HPPC12040-R33M-Q8ADF
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
HPPC12040-R33M-Q8ADF 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL 超利維 Customer: Customer P/N: IE1-8B0365 Drawing No: Quantity: X Pcs. Date : 2018/11/21 HPPC12040-R33M-Q8ADF Chilisin P/N: SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 東莞奇力新電子(東莞廠)有限公司 Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL:+886-3- 599-2646 FAX:+886-3- 599-9176 E-mail:sales@chilisin.com http://www.chilisin.com Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL:+86-769-8773-0251~3 FAX: +86-769-8773-0232 E-mail:cect@chilisin.com 奇力新電子(湖南廠)有限公司 奇力新電子(越南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel:84-316 255 688 Fax:84-316 255 689 E-mail:sales@chilisin.com Drawn by 吳韋邑 Wayne.Wu HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel:86-745-867-5882 E-mail:cect@chilisin.com Checked by 吳韋邑 Wayne.Wu Approved by 劉建志 Richard.Liu YG16600082 HPPC12040 Series Specification 1 Scope: This specification applies to Large current and Low Loss SMD Power INDUCTOR 2 Part Numbering: 3 Rating: Operating Temperature: - 55°C ~ 125°C Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max. 4 Marking: Ex : HPPC12040-R33M-Q8ADF Marking : R33 Marking color : Black 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35℃) Ordinary Humidity(25 to 85% RH) In case of doubt 20 to 30℃ 50 to 80 %RH HPPC12040 Series Specification 6 Configuration and Dimensions: Dimensions in mm TYPE HPPC12040 A 12.6 ± 0.2 B 13.65 ± 0.35 C 3.8 ± 0.2 D 3.5 ± 0.5 F 2.5 ± 0.5 7 Electrical Characteristics: Part No. HPPC12040-R33M-Q8ADF Inductance (uH ) Tolerance (±%) Test Freq. Irms(A) Typ Isat(A) Typ RDC(mΩ) Max Marking 0.33 20 100kHz,0.5V 45 67 0.65 R33 Note: 1.Operating temperature range -55℃~125℃ 2.Isat for Inductance drop 30% from its value without current. 3.Irms for a 40℃ temperature rise from 25℃ ambient. 4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions. Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 5.Absolute maximum voltage 30VDC HPPC12040 Series Specification 8 HPPC12040 Series 8.1 Construction: 8.2 Material List: HPPC12040 Series Specification 9 PACKAGING 9.1 Packaging -Cover tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction. 9.2 Packaging Quantity TYPE PCS/REEL HPPC12040 500 9.3 Reel Dimensions Dimensions in mm TYPE A B C D HPPC12040 330 100 13 24.4 HPPC12040 Series Specification 9 PACKAGING 9.4 Tape Dimensions in mm TYPE A0 B0 K0 D E W P P0 P2 HPPC12040 13 14.6 4.25 1.55 1.75 24 16 4 2 10 Recommended Pattern Dimensions in mm TYPE A(mm) HPPC12040 5.5 B(mm) C(mm) 11.25 3.25 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5. The moisture sensitivity level (MSL) of products is classified as level 1. HPPC12040 Series Specification 12 Graph:
物料型号:HPPC12040-R33M-Q8ADF
器件简介:适用于大电流、低损耗的SMD功率电感。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 额定电流:45A(典型值) - 饱和电流:67A(典型值) - 直流电阻:最大0.65mΩ - 工作温度范围:-55°C至125°C - 存储温度范围:-20°C至+40°C,相对湿度最大75% - 标称电感值:0.33μH,公差±20% - 测试频率:100kHz,0.5V
功能详解:文档中未提供详细的功能解释,但电感通常用于过滤信号、稳定电流和抑制噪声。
应用信息:适用于需要大电流和低损耗的应用场合。
封装信息:封装类型为HPPC12040,具体尺寸如下: - A:12.6±0.2mm - B:13.65±0.35mm - C:3.8±0.2mm - D:3.5±0.5mm - F:2.5±0.5mm
包装信息:每卷500个,卷轴尺寸为330mm x 100mm x 13mm,载体基带厚度最大0.1mm。
HPPC12040-R33M-Q8ADF 价格&库存
很抱歉,暂时无法提供与“HPPC12040-R33M-Q8ADF”相匹配的价格&库存,您可以联系我们找货
