C1608X7R151KETS C1608X7R181KETS C1608X7R221KETS C1608X7R271KETS C1608X7R331KETS C1608X7R391□ ETS C1608X7R471KETS C1608X7R561KETS C1608X7R681KETS C1608X7R821KETS C1608X7R102KETS C1608X7R122KETS C1608X7R152KETS C1608X7R182KETS C1608X7R222KETS C1608X7R272KETS C1608X7R332KETS C1608X7R392KETS C1608X7R472KETS C1608X7R562KETS C1608X7R682KETS C1608X7R822KETS C1608X7R103KETS C1608X7R123KETS C1608X7R153KETS C1608X7R183KETS C1608X7R223KETS C1608X7R273KETS C1608X7R333KETS C1608X7R393KETS C1608X7R473KETS C1608X7R563KETS C1608X7R683KETS C1608X7R823KETS C1608X7R104KETS C1608X7R124KETS C1608X7R154KETS C1608X7R184KETS C1608X7R224KETS C1608X7R334KETS C1608X7R474KETS C1608X7R684KETS C1608X7R105□ ETS C1608X7R225□ ETS C1608X7R562KFT C1608X7R682KFT C1608X7R822KFT C1608X7R103□ FT C1608X7R123KFT C1608X7R153KFT C1608X7R183KFT C1608X7R223□ FT C1608X7R273□ FT C1608X7R333KFT C1608X7R393KFT C1608X7R473KFT C1608X7R563KFT C1608X7R683KFT C1608X7R823KFT C1608X7R104□ FT C1608X7R124KFT C1608X7R154KFT C1608X7R184KFT C1608X7R224□ FT C1608X7R334KFT C1608X7R394KFT C1608X7R474□ FT C1608X7R564KFT C1608X7R105KFT C1608X7R225KFT C1608X7R101KET C1608X7R121KET C1608X7R151KET C1608X7R181KET C1608X7R221KET C1608X7R271KET C1608X7R331KET C1608X7R391□ ET C1608X7R471KET C1608X7R561KET C1608X7R681KET C1608X7R821KET C1608X7R102KET C1608X7R122KET C1608X7R152KET C1608X7R182KET C1608X7R222KET C1608X7R272KET C1608X7R332KET C1608X7R392KET C1608X7R472KET C1608X7R562KET C1608X7R682KET C1608X7R822KET C1608X7R103KET C1608X7R123KET C1608X7R153KET C1608X7R183KET C1608X7R223KET C1608X7R273KET C1608X7R333KET C1608X7R393KET C1608X7R473KET C1608X7R563KET C1608X7R683KET C1608X7R823KET C1608X7R104KET C1608X7R124KET C1608X7R154KET C1608X7R184KET C1608X7R224KET C1608X7R334KET C1608X7R474KET C1608X7R684KET C1608X7R105□ ET C1608X7R225□ ET Measuring Capacitance Condition Value Unit 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 120 nF 1V , 1kHz 150 nF 1V , 1kHz 180 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 390 nF 1V , 1kHz 470 nF 1V , 1kHz 560 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 120 nF 1V , 1kHz 150 nF 1V , 1kHz 180 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF Available Tolerance Thick. (mm) ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10%  ±5%,±10%  ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10%  ±5%,±10% ±10% ±10% ±10% ±10%,±20% ±10% ±10% ±10%,±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10%, ±20% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 DF (max.) 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 7.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II)* (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    31  Rev. 202204 MLCC  DARFON P/N General Purpose  RV   RV 10V 6.3V DARFON P/N DARFON P/N 2 C1608X7R101KDTS C1608X7R121KDTS C1608X7R151KDTS C1608X7R181KDTS C1608X7R221KDTS C1608X7R271KDTS C1608X7R331KDTS C1608X7R391KDTS C1608X7R471KDTS C1608X7R561KDTS C1608X7R681KDTS C1608X7R821KDTS C1608X7R102KDTS C1608X7R122KDTS C1608X7R152KDTS C1608X7R182KDTS C1608X7R222KDTS C1608X7R272KDTS C1608X7R332KDTS C1608X7R392KDTS C1608X7R472KDTS C1608X7R562KDTS C1608X7R682KDTS C1608X7R822KDTS C1608X7R103KDTS C1608X7R123KDTS C1608X7R153KDTS C1608X7R183KDTS C1608X7R223KDTS C1608X7R273KDTS C1608X7R333KDTS C1608X7R393KDTS C1608X7R473KDTS C1608X7R563KDTS C1608X7R683KDTS C1608X7R823KDTS C1608X7R104KDTS C1608X7R124KDTS C1608X7R154KDTS C1608X7R224KDTS C1608X7R334KDTS C1608X7R474KDTS C1608X7R684KDTS C1608X7R105□ DTS C1608X7R225KDTS C1608X7R475KDTS C1608X7R223KCTS C1608X7R104KCTS C1608X7R474KCTS C1608X7R105KCTS C1608X7R225KCTS C1608X7R475□ CTS C1608X7R101KDT C1608X7R121KDT C1608X7R151KDT C1608X7R181KDT C1608X7R221KDT C1608X7R271KDT C1608X7R331KDT C1608X7R391KDT C1608X7R471KDT C1608X7R561KDT C1608X7R681KDT C1608X7R821KDT C1608X7R102KDT C1608X7R122KDT C1608X7R152KDT C1608X7R182KDT C1608X7R222KDT C1608X7R272KDT C1608X7R332KDT C1608X7R392KDT C1608X7R472KDT C1608X7R562KDT C1608X7R682KDT C1608X7R822KDT C1608X7R103KDT C1608X7R123KDT C1608X7R153KDT C1608X7R183KDT C1608X7R223KDT C1608X7R273KDT C1608X7R333KDT C1608X7R393KDT C1608X7R473KDT C1608X7R563KDT C1608X7R683KDT C1608X7R823KDT C1608X7R104KDT C1608X7R124KDT C1608X7R154KDT C1608X7R224KDT C1608X7R334KDT C1608X7R474KDT C1608X7R684KDT C1608X7R105□ DT C1608X7R225KDT C1608X7R475KDT C1608X7R223KCT C1608X7R104KCT C1608X7R474KCT C1608X7R105KCT C1608X7R225KCT C1608X7R475□ CT Measuring Capacitance Condition Value Unit 1V , 1kHz 100 pF 1V , 1kHz 120 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 120 nF 1V , 1kHz 150 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF 1V , 1kHz 22 nF 1V , 1kHz 100 nF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.20 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.20                     □ Tolerance Code: J=±5%, K=±10%, M=±20%; Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  32 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II)* (I) (I) (I) (II) (II) (II)     C2012X7R Series (EIA0805)    DARFON P/N 2 C2012X7R101KGT C2012X7R151KGT C2012X7R181KGT C2012X7R221KGT C2012X7R271KGT C2012X7R331KGT C2012X7R391KGT C2012X7R471KGT C2012X7R561KGT C2012X7R681KGT C2012X7R821KGT C2012X7R102□ GT C2012X7R122KGT C2012X7R152KGT C2012X7R182KGT C2012X7R222KGT C2012X7R272KGT C2012X7R332KGT C2012X7R392KGT C2012X7R472KGT C2012X7R562KGT C2012X7R682KGT 50V C2012X7R101KGTS C2012X7R151KGTS C2012X7R181KGTS C2012X7R221KGTS C2012X7R271KGTS C2012X7R331KGTS C2012X7R391KGTS C2012X7R471KGTS C2012X7R561KGTS C2012X7R681KGTS C2012X7R821KGTS C2012X7R102□ GTS C2012X7R122KGTS C2012X7R152KGTS C2012X7R182KGTS C2012X7R222KGTS C2012X7R272KGTS C2012X7R332KGTS C2012X7R392KGTS C2012X7R472KGTS C2012X7R562KGTS C2012X7R682KGTS C2012X7R682KGPSG C2012X7R822KGTS C2012X7R103□ GTS C2012X7R123KGTS C2012X7R153KGTS C2012X7R183KGTS C2012X7R223□ GTS C2012X7R273KGTS C2012X7R333KGTS C2012X7R393KGTS C2012X7R473KGTS C2012X7R563KGTS C2012X7R683KGTS C2012X7R823KGTS C2012X7R104□ GTSD C2012X7R104KGTS C2012X7R124KGTS C2012X7R154KGTS C2012X7R184KGTS C2012X7R184KGPSG C2012X7R224KGTS C2012X7R224KGPS C2012X7R334KGPS C2012X7R474KGPS C2012X7R684KGPS C2012X7R105□ GPSG C2012X7R225KGPSG C2012X7R822KGT C2012X7R103□ GT C2012X7R123KGT C2012X7R153KGT C2012X7R183KGT C2012X7R223□ GT C2012X7R273KGT C2012X7R333KGT C2012X7R393KGT C2012X7R473KGT C2012X7R563KGT C2012X7R683KGT C2012X7R823KGT C2012X7R104KGT C2012X7R124KGT C2012X7R154KGT C2012X7R184KGT C2012X7R224KGT C2012X7R224KGP C2012X7R334KGP C2012X7R474KGP C2012X7R684KGP C2012X7R105□ GP C2012X7R225KGP Measuring Capacitance Condition Value Unit 1V , 1kHz 100 pF 1V , 1kHz 150 pF 1V , 1kHz 180 pF 1V , 1kHz 220 pF 1V , 1kHz 270 pF 1V , 1kHz 330 pF 1V , 1kHz 390 pF 1V , 1kHz 470 pF 1V , 1kHz 560 pF 1V , 1kHz 680 pF 1V , 1kHz 820 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 6.8 nF 1V , 1kHz 8.2 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 100 nF 1V , 1kHz 120 nF 1V , 1kHz 150 nF 1V , 1kHz 180 nF 1V , 1kHz 180 nF 1V , 1kHz 220 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%, ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%,±10% ±10% ±10% ±10% ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%,±10%,±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10% 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 1.25 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.80 0.85 0.85 0.85 0.85 1.25 0.85 1.25 1.25 1.25 1.25 1.25 1.25 33  Tolerance(mm) L/W ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15/±0.20 ±0.15/±0.20 ±0.20 Thick. ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 DF (max.) 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 10.0% 10.0% 10.0% Standard Packing Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) Rev. 202204 MLCC  DARFON P/N General Purpose  RV RV DARFON P/N DARFON P/N 2 35V C2012X7R474KNPS C2012X7R102KFTS C2012X7R122KFTS C2012X7R152KFTS C2012X7R182KFTS C2012X7R222KFTS C2012X7R272KFTS C2012X7R332KFTS C2012X7R392KFTS C2012X7R472KFTS C2012X7R562KFTS C2012X7R682KFTS C2012X7R103KFTS C2012X7R123KFTS C2012X7R153KFTS C2012X7R183KFTS C2012X7R223KFTS C2012X7R273KFTS C2012X7R333KFTS C2012X7R393KFTS C2012X7R473KFTS C2012X7R563KFTS C2012X7R683KFTS C2012X7R823KFTS C2012X7R104□ FTS C2012X7R124KFTS C2012X7R154KFTS C2012X7R184KFTS C2012X7R224KFTS C2012X7R224KFPS C2012X7R334KFPS C2012X7R474KFPS C2012X7R684KFPS C2012X7R105□ FPS C2012X7R225KFPS C2012X7R335KFPS C2012X7R475KFPS C2012X7R106KFPS C2012X7R123KETS C2012X7R104KETS C2012X7R224KETS C2012X7R224KEPS C2012X7R334KEPS C2012X7R474KEPS C2012X7R684KEPS C2012X7R105□ EPS C2012X7R225□ EPS C2012X7R335KEPS C2012X7R475□ EPS C2012X7R106□ EPS C2012X7R105□ DPS C2012X7R225□ DPS C2012X7R335KDPS C2012X7R475KDPS C2012X7R106KDPS C2012X7R226MDPS C2012X7R335KCPS C2012X7R475KCPS C2012X7R106□ CPS C2012X7R226MCPS C2012X7R106□ BPS C2012X7R474KNP C2012X7R102KFT C2012X7R122KFT C2012X7R152KFT C2012X7R182KFT C2012X7R222KFT C2012X7R272KFT C2012X7R332KFT C2012X7R392KFT C2012X7R472KFT C2012X7R562KFT C2012X7R682KFT C2012X7R103KFT C2012X7R123KFT C2012X7R153KFT C2012X7R183KFT C2012X7R223KFT C2012X7R273KFT C2012X7R333KFT C2012X7R393KFT C2012X7R473KFT C2012X7R563KFT C2012X7R683KFT C2012X7R823KFT C2012X7R104□ FT C2012X7R124KFT C2012X7R154KFT C2012X7R184KFT C2012X7R224KFT C2012X7R224KFP C2012X7R334KFP C2012X7R474KFP C2012X7R684KFP C2012X7R105□ FP C2012X7R225KFP C2012X7R335KFP C2012X7R475KFP C2012X7R106KFP C2012X7R123KET C2012X7R104KET C2012X7R224KET C2012X7R224KEP C2012X7R334KEP C2012X7R474KEP C2012X7R684KEP C2012X7R105□ EP C2012X7R225□ EP C2012X7R335KEP C2012X7R475□ EP C2012X7R106□ EP C2012X7R105□ DP C2012X7R225□ DP C2012X7R335KDP C2012X7R475KDP C2012X7R106KDP C2012X7R226MDP C2012X7R335KCP C2012X7R475KCP C2012X7R106□ CP C2012X7R226MCP C2012X7R106□ BP 25V 16V 10V 6.3V 4V Measuring Capacitance Condition Value Unit 1V , 1kHz 470 nF 1V , 1kHz 1.0 nF 1V , 1kHz 1.2 nF 1V , 1kHz 1.5 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 2.7 nF 1V , 1kHz 3.3 nF 1V , 1kHz 3.9 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 6.8 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 120 nF 1V , 1kHz 150 nF 1V , 1kHz 180 nF 1V , 1kHz 220 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 3.3 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 1V , 1kHz 12 nF 1V , 1kHz 100 nF 1V , 1kHz 220 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 3.3 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 3.3 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 0.5V , 120Hz 22 uF 1V , 1kHz 3.3 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 0.5V , 120Hz 22 uF 1V , 1kHz 10 uF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10%, ±20% ±10% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10% ±10% ±10%  ±20% ±10% ±10% ±10%, ±20%  ±20% ±10%, ±20% 1.25 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 0.85 0.85 0.85 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 Tolerance(mm) L/W ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.15/±0.20 ±0.20 ±0.15/±0.20 Thick. ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.    (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage. 34 DF (max.) Standard Packing Test Spec. 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 5.0% 5.0% 5.0% 10.0% 10.0% 12.5% 12.5% 12.5% 3.5% 3.5% 3.5% 3.5% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 10.0% 15.0% Embossed, 3Kpcs (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II)* (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II)* (I) (II) (II) (II) (II) (II)* (II) (II) (II) (II)* (II) Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs   C3216X7R Series (EIA1206)  50V 35V 25V 16V 10V 6.3V DARFON P/N 2 C3216X7R221KGTS C3216X7R102KGTS C3216X7R182KGTS C3216X7R222KGTS C3216X7R472KGTS C3216X7R562□ GTS C3216X7R103□ GTS C3216X7R123KGTS C3216X7R153KGTS C3216X7R183KGTS C3216X7R223KGTS C3216X7R273KGTS C3216X7R333KGTS C3216X7R393KGTS C3216X7R473KGTS C3216X7R563KGTS C3216X7R683KGTS C3216X7R823KGTS C3216X7R104□ GTS C3216X7R224KGPS C3216X7R224KGPSF C3216X7R334□ GPS C3216X7R474KGPSG C3216X7R474KGPS C3216X7R684KGPS C3216X7R105KGPSG C3216X7R105KGPS C3216X7R225KGPSL C3216X7R475KGPS C3216X7R106KGPSL C3216X7R105MNPS C3216X7R106KNPSL C3216X7R224KFPS C3216X7R334KFPS C3216X7R334KFPSG C3216X7R474KFPS C3216X7R474KFPSL C3216X7R105□ FPSG C3216X7R105KFPS C3216X7R225KFPS C3216X7R475KFPS C3216X7R106□ FPS C3216X7R104KETS C3216X7R474KEPS C3216X7R474KEPSL C3216X7R105KEPSL C3216X7R225KEPS C3216X7R475□ EPS C3216X7R106□ EPS C3216X7R226□ EPS C3216X7R225KDPS C3216X7R475□ DPS C3216X7R106□ DPS C3216X7R226□ DPS C3216X7R106KCPS C3216X7R226KCPS C3216X7R221KGT C3216X7R102KGT C3216X7R182KGT C3216X7R222KGT C3216X7R472KGT C3216X7R562□ GT C3216X7R103□ GT C3216X7R123KGT C3216X7R153KGT C3216X7R183KGT C3216X7R223KGT C3216X7R273KGT C3216X7R333KGT C3216X7R393KGT C3216X7R473KGT C3216X7R563KGT C3216X7R683KGT C3216X7R823KGT C3216X7R104□ GT C3216X7R224KGP C3216X7R334□ GP C3216X7R474KGP C3216X7R684KGP C3216X7R105KGP C3216X7R225KGP C3216X7R475KGP C3216X7R106KGP C3216X7R105MNP C3216X7R106KNP C3216X7R224KFP C3216X7R334KFP C3216X7R474KFP C3216X7R105KFP C3216X7R225KFP C3216X7R475KFP C3216X7R106□ FP C3216X7R104KET C3216X7R474KEP C3216X7R225KEP C3216X7R475□ EP C3216X7R106□ EP C3216X7R226□ EP C3216X7R225KDP C3216X7R475□ DP C3216X7R106□ DP C3216X7R226□ DP C3216X7R106KCP C3216X7R226KCP Measuring Capacitance Condition Value Unit 1V, 1kHz 220 pF 1V , 1kHz 1.0 nF 1V , 1kHz 1.8 nF 1V , 1kHz 2.2 nF 1V , 1kHz 4.7 nF 1V , 1kHz 5.6 nF 1V , 1kHz 10 nF 1V , 1kHz 12 nF 1V , 1kHz 15 nF 1V , 1kHz 18 nF 1V , 1kHz 22 nF 1V , 1kHz 27 nF 1V , 1kHz 33 nF 1V , 1kHz 39 nF 1V , 1kHz 47 nF 1V , 1kHz 56 nF 1V , 1kHz 68 nF 1V , 1kHz 82 nF 1V , 1kHz 100 nF 1V , 1kHz 220 nF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 470 nF 1V , 1kHz 680 nF 1V , 1kHz 1.0 uF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 1V , 1kHz 1.0 uF 1V , 1kHz 10 uF 1V , 1kHz 220 nF 1V , 1kHz 330 nF 1V , 1kHz 330 nF 1V , 1kHz 470 nF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 1V , 1kHz 100 nF 1V , 1kHz 470 nF 1V , 1kHz 470 nF 1V , 1kHz 1.0 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 0.5V , 120Hz 22 uF 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 0.5V , 120Hz 22 uF 1V , 1kHz 10 uF 0.5V , 120Hz 22 uF Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% ±10% ±5%,±10% ±10%,±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%,±10% ±10% ±10% ±5%,±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10%,±20% ±10% ±10% ±10% ±10%,±20% ±10% ±10% ±10% ±10% ±10% ±10%,±20% ±10%,±20% ±10%,±20% ±10% ±10%,±20% ±10%,±20% ±10%,±20% ±10% ±10% 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.95 1.15 1.25 1.25 1.60 1.60 1.25 1.60 1.60 1.60 1.60 1.60 1.60 0.95 0.95 1.25 1.25 1.60 1.25 1.60 1.60 1.60 1.60 0.85 1.25 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 Tolerance(mm) L/W ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 +0.3/-0.1 ±0.15 ±0.30 ±0.20 ±0.30 ±0.20 ±0.30 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.30 ±0.15 ±0.30 ±0.30 ±0.30 ±0.30 ±0.15 ±0.15 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.20 +0.3/-0.1 ±0.15 ±0.30 ±0.20 ±0.30 ±0.20 ±0.30 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.10 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 DF (max.) 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 10.0% 10.0% 10.0% 3.5% 10.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 5.0% 10.0% 10.0% 3.5% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% Standard Packing Paper, 4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (I) (II) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II)* (I) (I) (I) (I) (I) (II) (II)* (II)* (I) (II) (II) (II)* (II) (II)                     35  Rev. 202204 MLCC  DARFON P/N General Purpose  RV     C3225X7R Series (EIA1210)  RV 50V 35V 25V 16V 10V 6.3V DARFON P/N DARFON P/N 2 C3225X7R225MGPS C3225X7R475KGWS C3225X7R106KGWS C3225X7R106□ GPS C3225X7R106KNPS C3225X7R475KFPS C3225X7R475KFPSP C3225X7R106KFPS C3225X7R475KEPS C3225X7R106KEPS C3225X7R226□ EPS C3225X7R226KDPS C3225X7R476□ DPS C3225X7R476MCPS C3225X7R225MGP C3225X7R475KGW C3225X7R106KGW C3225X7R106□ GP C3225X7R106KNP C3225X7R475KFP C3225X7R106KFP C3225X7R475KEP C3225X7R106KEP C3225X7R226□ EP C3225X7R226KDP C3225X7R476□ DP C3225X7R476MCP Measuring Capacitance Condition Value Unit 1V , 1kHz 2.2 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 1V , 1kHz 10 uF 1V , 1kHz 10 uF 1V , 1kHz 4.7 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 1V , 1kHz 4.7 uF 1V , 1kHz 10 uF 0.5V , 120Hz 22 uF 0.5V , 120Hz 22 uF 0.5V , 120Hz 47 uF 0.5V , 120Hz 47 uF Available Tolerance Thick. (mm) ±20% ±10% ±10% ±10%,±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10%,±20% ±10% ±10%,±20% ±20% 2.50 2.50 2.00 2.50 2.50 2.00 2.50 2.00 2.50 2.00 2.50 2.50 2.50 2.50 36 Tolerance(mm) L/W ±0.3/±0.2 ±0.3 ±0.3/±0.2 ±0.30 ±0.30 ±0.3/±0.2 ±0.30 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 Thick. ±0.20 ±0.30 ±0.20 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.20 DF (max.) Standard Packing 5.0% Embossed, 1Kpcs 10.0% Embossed, 0.5Kpcs 15.0% Embossed, 1Kpcs 10.0% 10.0% Embossed, 1Kpcs 10.0% Embossed, 2Kpcs 10.0% Embossed, 1Kpcs 10.0% Embossed, 2Kpcs 5.0% Embossed, 1Kpcs 10.0% Embossed, 2Kpcs 10.0% Embossed, 1Kpcs 10.0% Embossed, 1Kpcs 10.0% 10.0% Embossed, 1Kpcs Test Spec. (II) (II) (II) (II) (II) (I) (I) (II) (II) (II) (II) (II) (II) (II)   DARFON P/N DARFON P/N 2 Measuring Condition 16V C0603X7S104□ ETS C0603X7S104KDTS C0603X7S224KDTS C0603X7S104KCTS C0603X7S224KCTS C0603X7S104□ ET C0603X7S104KDT C0603X7S224KDT C0603X7S104KCT C0603X7S224KCT  1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz 10V 6.3V Capacitance Value 100 100 220 100 220 Unit nF nF nF nF nF Available Tolerance Thick. (mm) ±10%,±20% ±10% ±10% ±10% ±10% 0.30 0.30 0.30 0.30 0.30 Available Tolerance Thick. (mm) ±10% ±10%,±20% ±10% 0.50 0.50 0.50 Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10% ±10% ±20% ±10% ±20% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Available Tolerance Thick. (mm) ±10% ±10% ±10% ±10%,±20% ±10%, ±20%  ±20% ±20% 1.25 1.25 1.25 1.25 1.25 1.25 1.25 Available Tolerance Thick. (mm) ±20% 1.60 Available Tolerance Thick. (mm) ±10%,±20% ±20% 2.50 2.50 Tolerance(mm) L/W ± 0.05 ± 0.05 ± 0.05 ± 0.05 ± 0.05 Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) Standard Packing Test Spec. 10.0% 10.0% 12.5% 10.0% 12.5% Paper, 15Kpcs  (II)* (II)  (II)* (II)  (II)* DF (max.) Standard Packing Paper, 15Kpcs Paper, 15Kpcs   C1005X7S Series (EIA0402)  RV 10V 6.3V DARFON P/N DARFON P/N 2 Measuring Condition C1005X7S105KDTS C1005X7S225□ DTS C1005X7S225KCTS C1005X7S105KDT C1005X7S225□ DT C1005X7S225KCT  1V , 1kHz  1V , 1kHz  1V , 1kHz Capacitance Value 1.0 2.2 2.2 Unit uF uF uF Tolerance(mm) L/W ± 0.10 ± 0.20 ± 0.20 Thick. ±0.10 ±0.20 ±0.20 10.0% 10.0% 10.0% Paper, 10Kpcs Paper, 10Kpcs Test Spec.  (II)*  (II)* (II)     C1608X7S Series (EIA0603)  RV DARFON P/N DARFON P/N 2 Measuring Condition 25V C1608X7S225KFTS C1608X7S225KETS C1608X7S475KETS C1608X7S225KDTS C1608X7S475KDTS C1608X7S106MDTS C1608X7S475KCTS C1608X7S106MCTS C1608X7S225KFT C1608X7S225KET C1608X7S475KET C1608X7S225KDT C1608X7S475KDT C1608X7S106MDT C1608X7S475KCT C1608X7S106MCT 1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz  1V , 1kHz 16V 10V 6.3V Capacitance Value 2.2 2.2 4.7 2.2 4.7 10 4.7 10 Unit uF uF uF uF uF uF uF uF Tolerance(mm) L/W ±0.20 ± 0.20 ± 0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 Thick. ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 DF (max.) Standard Packing Test Spec. 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% Paper, 4Kpcs (II)* (II) (II) (II) (II) (II)* (II) (II)* DF (max.) Standard Packing Test Spec. 10.0% 10.0% 12.5% 10.0% 10.0% 10.0% 10.0% Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs (II) (II) (II)*  (II)* (II)* (II)* (II)* DF (max.) Standard Packing Test Spec. 10.0% Embossed,2Kpcs (II) DF (max.) Standard Packing Test Spec. 10.0% 10.0% Embossed,1Kpcs Embossed,1Kpcs (II)  (II)* Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs   C2012X7S Series (EIA0805)  RV DARFON P/N 50V C2012X7S475KGPS C2012X7S225KFPS C2012X7S475KFPS C2012X7S106□ FPS C2012X7S106□ EPS C2012X7S226MDPS C2012X7S226MCPS 25V 16V 10V 6.3V Measuring Condition DARFON P/N 2 Capacitance Value C2012X7S475KGP 1V , 1kHz 4.7 C2012X7S225KFP  1V , 1kHz 2.2 C2012X7S475KFP  1V , 1kHz 4.7 C2012X7S106□ FP  1V , 1kHz 10 C2012X7S106□ EP  1V , 1kHz 10 C2012X7S226MDP  0.5V , 120Hz 22 C2012X7S226MCP  0.5V , 120Hz 22 Unit uF uF uF uF uF uF uF Tolerance(mm) L/W ± 0.20 ± 0.15 ±0.15/±0.20 ± 0.20 ±0.15/±0.20 ±0.20 ±0.20 Thick. ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 Embossed, 3Kpcs   C3216X7S Series (EIA1206)  RV DARFON P/N DARFON P/N 2 6.3V C3216X7S476MCPS C3216X7S476MCP Measuring Condition Capacitance Value 0.5V , 120Hz 47 Unit uF Tolerance(mm) L/W ±0.30 Thick. ±0.30   C3225X7S Series (EIA1210)  RV DARFON P/N DARFON P/N 2 50V 6.3V C3225X7S106□ GPS C3225X7S107MCPS C3225X7S106□ GP C3225X7S107MCP Measuring Condition Capacitance Value 1V , 1kHz 10 0.5V , 120Hz 100 Unit uF uF Tolerance(mm) L/W ±0.30 ± 0.30 Thick. ±0.30 ±0.30 □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request.  (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    37  Rev. 202204   General Purpose  RV MLCC    X7S Series    C0603X7S Series (EIA0201)    X7T Series    C1005X7T Series (EIA0402)  Capacitance RV DARFON P/N DARFON P/N 2 Measuring Condition Value Unit Available Tolerance Thick. (mm) 6.3V C1005X7T474KCTS C1005X7T474KCT 1V , 1kHz 470 nF ±10% 0.50 Available Tolerance Thick. (mm) ±20% ±20% 0.80 0.80 Available Tolerance Thick. (mm) ±20% ±20% 1.25 1.25 Available Tolerance Thick. (mm) ±10%,±20% 1.6 Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. ±0.10 ±0.10 10.0% Paper, 10Kpcs (II) DF (max.) Standard Packing Test Spec. 10.0% 10.0% Paper, 4Kpcs Paper, 4Kpcs (II) (II)* DF (max.) Standard Packing Test Spec. 10.0% 10.0% Embossed, 3Kpcs Embossed, 3Kpcs (II)* (II) DF (max.) Standard Packing Test Spec. 10.0% Embossed, 2Kpcs (II)*   C1608X7T Series (EIA0603)  RV DARFON P/N DARFON P/N 2 Measuring Condition 10V 6.3V C1608X7T225MDTS C1608X7T106MCTS C1608X7T225MDT C1608X7T106MCT 1V , 1kHz 1V , 1kHz Capacitance Value 2.2 10 Unit uF uF Tolerance(mm) L/W ±0.20 ± 0.20 Thick. ±0.20 ±0.20   C2012X7T Series (EIA0805)  RV DARFON P/N DARFON P/N 2 10V 6.3V C2012X7T226MDPS C2012X7T226MCPS C2012X7T226MDP C2012X7T226MCP Measuring Condition Capacitance Value 0.5V , 120Hz 22 0.5V , 120Hz 22 Unit uF uF Tolerance(mm) L/W ± 0.20 ± 0.20 Thick. ±0.20 ±0.20   C3216X7T Series (EIA1206)  RV DARFON P/N DARFON P/N 2 10V C3216X7T226□ DPS C3216X7T226□ DP Measuring Condition Capacitance Value 0.5V , 120Hz 22 Unit uF □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request.  38 Tolerance(mm) L/W ±0.30 Thick. ±0.30   General Purpose  MLCC  (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.    39  Rev. 202204   X7U Series    C3216X7U Series (EIA1206)  RV 6.3V 4V DARFON P/N DARFON P/N 2 C3216X7U476MCPS C3216X7U476MCP C3216X7U107MBPS C3216X7U107MBP Capacitance Value Unit 0.5V , 120Hz 47 uF 0.5V , 120Hz 100 uF Measuring Condition Available Tolerance Thick. (mm) ±20% ±20% 1.60 1.60 Tolerance(mm) L/W Thick. ± 0.30 ±0.30 ± 0.30 ±0.30        □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request.  (II)* High temperature load life test are applicable in rated voltage *100%. (II)/(II)* are applied with derating voltage.  40 DF (max.) Standard Packing Test Spec. 15.0% 15.0% Embossed, 2Kpcs Embossed, 2Kpcs (II)* (II)*     X8R Series    C1608X8R Series (EIA0603)  RV DARFON P/N DARFON P/N 2 Measuring Condition 50V C1608X8R104KGTS C1608X8R104KGT 1V , 1kHz 100 nF ±10% 0..8 Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. ±0.15 2.5% Paper, 4Kpcs (I) Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. 5.0% Embossed, 3Kpcs (I) ±0.15   C2012X8R Series (EIA0805)  RV DARFON P/N DARFON P/N 2 Measuring Condition 50V C2012X8R104KGPS C2012X8R104KGP 1V , 1kHz Capacitance Thick. Available Tolerance (mm) Value Unit 100 nF ±10% 1.25 ±0.15 ±0.15   MLCC    Capacitance Thick. Available Tolerance (mm) Value Unit     General Purpose                                                              □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request.    41  Rev. 202204   Test Spec.   General Purpose (I)  No Specification Item Temp. compensation type Test Method High dielectric constant type NP0: -55 to 125  ℃  X5R: -55 to 85  ℃  ---  X6S: -55 to 105  ℃  1 Operation Temperature Range X7R/X7S/X7T/X7U  : -55 to 125  ℃  X8R -55 to 150  ℃  Shown in the table of “Part Number & Characteristic”  The  rated  voltage  is  defined  as  the  maximum  voltage,  which  may be applied continuously to the capacitor.  2 Rated Voltage 3 Appearance No defects or abnormalities.  Visual inspection  4 Dimensions Within the specified dimension.  Using calipers  No defects or abnormalities.  No failure shall be observed when 250% of the rated voltage is  applied  between  the  terminations  for  1  to  5  seconds.  The  charge and discharge current is less than 50mA.  To apply rated voltage.  I.R.  ≧10GΩor RiCR≧500Ω-F (whichever is smaller)  The insulation resistance shall be measured with a DC voltage  not exceeding the rated voltage at 25℃  and 75%RH max, and  within 1 minute of charging.  5 Dielectric Strength 6 Insulation Resistance ( I.R.) 7 Capacitance 8 Q/Dissipation Factor ( D.F.) Within the specified tolerance  The  capacitance  /  D.F.  shall  be  measured  at  25℃  at  the  frequency  and  voltage  shown  in  the  table  of  “Part  Number  &  * X5R, X6S, X7R, X7S, X7T, X7U and X8R at 1000 hours  Characteristic”.  Shown  in  the  table  of  “Part  NP0:    If  C≦30pF,  DF≦1/(400+20C),  Number & Characteristic” C in pF  If C >30pF, DF≦0.1%.  Capacitance change  Capacitance change  1. Temperature compensation type:    NP0 within 0±30ppm/℃  under  X5R/X7R/X8R within ±15%  operating temperature range.  X6S/X7S within ±22%  The capacitance value at 25℃  and 85℃  shall be  measured and calculated from the formula given below.  T.C.=(C85-C25)/C25*ΔT*106(PPM/℃)  X7T: -33% to + 22%  9 Capacitance Temperature Characteristics 2. High dielectric constant type:    X7U:-56% to + 22%  The ranges of capacitance change compared with the 25℃  value over the temperature ranges shall be within the  specified ranges.    Measurement Voltage : Less than 1.0Vrms  (Refer to the electrical characteristics)  No removal of the terminations or marking defect.  10 Apply a parallel force of 5N to a PCB mounted sample for  10±1sec.    *2N for 0603 (EIA 0201).  Termination Strength No cracking or marking defects shall occur at 1mm deflection.  Solder the capacitor to the test jig (glass epoxy boards) shown  in Fig.a using a SAC305(Sn96.5Ag3.0Cu0.5) solder (then let sit  Capacitance change:    for 24±2 hours for X5R, X6S, X7R, X7S, X7T, X7U and X8R).  NP0: within ±5% or ± 0.5pF. (whichever is larger)  Then  apply  a  force  in  the  direction  shown  in  Fig.b.  The  X5R, X6S, X7R, X7S, X7T, X7U, X8R within ±12.5%  soldering  shall  be  done  with  the  reflow  method  and  shall  be  conducted with care so that the soldering is uniform and free of    defects such as heat shock.  (Unit in mm)  11 Deflection (Bending Strength) b c 20 50Pressurizing speed:1mm/sec.  4.5 40 a 100 T:1.6mm(0.8 mm for 0603 & 1005 size) Fig. a.  12 13 Solderability of Termination Resistance to Soldering Heat Size  0603  1005  1608  2012  3216  4520  4532  a  0.3  0.4  1.0  1.2  2.2  3.5  3.5  b  C  0.9  0.3  1.5  0.5  3.0  1.2  4.0  1.65  5.0  2.0  7.0  2.5  7.0  3.7  45 45 Fig.b.  *Preheat the capacitor at 120 to 150℃  for 1 minute.    Immerse the capacitor in a SAC305(Sn96.5Ag3.0Cu0.5)    solder solution at 270±5℃  for 10±1 seconds. Let sit at room  If C≦30pF, DF≦1/(400+20C)  To  satisfy  the  specified  initial  temperature for 24±2 hours, then measure.    spec.  If C >30pF, DF≦0.1%  * Preheat 150 to 200℃  for size≧3216.    I.R.≧10,000MΩ or RiCR≧ I.R.≧10,000MΩor RiCR≧ *High dielectric constant type:  500Ω-F.    500Ω-F.    Initial measurement : perform a heat treatment at 150+0/-10℃  (whichever is smaller)  (whichever is smaller)  for  one  hour  and  then  let  sit  for  24±2  hours  at  room  temperature. Perform the initial measurement.  No marking defects  Cap. Change NP0  within  ±2.5%  or  0.25pF  X5R/X6S/X7R/X7S/X7T/X7U/ ( whichever is larger )  X8R within ±7.5%  I.R. Flexure: 1mm  Capacitance Meter  90%  of  the  terminations  are  to  be  soldered  evenly  and  Immerse the test capacitor into a methanol solution containing  continuously.  rosin  for  3  to  5  seconds,  preheat  it  150  to  180℃  for  2  to  3  minutes  and  immerse  it  into  SAC305(Sn96.5Ag3.0Cu0.5)    solder of 245 ± 5℃  for 3±1seconds.  Appearance Q/D.F. Pressurize R230     42   Specification Item Temp. compensation type 14 Solder the capacitor to supporting jig (Glass epoxy board) and  Appearance No marking defects  Cap. Change NP0  within  ±2.5%  or  0.25pF  X5R/X6S/X7R/X7S/X7T/X8R  perform the five cycles according to the four heat treatments  ( whichever is larger )  within ±7.5%  listed in the following table. Let sit for 24±2hrs at room  X7U within ±30%  temperature, then measure.  If C≦30pF, DF≦1/(400+20C)  Temperature cycle (Thermal shock) Test Method High dielectric constant type Q/D.F. If C >30pF, DF≦0.1%  I.R.≧10GΩor RiCR≧500Ω-F.    (whichever is smaller)  I.R. To  satisfy  the  specified  initial  Step 1: Minimum operating temperature  spec.  Step 2: Room temperature  30±3min  I.R. ≧ 10GΩor  RiCR ≧ Step 3: Maximum operating temperature  500Ω-F.    Step 4: Room temperature  (whichever is smaller)  *High dielectric constant type:    30±3min  2~3 min  2~3min  MLCC  No Initial measurement: perform a heat treatment at 150±10℃  for  one hour and then let sit for 24±2 hours at room temp. Perform  the initial measurement.  Cap. Change Q/D.F. 15 Humidity load No marking defects  Apply the rated voltage at 40±2℃  and 90 to 95% humidity for  NP0  within  ±7.5%  or  0.75pF  X5R/X6S/X7R/X7S/X7T/X7U 500±12 hours. The charge / discharge current is less than  50mA.  ( whichever is larger )  /X8R within ±12.5%    If C>30pF, DF≦0.5%  X5R/X6S/X7R/X7S/X7T/X7U /X8R  200%  max  of  initial  [Temperature compensation type]  If C≦30pF,DF≦1/(100+10xC/3)  spec..  Remove and let sit for 24±2 hours at room temperature, then  C in pF  measure.    I.R.≧500MΩ or    I.R.≧500MΩ or    RiCR≧25Ω-F.    RiCR≧25Ω-F.    [High dielectric constant type]  (whichever is smaller)  (whichever is smaller)  *Initial measurement  Perform a heat treatment at 150+0/-10°C for one hour and then  let sit for 24±2 hours at room temperature.  I.R. Perform the initial measurement.  *Measurement after test  Perform a heat treatment and then let sit for 24±2 hours at  room temperature, then measure.  Appearance Cap. Change Q/D.F. 16 High temperature load life test No marking defects  Apply 200%of the rated voltage for 1000±12 hours at the  maximum operating temperature ± 3℃. The charge / discharge  NP0  within  ±7.5%  or  0.75pF  X5R/X6S/X7R/X7S/X7T/X7U current is less than 50mA.  ( whichever is larger )  /X8R within ±12.5%  [Temperature compensation type] If C>30pF, DF≦0.3%  X5R/X6S/X7R/X7S/X7T/X7U /X8R  200%  max  of  initial  Remove and let sit for 24±2 hours at room temperature, then  If 10pF B = C > D > E 56 【Temperature Coefficient】 Class 1 (Temperature Compensation series)   Class 2 (High Dielectric Constant Series) MLCC      57   Rev. 202204 【DC Voltage Coefficient】 【Aging Rate】 The capacitance and dissipation factor of class 2 capacitors decreases with time. It is known  as ‘aging’ that follows a logarithmic low and expressed in terms of an aging constant. Aging is  that follows a logarithmic low and expressed in terms of an aging constant. Aging is  caused by a gradual re-alignment of the crystalline structure of the ceramic. The aging  alignment of the crystalline structure of the ceramic. The aging  constant is defined as the percentage loss of capacitance at a  time decade’. The law of  constant is defined as the percentage loss of capacitance at a ‘time decade capacitance aging is expressed as following equation: Ct2 = Ct1 x (1 – k x log10(t2/t1)) Ct1: Capacitance after t1 hours of start aging. Ct2: Capacitance after t2 hours of start aging. k: aging constant (capacitance decrease per decade) t1, t2: time in hours from start of aging. A typical curve of aging rate is shown in following  figure.    When heating the capacitors above Curie temperature (130 When heating the capacitors above Curie temperature (130℃~150℃) the capacitance can be  ) the capacitance can be  re-new. So capacitance of class 2 capacitors will be complete de new. So capacitance of class 2 capacitors will be complete de-aged by soldering process;  aged by soldering process;  subsequently a new aging process begins.    Because of aging, it is specified an age for measurement to meet the prescribed tolerance for  class 2 capacitors. Normally, 1000 hours (t ss 2 capacitors. Normally, 1000 hours (t2=1000 hrs) is defined.    58 【Voltage Voltage Derating & Applied Voltage】 Voltage MLCC  The derated MLCC should be applied with the derating voltage. The “Temperature of MLCC”  The derated MLCC should be applied with the derating voltage The “Temperature of MLCC” is the  surface temperature of MLCC including self surface temperature of MLCC including self-heating effect. The maximum operating voltage of  maximum operating voltage of  MLCC with reference to the maximum voltage (Vmax) as shown in the following graph.  MLCC with reference to the maximum voltage (Vmax) is as shown in the following graph. Voltage Voltage Voltage Voltage Voltage Cautions by types of voltage applied to MLCC · For DC voltage or DC+AC voltage, DC voltage or  the maximum value of DC + AC voltage should not exceed the rated voltage of MLCC. · For AC  the maximum value of DC + AC voltage should not exceed the rated voltage of MLCC. · For AC  voltage or pulse voltage, the peak peak value of AC voltage or pulse voltage should not exceed  voltage or pulse voltage, the peak-to-peak value of AC voltage or pulse voltage should not exceed  the rated voltage of MLCC. · Abnormal voltage such as surge voltage, static electricity should not  exceed the rated voltage of MLCC. d the rated voltage of MLCC.  Ti me 0 V max V max V max V max V max 0 0 0 Ti me DC Voltage AC Voltage Ti me DC+AC Voltage Ti me 0 Ti me DC+AC Voltage DC+Pulse Voltage   【Peeling Off Force】 Peeling off force: 0.1N to 1.0  N* in the direction shown as below.  The peeling speed: 300±10 mm/min The peeling speed: 300±10 mm/min      165  °  to 180° to 180 Peeling force  Top tape    Base tape    1. The taped tape on reel is wound  The taped tape on reel is wound clockwise. The sprocket holes are to the right as the tape is  clockwise. The sprocket holes are to the right as the tape is  pulled toward the user.  2. There are minimum 150 mm as the leader and minimum 40 mm empty tape as the tail is  There are minimum 150 mm as the leader and minimum 40 mm empty tape as the tail is  attached to the end of the tape. attached to the end of the tape.    59   Rev. 202204
C1005X7R102KGT 价格&库存
很抱歉,暂时无法提供与“C1005X7R102KGT”相匹配的价格&库存,您可以联系我们找货
