QR0612J430RP05
QR0612J430RP05
    EVEROHMS(天二)
    贴片电阻 0612
QR0612J430RP05 数据手册
■ AEC-Q200 Chip Resistor— QR Series (Wide Terminal Type) ■ Application ■ Features ─ Automotive electronics ─ Small size and light weight ─ Navigation equipment ─ Reduction of assembly costs and matching with placement machines ─ Power supply , ECU etc. ─ Reliability, high quality and fast delivery ─ Indoor lighting, Central door locking, Wiper module ─ Chip resistor of the wide terminal type. ■ Standard Electrical Specifications Item Type Rated Power at 70℃ ℃ Max Working Voltage Max Overload Voltage 0.75 W 200V 400V QR0612 ● T.C.R. (PPM/℃ ℃) Resistance Range F(± ±1%) J(± ±5%) ±100 10Ω~3.3KΩ 10Ω~3.3KΩ ±100 3.6KΩ~1MΩ 3.6KΩ~1MΩ Operating Temperature Range :−55℃〜+155℃. ■ Type Dimension- Chip Resistor ■ Dimension Unit: mm TYPE L W H l1 l2 QR0612 1.60 ± 0.15 3.20 ± 0.15 0.60 ± 0.10 0.30 ± 0.20 0.45 ± 0.15 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Parts Number Explanation ■ Example: QR Product Ty pe QR 0612 J 10R P S iz e R es is tor Tole ra nc e R es is tors Pac ka ge (Inch) 06 12 F: ±1% Value 05 P:Pa per Tapi ng Quantity 0 5:5 00 0PC S Optiona l 0.7 5W J: ±5% ■ Appendix For SMD Chip Resistor ● Packaging Information ◆ For All Series ■ Dimension Unit: mm TYPE QR0612 TEL: 886-7-8116611 SIZE 7” 5K/Reel FAX: 886-7-8115533 A ψB ψC ψD W ψM 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 E-mail: service@everohms.com http://www.everohms.com ■ Tapping Specification ■ Dimension Packaging Unit: mm Type A B W E F G H T ψD P +0.10 Paper Type QR0612 1.90±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 1.50 4.0±0.1 -0 ■ Packing Material Data / Storage Data ■ Front & Back Lead Dimension ■ Top Adhesive Peel Off Strength:10~70g TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Package External Box Size Inner Box Size Size H(mm) Reel Contain Length (Kpcs) (mm) Width (mm) Height (mm) 1 13 25K 180 180 60 2 24 50K 180 180 110 3 36 150K 430 200 200 5 60 300K 400 400 200 10 113 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery. ● Reliability Test and Requirement Test Item Test Method Temperature JIS C 5201-1 Coefficient of clause 4.8 Resistance (T.C.R) Procedure Requirements -55℃ or +155℃, 25℃ is the reference temperature Refer to Ratings Short Time Overload JIS C 5201-1 clause 4.13 2.5 times RCWV or Max. Overload voltage whichever is less for 5 seconds. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.10Ω) Soldering Heat JIS C 5201-1 clause 4.18 260±5℃ for 10 seconds. 1%:±(0.5%+0.05Ω) 5%:±(1.0%+0.05Ω) Temperature Cycling JIS C 5201-1 clause 4.19 -55℃ to +155℃,5 cycles 1%:±(0.5%+0.05Ω) 5%:±(1.0%+0.10Ω) Load Life in Humidity JIS C 5201-1 clause 4.24 40±2℃, 90~95% R.H. RCWV or Max. working voltage for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 1%:±(0.5%+0.05Ω) 5%:±(2.0%+0.05Ω) Load Life (Endurance) JIS C 5201-1 clause 4.25 70±2℃, RCWV or Max. working voltage for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 1%:±(1.0%+0.05Ω) 5%:±(3.0%+0.10Ω) Bending once for 5 seconds D: 0612 = 2mm ±1:±(1.0%+0.05Ω) ±5:±(1.0%+0.05Ω) Terminal Bending JIS C 5201-1 Strength clause 4.33 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com AEC-Q200 test Test Item Test Method Procedure Requirements Temperature Cycling JESD22 Method JA-104 1000 Cycles (-55℃ to +125℃) Measurement at 24± 1%:±(0.5%+0.05Ω) 4 hours after test conclusion. 5%:±(1.0%+0.10Ω) Resistance to Solvent MIL-STD-202 Method 215 Add Aqueous wash chemical-OKEM clean or equivalent. 1%:±(0.5%+0.05Ω) 5%:±(0.5%+0.05Ω) Biased Humidity MIL-STD-202 Method 103 1000 hours 85℃/85%RH. 1%:±(0.5%+0.05Ω) 5%:±(2.0%+0.05Ω) 1000 hrs. @ T=125℃. 1%:±(0.5%+0.05Ω) 5%:±(2.0%+0.05Ω) High Temperature MIL-STD-202 Exposure (Storage) Method 108 Operation Life MIL-STD-202 Method 108 125℃,or Max.working voltage for 1000 hrs with 1.5 1%:±(1.0%+0.05Ω) hrs"ON" and 0.5hr "OFF" 5%:±(3.0%+0.10Ω) External Visual MIL-STD-883 Method 2009 Electrical test not required. Inspect device construction, marking and workmanship. - MIL-STD-202 Mechanical Shock Method 213 Impact acceleration:1500g Pulse duration:0.5ms Number of shocks:30 shocks(5 shocks for each face) 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.10Ω) MIL-STD-202 Method 204 5 g’s for 20min., 12 cycles each of 3 orientations. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.10Ω) Vibration ESD Solderability Board Flex TEL: 886-7-8116611 ACE-Q200- 002 0612:1KV or ISO/DIS 10605 For the product % J-STD-002 (1) 4 hrs 155℃ dry heat (2) 260±5℃ 10 sec. 1%:±(0.5%+0.05Ω) 5%:±(1.0%+0.05Ω) AEC Q200-005 Beading once for 60 seconds 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ● General Information ■ Recommend Land Pattern Design ( For Reflow Soldering ) ■ Dimension Type Item Unit: mm 0612 A 0.70 B 2.30 C 3.20 ■ Performance Characteristics ■ Power Derating Curve DERATING CURVE 100 Power Ratio(%) 80 60 40 155℃ ℃ 20 -55 0 20 40 60 70 80 100 120 140 160 Power rating or current rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating Curve. Ambient Temperature (℃) ■ Voltage Rating or Current Rating Resistance Range: ≧1Ω Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula as following: E(RCWV)=√ √P× ×R E=Rated voltage(V) P=Power rating(W) R=Nominal resistance(Ω) ■ Soldering Profile TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Equipments Applicable: Our company’s products are produced under low temperature processing applicable to IR reflow surface mounting devices. It is comparatively not applicable to wave soldering which will possibly cause the risk ablating the element protection layer and the front conductor and cause the drift of the resistance value and ablation of the markings. ■ Product Testing Method: Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch at the back of both electrodes. Supposed different testing points or methods are requested, please advise beforehand and customized-made production is available. Mar 2017 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com
QR0612J430RP05 价格&库存
很抱歉,暂时无法提供与“QR0612J430RP05”相匹配的价格&库存,您可以联系我们找货
