ROHS Compliant
承 認 書
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N
PART NO:
DESCRIPTION:
PRODUCTS NO:
PRODUCTS REV:
DATE:
SMD POWER INDUCTORS
BCRH8D43-100N
1
2018-6-11
PURCHASER CONFIRMED
REMARK
PROVIDER ENGINEER DEPT.
APPROVAL BY
CHECK BY
DRAWN BY
chenlinli
誠陽實業有限公司
TAIWAN CHENG YANG COMPONENT CORP
TAIPEI OFFICE
2F-1, NO. 176, Chine-Yi Road., Zhonghe District, New Taipei City, TAIWAN(R.O.C)
新北市中和區建一路176號2樓之一
POSTAL CODE: 23500
TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 E-mail:h21803@ms29.hinet.net
寶誠電子有限公司
CHINA FACTORY
ZHUHAI BAO CHENG ELECTRONICSCO.,LTD
Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA
中國廣東省珠海市塘家灣鎮官塘工業區
POSTAL CODE: 519085
TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz
昆山誠陽電子有限公司
KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP
Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province, China
CHINA FACTORY
江蘇省昆山市高科技工業園區強安路38號
POSTAL CODE: 215300
TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw
ROHS Compliant
TEST DATA
DIMENSION&ELECTRIC CHARACTER
CUSTOMER:
PART NO.:
DESCRIPTION:
SMD INDUCTOR
SERIES NO:
BCRH8D43-100N
1.MECHANICAL DIMENSION
A1
UNIT:mm
2R2
2.RECOMMEND LAND PATTERN DIMENSIONS
A
8.3MAX
A1
10.0MAX
B
8.3MAX
C
4.7MAX
D
6.3REF
E
2.5REF
F
1.2REF
G
H
I
3.SEPCIFICATIONS
Part Number
L
Inductance
(uH)
@(0A)
BCRH8D43-100N
10.0
Rdc (mOHM)
Typical
Max
34
36
Heat Rating Current DC
Amps.Idc(A)
Saturation Current DC
Amps.ldc(A)
Typical
Typical
3.5
3.6
(1). All test data is referenced to 25℃ ambient.
(2). Operating Tenperature Rangr-30℃ to +100℃.
(3). DC current(A)that will cause an approximate△T of 40℃.
(4). DC current(A)that will cause Lo to drop approximately 35%.
(5). The part temperature(ambient+temp rise)should not exceed 100℃ under worst case operating conditions.Circuit
design,component placement,PWB trace size and thickness,airflow and other cooling provisions all affect the part
temperature part temperature should be verified in the end appliation.
4.PACKAGING INFORMATION
paets are packaged on 13"reels
800 parts per reel.
A0= 10.0mm+0.1/-0
100
B0= 8.3mm+0.1/-0
K0= 4.7mm+0.1/-0
APPROVED BY:
CHECKED BY:
DRAWN BY:chenlinli
Rohs Compliant
ZHUHAI BAOCHENG ELECTRONICS CO.,LTD
TEST DATA FOR PREPRODUCTION SAMPLE
CUSTOMER:
CUSTOMER P/N:
CUSTOMER REV:
TEST DATE:2018-6-11
PART NAME: SMD INDUCTOR
CY PART NO:BCRH8D43-100N
CY REV:
QUANTITY:10PCS
TEST ITEM
A
A1
B
C
8.30
10.00
8.30
4.70
MAX
MAX
MAX
MAX
01
8.07
9.63
8.03
4.46
02
8.04
9.62
8.01
4.48
03
8.05
9.53
8.04
4.32
04
8.03
9.57
7.98
4.37
05
8.01
9.60
8.00
4.39
06
8.03
9.44
8.04
4.38
07
7.97
9.49
7.99
4.30
08
8.08
9.47
8.06
4.45
09
8.13
9.47
7.99
4.48
10
8.03
9.45
8.06
4.34
X
8.04
9.53
8.02
4.40
σ
0.041
0.069
0.028
0.063
Cpk
2.09
5.92
39.13
23.11
SPEC.
D
E
F
G
H
I
11
12
13
14
15
APPROVED BY
CHECKED BY
PREPARED BY
Vincent
ChenFei
ZhaoQian
BWIEG0002-06A
8.3
8.3
4.7
J
Rohs Compliant
CUSTOMER P/N:
CUSTOMER:
PART NAME: SMD INDUCTOR CY PART NO:BCRH8D43-100N
TEST ITEM
L(0A)
L(3.6A)/L(0A)·100%
DCR(S-F)
CUSTOMER REV:
TEST DATE:2018-6-11
CY REV:
QUANTITY:10PCS
TEST
100KHZ 0.25V
CONDITION
SPEC.
10uH
+30%
≥65%
AT DC 3.6A
36mΩ
MAX
01
10.00
83%
33.8
02
10.74
85%
34.4
03
10.02
82%
33.9
04
9.86
83%
34.2
05
10.53
80%
33.9
06
10.58
82%
34.3
07
10.67
79%
34.2
08
11.08
83%
35.1
09
10.62
85%
34.5
10
9.79
86%
33.6
11
12
13
14
15
X
10.39
34.19
σ
0.414
0.409
Cpk
2.73
1.48
1. TEST INSTRUMENTS:
□HP-4284A METER
■HP-4285A METER
□HP-4191A METER
□VR116+VR7220 METER
□CH-3200 METER
□CH-310 METER
□CH-3305 METER
■CD1068+CD1320 METER
□WK3260B+WK3265B METER
□VR562 METER
■CH-502B DCR METER
2.CONDITION
TEMPERATURE: 25℃
HUMIDITY:
65%RH
CORE:DR8*4.2D-3 B:4.0 F:2.6 T12S
RI8*3.4*6.5T T12S
WIRE:0.26mm*2p*11.5TS (REF)
TEMINAL:8D43 T2N
APPROVED BY
CHECKED BY
PREPARED BY
Vincent
ChenFei
ZhaoQian
BWIEG0002-07A
7
36
ROHS Compliant
ELECTRONICS CHARACTER TEST CHART
CUSTOMER:
PART NAME:
SMD INDUCTOR
CUSTOMER P/N:
TEST DATE:2018-6-11
CY P/N:BCRH8D43-100N
SAMPLE CO:
CD1068+CD1320 METER
1.CURVES OF TEMPERATURE AND INDUCTAME VARIED WITH TP CARRENT
TEMPERATURE RISE CURRENT
DC:3.5A TEST INSTRUMENTS
TEST TERM:
100KHZ 0.25V
2.INDUCTCMCE VS CURRENT
TEST INSTRUMENTS:
● Saturated
Current point
■DTL=-35%
▲DTL=-50%
CURRENT (A)
TEST TERM:
0.25V
3.INDUCTCMCE VS FREQUENCUY
TEST INSTRUMENTS:
FREQUENCY(Hz)
1.TEST CONDITION
TEMPERATURE: 25℃
HUMIDITY: ≦ 65% RH
APPROVED BY
CHECKED BY
PREPARED BY
chenlinli
很抱歉,暂时无法提供与“BCRH8D43-100N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.58552
- 10+2.05211
- 30+1.82348
