AC0603DR-07110KL
AC0603DR-07110KL
    YAGEO(国巨)
    贴片电阻 0603
AC0603DR-07110KL 数据手册
DATA SHEET THICK FILM CHIP RESISTORS AUTOMOTIVE GRADE AC series ±5%, ±1%, ±0.5%, ±0.1% (LOW TCR) Sizes 0201/0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – November 17, 2023 V.11 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount AC 0201 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AC0201 to AC2512 chip resistors with leadfree terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS ⚫ ⚫ All general purpose applications Car electronics, industrial application FEATURES ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ AEC-Q200 qualified Moisture sensitivity level: MSL 1 AC series soldering is compliant with J-STD-020D Halogen free epoxy RoHS compliant - Products with lead-free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reduce environmentally hazardous waste High component and equipment reliability The resistors are 100% performed by automatic optical inspection prior to taping. GLOBAL PART NUMBER AC XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE B = ± 0.1% for low TCR F = ± 1% D = ± 0.5% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE = Base on spec E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel & Standard power 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE 1Ω to 22 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter B is for bulk AOI ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76Ω) 1R = 1Ω 1R5 = 1.5Ω 9R76 = 9.76Ω XXRX (10 to 97.6Ω) 10R = 10Ω 97R6 = 97.6Ω XXXR (100 to 976Ω) 100R = 100Ω 976R = 976Ω XKXX (1 to 9.76 KΩ) 1K = 1,000Ω 9K76 = 9760Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000Ω 9M76= 9,760,000Ω XXMX (10 MΩ) 10M = 10,000,000Ω O RDERING EXAMPLE The ordering code for an AC0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel is: AC0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. 3. AC series with 0.5% tolerance is also available. For further information, please contact sales. www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 MARKING AC0201 / AC0402 No marking Fig. 1 AC0603 / AC0805 / AC1206 / AC1210 / AC2010 / AC2512 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 2 Value=10 KΩ AC0603 YNSC037 Fig. 3 E-24 series: 3 digits, ± 1% & ± 0.5% One short bar under marking letter Value = 24 Ω E-96 series: 3 digits, ± 1% & ± 0.5% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AC0805 / AC1206 / AC1210 / AC2010 / AC2512 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ AC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ YNSC103 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 7 Value = 10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AC series is the same as RC series. www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 CONSTRUCTION The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a protective glass. The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as shown in Fig.8. OUTLINES Fig. 8_1 Fig. 8_2 Chip resistor outlines AC2010/ 2512 double power chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 9 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AC0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 0.12 ± 0.05 0.15 ± 0.05 AC0402 1.00 ± 0.05 0.50 ± 0.05 0.32 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AC0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AC0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AC1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.45 ± 0.20 AC1210 3.10 ± 0.10 2.60 ± 0.15 0.55 ± 0.10 0.45 ± 0.15 0.50 ± 0.20 AC1218 3.10 ± 0.10 4.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 AC2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10 0.55 ± 0.15 0.55 ± 0.20 AC2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 For dimension, please refer to Table 1 AC0201/0402 0603/0805/1206/1210/ 2010/2512 I1 AC1218 Side view for all type I1 I1 W W Fig. 9 Chip resistor dimensions H W I2 L L L YNSC096 www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AC0201 POWER 1/20 W Operating Max. Temperature Working Range Voltage -55°C to 155°C 25V Max. Dielectric Overload Withstanding Voltage Voltage 50V 50V Resistance Range Temperature Coefficient Jumper Criteria 5% (E24) 1Ω ≤ R ≤ 10Ω Rated Current 1Ω ≤ R ≤ 10MΩ -100/+350 ppm°C 0.5A 1% (E24/E96) 10Ω < R ≤ 10M Maximum 1Ω ≤ R ≤ 10MΩ ± 200 ppm°C Current 0.5% (E24/E96) 1.0A 10Ω ≤ R ≤ 1MΩ Jumper
AC0603DR-07110KL
物料型号:文档中提到的物料型号为YAGEO Phicomp Chip Resistor Surface Mount AC系列,具体型号包括AC0201至AC2512。
器件简介:AC系列是车规级厚膜芯片电阻,采用无铅端子制造,符合RoHS标准和无卤要求,适用于一般用途、汽车电子和工业应用。
引脚分配:文档中没有明确提到具体的引脚分配,但提到了电阻器是在汽车级陶瓷基板上制造,两端有内部金属电极,并通过电阻性釉料连接。
参数特性:AC系列电阻具有不同的公差等级(±0.5%,±1%,±5%),温度系数,以及不同的封装尺寸。电阻值范围从1Ω到22MΩ。
功能详解:电阻器通过调整釉料的组成来获得所需的电阻值,并通过激光修调实现精度。所有电阻器在封装前都经过了100%的自动光学检查。
应用信息:AC系列电阻适用于一般用途、汽车电子和工业应用,符合AEC-Q200标准,具有MSL 1的湿度敏感度等级。
封装信息:文档提供了不同尺寸的封装信息,包括尺寸、高度和宽度等,以及推荐的焊盘和焊接配置文件,与RC系列相同。
AC0603DR-07110KL 价格&库存
很抱歉,暂时无法提供与“AC0603DR-07110KL”相匹配的价格&库存,您可以联系我们找货
AC0603DR-07110KL
    • 5000+0.02423
    库存:5000
    AC0603DR-07110KL
      • 50+0.04126
      • 500+0.03273
      • 1500+0.02798
      • 5000+0.02430
      • 25000+0.02182
      • 50000+0.02052
      AC0603DR-07110KL
        • 1+0.11420
        • 100+0.07500
        • 1000+0.05080
        • 2500+0.03510
        • 5000+0.02500
        库存:1800
