RNS14F2200A520NH
RNS14F2200A520NH
    FUTABA(台湾双羽)
    插件,D1.7xL3.5mm
    插件电阻 220Ω ±1% 250mW ±100ppm/℃
RNS14F2200A520NH 数据手册
COMPANY HISTORY 1973,3 月 與日本福島雙羽簽訂技術合作合約 January 1973 Signed technical cooperation agreement with Fukushima Futaba in Japan. 1973,10 月 October 1973 台灣雙羽電機股份有限公司正式成立 Founded as Futaba Electric Co., Ltd. 1974, 9 月 開始量產氧化金屬膜電阻器 November 1999 Mass production of Metal Oxide Film Resistor. 1997,6 月 成立大陸廠,雙羽電子(深圳)有限公司 June 1997 Established Shenzhen plant in China. 1997,10 月 台灣廠取得 ISO 9000 : 1994 認證 October 1997 Futaba Taiwan HQ achieved ISO 9000 : 1994 certification. 1998,1 月 開始量產高阻值金屬釉電阻器 January 1998 Mass production of High Meg Metal Glaze Resistor. 1999,3 月 大陸廠(深圳)取得 ISO 9000 : 1994 認證 March 1999 Shenzhen plant achieved ISO 9000: 1994 certification. 1999,11 月 成立大陸廠:雙葉電子廠 November 1999 Established Shuangya Electronics Co. in China. 2002,8 月 台灣廠取得 ISO 9001 : 2000 改版認證 August 2002 Futaba Taiwan HQ achieved ISO 9001: 2000 certification. 2003.1 月 January, 2003 大陸廠(深圳)取得 ISO 9001 : 2000 改版認證 Shenzhen plant achieved ISO 9001: 2000 certification. 2003.1 月 導入無鉛產品;導入 RoHS January 2003 Implemented Lead-Free products. 2003.4 月 台灣廠取得 SONY 綠色夥伴認證 April 2003 Futaba Taiwan HQ achieved SONY green partner certification. 2003,9 月 成立大陸廠,雙羽電子(蘇州)有限公司 September 2003 Established Suzhou plant in China. 2004,8 月 大陸廠(蘇州)取得 ISO 9001 : 2004 認證 August 2004 Suzhou plant achieved ISO 9001: 2004 certification. 2005,12 月 大陸廠(深圳)取得 ISO 14001 : 2004 認證 December 2005 Shenzhen plant achieved ISO 14001: 2004 certification. 2006,3 月 大陸廠(蘇州)取得 ISO 14001 : 2004 認證 March 2006 Suzhou plant achieved ISO 14001: 2004 certification. 2008,8 月 導入無鹵產品 August 2008 Implemented Halogen-Free products. 2009,8 月 台灣及大陸廠均取得 ISO 9001 : 2008 認證(台灣廠、深圳廠、雙葉廠、蘇州廠) August 2009 Taiwan, Shenzhen, Shuangya and Suzhou achieved ISO 9001: 2008 certification. 2010, 2 月 大陸廠(蘇州)取得 TS 16949 : 2009 認證 February 2010 Suzhou plant achieved TS 16949: 2009 certification. 2012, 7 月 大陸廠(雙葉)更名為富羽雙華電阻材料有限公司 July 2012 Shuangya renamed to Futaba Electronics Co., Ltd. 1 INDEX 固定電阻器 Fixed Resistors 品類 Type 產品名稱 Product Name 品名 Type 頁 Page 氧化金屬膜電阻器 METAL OXIDE FILM RESISTOR RS 4‧5 金屬皮膜固定電阻器 FIXED METAL FILM RESISTOR RN 6‧7 金屬皮膜精密電阻器 METAL FILM PRECISION RESISTOR RP 8‧9 金屬釉電阻器 METAL GLAZE RESISTOR RM 10‧11 耐突波電阻器 SURGE RESISTOR RV 12‧13 高阻值電阻器 HIGH RESISTANCE RESISTOR RR 14‧15 保險絲電阻器 FUSIBLE RESISTOR RF 16‧17 電流式保險絲電阻器 RATED CURRENT FUSIBLE RESISTOR RFA 18‧19 高能量突波繞線保險絲電阻器 HEAT ENERGY SURGE WIRE WOUND FUSIBLE RESISTOR WF 20‧21 NON-SMOKE THERMAL FUSE RESISTOR RFT 22‧23 防爆保險絲電阻器 ANTI-BURST FUSIBLE RESISTOR RFB / RFF 24‧25 Wire 繞線電阻器 WIRE WOUND RESISTOR RW 26‧27 Wound 無感電阻器 NON INDUCTIVE RESISTOR NW/NM/NV 28‧29 Ceramic 金屬板電阻器 METAL PLATE CEMENT RESISTOR MPC / MPH 30‧31 Cased 薄型金屬板電阻器 METAL PLATE CEMENT RESISTOR MPM 32‧33 薄型電阻器 METAL PLATE CEMENT RESISTOR MPT / MPQ 34‧35 水泥電阻器 CEMENT RESISTOR RG 36‧37 高絕緣水泥電阻器 CEMENT RESISTOR RGK 38‧39 電流偵測電阻器 CURRENT SENSOR RESISTOR RGC 40‧41 高脈衝繞線電阻器(可加溫度保險絲) HIGH PULSE WIRE WOUND RESISTOR HVW 42‧43 Aluminum 黃金鋁殼電阻器 ALUMINUM CASED POWER RESISTOR GR 44‧45 Cased 薄型鋁殼電阻器 FLAT TYPE METAL CLAD WIRE WOUND RESISTOR GH 46‧47 方型鋁殼電阻器 SQUARE SHAPE ALUMINUM SHELL RESISTOR RA 48‧49 船型鋁殼電阻器 TRAPEZOID ALUMINUM SHELL RESISTOR RAMH 50‧51 High Power 大功率電阻器 POWER WIRE WOUND RESISTOR RQ 52‧53 Other 塗裝絕緣型 0Ω電阻器 COAT-INSULATED ZERO OHM RESISTOR RZ 54‧55 低阻值電阻器 LOW RESISTANCE RESISTOR ST 56‧57 低阻值電阻器 LOW RESISTANCE RESISTOR LR 58‧59 模造電阻器 POWER CHIP RESISTOR MR 60‧61 Film High Fusing 可復式水泥繞線電阻組合溫度保險絲電阻 器 附錄 APPENDIX 造型 FORMING TAPING(A52/A64/A73)‧L TYPE‧C TYPE‧FA5 TYPE‧FB5 TYPE‧FC5 TYPE‧M TYPE‧D TYPE‧Y TYPE‧YT TYPE‧FT TYPE RG SERIES TYPE P TYPE‧Z TYPE‧M TYPE‧S TYPE‧H TYPE 頁 Page 62‧63 64 RESISTANCE TOLERANCE / BASIC VALUE E24 & E96 65 RESISTOR LOADING CALCULATION AND SURGE TEST METHOD 66‧69 2 額定電力 Power Rating (W) 3 電阻公差 Resistance Tolerance ± 0.01% ± 0.05% ± 0.1% ± 0.5% ± 1% >± 5% 歐洲 中國 RoHS RoHS ± 2% ± 5% ◎ ◎ ● ◎ ◎ 品名 Type 頁 Page RS 4‧5 ● RN 6‧7 ● RP 8‧9 RM 10‧11 ○ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ● ◎ ◎ ◎ ● RV 12‧13 ◎ ◎ ◎ ● RR 14‧15 ◎ ● RF 16‧17 ● RFA 18‧19 ◎ ● WF 20‧21 ◎ ● RFT 22‧23 ◎ ● RFB / RFF 24‧25 ◎ ◎ ● ○ RW 26‧27 ◎ ◎ ● ○ NW / NM / NV 28‧29 ◎ ◎ ◎ ● ○ MPC / MPH 30‧31 ◎ ◎ ● ○ MPM 32‧33 ◎ ● ○ MPT / MPQ 34‧35 △ ◎ △ △ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ● RG 36‧37 △ △ ◎ ● RGK 38‧39 ◎ ◎ ◎ ● RGC 40‧41 ◎ ● HVW 42‧43 ◎ ● GR 44‧45 ◎ ● GH 46‧47 ◎ ● RA 48‧49 ◎ ● RAMH 50‧51 ◎ ● RQ 52‧53 ● RZ 54‧55 ◎ △ △ ○ ◎ ◎ ◎ ◎ ◎ ● ST 56‧57 ◎ ◎ ◎ ● LR 58‧59 ◎ ◎ ◎ ● MR 60‧61 NOTE:△ Please contact our sales 額定電力 Power Rating (W) 頁 Page AVAILABLE : 1/4W~5W 62‧63 AVAILABLE : 1W~40W 64 RESISTANCE TOLERANCE / BASIC VALUE E24 & E96 65 RESISTOR LOADING CALCULATION AND SURGE TEST METHOD 66‧69 3 POWER TYPE RSU 氧化金屬膜電阻器 RSS 小型氧化金屬膜電阻器 RSP 超小型氧化金屬膜電阻器 METAL OXIDE FILM RESISTOR (Standard Type) METAL OXIDE FILM RESISTOR (Small Type) METAL OXIDE FILM RESISTOR (Super Small Type) ■結構圖 Construction 塗裝顏色 (Coating Color) : 1 端子線 Lead wire 標 準 品 (Standard Type)灰色 (Gray) 2 瓷 棒 Ceramic base 3 鐵 帽 Cap 4 切割線 Helical cutting groove 小 型 品 (Small Type)粉紅色(Pink) 超小型品 (Super Small Type)粉紅色(Pink) 5 6 7 導電皮膜 Conductive film 標 示 Marking or color code 絕緣塗料 Insulation coat ■外型尺寸 Dimensions 標 示 (Marking ) : 色 碼 (Cloor Code )(1/4W、S1/2W) Dimensions (mm) L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/4,S1/2,P1 6.0±0.5 7 2.4±0.3 28±2 210 ■特性 Feature 1/2,S1,P2 9±0.5 11 3.0±0.5 0.6±0.05 P2:0.7±0.05 28±3 285 ◎ 使用不燃性塗料,具不燃與絕緣之安全特性(UL94 V-0) 1,S2,P3 12±1 15 4.0±0.5 Flameproof and insulating coating designed to assure 2,S3,P5 16±1 18 5.5±0.5 safe usage by special non-flammable silicon-base. 3,S5 25±1 28 8.5±0.5 Rated Power (W) 字 (Alphanumeric) (1/2W~S5W) 文 (Equivalent to UL94 V-0) L 728 0.8±0.05 38±3 1380 3768 ■料號編碼 Type composition ◎ 小型化能高密度插裝 例 Small size are good for high density application. Example RS U 型名 Type 品名 Size 14 J R100 A520 NH ◎ 高信賴性 High reliability. ◎ 耐熱性佳,表面溫昇低 High thermal stability and low surface temperature rise. ◎ 產品符合歐盟 RoHS 要求 額定功率 誤差值 電阻值(Ω) 二次加工 Rated Power Tolerance Resistance Forming 端子線 Lead Wire U: Standard 14:1/4W F±1% R100=0.1 See table 熱鍍線 S: Small 12:1/2W G±2% 1R00=1 below Heat plated 01:1W J±5% 10R0=10 P:Super small Products is compliance the EU-RoHS request. ■參考規格 Reference standards 02:2W 1000=100 03:3W 1001=1K 05:5W 1002=10K ● JIS C 5201-1 1003=100K ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) 最高過負荷電壓 最高使用電壓 Max. 耐電壓 Dielectric Max. Overload Working Voltage Withstanding Voltage Voltage F±1% (E96) G±2% (E24) J±5% (E24) 1/4,S1/2,P1 0.1 ~ 910K 1/2,S1,P2 0.1 ~ 33K 0.1 ~ 470K 1,S2,P3 0.1 ~ 33K 0.1 ~ 750K 2,S3,P5 0.1 ~ 33K 0.1 ~ 330K 3,S5 0.1 ~ 33K 0.1 ~ 100K 250V 500V 250V 350V 700V 350V 500V 1000V 500V 4 溫度係數 T.C.R. 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A52 A64 A73 FT YT L 2500 - - 2000 - 2500 F±1%: ±100ppm/ºC 2000 - - 2000 2000 2500 G±2%: 1000 1000 - 1000 1000 1000 ±200ppm/ºC J±5%: 500 500 500 - 1000 1000 ±350ppm/ºC - - - - - 200 ■額定溫度下降曲線圖 Derating curve 例 ■表面溫度上升 Surface Temperature Rise V.S. LoadedPower Power Vs. Loaded Example (ºC) ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping L Forming C Forming F Forming M Forming D Forming A52 A64 A73 FT YT L10 L12.5 L15 L20 L30 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 1/4,S1/2,P1 ○ - - ○ - ○ - - - - - - - - - ○ - - - - - - - - 1/2,S1,P2 ○ - - ○ ○ - ○ - - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - 1,S2,P3 ○ - - ○ ○ - - ○ - - - ○ - - ○ ○ ○ ○ - ○ - - ○ - 2,S3,P5 ○ ○ ○ - ○ - - - ○ - - - ○ - ○ ○ ○ ○ - - ○ - - ○ 3,S5 - - - - - - - - - ○ - - - ○ - - - - - - - - - - ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19)(4.19) 斷續過負荷 Intermittent overload ±(5%+0.1Ω) Applicable more than100Ω; Rated voltage ×3 1s ON / 25s OFF , 10,000 cycles(4.13) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 5 POWER TYPE RNU 金屬皮膜固定電阻器 RNS 小型金屬皮膜固定電阻器 FIXED METAL FILM RESISTOR (Standard Type) FIXED METAL FILM RESISTOR (Small Type) ■結構圖 Construction 塗裝顏色 (Coating Color ): 標 準 品: S1/2W 深藍色 Dark blue 1 端子線 Lead wire 2 瓷 棒 Ceramic base 3 鐵 帽 Cap 4 切割線 Helical cutting groove 5 6 7 導電皮膜 Conductive film 標 示 Marking or color code 絕緣塗料 Insulation coat 小 型 品: others 淺藍色 Light blue, 標 示 (Marking) : 色 碼 (Color Code) (1/8,S1/4,1/4,S1/2) 文 字 (Alphanumeric) (≧ 1/2W) ■ 外型尺寸 Dimensions Dimensions (mm) L L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/8,S1/4 3.5±0.5 5 1.7±0.3 0.45±0.05 27±3 110 ■特性 Feature 1/6 3.5±0.5 5 1.7±0.4 0.45±0.05 27±3 110 ◎高精密低溫度係數金屬膜電阻器 1/4,S1/2 6.0±0.5 7 2.3±0.3 0.52±0.05 27±3 210 1/2,S1 9±1 11 3.2±0.5 0.56±0.05 27±3 285 1,S2 12±1 15 4.0±0.5 0.8±0.05 38±3 728 2,S3 16±1 18 5.5±0.5 0.8±0.05 38±3 1380 10R0 A520 NH 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire Rated Power (W) High precision and low T.C.R. of metal film resistor. ◎長期穩定性佳 Excellent stability for long time service. ◎可自動插件 ■料號編碼 Type composition Automatic insertion is applicable. 例 ◎產品符合歐盟 RoHS 要求 Example RN U 型名 Type 品名 Size 14 J Products is compliance the EU-RoHS request. ■參考規格 Reference standards ● JIS C 5201-1 額定功率 誤差值 Rated Power Tolerance U: Standard 18:1/8W F±1% 10R0=10 See table 熱鍍線 S: Small 14:1/4W G±2% 1000=100 below Heat plated 12:1/2W J±5% 1001=1K 01:1W J±5% 1002=10K 02:2W 1003=100K 03:3W 1004=1M ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) F±1% (E96) G±2% (E24) J±5% (E24) 最高使用電壓 Max. 最高過負荷電壓 Max. 耐電壓 Dielectric Working Voltage Overload Voltage Withstanding Voltage 1/8,1/6, S1/4 10Ω~1M 200V 400V 1/4,S1/2 10Ω~2.2M 250V 500V 2,S3 300V ±100ppm/ºC 1/2,S1 1,S2 溫度係數 T.C.R. 10Ω~5.1M 350V 500V 700V 500V 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A52 A64 A73 FT YT L 5000 - - - - - 2500 - - 2000 - 2000 - - 2000 2000 2500 1000 1000 - 1000 1000 1000 500 6 500 500 - 2500 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping A26 A52 A64 FT YT L Forming C Forming F Forming M Forming D Forming L10 L12.5 L15 L20 L30 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 1/8,1/6 ○ - - - - - - - - - - - - - - - - - - - - - - - 1/4,S1/2 - ○ - ○ - ○ - - - - - - - - ○ ○ ○ ○ - - - - - - 1/2,S1 - ○ - ○ ○ - ○ - - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - 1,S2 - ○ ○ ○ ○ - - ○ - - - ○ - - ○ ○ ○ ○ - ○ - - ○ - 2,S3 - ○ ○ - ○ - - - ○ - - - ○ - ○ ○ ○ ○ - - ○ - - ○ ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(1.5%+0.05Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 斷續過負荷 Intermittent overload ±(1%+0.05Ω) Applicable more than100Ω; Rated voltage ×3 1s ON / 25s OFF , 1,000 cycles(4.13) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 7 POWER TYPE RPU 金屬皮膜精密電阻器 RPS 小型金屬皮膜精密電阻器 METAL FILM PRECISION RESISTOR (Standard Type) METAL FILM PRECISION RESISTOR (Small Type) ■結構圖 Construction 1 端子線 Lead wire 塗裝顏色(Coating Color) : 2 瓷 棒 Ceramic base 標 準 :≦ 1/6W Blue epoxy paint 3 鐵 帽 Cap 4 切割線 Helical cutting groove 標 品:≦ 1/6W 藍色環氧樹脂塗料 標 品:≧ 1/4W RPU/ gray; RPS/ pink 導電皮膜 Conductive film 5 6 標 示 Marking or color code 絕緣塗料 Insulation coat 7 準 品:≧ 1/4W RPU / 灰色; RPS / 粉紅色 標 示 (Marking) : 色 碼 (Color Code)(≦ S1/2) 文 字 (Alphanumeric) (1/2~S3) ■外型尺寸 Dimensions Dimensions (mm) L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/8,1/6,S1/4 3.5±0.5 5 1.7±0.3 0.45±0.05 27±3 110 1/4,S1/2 6.0±0.5 7 2.3±0.3 0.6±0.05 27±3 210 1/2,S1 9±1 11 3.2±0.5 0.6±0.05 27±3 285 1,S2 12±1 15 4.0±0.5 0.8±0.05 38±3 728 2,S3 16±1 18 5.5±0.5 0.8±0.05 38±3 1380 R100 A520 NH 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire Rated Power (W) ■特性 Feature ◎高精密低溫度係數金屬膜電阻器.電詛值容許差± 0.01% High precision and low T.C.R. of metal film resistor L and resistance tolerance±0.01%. ◎長期穩定性佳 ■料號編碼 Type composition Excellent stability for long time service. 例 ◎產品符合歐盟 RoHS 要求 Example RP U 型名 Type 品名 Size 14 F Products is compliance the EU-RoHS request. ■參考規格 Reference standards 額定功率 誤差值 Rated Power Tolerance U: Standard 18:1/8W F±1% 10R0=10 See table 熱鍍線 S: Small 14:1/4W D±0.5% 1000=100 below Heat plated 12:1/2W B±0.1% 1001=1K ● JIS C 5201-1 01:1W 1002=10K 02:2W 1003=100K ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) 最高使用電壓 Max. 0.01%、0.02%、0.05%、0.1%、1% Working Voltage 1/8,1/6 S1/4 200V 1/4,S1/2 1/2,S1 1,S2 2,S3 10Ω~100K 250V 350V 最高過負荷電壓 Max. Overload Voltage 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 300V 250V ± 100ppm/ºC 350V 500V 700V 8 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A26 A52 A64 FT YT L 5000 - - - - - - 2500 - 2000 - - - 2000 - 1000 2000 2500 - 1000 1000 1000 1000 1000 - 500 500 - 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping A26 A52 A64 FT L Forming C Forming F Forming M Forming D Forming YT L10 L12.5 L15 L20 L30 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 1/8,1/6 ○ - - - - - - - - - - - - - - - - - - - - - - - 1/4,S1/2 - ○ - ○ - ○ - - - - - - - - ○ ○ ○ ○ - - - - - - 1/2,S1 - ○ - ○ ○ - ○ - - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - 1,S2 - ○ ○ ○ ○ - - ○ - - - ○ - - ○ ○ ○ ○ - ○ - - ○ - 2,S3 - ○ ○ - ○ - - - ○ - - - ○ - ○ ○ ○ ○ - - ○ - - ○ ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(1.5%+0.05Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 斷續過負荷 Intermittent overload ±(1%+0.05Ω) Applicable more than100Ω; Rated voltage ×3 1s ON / 25s OFF , 10,000 cycles(4.13) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 9 DISCHARGE PATH RESISTOR RMU 金屬釉電阻器 RMS 小型金屬釉電阻器 RMH 大型金屬釉電阻器 METAL GLAZE RESISTOR (Standard Type) METAL GLAZE RESISTOR (Small Type) METAL GLAZE RESISTOR (Large-scale Type) ■結構圖 Construction 塗裝顏色(Coating Color): 1 端子線 Lead wire 標 準 品 Standard Type(1/6W,1/4W Dark blue ,other pink) 2 瓷 棒 Ceramic base 小 型 品 Small Type(≧ 1/2W Pink) 3 鐵 帽 Cap 4 切割線 Helical cutting groove 大 型 品 Large-scale Type(Pink) 標 示 (Marking): 色 碼 (Color Code) ( ≦ S1/2W) 文 5 6 7 金屬釉皮膜 Metal glaze film 標 Marking or color code 示 絕緣塗料 Insulation coat ■外型尺寸 Dimensions Dimensions (mm) Rated Power (W) 字 (Alphanumeric) (1/2W~S3W、H1W) L L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/6,S1/4 3.3±0.3 4 1.8±0.2 0.45±0.05 28±2 120 ■特性 Feature 1/4,S1/2 6.0±0.5 7 2.4±0.3 0.6±0.05 28±2 218 ◎使用不燃性塗料,具不燃與絕緣之安全特性(UL94 V-0) 1/2,S1 9±0.5 11 3.3±0.5 0.6/0.8±0.05 28±3 320 1,S2 12±1 15 4.5±0.5 2,S3,H1 16±1 18 5.5±0.5 0.8±0.05 38±3 Flameproof and insulating coating designed to assure safe usage by special non-flammable silicon-base. 780 1450 (Equivalent to UL94 V-0) ■料號編碼 Type composition ◎產品符合歐盟 RoHS 要求 例 Products is compliance the EU-RoHS request. ■產品認證 Approvals awarded ● UL 1676 & c-UL (CSA C22.2 No.1-98)File No.E220321 1/2,1,2 Watt,680K to 10M 125V ; 1/2,1,2 Watt,960K to 12M 250V ● EN 60065 (VDE 0860): 2011-10 Clause 14.1a 、14.1b Ausweis-Nr : 40030403 (1/4,1/2,1 Watt)100K to 100M Example R U 14 型名 Type 品名 Size J 1005 A520 NL 額定功率 誤差值 電阻值(Ω) 二次加工 Rated Power Tolerance Resistance Forming 端子線 Lead Wire U: Standard 16:1/6W F±1% 10R0=10 See table 電鍍線 S: Small 14:1/4W G±2% 1000=100 below Electro plated H: Large-scale 12:1/2W J±5% 1001=1K Ausweis-Nr : 40030404 (1/2,1,2 Watt)100K to 100M ● SEMKO&CB : 1/4,1/2,1,2 Watt,100K to 100M. Reference No.913033 1/4,1/2,1,2 Watt,100K to 100M 01:1W 1002=10K 02:2W 1003=100K 03:3W 1004:1M 1005=10M ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) 最高使用電壓 Max. 耐電壓 Dielectric F±1% (E96) G±2% (E24) J±5% (E24) Working Voltage Withstanding Voltage 1/6,S1/4 300V 1/4,S1/2 1/2,S1 300V 1600V 10Ω~< 100M 3500V 700V 1,S2 7000V 2,S3,H1 10000V 溫度係數 T.C.R. 10 F±1%: ±100ppm/ºC G±2%: ±200ppm/ºC J±5%: ±200ppm/ºC 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A26 A52 A64 FT YT L C M D 5000 - - - - - - - - - 2500 - 2000 - - 2000 - 2000 2000 2500 2500 2500 2500 - 1000 - 1000 1000 1000 1000 1000 1000 - 500 500 - 2500 2500 2500 2500 1000 1000 1000 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping A26 A52 A64 FT YT L Forming C Forming L10 L12.5 L15 L20 C12.5 C15 F Forming C20 FA5 M Forming D Forming FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 1/6,S1/4 ○ ○ - - - - - - - - - - - - - - - - - - - - 1/4,S1/2 - ○ - ○ - ○ - - - - - - - - - - - - - - - - 1/2,S1 - ○ - ○ ○ - ○ - - ○ - - ○ ○ ○ ○ ○ - - ○ - - 1,S2 - ○ - ○ ○ - - ○ - - ○ - ○ ○ ○ ○ - ○ - - ○ - 2,S3,H1 - ○ ○ - ○ - - - ○ - - ○ ○ ○ ○ ○ - - ○ - - ○ ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(1.5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 斷續過負荷 Intermittent overload ±(5%+0.1Ω) Applicable more than100Ω; Rated voltage ×3 1s ON / 25s OFF , 10,000 cycles(4.13) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 不燃性 Flameproof 無燃燒現象 No evidence of flaming or arcing AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) 脈衝測試 Pulse withstanding voltage ±20% The following discharge cycle is repeated in the circuit of the left fig. 2.5 sec. ON 2.5 sec. OFF 50 cycles. With following DC pulse test voltage. Pulse voltage:1/6W,S1/4W : (3KV). DC POWER 10MΩ SW Capacitor RX ≧ 1/4W < 100K:(3KV)//100 K~620K:(5KV) > 620 K:(10KV) Capacitor : UL-0.01 μF Non-UL 0.001μF 11 HIGH VOLTAGE PATH RESISTOR RVU 耐突波電阻器 RVS 小型耐突波電阻器 SURGE RESISTOR (Standard Type) SURGE RESISTOR (Small Type) ■結構圖 Construction 塗裝顏色(Coating Color ): 標 示 (Marking ) 文 字 (Alphanumeric) ■特性 Feature 1 端子線 Lead wire 2 瓷 棒 Ceramic base 3 鐵 帽 Cap 4 切割線 Helical cutting groove 金屬釉皮膜 Metal glaze film 5 6 標 7 絕緣塗料 示 Marking Insulation coat ■外型尺寸 Dimensions ◎阻值範圍: 680K~3G ◎長期穩定性佳 Stable and long service life. ◎可承受 10KV 突波的衝擊 Dimensions (mm) L L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/2,S1 9±0.5 11 3.3±0.5 0.6±0.05 28±3 285 1,S2 12±1 15 4.5±0.5 0.8±0.05 38±3 728 2,S3 16±1 18 5.5±0.5 0.8±0.05 38±3 1380 1004 A520 NH 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire Rated Power (W) Resistance value range is 680K~3G. Acceptable pulse of 10KV discharge. ◎溫度係數小 ■料號編碼 Type composition Small temp. coeff. of resistance. 例 ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. Example RV U 型名 Type 品名 Size 12 J 額定功率 誤差值 Rated Power Tolerance ■參考規格 Reference standards U: Standard ● JIS C 5201-1 S: Small 12:1/2W J±5% 1003=100K See table 1004=1M 01:1W below 熱鍍線 Heat plated SS :Small 02:2W 03:3W ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping L Forming C Forming F Forming M Forming D Forming A26 A52 A64 FT YT L10 L12.5 L15 L20 C12.5 C15 C20 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 1/2,S1 - ○ - ○ ○ - ○ - - ○ - - ○ ○ ○ ○ ○ - - ○ - - 1,S2 - ○ ○ ○ ○ - - ○ - - ○ - ○ ○ ○ ○ - ○ - - ○ - 2,S3 - ○ ○ - ○ - - - ○ - - ○ ○ ○ ○ ○ - - ○ - - ○ ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) J±5% (E24) 1/2,S1 1,S2 2,S3 最高使用電壓 Max. 耐電壓 Dielectric Working Voltage Withstanding Voltage 溫度係數 T.C.R. 3500V 680K~10M 7000V ±200ppm/ºC 700V 10000V 12 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A26 A52 A64 - 2000 - - 1000 1000 1000 1000 1000 1000 1000 1000 - 500 500 FT YT L C M D 2000 2000 2500 2500 2500 2500 1000 1000 1000 1000 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(1.5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance ≧ 50GΩ 10M DC POWER SW 0.01μF 10M ±3% 台灣雙羽脈衝試驗 Futaba Pulse withstanding voltage 350ºC ±10ºC for 3.5 seconds (手焊錫) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) ±20% UL 脈衝測試 UL Pulse withstanding voltage 260ºC ±5ºC for 10 seconds (焊錫槽) DC POWER RX The following discharge cycle is repeated in the circuit of the left fig. 2.5 sec. ON 2.5 sec. OFF 50 cycles. Test voltage (DC surge) 10KV(Max) SW 0.0025μF RX The following discharge cycle is repeated in the circuit of the left fig. 1 sec. ON 1 sec. OFF 50 cycles. Test voltage (DC surge) is shown below: Pulse voltage : 14KV(Max) 耐突波測試 Surge Test High Energy Test 高能量測試 ITEM Low Energy Test 低能量測試 SPEC. 規格 項目 ITEM SPEC. 規格 項目 Capacitance 電容值 (μF) 0.12μF Capacitance 電容值 (μF) 0.03μF Voltage 電壓 (KV) 10KV Voltage 電壓 (KV) 10KV Charging/Discharge Time 充/放電時間 10sec / 2sec Charging/Discharge Time 充/放電時間 10sec / 2sec Cycle 週期 12sec Cycle 週期 12sec Charging/Discharge Cycles 充/放電次數 1,000 Cycles Charging/Discharge Cycles 充/放電次數 10,000 Cycles Criteria 判定標準 + 100% ~ -20% Criteria 判定標準 13 + 100% ~ -10% HIGH VOLTAGE PATH RESISTOR RRU 高阻值金屬釉電阻器 RRS 高阻值小型金屬釉電阻器 HIGH RESISTANCE RESISTOR (Standard Type) HIGH RESISTANCE RESISTOR (Small Type) ■結構圖 Construction 塗裝顏色(Coating Color): RRU1/6W、RRU1/4W 深藍色 Dark blue 粉紅色 other pink 標 示 (Marking): 色 碼 (Color Code) ≦ S1/2W 文 字 (Alphanumeric) 1/2W~S3W 1 端子線 Lead wire 2 瓷 棒 Ceramic base 3 鐵 帽 Cap 4 切割線 Helical cutting groove 金屬釉皮膜 Metal glaze film 5 Marking or color code 6 標 示 7 絕緣塗料 Insulation coat ■外型尺寸 Dimensions Dimensions (mm) L L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/6,S1/4 3.3±0.3 4 1.8±0.2 0.45±0.05 28±2 120 1/4,S1/2 6.0±0.3 7 2.4±0.1 28±2 218 1/2,S1 9±0.5 11 3.3±0.5 28±3 320 1,S2 12±1 15 4.5±0.5 2,S3 16±1 18 5.5±0.5 5W,S7W 24±1 26 8±10.5 Rated Power (W) ■特性 Feature ◎阻值範圍 101MΩ~3GΩ Resistance value range is 101MΩ~3GΩ. ◎溫度係數可低至 50ppm 一般為 200ppm 0.6±0.05 780 0.8±0.05 38±3 1450 3800 Low T.C.R.to 50ppm. Normal is 200ppm. ■料號編碼 Type composition ◎長期穩定性與長效使用壽命 例 Long load life and long term stability. ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. Example RR U 14 J 型名 Type 品名 Size 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) 二次加工 Resistance Forming 端子線 Lead Wire U: Standard 16:1/6W F±1% 1006=100M See table 熱鍍線 S: Small 14:1/4W G±2% 12:1/2W J±5% ■ 參考規格 Reference standards ● JIS C 5201-1 10R0 A520 below 1007=1G NH Heat plated 01:1W 02:2W 03:3W 05:5W 07:7W ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) J±5% (E24) 最高使用電壓 Max. Working Voltage 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A26 A52 A64 FT YT L C M D - - - - 1/6,S1/4 500V 5000 - - - - 1/4,S1/2 1600V - 2500 - 2000 - - 2000 - 2000 2000 1000 2500 2500 2500 - 1000 1000 1000 1000 1000 1000 1000 1000 1/2,S1 1,S2 ≧ 100M~3G 3500V 7000V 700V ±200ppm/ºC (±50ppm/ºC is contact salse) 2,S3 10000V - 500 500 - 5W,S7W 15000V - - - - 14 2500 2500 2500 2500 1000 1000 1000 1000 1000 - 500 500 500 500 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(1.5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1.5%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance ≧50GΩ ±20% 260ºC ±5ºC for 10 seconds (焊錫槽) 350ºC ±10ºC for 3.5 seconds (手焊錫) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 10M SW The following discharge cycle is repeated in the circuit of the left fig. UL 脈衝測試 UL Pulse withstanding voltage DC POWER 0.01μF RX 2.5 sec. ON 2.5 sec. OFF 50 cycles. Pulse test voltage (DC surge) 10KV. 15 FUSING RESISTOR RFU 保險絲電阻器 RFS 小型保險絲電阻器 FUSIBLE RESISTOR (Standard Type) FUSIBLE RESISTOR (Small Type) ■結構圖 Construction 塗料顏色 (Coating Color ): 1 端子線 Lead wire 保險型皮膜 Fusible film 5 2 瓷 棒 Ceramic base 標準品 (Standard Type) 灰 Gray 3 鐵 帽 Cap 小型品 (Small Type) 粉紅 Pink 4 切割線 Helical cutting groove 標示 (Marking): 色環 (Color Code) 1/6W、1/4W、1/3W、S1/2W 文字 (Alphanumeric) 1/2W~S3W Marking or color code 6 標 示 7 絕緣塗料 Insulation coat ■外型尺寸 Dimensions Dimensions (mm) L L1 Max. D Ød ℓ Weight (g) (1000pcs) 1/6,S1/4 3.3±0.3 4 1.7±0.3 0.45±0.05 27±3 120 1/4,1/3,S1/2 6.0±0.3 7 2.4±0.1 28±2 218 1/2,S1,P2 9±0.5 11 3.0±0.5 28±3 320 1,S2 12±1 15 4.5±0.5 2,S3 16±1 18 5.5±0.5 Rated Power (W) ■特性 Feature ◎使用不燃性塗料,具不燃與絕緣之安全特性(UL94 V-0) Flameproof and insulating coating designed to assure safe usage by special non-flammable silicon-base. 0.6±0.05 0.8±0.05 780 38±3 1450 (Equivalent to UL94 V-0) ■料號編碼 Type composition ◎正常情況下具電阻功能 RF U 型名 Type 品名 Size Function as a resistor in normal operation. ◎異常過負荷時可快速熔斷 Quick fusing protects circuit from excessive overload. ◎產品符合歐盟 RoHS 要求 14 J R100 額定功率 誤差值 電阻值(Ω) Rated Power Tolerance Resistance U: Standard 16:1/6W S: Small 14:1/4W J±5% A520 NH 二次加工 Forming 端子線 Lead Wire 1006=100M See table 熱鍍線 below 1007=1G Heat plated 12:1/2W Products is compliance the EU-RoHS request. 01:1W ■參考規格 Reference standards 02:2W ● JIS C 5201-1 03:3W ■二次加工對應表 Taping & Forming Matrix Rated Power (W) 例 Example Radial Taping Taping L Forming C Forming F Forming M Forming D Forming A52 A64 A73 FT YT L10 L12.5 L15 L20 L30 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 1/6,S1/4 ○ - - - - - - - - - - - - - - - - - - - - - - - 1/4,S1/2,1/3 ○ - - ○ - ○ - - - - - - - - - - - - - - - - - - 1/2,S1,P2 ○ - - ○ ○ - ○ - - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - 1,S2 ○ ○ - ○ ○ - - ○ - - - ○ - - ○ ○ ○ ○ - ○ - - ○ - 2,S3 - ○ - - ○ - - - ○ - - - ○ - ○ ○ ○ ○ - - ○ - - ○ ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) 最高使用電壓 Max. Working Voltage J±5% (E24) 最高過負荷電壓 Max. Overload Voltage 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A52 A64 FT YT L C - - - - 1/6,S1/4 0.1~1K 100V 150V 200V 5000 - 1/4,1/3 0.1~15K 250V 300V 250V 2500 - 2000 2000 2500 2500 S1/2,S1,P2 0.1~33K 250V 300V 250V ±350ppm/ºC 2500 - 1000 1000 2500 2500 250V 300V 300V 2000 - 1000 1000 2500 2500 350V 500V 300V 1000 500 1000 1000 1000 1000 1/2 1,2,S2,S3 0.1~4.7K 16 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■熔斷特性 Fusing characteristics 殘留阻值為公稱阻值 100 倍以上( Residual resistance ≧ 100 times nominal resistance ) Rated Power (W) Resistance Range 40PR 40 PR 30PR 40 PR 25PR 40 PR 16PR 40 PR 1/6、S1/4 0.10 ~ 1KΩ 0.10 ~ 0.18Ω 0.20 ~ 0.47Ω 0.51 ~ 1KΩ ------ 1/4、1/3 0.10 ~ 15KΩ 0.10 ~ 0.22Ω ------ 0.24 ~ 9.1Ω 10 ~ 15KΩ S1/2、P2 0.10 ~ 33KΩ ------ ------ 0.10 ~ 1.0Ω 1.1 ~ 33KΩ S1、P2 0.10 ~ 33KΩ ------ ------ 0.10 ~ 1.0Ω 1.1 ~ 33KΩ 1/2 0.10 ~ 4.7KΩ 0.10 ~ 0.33Ω 0.47 ~ 0.91Ω 1.0 ~ 9.1Ω 10 ~ 4.7KΩ 1、S2 0.10 ~ 4.7KΩ ------ ------ 0.10 ~ 1.0Ω 1.1 ~ 4.7KΩ 0.10 ~ 4.7KΩ ------ ------ 0.10 ~ 1.0Ω 1.1 ~ 4.7KΩ 2、S3 Fusing Time 60 Sec Max ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 4 倍額定功率,5 秒 4 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫效果 Soldeability 95 % (min) coverage Temp. of solder 245ºC ± 5ºC duration of immersion 3s±0.5s 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 17 RATED CURRENT FUSIBLE RESISTOR 電流式保險絲電阻器 RFA RATED CURRENT FUSIBLE RESISTOR (Standard Type) ■結構圖 Construction 塗料顏色 (Coating Color ): 1 端子線 Lead wire 標準品 (Standard Type) Gray 2 瓷 棒 Ceramic base 標示 (Color Code) 3 鐵 帽 Cap 4 切割線 Helical cutting groove 5 保險型皮膜 Fusible film color code 6 標 示 7 絕緣塗料 Insulation coat ■特性 Feature ■外型尺寸 Dimensions ◎使用不燃性塗料,具不燃與絕緣之安全特性(UL94 V-0) Flameproof and insulating coating designed to assure safe usage by special non-flammable silicon-base. Dimensions (mm) Rated Current (A) L ≦ 3A > 3A (Equivalent to UL94 V-0) ◎電流式保險絲提供電阻器熔斷遲延的性能及 L1 Max. D Ød 6.0±0.3 7 2.4±0.1 9±0.5 11 3.0±0.5 0.6±0.05 ℓ Weight (g) (1000pcs) 28±2 218 28±3 320 在定電流作業下的高穩定性 ■料號編碼 Type composition The rated current fusible resistor combines time delay performance Characteristics with the proven reliability of a rated current fusible. ◎產品符合歐盟 RoHS 要求 例 Example RF A 00 J A100 A520 NH 型名 Type 品名 Size 空欄 Blank 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 無註記 F±1% A100=0.1A See table 熱鍍線 G±2% 1A50=1.5A below Heat plated J±5% 3A00=3A Products is compliance the EU-RoHS request. ■參考規格 Reference standards ● JIS C 5201-1 7A00=7A ■二次加工對應表 Taping & Forming Matrix Rated Current (A) Radial Taping Taping L Forming C Forming F Forming M Forming D Forming A52 A64 A73 FT YT L10 L12.5 L15 L20 L30 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 ≦ 3A ○ - - ○ - ○ - - - - - - - - - - - - ○ - - ○ - - > 3A ○ - - ○ ○ - ○ - - - ○ - - - ○ ○ ○ ○ - ○ - - ○ - ■額定電流電阻表面溫度曲線 ■額定 Ratings Rated Current (A) ≦ 3A D20 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 100V ±350ppm/ºC > 3A 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A52 A64 FT YT L C 2500 - 2000 2000 2500 2500 2000 - 1000 1000 2500 2500 ■熔斷特性 Fusing characteristics 額定電流% Percentage of Ampere Rating 熔斷時間 Opening Time 100% 4Hours Min 200% 1 second~60second Max 300% 0.2 second~3 second Max 800% 0.02 second~0.2 second Max 殘留阻值為公稱阻值 100 倍以上( Residual resistance ≧ 100 times nominal resistance ) 18 Curve of temp. rise and rated current 10 MΩ ■訂購資訊 Ordering information ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■定電流熔斷曲線 Fuse curve of rated current Rating ratio of Ampere Fusing 1/10A~7A 100000 10000 1000 Order Amperes Voltage Body Melting A250 1/4 125 25*65 0.125 A375 3/8 125 25*65 0.28 A500 1/2 125 25*65 0.50 A750 3/4 125 25*65 1.12 1A00 1.00 125 25*65 2.00 1A50 1.1/2 125 25*65 5.50 2A00 2.00 125 25*65 8.00 2A25 2.1/4 125 25*65 10.12 2A50 2.1/2 125 25*65 12.50 3A00 3.00 125 25*65 18.0 3A15 3.15 125 25*65 20.0 4A00 4.00 125 28*92 32.0 5A00 5.00 125 28*92 50.0 7A00 7.00 125 28*92 98.0 100 Time(s) 10 1 0.1 0.01 0% 100% 200% 300% 400% 500% Loading Ratio of Ampere (%) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 4 倍額定功率,5 秒 4 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫效果 Soldeability 95 % (min) coverage Temp. of solder 245ºC ± 5ºC duration of immersion 3s±0.5s 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 不燃性 Flameproof 260ºC ±5ºC for 10 seconds (焊錫槽) 350ºC±10ºC for 3.5 seconds (手焊錫) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 無燃燒現象 No evidence of flaming or arcing 19 AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) FUSING RESISTOR WFU 高能量突波繞線保險絲電阻器 WFS 小型高能量突波繞線保險絲電阻器 FUSIBLE RESISTOR (Standard Type) HEAT ENERGY SURGE WIRE WOUND FUSIBLE RESISTOR (Small Type) ■結構圖 Construction 塗料顏色(Coating Color):: 1 端子線 Lead wire 標準品 (Standard Type) Gray 2 瓷 小型品(Small Type) Pink 3 鐵 帽 Cap 標示(Marking): 棒 Ceramic base 繞 5 標 示 Wire wound 線 Marking or color code 絕緣塗料 Insulation coat 6 ■外型尺寸 Dimensions 色碼(Color Code ) S1/2W Dimensions (mm) Rated Power (W) 文字(Alphanumeric) 1/2W~S3W ■特性 Feature ◎電壓式繞線保險絲提供高突波能量的特性,準確的熔 斷性能,及在額定功率下作業的高穩定性 The voltage type wire wound fusible resistor can provide L L1 Max. D S1/2 6.0±0.3 7 2.4±0.1 1/2,S1 9.0±0.5 11 3.0±0.5 1,S2 12±1 15 4.5±0.5 2,S3 16±1 18 5.5±0.5 reliable fusing behavior stable performance and ■料號編碼 Type composition endurance to surge voltage. 例 ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. U 型名 Type 品名 Size 12 S: Small Radial Taping L Forming 0.6±0.05 28±3 0.8±0.05 38±3 200 285 728 1380 R100 A520 NH 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire R100=0.1 See table 熱鍍線 01:1W 1R00=1 below Heat plated 02:2W 10R0=10 03:3W 1000=100 J±5% 12:1/2W ■二次加工對應表 Taping & Forming Matrix Taping ℓ J 額定功率 誤差值 Rated Power Tolerance U: Standard ● JIS C 5201-1 Ød Weight (g) (1000pcs) Example WF ■參考規格 Reference standards Rated Power (W) 4 C Forming F Forming M Forming D Forming A52 A64 A73 FT YT L10 L12.5 L15 L20 L30 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 S1/2 ○ - - ○ - ○ - - - - - - - - ○ ○ ○ ○ - - - - - - 1/2,S1 ○ - - ○ ○ - ○ - - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - 1,S2 ○ ○ - ○ ○ - - ○ - - - ○ - - ○ ○ ○ ○ - ○ - - ○ - 2,S3 - ○ - - ○ - - - ○ - - - ○ - ○ ○ ○ ○ - - ○ - - ○ ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) J±5% (E24) 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. Overload Voltage 耐電壓 Dielectric Withstanding Voltage S1/2 1/2,S1 1,S2 溫度係數 T.C.R. A52 A64 2500 - 2000 2000 2500 2500 ± 500ppm/ºC 2000 - 1000 2000 2500 2500 ≦ 1Ω: 0.1 ~ 150 100V 150V 100V > 1Ω: ± 300ppm/ºC 2,S3 20 包裝 Taping/Ammo,Forming/Bulk pack (pcs) FT YT L C 1000 1000 1000 1000 1000 1000 500 500 1000 1000 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 ■突波特性 Example 例 ■額定功率表面溫升 Surface Temperature Rise Example Vs. Loaded Power PULSE LOADING CURVE FOR WIRE WOUND FUSIBLE 1/2W & S1W 1W 10000000 1000000 100000 Power (W) (ºC) 2W 10000 1000 100 10 1 (ºC) 1.00E+04 1.00E+03 2.00E+02 1.00E-01 7.00E-03 5.50E-04 4.00E-05 3.00E-05 5.00E-07 2.50E-08 0.1 Time(second) ■熔斷特性 Fusing characteristics 殘留阻值為公稱阻值 100 倍以上( Residual resistance ≧ 100 times nominal resistance ) Power Rating I=constant Opening Time 1/2W Power Rating I=constant Opening Time 1W Power Rating I=constant Opening Time 16W 10 sec Min & 24W 10 sec Min & 23W 10 sec Min & 18W 3sec ~ 60 sec Max S1W 28W 8sec ~ 45 sec Max S2W 40W 10sec ~ 30 sec Max S3W 20W 2 sec ~ 30 sec Max 32W 5 sec ~ 30 sec Max & 48W 3 sec ~ 8 sec Max 22W 1sec ~ 15sec Max 36W 2sec ~ 15sec Max P3W 60W 2sec ~ 5sec Max 2W ■ 試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 4 倍額定功率,5 秒 4 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫效果 Soldeability 95 % (min) coverage Temp. of solder 245ºC ± 5ºC duration of immersion 5s±0.5s 絕緣電阻 Insulation resistance >1,000MΩ 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 不燃性 Flameproof 無燃燒現象 No evidence of flaming or arcing 21 AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) NON-SMOKE THERMAL FUSE RESISTOR RFT 水泥繞線電阻組合溫度保險絲電阻器 NON-SMOKE THERMAL FUSE RESISTOR (RFT Type) ■結構圖 Construction 本體顏色 (Body color): 白 色 (White) 標 示 (Marking) : 文 字 (Alphanumeric ) 1 瓷 2 矽水泥 3 殼 Ceramic case 4 電阻器 Resistor Silicon cement 5 端子線 Lead wire 溫度保險絲 Thermal fuse 6 標 Marking 示 ■外型尺寸 Dimensions ■特性 Feature Dimensions (mm) Rated Power (W) H±1 W±1 h±1 P±1 s±1 2 20 12 5 5 7 0.6 ±0.1 0.8 ±0.1 3 25 12 5 5 9 1.0 ±0.1 0.8 ±0.1 5 25 13.5 5 5 9 1.0 ±0.1 0.8 ±0.1 7 39 13 5 5 9 1.0 ±0.1 0.8 ±0.1 10 25 20 5 12 9 0.8 ±0.1 0.8 ±0.1 10s 35 16 5 7 12 1.0 ±0.1 0.8 ±0.1 T133 NH ◎不燃與絕緣之安全設計 Compact type with safety design of Non-flammability and insulation. ◎可依客戶需求製作 Can be produced according to customer’s request. ◎產品符合歐盟 RoHS 要求 Fuse: Ød1 Wire: Ød2 Products is compliance the EU-RoHS request. ■料號編碼 Type composition ■產品認證 Approvals awarded ● UL 1412 File No.E257690 CUL UL1412 Recognized :≤ 145ºC / 3W、5W、7W、10W / RF T 型名 Type 品名 Size J 額定功率 誤差值 Rated Power Tolerance 10R0 電阻值(Ω) 溫度 端子線 Resistance Temperature Lead Wire 溫度型 03:3W F±1% 1R00=1 T133 : 熱鍍線 Thermal 05:5W G±2% 10R0=10 133℃ Heat plated 07:7W J±5% 1000=100 A0:10W K±10% 0.1Ω~ 1KΩ ■參考規格 Reference standards 03 例 Example ● JIS C 5201-1 ■額定 Ratings Thermal Fuse Temperature Function Tf Thermal Fuse Temp. 65 76 86 Power Rating (W) Voltage Rating 3W 5W 7W 10W 、10WS 61±3 0.3 0.4 0.6 0.7 72±3 0.5 0.6 0.8 1 81±2 0.6 0.8 1 1.3 102 98±3 0.9 1.1 1.4 1.7 115 111±2 1.1 1.4 1.7 2.1 127 123±2 1.3 1.7 2 2.5 133 129±3 1.5 2 2.4 3 136 131±2 1.6 2.1 2.6 3.2 139 134±2 1.7 2.2 2.7 3.3 145 140±2 1.8 2.3 2.8 3.5 187 182±2 1.8 2.3 3.3 4.6 192 187±2 1.8 2.3 3.3 4.6 219 215±2 1.8 2.3 3.3 4.6 AC 250V 22 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 1000V ± 350ppm/ºC ■額定溫度下降曲線圖 Derating curve 例 Example 試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 試驗溫度 70ºC,30 分鐘 70ºC (30min) 短時間過負荷 Short time overload ±(2%+0.05Ω) √ 4PR 倍額定功率,5 秒 √ 4PR times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(2%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 23 FUSING RESISTOR RFB 防爆保險絲電阻器 RFF 防爆保險絲電阻器 ANTI-BURST FUSIBLE RESISTOR (Wire Type) ANTI-BURST FUSIBLE RESISTOR (Film Type) ■結構圖 Construction 本 體 顏 色 (Body Color): 白 色 (White) 1 端子線 Lead wire 標 示 (Marking) : 2 鐵 帽 Cap 色 碼 (Color Code) (1/4W) 3 瓷 棒 Ceramic base 文 字 (Alphanumeric) (1/2W~3W) 4 繞 線 Wire wound 5 標 示 Marking 6 瓷 管 Ceramic tube 7 ■特性 Feature ■外型尺寸 Dimensions ◎防爆式繞線保險絲或防爆式皮膜保險絲 Rated Power (W) L L1 Max. D 1/4 6.6±0.5 10 3.6±0.5 1/2 11±1 14 4.3±0.5 Resistors can provide reliable and environmentally safe 1 11±1 14 4.3±0.5 fusing behavior. 2 13±1 16 5.5±0.5 3 17±1 20 7.0±0.5 The ANTI-BURST Type wire wound or film type fusible. ◎提供無爆裂與保護環境的安全熔斷特性,準確的熔斷性能 ◎在額定功率下作業的持久高穩定性 Reliable performance and endurance to surge voltage. Dimensions (mm) ■料號編碼 Type composition ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ■產品認證 Approvals awarded Insulation coat 絕緣塗料 Weight (g) (1000pcs) Ød ℓ 0.6±0.05 26±2 490 30±3 1250 35±3 2300 310 490 0.8±0.05 例 Example RF B 14 J R100 A520 NH 型名 Type 品名 Size 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire B: Wire 14:1/4W J±5% R100=0.1 See table 熱鍍線 F: Film 12:1/2W 1R00=1 below Heat plated 01:1W 10R0=10 02:2W 1000=100 ● UL 1412 File No.E257690 ■參考規格 Reference standards ● JIS C 5201-1 03:3W ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Taping Radial Taping L Forming C Forming A52 A64 A73 FT YT L10 L12.5 L15 L20 L30 C12.5 C15 1/4 ○ - - - - - - - - - - 1/2,1 ○ - - - - - - ○ - - 2 - ○ - - - - - - ○ 3 - - - - - - - - - F Forming M Forming FD5 M12.5 M15 D Forming C20 C30 FA5 FB5 FC5 M20 D12.5 D15 D20 - - - - - - - - - - - - - - ○ - - ○ ○ ○ ○ - ○ - - ○ - - - - ○ - ○ ○ ○ ○ - - ○ - - ○ - - - - - - - - - - - - - - - ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) J±5% (E24) 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. 耐電壓 Dielectric Overload Voltage Withstanding Voltage 溫度係數 T.C.R. 1/4 ≦ 1Ω: 1/2 1 0.1 ~ 100 250V 500V 1,500V > 1Ω: 2 3 ± 500ppm/ºC ± 300ppm/ºC 100V 150V 2,000V 24 包裝 Taping/Ammo,Forming/Bulk pack (pcs) A52 A64 FT YT L C 1000 - - - - - 1000 - - - 2500 2500 1000 - - - 1000 1000 - 500 - - 1000 1000 - - - - - - ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■熔斷特性 Fusing characteristics (參考用 Reference) 殘留阻值為公稱阻值 100 倍以上( Residual resistance ≧ 100 times nominal resistance ) Power Rating I=constant Opening Time 45W 8 sec ~ 40 sec Max 1/4W 50W 1/2W Power Rating I=constant Opening Time 20W 8 sec ~ 35 sec Max & 25W 3 sec ~ 15 sec Max 2W 55W 30W 60 50 50 50 40 30 20 10 10 0 0 40 45 50 55 Fusing Time(s) 60 Fusing Time(s) 60 35 2 sec ~ 10 sec Max 40W 1sec ~ 5sec Max 40 30 20 10 10 60 35W 70 70 20 5 sec ~ 35 sec Max RFB2W & 3W Fusing Curve RFB1/2W & 1W Fusing Curve RFB1/4W Fusing Curve Fusing Time(s) 2sec ~ 10sec Max 70 30 30W 3W 2sec ~ 8sec Max 40 Opening Time & 5 sec ~ 20 sec Max 1W Power Rating I=constant 15 20 25 30 35 0 20 25 Power(W) Power(W) 30 35 40 45 Power(W) ※能量可以依客戶需求製作 Energy can be produced according to customer demand ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 4 倍額定功率,5 秒 4 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫效果 Soldeability 95 % (min) coverage Temp. of solder 245ºC ± 5ºC duration of immersion 3s±0.5s 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 不燃性 Flameproof 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 無燃燒現象 No evidence of flaming or arcing 25 AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) WIRE RESISTOR RWU 繞線電阻器 RWS 小型繞線電阻器 RWP 超小型繞線電阻器 WIRE WOUND RESISTOR (Standard Type) WIRE WOUND RESISTOR (Small Type) WIRE WOUND RESISTOR (Super Small Type) ■結構圖 Construction 塗 料 顏 色 (Coating Color ): 標 準 品 (Standard Type) Gray 小 型 品 (Small Type) Pink 1 端子線 Lead wire 4 繞 線 Wire wound 2 瓷 棒 Ceramic base 5 標 示 Marking or color code 3 鐵 帽 Cap 6 絕緣塗料 Insulation coat ■外型尺寸 Dimensions 超 小 型 品 (Super Small Type) Pink Dimensions (mm) Rated Power (W) 標 示 (Marking ) : 色 碼 (Color Code) (RWP1W) 文 字 (Alphanumeric) (1/2W~10W) ■特性 Feature ◎使用不燃性塗料,具不燃與絕緣之安全特性(UL94 V-0) Flameproof and insulating coating designed to assure safe usage by special non-flammable silicon-base. L L1 Max. D Ød ℓ Weight (g) (1000pcs) P1 6±0.5 7 2.4±0.1 0.6±0.05 28±3 210 P1 (UL) 9.5±1 12 4.5±1 0.7±0.05 28±3 510 1/2,S1,P2 9±0.5 11 3.3±0.5 0.6/0.8±0.05 28±3 285 1,S2,P3 12±1 15 4.5±0.5 2,S3,P5 16±1 18 5.5±0.5 0.8±0.05 38±3 3,S5,7 25±1 28 8.5±0.5 44MAX 46MAX 8MAX 0.8±0.05 38±3 10 (Equivalent to UL94 V-0) ◎小型化能高密度插裝 ■料號編碼 Type composition Small size are good for high density application. ◎長期穩定性佳 Stable long service life. RW U 型名 Type 品名 Size Products is compliance the EU-RoHS request. 1380 3768 6200 例 Example 12 J 1000 額定功率 誤差值 電阻值(Ω) Rated Power Tolerance Resistance U: Standard ◎產品符合歐盟 RoHS 要求 728 A520 NH 二次加工 Forming 端子線 Lead Wire 12:1/2W F±1% R100=0.1 See table 熱鍍線 S: Small 01:1W G±2% 1R00=1 below Heat plated P:Super small 02:2W J±5% 10R0=10 ■產品認證 Approvals awarded ● RWP1W Series UL1412 File No.E257690 03:3W 1000=100 05:5W 1001=1K 07:7W 1002=10K ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) J±5% (E24) P1 0.1 ~ 100 1/2,S1,P2 0.05 ~ 150 1,S2,P3 0.05 ~ 330 2,S3,P5 3,S5,7 7,10 最高使用電壓 Max. Working Voltage 耐電壓 Dielectric Withstanding Voltage 250V A64 FT YT L C M D 5000 2500 - - - - - - - - 2000 - 2000 2000 2500 2500 2500 2500 - 1000 - 2000 2000 1000 1000 1000 1000 - 500 500 - 500V - - - - - 500 500 - 500 500V - - - - - - - - - ≦ 1Ω: 350V ± 500ppm/ºC > 1Ω: 500V 0.05 ~ 1K 0.05 ~ 15K 0.05 ~ 27K A26 (UL)1000V 350V 500V 包裝 Taping/Ammo,Forming/Bulk pack (pcs) 溫度係數 T.C.R. ± 300ppm/ºC 26 A52 1000 1000 1000 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping A26 A52 A64 FT L Forming C Forming F Forming M Forming D Forming YT L10 L12.5 L15 L20 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 D30 P1 ○ - - ○ - ○ - - - - - - - ○ ○ ○ ○ - - - - - - - 1/2,S1,P2 - ○ - ○ ○ - ○ - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - - 1,S2,P3 - ○ - ○ ○ - - ○ - - ○ - - ○ ○ ○ ○ - ○ - - ○ - - 2,S3,P5 - ○ ○ - ○ - - - ○ - - ○ - ○ ○ ○ ○ - - ○ - - ○ - 3,S5 - - - - - - - - - - - ○ - - - - - - - - - - ○ 7,10 - - - - - - - - - - - - - - - - - - - - - - - - ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫效果 Soldeability 95 % (min) coverage Temp. of solder 245ºC ± 5ºC duration of immersion 3s±0.5s 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 不燃性 Flameproof 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 無燃燒現象 No evidence of flaming or arcing 27 AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) NON INDUCTIVE RESISTOR NWU NMU NWS NMS NWP NMP NVU 繞線式無感電阻器 皮膜無感精密電阻器 NON INDUCTIVE PRECISION RESISTOR (Standard Type) NON INDUCTIVE RESISTOR (Wirewouud standard Type) NVS 小型繞線式無感電阻器 小型皮膜無感精密電阻器 NON INDUCTIVE PRECISION RESISTOR (Small Type) NON INDUCTIVE RESISTOR (Small Wirewouud Type) NVP 超小型繞線式無感電阻器 超小型皮膜無感精密電阻器 NON INDUCTIVE PRECISION RESISTOR (Super Small Type) NON INDUCTIVE RESISTOR (Super Small Wirewouud Type) ■結構圖 Construction 端子線 Lead wire 1 塗 料 顏 色 (Coating Color) : 2 瓷 棒 Ceramic base 標 準 品 (Standard Type) Gray 3 鐵 帽 Cap 6 小 型 品 (Small Type) Pink 4 切割線 Helical cutting groove 7 標 示 (Marking) : 色 碼 (Color Code) (S1/2W) 文 字 (Alphanumeric) (1/2W~7W) ◎使用不燃性塗料,具不燃與絕緣之安全特性.(UL94 V-0) L L1 Max. D Ød ℓ Weight (g) (1000pcs) P1 6±0.3 7 2.4±0.1 28±2 210 1/2,S1,P2 9±0.5 11 3.3±0.5 0.6±0.05 P2:0.7 28±3 285 1,S2,P3 12±1 15 4.5±0.5 2,S3,P5 16±1 18 6±1 Flameproof and insulating coating designed to assure 3,S5 25±1 28 8.5±0.5 safe usage by special non-flammable silicon-base. 7 25±1 28 8.5±0.5 (Equivalent to UL94 V-0) 10 40±1 42 8.5±0.5 ■料號編碼 Type composition ◎小型化能高密度插裝 Small size are good for high density application. ◎超低電感量 (1KHz : 3μH 以下) Low inductance value (1KHz : Under 3μH). NW U 型名 Type 品名 Size 12 Products is compliance the EU-RoHS request. 0.1~10 1/2,S1,P2 0.05 ~ 22 1,S2,P3 0.05 ~ 47 2,S3,P5 3,S5 7 10 2Ω~ 14M 0.05 ~ 220 2Ω~ 1M 0.1~1k 10~1M 例 Example J 1000 A520 NH 二次加工 Forming 端子線 Lead Wire NM S: Small 01:1W J±5% 1R00=1 below Heat plated NV 02:2W 10R0=10 03:3W 1000=100 P:Super small 2Ω~ 12M 0.05 ~ 100 6434 熱鍍線 最高使用電壓 Max. 耐電壓 Dielectric Working Voltage Withstanding Voltage 1000V 33±1 See table 750V 10Ω~ 3G 3768 R100=0.1 ■額定 Ratings P1 3768 G±2% ● JIS C 5201-1 NV (Film) 0.8±0.05 1380 12:1/2W ■參考規格 Reference standards 阻值範圍 Resistance Range (Ω) 728 38±3 (S2W S3W 36±3) 額定功率 誤差值 電阻值(Ω) Rated Power Tolerance Resistance NW U: Standard ◎產品符合歐盟 RoHS 要求 NM (Film) Marking or color code 標 示 絕緣塗料 Insulation coat Dimensions (mm) Rated Power (W) ■特性 Feature NW (Wire) 導電層材 Conductive film/NM、NV ■外型尺寸 Dimensions 超 小 型 品 (Super Small Type) Pink Rated Power (W) Wire wound/NW 繞 線 5 NW : 350V NM、NV : 500V 1500V 10000V 28 05:5W 1001=1K A0:10W 1002=10K 包裝 Taping/Ammo pack (pcs) 溫度係數 T.C.R. A26 NW Type A52 A64 FT YT 5000 2500 - 2000 - - 1000 1000 ≦ 1Ω:± 500ppm/ºC - 2000 > 1Ω:± 300ppm/ºC - 1000 1000 1000 1000 NM、NV Type - 500 ≦ 300Ω:± 350ppm/ºC - - - - - > 300Ω:± 200ppm/ºC - - - - - - - - - - 500 1000 1000 ■額定溫度下降曲線圖 Derating curve 例 Example NW Type NV Type (ºC) (ºC) ■二次加工對應表 Taping & Forming Matrix Rated Power (W) Radial Taping Taping A26 A52 A64 FT YT L Forming C Forming F Forming M Forming D Forming L10 L12.5 L15 L20 C12.5 C15 C20 C30 FA5 FB5 FC5 FD5 M12.5 M15 M20 D12.5 D15 D20 D30 P1 ○ ○ - - - - - - - - - - - - - - - - - - - - - - 1/2,S1,P2 - ○ - ○ ○ - ○ - - ○ - - - ○ ○ ○ ○ ○ - - ○ - - - 1,S2,P3 - ○ ○ ○ ○ - - ○ - - ○ - - ○ ○ ○ ○ - ○ - - ○ - - 2,S3,S5,P5 - ○ ○ - ○ - - - ○ - - ○ - ○ ○ ○ ○ - - ○ - - ○ - 3 - - - - - - - - - - - - ○ - - - - - - - - - - ○ 7 - - - - - - - - - - - - - - - - - - - - - - - - ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp.(30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫效果 Soldeability 95 % (min) coverage Temp. of solder 245ºC ± 5ºC duration of immersion 3s±0.5s 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 不燃性 Flameproof 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 無燃燒現象 No evidence of flaming or arcing 29 AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) METAL PLATE CEMENT RESISTOR MPC 金屬板電阻器 MPH 金屬板電阻器 METAL PLATE CEMENT RESISTOR (MPC Type) METAL PLATE CEMENT RESISTOR (MPH Type) MPC TYPE MPH TYPE Only Available In 4W 本 體 顏 色 (Body color): 白 色 (White) 本體顏色 (Body color): 標 示 (Marking): 白色 ◎阻值範圍 0.01Ω~25Ω. (White) Resistance value range 0.01Ω~25Ω. 塗料顏色 (Coating color ) Coating color Green 綠色 標 示 (Marking): (Green) 文 字 (Alphanumeric) ■料號編碼 Type composition ■特性 Feature ◎不燃與絕緣之安全設計 Compact type with safety design of Non-flammability and Insulation. 例 Example MPC 02 J R010 S000 CP 型名 Type 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 01:1W F±1% R010=0.01 S000 : CP Wire 02:2W G±2% R100=0.1 Straight 03:3W J±5% 1R00=1 F090 : 05:5W K±10% 10R0=10 Forming ◎低阻值耐突波佳 Low resistance and resilient to surge current. ◎無電感 Non- inductance. A0:10W ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ■參考規格 Reference standards MPH 04 J R100 S002 CP 型名 Type 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 04:4W J±5% R100=0.1 S002: 2Pin CP Wire 1R00=1 S004: 4Pin ● JIS C 5201-1 K±10% ■額定 Ratings TYPE 01 Rated Power (W) 阻值範圍 Resistance Range (Ω) 1 0.01~0.5 2 0.01~0.05 73 3 74 MPH Forming --- 0.1~1.0 5 0.01~1.0 0.01~0.08 75 1.5~2.2 10 0.1~3.3 708 2+2 0.1~1.0 735 Straight 0.1~1.0 722 733 包裝 Pack (pcs) 1000 0.006~0.08 71 MPC 溫度係數 T.C.R. 0.1~1.0 78 72 耐電壓 Dielectric Withstanding Voltage 0.1~1.0 70 76 誤差值 Tolerance 3+3 F±1% G±2% J±5% K±10% 500V ±100ppm/ºC ±200ppm/ºC ±350ppm/ºC 500 500 0.1~1.0 --- 0.01~0.08 725 5+5 0.1~1.0 04 4 0.1~33 K±10% 30 200 ■結構圖 Construction MPC & MPH TYPE MPC Type MPH Type Only Available In 4W 1W 腳距 P : 5 ±0.5mm 1 端子線 Lead wire 2 矽水泥 Silicon cement 3 金屬板 Metal board 4 標 Marking 示 5 瓷 殼 Ceramic case ■外型尺寸 Dimensions TYPE Dimensions (mm) A B C Ød Weight (g) (1000pcs) 01 10±1.0 10±1.0 5±0.5 0.8±0.05 1250 70 , 76 , 78 8.0±1.0 13±1.0 4±0.5 0.6±0.05 1250 72 , 73 13±1.0 13±1.0 5±0.5 0.6±0.05 2350 71 18±1.0 14±1.0 5±0.5 0.6±0.05 3400 74 , 75 18±1.0 14±1.0 5±0.5 0.8±0.05 3400 722 18±1.0 26±1.0 5±0.5 0.8±0.05 5900 708 9.0±1.0 26±1.0 5±0.5 0.6±0.05 3000 735 13±1.0 26±1.0 5±0.5 0.6±0.05 5000 733 13±1.0 26±1.0 5±0.5 0.6±0.05 5000 725 18±1.0 26±1.0 5±0.5 0.8±0.05 6000 4 21 ±1.0 15 ±1.0 2.0±0.5 0.6±0.05 1650 型名 Model MPC MPH ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.05Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(2%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(2%+0.05Ω) 絕緣電阻 Insulation resistance MPH : >10MΩ MPC : >1000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 31 METAL PLATE CEMENT RESISTOR MPM 金屬板電阻器 METAL PLATE CEMENT RESISTOR (MPM Type) ■結構圖 Construction MPM TYPE MPM 4W 本體顏色 (Body color) 白 綠 色 (White) MPM 7W 色 (Green) 標 示 (Marking) 塗料顏色 (Coating color) 文 字 (Alphanumeric) 1 端 子 線 Lead wire 5 金 屬 板 Metal board ■特性 Feature 2 金 屬 殼 Metal shell 6 捺 ◎不燃與絕緣之安全設計 3 電 鍍 層 Plating layer 4 陶 瓷 板 Ceramic base 7 絕緣塗料 Insulation coat Compact type with safety design of Non-flammability and 印 Marking insulation. ■外形尺寸 Dimensions ◎低阻值耐突波佳及可用於電流偵測 Low resistance and resilient to surge current ,and current sensor application . ◎無電感 Non- inductance. Dimensions (mm) 型名 Model A B C h Ød P1 P2 MPM 4W 18±0.5 15±1.0 2.0±0.5 15±3 0.60±0.05 5.5±0.5 9.5±0.5 ◎產品符合歐盟 RoHS 要求 MPM 5W 18±0.5 15±1.0 2.0±0.5 15±3 0.60±0.05 5.5±0.5 9.5±0.5 Products is compliance the EU-RoHS request. MPM 7W 32±1.0 15±1.0 3(MAX) 16±3 0.60±0.05 5.0±0.5 9.5±0.5 Ød=0.5±0.05 (36Ω~100MΩ) Ød=0.8±0.05 for current sensor application ■料號編碼 Type composition ■測試標準 Test Standard 例 1. JIS C 5201-1 2. R.C loop for Surge test. Example MPM 04 K R010 S002 CP 型名 Type 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 04:4W F±1% R010=0.01 S002 : CP Wire 05:5W J±5% R100=0.1 2Pin 07:7W K±10% 1R00=1 S004 : 10R0=10 4Pin ■額定 Ratings TYPE MPM Rated Power (W) 阻值範圍 Resistance Range(Ω) 4 0.01~100M 5 0.01~100M 7 0.005~100M 誤差值 Tolerance F±1% J±5% K±10% 32 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 500V Normal Type ± 350ppm/ºC CSR ± 100ppm/ºC ± 50ppm/ºC ± 25ppm/ºC 包裝 Pack (pcs) Straight Forming 1200 --- ■額定溫度下降曲線圖 Derating curve 例 Example 4W (ºC) 5W (ºC) 7W (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.1Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(2%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >10MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 33 METAL PLATE CEMENT RESISTOR MPT 金屬板電阻器 MPQ 金屬板電阻器 METAL PLATE CEMENT RESISTOR (MPT Type) METAL PLATE CEMENT RESISTOR (MPQ Type) MPQ TYPE MPT TYPE 本體顏色 (Body color): 本體顏色 (Body color): 白 塗料顏色 (Coating color) : 塗料顏色 (Coating color ): 藍 標 文 色 (White) 白 色 (White) 色 (Blue) 綠 色 (Green) 示 (Marking ): 標 示 (Marking) : 字 (Alphanumeric ) 文 字 (Alphanumeric) ■特性 Feature ■外形尺寸 Dimensions ◎不燃與絕緣之安全設計 Compact type with safety design of Non-flammability and insulation. Dimensions mm) Weight (g) (1000pcs) 型名 Model A B C h Ød MPT 03 15 ±1.0 13 ±1.0 0.7±0.1 15±3.0 0.5±0.05 630 MPQ 05 16 ±1.0 16 ±1.0 6.0±0.5 4.5±0.5 0.8±0.05 3110 ◎低阻值耐突波佳 Low resistance and resilient to surge current. ◎無電感 Non- inductance. ◎產品符合歐盟 RoHS 要求 ■料號編碼 Type composition Products is compliance the EU-RoHS request. 例 ◎可依客戶需求製作 Can be produced according to customer’s request. Example MPQ 05 J R010 S00 CP 型名 Type 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire MPT 03:3W F±1% R010=0.01 S000 : 銅線 MPQ 05:5W G±2% R100=0.1 Straight CP Wire J±5% 50RO=50 K±10% 1000=100 1001=1K 1002=10K ■額定 Ratings 型名 Model Rated Power (W) 阻值範圍 Resistance Range(Ω) J±5%、K ± 10%(E24) MPT 03 3 36~100M MPQ 05 5 0.01~0.5 34 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 包裝 Plate / Bulk pack(pcs) 500V ±350ppm/ºC 200 ■結構圖 Construction MPQ Type MPT Type 1 端子線 Lead wire 3 標 2 導電層 Print impedance layer 4 陶瓷板 示 1 矽水泥 Silicon cement Marking 2 標 示 Marking Ceramic base 3 端子線 Lead wire 4 金屬板 Metal board 5 瓷 殼 Ceramic case ■額定溫度下降曲線圖 Derating curve MPQ Type MPT Type (ºC) (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(2%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(2%+0.05Ω) 絕緣電阻 Insulation resistance >10MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 不燃性 Flameproof 無燃燒現象 No evidence of flaming or arcing 脈衝測試 (MPT Type) Pulse withstanding voltage ±20% DC POWER 10M AC voltage of 2,4,8,16,32 times the power rating for 1min. (V ≦ 4 times max. working voltage) SW 1pF RX 35 The following discharge cycle is repeated in the circuit of the left 2.5 sec. ON 2.5 sec. OFF 10,000 cycles. With following DC pulse test voltage. Pulse voltage: 10 KV CEMENT RESISTOR RGW 水泥電阻器 RGF 水泥電阻器 CEMENT RESISTOR (Wire Type) CEMENT RESISTOR (film Type) ■結構圖 Construction 本體顏色 (Body color): 白 色 (White) 標 示 (Marking): 文 字 (Alphanumeric) 線 Lead wire 鐵 帽 Cap 3 瓷 棒 Ceramic base 4 繞線/皮膜 Wire wound / Film 1 端 2 子 ■料號編碼 Type composition ■特性 Feature RG W 型名 Type 品名 Size ◎不燃與絕緣之安全設計 Compact type with safety design of non-flammability 01 6 絕緣塗料 Insulation coat 7 瓷 示 Marking 殼 Ceramic case 例 Example J R100 額定功率 誤差值 電阻值(Ω) Rated Power Tolerance Resistance PG00 NH 二次加工 Forming 端子線 Lead Wire 01:1W F±1% R100=0.1 PG00=P Type NH=Heat F: Film 02:2W G±2% 1R00=1 MG00=M Type Plated ◎可提供低電感 Low inductance is available. ◎長期穩定性佳 05:5W J±5% 10R0=10 SG00=S Type NL=Electro 07:7W K±10% 1000=100 TG00=T Type A0:10W 1001=1K HG02=H Type B5:25W 1002=10K Plated ■造型對應表 Type matrix ◎可依客戶需求製作 Can be produced according to customer’s request. RG Type P ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. Rated Power(W) 1 2 3 5 7 10 15 20 25 ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ ◎ Z M ◎ T ■參考規格 Reference standards S ● JIS C 5201-1 H ◎ 30 40 ◎ ◎ RGK TYPE Available : 4W 5W 6W 7W 9W 11W 17W ■額定 Ratings Rated Power (W) 標 W: Wire and insulation. Stable long life. 5 阻值範圍 Resistance Range(Ω) 皮膜型 Film Type 繞線型 Wire wound Type 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. Overload Voltage 1 4~39K 0.1~330 150V 500V 2 4~39K 0.1~330 150V 750V 3 4~39K 0.1~330 350V 1000V 5 4~50K 0.1~1K 350V 1000V 7 4~100K 0.1~2.2K 500V 1500V 10 4~100K 0.1~4.7K 750V 1500V 15 4~100K 1~5.1K 1000V 1500V 20 4~100K 1~10K 1000V 1500V 25 4~100K 1~10K 1000V 1500V 30 4~100K 1~10K 1000V 1500V 40 4~100K 1~10K 1000V 1500V 36 耐電壓 Dielectric Withstanding Voltage 1000V 溫度係數 T.C.R. ≦ 1Ω: ± 600 ppm/ºC > 1Ω: ± 350 ppm/ºC ■額定溫度下降曲線圖 Derating curve 例 Example RGW RGF (ºC) (ºC) ■造型圖 (Dimensions see as APPENDIX) P Type Z Type M Type S Type T Type H Type ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 10 倍額定功率,5 秒 10 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70≧ for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 37 CEMENT RESISTOR RGK 水泥電阻器 CEMENT RESISTOR (RGK Type) ■結構圖 Construction 本 體 顏 色 (Body color): 白 色 (W hite) 標 示 (Marking ): 文 字 (Alphanumeric ) 線 Lead wire 鐵 帽 Cap 3 瓷 棒 Ceramic base 4 繞線/皮膜 Wire wound / Film 1 端 2 子 5 標 6 絕緣塗料 Insulation coat 7 瓷 示 Marking 殼 Ceramic case ■外型尺寸 Dimensions Rated Power (W) W (mm) H (mm) 4 6.8±0.3 6.8±0.3 25±1 5 6.8±0.3 6.8±0.3 25±1 6 6.8±0.3 6.8±0.3 25±1 7 6.8±0.3 6.8±0.3 9 9.5±0.5 9.5±0.5 33±1 11 9.0±0.3 9.0±0.3 50±1 17 9.5±0.5 9.0±0.3 75±1 ■特性 Feature ◎不燃與絕緣之安全設計 Compact type with safety design of non-flammability and insulation. ◎可提供低電感 Low inductance is available. ◎長期穩定性佳 Stable long life. ■料號編碼 Type composition ◎可依客戶需求製作 L (mm) ℓ (mm) 33±3 33±1 例 Example RGK 05 J R100 S000 NH 型名 Type 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 04:4W F±1% R010=0.01 See table 熱鍍線 05:5W G±2% R100=0.1 below Heat plated 07:7W J±5% 1R00=1 A0:10W K±10% 10R0=10 Can be produced according to customer’s request. ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ■參考規格 Reference standards ● JIS C 5201-1 1000=100 1001=1K 1002=10K ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range(Ω) 4 0.01Ω~ 9.1K 5 0.022Ω~ 15K 6 0.022Ω~ 15K 7 0.05Ω~ 30K 9 0.05Ω~ 33K 11 0.1Ω~ 47K 17 0.20Ω~ 82K 溫度係數 T.C.R. 誤差值 Tolerance 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. Overload Voltage 耐電壓 Dielectric Withstanding Voltage ± 350ppm/ºC F±1% G±2% J±5% K±10% 1000V 2000V 2000V 38 ■額定溫度下降曲線圖 Derating curve 例 Example 4W~7W (ºC) 9W~11W (ºC) >15W (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp.(30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ±10ºC for 3.5 seconds (手焊錫) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 39 CURRENT SENSOR RESISTOR RGC 電流偵測電阻器 CURRENT SENSOR RESISTOR (RGC Type) ■結構圖 Construction 本 體 顏 色 (Body color): 白 色 (White) 標 示 (Marking ) : 文 字 (Alphanumeric) 1 端子線 Lead wire 5 2 瓷 棒 Ceramic base 6 絕緣塗料 Insulation coat 3 鐵 帽 Cap 4 繞 線 Wire wound 7 瓷管/瓷殼 Ceramic tube / Ceramic case 標 示 Marking ■外型尺寸 Dimensions Rated Power (W) L (mm) L1 Maxd (mm) D (mm) ℓ (mm) Ød (mm) 1 11.5±1 15 4.3±1 26±2 0.6±0.05 2 11.5±1 15 4.3±1 26±2 0.6±0.05 3 15±1 19 5.5±1 32±2 0.8±0.05 4 22±1 26 8.0±1 27±3 1.0±0.05 5 22±1 26 8.0±1 30±2 0.8±0.05 7 22±1 26 9.0±1 30±2 0.8±0.05 9 38±1 42 9.0±1 30±2 0.8±0.05 10 37±1 41 10 ±1 30±2 0.8±0.05 20 42±1 46 12 ±1 30±2 0.8±0.05 ■特性 Feature ◎不燃與絕緣之安全設計 Compact type with safety design of non-flammability and insulation. ◎可提供低電感 Low inductance is available. ◎長期穩定性佳 Stable long life. ◎ 7W、9W 為方型瓷殼 ◎可依客戶需求製作 ■料號編碼 Type composition Can be produced according to customer’s request. ◎產品符合歐盟 RoHS 要求 Example 例 RGC 03 J R100 A52 NH 型名 Type 額定功率 Rated Power 誤差值 Tolerance 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 03:3W F±1% R001=0.001 See table 熱鍍線 ■參考規格 Reference standards 05:5W G±2% R010=0.01 below Heat plated ● JIS C 5201-1 07:7W J±5% R100=0.1 A0:10W K±10% Products is compliance the EU-RoHS request. ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range(Ω) 溫度係數 T.C.R. 誤差值 Tolerance ±20ppm/ºC ±50ppm/ºC ±100ppm/ºC F±1% G±2% J±5% K±10% 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. Overload Voltage 耐電壓 Dielectric Withstanding Voltage 1 2 3 4 5 7 0.001Ω~ 0.1Ω (1mΩ~ 100mΩ) PR PR 9 10 20 40 10PR 10 PR 2000V ■額定溫度下降曲線圖 Derating curve 例 Example 4W~7W (ºC) 9W~11W (ºC) >15W (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp.(30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >100MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 41 HIGH PULSE WIRE WOUND RESISTOR 高脈衝繞線電阻器 HVW HIGH PULSE WIRE WOUND RESISTOR (Standard Type) ■結構圖 Construction 本 體 顏 色 (Body color): 白 色 (White) 標 示 (Marking) : 文 字 (Alphanumeric ) 1 端子線 Lead wire 2 瓷 棒 Ceramic base 3 鐵 帽 Cap 4 繞 線 Wire wound Marking 5 標 6 絕緣塗料 Insulation coat 7 瓷 示 管 Ceramic tube ■外型尺寸 Dimensions Dimensions(mm) Weight(g) (1000pcs) Rated Power (W) L L1 Max. D 1 14±2 18 5±1 1250 2 16±2 20 7±1 2250 3 27±2 31 6±1 4 40±2 45 7±1 5500 5 43±2 48 7±1 5900 ■特性 Feature ◎防爆式繞線高脈衝特性 The ANTI-BURST Type wire wound type High pulse safe usage by special non-flammable silicon-base. ◎可承受 25KV 突波的衝擊. Ød ℓ 0.8 ± 0.05 35 ± 3 3000 Acceptable pulse of 25KV discharge. ◎高信賴性 High reliability. ■料號編碼 Type composition ◎產品符合歐盟 RoHS 要求 例 Products is compliance the EU-RoHS request. Example HV W 型名 Type 品名 Size 01 J 10R0 S000 NH 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire J±5% 10R0=10 See table 熱鍍線 below Heat plated 額定功率 誤差值 Rated Power Tolerance W: Wire 01:1W ■參考規格 Reference standards 02:2W K±10% 1000=100 ● JIS C 5201-1 03:3W M±20% 1001=1K 04:4W 1002=10K 05:5W 1003=100K ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range(Ω) 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. Overload Voltage 1 300V 600V 2 400V 800V 450V 900V 3 4 5 J±5%(E24) K±10%(E24) M±20%(E24) 10~390K 550V 1000V 1100V 42 耐電壓 Dielectric Withstanding Voltage 溫度係數 T.C.R. 15KV 250V 350V 500V 脈衝電壓 Pulse withstanding voltage ±300 ppm/ºC 25KV ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(2%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(2%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(2%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 脈衝測試 Pulse withstanding voltage ±5% 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 10M DC POWER The following discharge cycle is repeated in the circuit of the left fig. 1 sec. ON 1 sec. OFF 10,000 cycles. With following DC pulse test voltage. Pulse voltage: DC 14 kV SW 1pF RX 43 ALUMINUM CASED POWER RESISTOR 黃金鋁殼電阻器 GRR ALUMINUM CASED POWER RESISTOR (GR Type) ■結構圖 Construction 外 觀 顏 色 (Body Color ): 標 示 (Marking) : 金 黃 色 (Gold ) 文 字 (Alphanumeric ) ■特性 Feature 端 子 線 Lead wire 2 鋁 Aluminum case 3 矽 水 泥 Silicon cement 4 鐵 Cap 1 ◎高穩定性強之設計和高脈衝 20KV High stability strong construction and anti-surge to 20KV. ◎可依客戶需求製作 殼 帽 5 6 瓷 棒 Ceramic base 繞線/皮膜 Wire wound / Film 7 標 示 Marking Can be produced according to customer’s request. ◎產品符合歐盟 RoHS 要求 ■外形尺寸 Dimensions (mm) Products is compliance the EU-RoHS request. ◎可提供低電感 Rated Power (W) 5 10 25 50 85 100 225~300 D±2 81 85 95 116 93.5 120±3 150 C±1 15.5 19 27 50 75 89 114 A±0.4 11.5 14.5 18 39 64 70 76 L±1 5 33±3 33±3 33±3 9 12.5 18 Low inductance is available. ■料號編碼 Type composition RG W 05 型名 品名 Type Size Wire 額定功率 Rated Power 例 Example J 10R0 P000 GR 誤差值 電阻值(Ω) 二次加工 端子線 Tolerance Resistance Forming Lead Wire 05:5W F±1% R100=0.1 P000= Aluminum F±1 16.5 20.5 27.3 29 29 71.5 76 A0:10W G±2% 1R00=1 Straight Cased B±0.4 12.5 14 19.5 21.6 10 57 64 E±1 8.5 10 13.4 16 16 46 54 N±0.1 2.2 2.2 2.2 2.2 2.2 --- --- K±0.3 2.5 2.4 3.2 3.2 3.2 4.8 4.8 G±1 8 10 15.5 15.5 15.5 44.5 55.6 J±1 2.2 5 6.6 7.6 8 21 24.4 H±0.2 1.5 2 2.2 2.2 2.2 4.7 6.4 E0:50W J±5% 10R0=10 P00T= P0:300W K±10% 1000=100 Terminal 1001=1K NW00= 1002=10K No sense 1005=10M winding 1007=1000M NWOT= Terminal ■額定 Ratings 型名 Type GR-5 GR-10 GR-25 GR-50 GR-100 GR-225 GR-300 阻值範圍 Resistance Range(Ω) Rated Power (W) Material Standard Non-inductive 4.5 Film 1.5K~1G 200~10M 材質 5 Wire Wound 0.1Ω~1.5K 0.02~200 8.5 Film 2K~1G 470~10M 10 Wire Wound 0.1~2K 0.02~470 20 Film 4.7K~1G 1.2K~10M 25 Wire Wound 0.5~4.7K 0.1~1.2K 45 Film 10K~2G 1.5K~1M 50 Wire Wound 1~40K 0.2~1.5K 100 Wire Wound 3~25K 0.5~4K 225~300 Wire Wound 3~25K 0.5~4K 誤差值 Tolerance 溫度係數 T.C.R. 最高使用電壓 Max. Working Voltage 耐電壓 Dielectric Withstanding Voltage 1500V 1000V ± 25ppm/ºC F±1% G±2% J±5% K±10% ± 50ppm/ºC ± 100ppm/ºC ± 350ppm/ºC Note:The highest resistance can be contact our sales. 44 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■負荷電力對表面溫度上升圖 SURFACE TEMPERATURE RISE Vs. LOADED POWER ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 焊錫耐熱 Resistance to soldering heat ±(1%+0.05Ω) 絕緣電阻 Insulation resistance >1,000MΩ 260ºC ± 5ºC for 10 seconds (焊錫槽) 350ºC ± 10ºC for 3.5 seconds (手焊錫)(4.18) 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 45 FLAT TYPE METAL CLAD WIRE WOUND RESISTOR GHR 薄型鋁殼電阻器 FLAT TYPE METAL CLAD WIRE WOUND RESISTOR (GH Type) ■結構圖 Construction 外 觀 顏 色 (Body Color): 銀 色 (Silver) 標 示 (Marking): 文 字 (Alphanumeric) ■特性 Feature ◎精密型高額定功率 High power rating, and ultra precision. 4 XØ5.0 ( 100W~250W ) 6 XØ5.0 ( 300W~500W ) ◎可依客戶需求製作 Can be produced depending on to customer’s request. ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ◎可提供低電感 (≦ 1KHz : 3μH) Low inductance is available. ■料號編碼 Type composition RG W J0 J J0:100W J±5% M0:150W 絕 緣 板 Insulation plate 2 繞 線 Wire wound 3 鋁 殼 Aluminum case 4 絕緣電線 Silicon rubber wire 5 基 板 Ceramic base 6 絕緣塗料 Insulation coat 7 標 Marking 示 ■外型尺寸 Dimensions 例 Example Rated Power (W) L1±2 (mm) L2±2 (mm) 100 90 70 150 120 100 200 150 130 250 180 160 1000=100 300 210 190 1001=1K 400 270 250 500 330 310 10R0 S245 GH 型名 品名 額定功率 誤差值 電阻值(Ω) 二次加工 薄型鋁殼 Type Size Rated ower Tolerance Resistance Forming Aluminum Wire 1 R100=0.1 1R00=1 Straight Aluminum Length Cased 10R0=10 W1±2 (mm) W2±2 (mm) 80 70 ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range(Ω) Standard Non-inductive 60 0.1Ω~ 500Ω 0.05Ω~ 10KΩ 100 1Ω~ 1.0KΩ 2Ω~ 500Ω 150 1Ω~ 1.2KΩ 2Ω~ 600Ω 200 1Ω~ 1.4KΩ 2Ω~ 700Ω 250 1Ω~ 1.6KΩ 2Ω~ 800Ω 300 1Ω~ 1.8KΩ 2Ω~ 900Ω 400 1Ω~ 2.0KΩ 2Ω~ 1KΩ 500 1Ω~ 2.5KΩ 2Ω~ 1.2KΩ 誤差值 Tolerance 溫度係數 T.C.R. 最高使用電壓 Max. 最高過負荷電壓 Max. 耐電壓 Dielectric Working Voltage Overload Voltage Withstanding Voltage 500V J±5% ±350ppm/ºC 750V 1000V 46 1500V 1500V/DC ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(1%+0.05Ω) 5 倍額定功率,5 秒 5 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(1%+0.05Ω) 40ºC,95% RH,240 小時 40ºC, 95% RH for 240 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 絕緣電阻 Insulation resistance >1,000MΩ 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 47 SQUARE SHAPE ALUMINUM SHELL RESISTOR RAR 方型鋁殼電阻器 SQUARE SHAPE ALUMINUM SHELL RESISTOR (RA Type) ■結構圖 Construction 外 觀 顏 色 (Body Color ): 標 示 (Marking ) : 色 (Silver) 文 字 (Alphanumeric) Insulation plate 1 絕 緣 板 2 繞 線 Wire wound ■特性 Feature 3 鋁 殼 ◎精密型高額定功率 4 絕緣電線 Silicone rubber wire 5 瓷 Ceramic tube 6 絕緣塗料 Insulation coat 7 標 Marking 銀 High power rating, and ultra precision. ◎可依客戶需求製作 Can be produced according to customer’s request. 管 示 Aluminum case ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ■外型尺寸 Dimensions ◎可提供低電感 Rated Power (W) L1±2 (mm) L2±2 (mm) 60 50 75 例 Example 80 70 95 10R0 NP00 100 85 110 額定功率 誤差值 電阻值(Ω) Rated ower Tolerance Resistance 無感/端片 No senseend piece 120 100 130 150 140 165 J±5% R100=0.1 S300: 200 160 200 300 240 280 400 320 360 500 400 440 600 480 520 800 560 600 Low inductance is available. ■料號編碼 Type composition RA SQ 型名 Type 品名 Size 301 J Square 600:60W Shape 101:100W 1R00=1 300mm 301:300W 10R0=10 Straight 801:800W 1000=100 Length 1001=1K ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range(Ω) Standard Non-inductive 60 0.001 ~ 5K 0.1 ~ 100Ω 80 0.001 ~ 6K 0.2 ~ 100Ω 100 0.001 ~ 8K 0.2 ~ 100Ω 120 0.001 ~ 10K 0.2 ~ 100Ω 150 0.001 ~ 12K 0.2 ~ 100Ω 200 0.001 ~ 15K 0.2 ~ 150Ω 300 0.001 ~ 18K 0.5 ~ 150Ω 400 0.001 ~ 20K 0.5 ~ 200Ω 500 0.001 ~ 25K 0.5 ~ 500Ω 600 0.001 ~ 30K 1 ~ 1K 800 0.001 ~ 30K 1 ~ 1K 誤差值 Tolerance 溫度係數 T.C.R. J±5% ±350ppm/ºC 48 最高使用電壓 Max. 最高過負荷電壓 Max. 耐電壓 Dielectric Working Voltage Overload Voltage Withstanding Voltage 1000V 2000V AC 1500V ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■負荷電力對表面溫度上升圖 Temperature (°C) SURFACE TEMPERATURE RISE Vs. LOADED POWER Power rate (%) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 10 倍額定功率,5 秒 10 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(3%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(3%+0.05Ω) 40ºC,95% RH,500 小時 40ºC, 95% RH for 500 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 耐電壓 Dielectric withstanding voltage ±(0.2%+0.05Ω) Test voltage : 1,500 V Duration time 60 s 絕緣電阻 Insulation resistance >1,000MΩ 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 耐熱性 Heat Resistance ±(0.5%+0.05Ω) Temp. 275ºC for 2 hours. 49 TRAPEZOID ALUMINUM SHELL RESISTOR RAMH 船型鋁殼電阻器 TRAPEZOID ALUMINUM SHELL RESISTOR (RAMH Type) ■結構圖 Construction 外觀顏色 (Body Color) : 標示 (Marking ): 文字 (Alphanumeric ) Insulation plate 1 絕 緣 板 2 繞 線 Wire wound ■特性 Feature 3 鋁 殼 ◎精密型高額定功率 4 絕緣電線 Silicone rubber wire 5 瓷 Ceramic tube 6 絕緣塗料 Insulation coat 7 標 Marking (Silver) 銀色 High power rating, and ultra precision. ◎可依客戶需求製作(尺寸、功率、電感值) Can be produced according to customer’s request. Products is compliance the EU-RoHS request. Rated Power (W) L1±2 (mm) L2±2 (mm) P±1.5 (mm) 60 50 80 62 80 60 90 72 100 75 105 87 120 90 120 102 150 120 150 132 200 140 170 152 300 180 210 192 400 230 260 242 500 300 330 312 600 360 390 372 800 400 430 412 1000 530 560 542 ◎可提供低電感 Low inductance is available. ■料號編碼 Type composition Example RA MH 型名 Type 品名 Size Ship Type 301 J 10R0 S000 額定功率 誤差值 電阻值(Ω) Rated ower Tolerance Resistance 直線 Straight J±5% S200: 600:60W 示 ■外型尺寸 Dimensions ◎產品符合歐盟 RoHS 要求 例 管 Aluminum case R100=0.1 101:100W 1R00=1 200mm 301:300W 10R0=10 Straight 801:800W 1000=100 Length 102:1000W 1001=1K ■額定 Ratings 阻值範圍 Resistance Range(Ω) Rated Power (W) Standard Non-inductive 60 0.001 ~ 5K 0.1 ~ 100Ω 80 0.001 ~ 6K 0.2 ~ 100Ω 100 0.001 ~ 8K 0.2 ~ 100Ω 120 0.001 ~ 10K 0.2 ~ 100Ω 150 0.001 ~ 12K 0.2 ~ 100Ω 200 0.001 ~ 15K 0.2 ~ 150Ω 300 0.001 ~ 18K 0.5 ~ 150Ω 400 0.001 ~ 20K 0.5 ~ 200Ω 500 0.001 ~ 25K 0.5 ~ 500Ω 600 0.001 ~ 30K 1 ~ 1K 800 0.001 ~ 30K 1 ~ 1K 誤差值 Tolerance 溫度係數 T.C.R. 最高使用電壓 Max. Working Voltage 最高過負荷電壓 Max. Overload Voltage 耐電壓 Dielectric Withstanding Voltage J±5% ±350ppm/ºC 1000V 2000V AC 1500V NOTE: 1.The impedance value request is over above table, please contact our sales. 2. The TCR request please ask before order. 50 ■額定溫度下降曲線圖 Derating curve 例 Example (ºC) ■負荷電力對表面溫度上升圖 SURFACE TEMPERATURE RISE Vs. LOADED POWER Temperature (°C) NOTE: 1.Pulse function can design for client request. Please contact our sales. 2.We can offer the Temperature probe design of impedance wire inner. Power rate (%) ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.05Ω) 10 倍額定功率,5 秒 10 times the rated power for 5 seconds 負荷壽命 Load life ±(5%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(5%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(3%+0.05Ω) 40ºC,95% RH,500 小時 40ºC, 95% RH for 500 hours 溫度循環 Temperature cycle ±(1%+0.05Ω) 5 cycles for -25ºC (30min); room temp. (30min) ~ +85ºC (30min) room temp. (30min)(4.19) 耐電壓 Dielectric withstanding voltage ±(0.2%+0.05Ω) Test voltage : 1,500 V Duration time 60 s 絕緣電阻 Insulation resistance >1,000MΩ 500V 絕緣測試 1 分鐘 500V insulation test 1min.(4.6.1) 耐熱性 Heat Resistance ±(0.5%+0.05Ω) Temp. 275ºC for 2 hours. 51 POWER WIRE WOUND RESISTOR 大功率型電阻器 RQR POWER WIRE WOUND RESISTOR (Fixed & Non-inductive Type ; Adjustable Type) ■結構圖 Construction 塗料顏色 (Coating Color) : 綠 標示 (Marking): (Green) 色 文字 (Alphanumeric) ◎可提供低電感 ◎防爆式繞線高脈衝特性 The ANTI-BURST Type wire wound type High pulse safe usage by special non-flammable silicon-base. ◎可承受 25KV 突波的衝擊 Acceptable pulse of 25KV discharge. ◎高信賴性 High reliability. ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ◎可提供低電感 架 Iron stand 1 鐵 2 陶瓷墊圈 Ceramic washer 3 標 示 Marking Low inductance is available. FR 型名 Type 品名 Size 6 Wire wound 繞 線 瓷 棒 Ceramic base 絕緣塗料 Insulation coat ■額定溫度下降曲線圖 Derating curve ■料號編碼 Type composition RQ 4 100 例 Example J 10R0 例 C2 額定功率 誤差值 電阻值(Ω) 銅環數 Rated Power Tolerance Resistance Copper ring 樣式 style FR: Fixed 100:10W J±5% 10R0=10 C2:2Ring HG:臥式 NR: 101:100W K±10% 1000=100 C3:3Ring VZ:立式 1001=1K C4:4Ring VN:無 Non-inductive 102:1000W MR: 1002=10K Adjustable 1003=100K Example HG (ºC) ■外型尺寸 Dimensions Dimensions (mm) 10 Rated Power (W) 20 30 50 60 80 100 120 150 160 200 250 300 400 500 600 700 800 1000 1300 1500 2000 L±2 45 60 75 110 90 110 140 160 195 L±4 185 210 210 260 330 330 400 460 460 540 600 600 650 D±1 12 17 17 25 28 28 28 28 28 D±2 35 35 40 40 40 50 50 50 60 60 65 65 65 g±1 18 22 22 30 32 32 32 32 32 g±2 36 36 38 38 38 50 50 50 55 55 62 62 62 W±1 4 5 5 8 8 8 8 8 8 W±2 10 10 12 12 12 12 10 12 15 15 15 15 15 G±1 2 2 2 5 5 5 5 5 5 G±1 5 5 5 5 5 6 4 6 6 6 6 6 6 H±1 9 12 12 18 19 19 19 19 17 H±1 19 19 20 20 20 25 25 25 30 30 30 30 30 N±0.5 3 4 4 6 6 6 6 6 6 N±2 8 10 8 8 8 9 9 9 10 10 10 10 10 L1±2 62 90 112 166 146 166 196 216 251 L1±1 245 284 274 335 403 410 480 530 535 615 722 722 722 K±2 28 36 36 60 60 60 60 60 60 76 76 78 78 82 110 110 100 110 110 115 115 115 K±4 T±0.3 1 1 1 1.2 1.2 1.2 1.2 1.2 1.2 T±0.3 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.6 M±1 10 17 17 28 28 28 28 28 28 40 40 40 40 48 48 48 50 50 50 50 50 M±2 40 NOTE: Over above table list request please contact sales. 52 ■額定 Ratings 阻值範圍 Resistance Range (Ω) Rated Power (W) 標準 Standard ; FR 無感 Non-inductive ; NR 可調 Adjustable ; MR 10 1-3KΩ ------ 20 1-7KΩ 1-360Ω 30 1-10KΩ 1-500Ω 50 0.1-25KΩ 0.1-8KΩ 1-1.3KΩ 60 0.1-30KΩ 0.1-10KΩ 1-1.5KΩ 80 0.1-40KΩ 0.1-20KΩ 0.1-2KΩ 100 0.1-50KΩ 0.1-25KΩ 0.1-2.4KΩ 120 0.1-60KΩ 0.1-30KΩ 0.1-3KΩ 150 0.3-75KΩ 0.3-35KΩ 0.3-3.6KΩ 160 0.3-80KΩ 0.3-40KΩ 0.3-3.9KΩ 200 0.3-100KΩ 0.3-50KΩ 0.3-5KΩ 250 0.5-125KΩ 0.5-60KΩ 0.3-6.2KΩ 300 0.5-150KΩ 0.5-75KΩ 0.3-7.5KΩ 400 0.5-200KΩ 0.5-100KΩ 0.5-10KΩ 500 0.5-250KΩ 0.5-120KΩ 0.5-13KΩ 600 0.8-300KΩ 0.8-150KΩ 0.5-15KΩ 700 0.8-350KΩ 0.8-180KΩ 0.5-18KΩ 800 0.8-400KΩ 0.8-200KΩ 0.8-20KΩ 1000 1-500KΩ 1-250KΩ 1-25KΩ 1300 1-500KΩ 1-250KΩ 1-25KΩ 1500 1-500KΩ 1-250KΩ 1-25KΩ 2000 1-750KΩ 1-300KΩ 1-39KΩ 誤差值 Tolerance 溫度係數 T.C.R. 最高使用電 Max. Working Voltage 耐電壓 Dielectric Withstanding Voltage J±5% K±10% ±350ppm/ºC 1500V 750V NOTE: impedance request is over above table, please contact sales. ■試驗條件與方法 The testing method and condition. 試驗項目 Test Items 規格值 Performance Requirements 試驗方法 Test Methods and Standard.(JISC5201-1) 電阻值 Resistance 規定的誤差值內 Within of specified tolerance 測量點從端蓋 10mm Measuring points are distance 10mm from the end cap(4.5) 溫度係數 T.C.R. 規定值內 Within of specified T.C.R. 室溫+100ºC Room temperature +100ºC(4.8) 短時間過負荷 Short time overload ±(2%+0.1Ω) 6.25 倍額定功率,5 秒 6.25 times the rated power for 5 seconds(4.13) 負荷壽命 Load life ±(1%+0.1Ω) Rated voltage at 70ºC for 1,000 hours 1.5hr ON / 0.5hr OFF Cycles(4.25.1) 耐濕負荷壽命 Load life in humidity ±(1%+0.1Ω) 10% rate power load 40ºC, 95% RH for 1,000 hours 1.5h ON / 0.5h OFF cycle(4.24) 耐濕性 Moisture resistance ±(3%+0.1Ω) 40ºC,95% RH,500 小時 40ºC, 95% RH for 500 hours 耐電壓 Dielectric withstanding voltage Flash over, burning, insulation damage should not be observed Test voltage : 750 V (MR 可調品除外) Duration time 60 s 絕緣電阻 Insulation resistance >100MΩ 500V 絕緣測試 1 分鐘 (MR 可調品除外) 500V insulation test 1min.(4.6.1) 53 COAT- INSULATED ZERO OHM RESISTOR RZU RZS 塗裝防火型 0Ω電阻器 RZY 絕緣樹脂型 0Ω電阻器 RZT 鐵芯型 0Ω電阻器 FIRE PREVENTION COAT ZERO OHM RESISTOR (RZU Type , RZS Type) INSULATION RESIN ZERO OHM RESISTOR (RZY Type) IRON CORE ZERO OHM RESISTOR (RZT Type) ■結構圖 Construction 1 端子線 Lead wire 2 瓷 棒 Ceramic base RZU fire prevention coat (Gray)、RZS (pink) 3 鐵 帽 Cap RZU 塗裝防火型(灰色) 、RZS (粉紅色) 4 鐵 蕊 Iron core 塗料顏色 (Coating Color): 5 電 鍍 錫 Tin plating 6 標 7 絕緣塗料 Insulation coat 示 Marking or color code RZY Insulation resin (Yellowish)、RZT iron core. (or blue) ■外型尺寸 Dimensions RZY 絕緣樹脂(淡黃色),RZT 鐵芯型(or 藍色) 示 (Marking):色環 Color Code(≦ S1/2W) 標 文字 Alphanumeric (1/2W、1W) Dimensions(mm) Rated Power(W) L L1 Max. D Ød ℓ Weight(g) (1000pcs) 1/8,1/6 3.3±0.3 4 1.8±0.3 0.45±0.05 28±2 120 1/4 6.0±0.3 7 2.4±0.1 0.6±0.05 28±2 218 1/2 9±0.5 11.1 3.0±0.5 0.6±0.05 28±3 320 S1 9±0.5 11.1 3.0±0.5 0.6±0.05 28±3 320 ■特性 Feature ◎可自動插件 Automatic insertion is applicable. ◎長期穩定性佳 ■料號編碼 Type composition Excellent long term stability. RZ U 型名 Type 品名 Size ◎產品符合歐盟 RoHS 要求 Products is compliance the EU-RoHS request. ■參考規格 Reference standards 14 X 額定功率 誤差值 Rated Power Tolerance U: Standard 16:1/6W S: Small 14:1/4W ● JIS C 5201-1 例 Example 無註記 R000 A520 NH 電阻值(Ω) Resistance 二次加工 Forming 端子線 Lead Wire 0Ω See table 熱鍍線 below Heat plated 12:1/2W 01:1W ■額定 Ratings Rated Power (W) 阻值範圍 Resistance Range (Ω) RZU1/6 RZU1/4 RZU1/2
RNS14F2200A520NH
1. 物料型号:文档中提到了多种电阻器型号,包括但不限于MPC、MPH、MPM、MPQ、MPT、MPQ、RGW、RGF、RGK、RGC、HVW、GR、GH、RA、RAMH等。
2. 器件简介:文档描述了多种电阻器的特性,如金属板水泥电阻器(MPC、MPH)、电流检测电阻器(RGC)、高脉冲绕线电阻器(HVW)、铝壳电阻器(GR、GH、RA、RAMH)等。这些电阻器具备不同的特性,例如小尺寸、高稳定性、低电感、符合欧盟RoHS要求等。
3. 引脚分配:文档中提供了电阻器的引脚分配信息,例如MPC和MPH类型的电阻器的引脚线(Lead wire)和金属板(Metal board)等。
4. 参数特性:文档列出了电阻器的各种参数特性,包括额定功率、电阻值范围、公差、温度系数(T.C.R.)、最高使用电压、耐电压、绝缘电阻等。
5. 功能详解:文档详细解释了电阻器的功能,如金属板水泥电阻器的不燃与绝缘安全设计、低阻值耐突波特性、无电感特性等。
6. 应用信息:虽然文档没有直接提供具体的应用案例,但从电阻器的特性可以推断,它们可能被应用于需要高稳定性和安全性的电子设备中,例如电源管理、电机驱动、传感器电路等。
7. 封装信息:文档提供了电阻器的封装信息,包括外形尺寸、重量等,这些信息对于设计电路和选择合适电阻器至关重要。
RNS14F2200A520NH 价格&库存
很抱歉,暂时无法提供与“RNS14F2200A520NH”相匹配的价格&库存,您可以联系我们找货
