7M25000146
7M25000146
    TXC(台晶)
    SMD3225_4P
    无源晶振 SMD3225_4P
7M25000146 数据手册
TXC CORPORATION www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2×2.5 NOMINAL FREQ. : 25.000625MHz TXC P/N : 7M25000146 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. MSL:Level 1 RoHS Compliant FMT-DOC024 Issue Date: 04.17'15 VER.G TXC CORPORATION www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2×2.5 NOMINAL FREQ. : 25.000625MHz TXC P/N : 7M25000146 REVISION : S1 PE/RD QA MFG Robin Huang 3-Mar-16 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required MSL:Level 1 RoHS Compliant FMT-DOC024 Issue Date: 04.17'15 VER.G TXC P/N: TXC CORPORATION Rev Revise page S1 N/A FMT-DOC024 Revise contents Initial released 7M25000146 REVISION: S1 PAGE: 1 Date Ref.No. Reviser 3-Mar-16 N/A Xiaoyan Jiang Issue Date: 04.17'15 VER.G TXC CORPORATION TXC P/N: 7M25000146 REVISION: S1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 DIMENSIONS P.4 3 MARKING P.4 4 FACTORY LOCATION P.4 5 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS FMT-DOC024 P.8~9 Issue Date: 04.17'15 VER.G TXC P/N: TXC CORPORATION 7M25000146 REVISION: S1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters Symbol Electrical Spec. Min. Typ. Max. Notes Units FL 25.000625 MHz - - Fundamental - - CL 18 pF - 4 Frequency Tolerance - ±10 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±20 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance -40 ~ 85 ±3 - ℃ ppm 1st Year 8 Drive Level DL - 10 100 uW - 9 Effective Resistance Rr Rr - - 50 Ω - 10 Shunt Capacitance C0 C0 - - 3 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -55 ~ 125 ℃ at DC 100V - TXC P/N: TXC CORPORATION 7M25000146 S1 REVISION: ■ DIMENSIONS (Unit:mm) PAGE: 4 Unit:mm 0.70 ± 0.10 3.20 ± 0.10 GND 3 3 4 2.50 ± 0.10 4 1 GND 2 1 2 1.20±0.10 1 2 4 3 1.40 0.80 1.40 0.70±0.10 Bottom View 1.20 0.50 1.20 0.20 1.00±0.10 0.90±0.10 Internal View Connection Suggested Layout *Coplanarity of solderable areas Camber 0.10 mm Max ■ MARKING   T TXC Logo Frequency Code Ex.: Pin 1 Index Mark 25.000625 MHz = 250 Tracking Code Production Location:Taiwan, China(Ningbo), China(Chungking). ■ SUGGESTED REFLOW PROFILE Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. (℃) 10 sec 260 220 180 150 Time (sec) 120 sec 60 sec ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Re-solder times: twice FMT-DOC024 Issue Date: 04.17'15 VER.G TXC CORPORATION TXC P/N: 7M25000146 REVISION: S1 PAGE: 5 ■ STRUCTURE ILLUSTRATION A-A' sectional drawing C-C' sectional drawing B-B' sectional drawing NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Package Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu - 3 PAD Au - Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 5 Conductive adhesive Resin+Ag - 6 Electrode Noble Metal - FMT-DOC024 - Issue Date: 04.17'15 VER.G TXC P/N: TXC CORPORATION 7M25000146 REVISION: S1 PAGE: 6 ■ EMBOSS CARRIER TAPE & REEL DIMENSIONS A 1.65±0.10 B C D E F G H 3.40±0.10 2.70±0.10 4.00±0.10 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm) REMARK : User direction of feed DIMENSIONS FMT-DOC024 L L1 W W1 178±1.00 13±0.50 11.5±0.20 8±0.10 (UNIT:mm) Issue Date: 04.17'15 VER.G TXC P/N: TXC CORPORATION 7M25000146 REVISION: S1 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Lable B) Size:80 X 40mm [STORAGE] 1.Don't be caught in the rain. 2.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 3.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 04.17'15 VER.G TXC CORPORATION TXC P/N: 7M25000146 REVISION: S1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1.1 Drop Test 1.2 Mechanical Shock Test Methods 150 cm height,3 times on concrete floor . A.C Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5 ms duration time Vibration 1.3 Test Criteria Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes Perpendicular axes each test time 4 Hrs A.C A.C (Total test time 12 Hrs) Solderability 1.4 Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Methods Test Item Pre-heat temperature 2.1 Resistance To Soldering Heat Test Criteria 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. B.C.D 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 Hrs B.C.D 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 Hrs B.C.D Total 100 cycles of the following temperature cycle 2.4 Temperature cycle 2.5 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 500 Hrs FMT-DOC024 B.C.D B.C.D Issue Date: 04.17'15 VER.G TXC CORPORATION TXC P/N: 7M25000146 REVISION: S1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±5ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. Measurement condition Electrical characteristics measured by S&A250B or equivalent. FMT-DOC024 Issue Date: 04.17'15 VER.G
7M25000146
物料型号:7M25000146 器件简介:SMD SEAM SEALING X'TAL 3.2×2.5,频率为25.000625MHz的晶振 引脚分配:文档中未明确提供引脚分配信息 参数特性:包括负载电容18pF、频率容差±10ppm、频率稳定性±20ppm、工作温度范围-40至85℃、老化率±3ppm第一年、驱动级别10至100μW、有效电阻50pΩ、并联电容3pF、绝缘电阻500MΩ(DC 100V)、存储温度范围-55至125℃ 功能详解:文档中未明确提供功能详解 应用信息:文档中未明确提供应用信息 封装信息:封装尺寸3.2×2.5mm,重量0.018±0.001g/pcs
7M25000146 价格&库存
很抱歉,暂时无法提供与“7M25000146”相匹配的价格&库存,您可以联系我们找货
