CR-05FA7--3K01
CR-05FA7--3K01
    VIKING(光颉)
    贴片电阻 0805
CR-05FA7--3K01 数据手册
Data Sheet Customer: Product: Automotive Grade Chip Resistor – CR..A Series Size: 0201/0402/0603/0805/1206/1210/2010/2512 Issued Date: 21-Oct-19 Edition: REV.B1 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 21-Oct-19 21-Oct-19 21-Oct-19 21-Oct-19 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) Automotive Grade Chip Resistor CR..A Series Automotive Grade Chip Resistor-CR..A Series Scope This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. Features AEC-Q200 Compliance Highly reliable multilayer electrode construction Compatible with all soldering process 100% CCD inspection Construction Applications Automotive Industry L Telecommunication Equipments D1 Radio and Tape Recorders, TV Tuners Digital Cameras, Watches, Pocket Calculators     W T   Computers, Instruments Medical Equipment  D2  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat Dimensions Size L W T D1 D2 (Inch) (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) CR-01 0201 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 CR-02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 CR-03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 CR-05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 CR-06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 CR-10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 CR-0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 CR-12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type www.viking.com.tw For detail questions, contact sales@viking.com.tw 1 Edition : REV.B1 Revision: 21-Oct-2019 CR..A Series Automotive Grade Chip Resistor Part Numbering Part Number CR-03FA7---10R CR- 03 F Product Type Dimensions Resistance Tolerance D: ±0.5% F: ±1% J: ±5% CR- 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 A Function Code A: Automotive Grade - Packaging Code 4: 7” Reel 4Kpcs 6: 7” Reel 10Kpcs 7: 7” Reel 5Kpcs 9: 10” Reel 8Kpcs A: 10” Reel 10Kpcs B: 10” Reel 20Kpcs C: 13” Reel 40Kpcs D: 13” Reel 20Kpcs C: High Power & Automotive Grade Recommend Land Pattern - - 1 0 R Resistance - - - 1R2: 1.2Ω - - - 3K3: 3.3KΩ - - - 10K: 10KΩ - - 100K: 100KΩ “-“ to fill up 6 spaces Derating Curve Derating Curve 100 A Type A (mm) B (mm) C (mm) CR-01 0.30 0.25 0.30 CR-02 0.50 0.45 0.60 CR-03 0.90 0.60 0.90 CR-05 1.20 0.70 1.30 CR-06 2.00 0.90 1.60 CR-10 2.00 0.90 2.80 CR-0A 3.80 0.90 2.80 CR-12 4.90 1.60 3.50 Power ratio (%) . C B 7 CR-02 CR-03 CR-05 CR-06 CR-10 CR-0A CR-12 80 60 40 CR-01 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s www.viking.com.tw For detail questions, contact sales@viking.com.tw 2 Edition : REV.B1 Revision: 21-Oct-2019 CR..A Series Automotive Grade Chip Resistor (3) Time of soldering iron at maximum temperature point 410C:5s Standard Electrical Specifications Power Rating at 70C Jumper Rated Current Item Type Operating Temp. Range Max. Operating Voltage Max. Overload Voltage 25V 50V Resistance Range ±1%(E24 -55 ~ +125C Jumper: 1A 1/16W CR-02 (0402) -55 ~ +155C 50V CR-03 (0603) 100V 75V CR-05 (0805) -55 ~ +155C 150V 1/4W -55 ~ +155C 200V 1/2W -55 ~ +155C 200V CR-0A (2010) -55 ~ +155C 200V CR-12 (2512) 0Ω (
CR-05FA7--3K01
物料型号:Viking Automotive Grade Chip Resistor - CR..A Series
器件简介:这是一系列符合AEC-Q200标准的汽车级芯片电阻,采用钌基材料制造,具有高可靠性的多层电极结构,兼容所有焊接工艺,并通过100% CCD检测。
引脚分配:文档中没有明确提到引脚分配,但提到了电阻的尺寸和结构,包括基板、边缘电极、电阻层、底电极、阻挡层、主覆盖层、顶电极和外部电极。
参数特性: - 尺寸范围:0201/0402/0603/0805/1206/1210/2010/2512 - 发布日期:2019年10月21日 - 版本:REV.B1 - 符合RoHS标准
功能详解: - 这些电阻适用于汽车行业、通信设备、收音机、磁带录音机、电视调谐器、数码相机、手表、袖珍计算器、计算机、仪器和医疗设备。
应用信息:适用于上述提到的各种应用领域。
封装信息: - 提供了不同尺寸的电阻封装,包括0201至2512,并给出了每个尺寸的详细尺寸、重量和包装信息。
CR-05FA7--3K01 价格&库存
很抱歉,暂时无法提供与“CR-05FA7--3K01”相匹配的价格&库存,您可以联系我们找货
