WD3153D-10/TR
WD3153D-10/TR
    WILLSEMI(韦尔)
    DFN10L_2X2MM
    WD3153D-10/TR
WD3153D-10/TR 数据手册
WD3153 WD3153 3-Channel LED Driver Http//:www.sh-willsemi.com Descriptions The WD3153 is a 3-channel LED driver designed to LED0 1 10 SCL LED1 2 9 SDA LED2 3 8 CHRG without processor control. INTN 4 7 SET Three independent LED channels have accurate VCC 5 6 NC produce variety of lighting effects. The device has a program memory for creating variety of lighting sequences. When the program memory has been loaded, the WD3153 can operate independently programmable current sinks, from 0mA to 25mA with 5 GND Pin configuration (Top view) steps and 8-bit flexible PWM control. Each channel can be configured into each of the three program execution engines. Program execution engines have program memory for creating desired lighting sequences with PWM control. 3153 WDYW Features  Supply voltage: 2.4V to 5.5V  Three independently programmable LED outputs DFN2X2-10L with 8-bit PWM control and 3-bit current setting (from 0mA to 25mA)  Autonomous operation 3153 with three program execution engines Y = Year code W = Week code 2  Direct I C register control for lighting  I C Compatible Interface = Device code Marking 2  Power supply support 1.8V to 5.5V  Data transfers up to 400kbps  INTN interrupt function  Typical LED output saturation voltage 80mV  LED output current accuracy ±2% and current Order information Device Package Shipping WD3153D-10/TR DFN2X2-10L 3000/Reel&Tape matching ±1%  Operating temperature: -40℃ to 85℃  Built-in oscillator with ±5% accuracy  ESD HBM 4kV  Support charging indication under low battery  DFN2X2-10L package condition   Directly start up breathing light on LED0  Breathing period: 5s or continuous Applications Low power consumption  Smart Phones  Operating current: 80uA  Tablets  Less than 1uA in shut down mode  Indicator lights Will Semiconductor Ltd. 1 Nov. 2017 - Rev. 1.2 WD3153 Typical applications VBAT CHRG VBUS VBAT VCC 30K CHRG VCC 1uF 10K Charger GND VIO SET INTN LED0 G B VIO SET 4.7KΩ *3 WD3153 VBAT 1uF GND R VBAT WD3153 CPU R INTN LED1 SCL SCL LED2 SDA SDA G VBAT B Fig1 Charging Indicator Application 4.7KΩ *3 INTN LED0 CPU INTN LED1 SCL SCL LED2 SDA SDA Fig2 Adapter Plug In Indicator Application Pin descriptions No. Name I/O Description 1 LED0 Analog LED driver current sink terminal 2 LED1 Analog LED driver current sink terminal 3 LED2 Analog LED driver current sink terminal 4 INTN Open drain 5 VCC Power 6 NC Not internally connected 7 SET I Charge indicator set. 0: LED0 output 5mA/5S period 1: LED0 output 5mA continuous 8 CHRG I Charge indicator input. Internal pull-down resistor of 15KΩ between CHRG and GND. 9 SDA I/O 10 SCL I EP GND Ground Interrupt output 2.4V~5.5V power supply 2 I C serial interface data input/output. 1.8V/5.5V compatible 2 I C serial interface clock. 1.8V/5.5V compatible Connect to ground. Block diagram VBG OSC UVLO OTP VCC SET CHRG LED0 Control Logic Constant Current LED Driver INTN SCL SDA I2C LED1 LED2 REG GND Will Semiconductor Ltd. 2 Nov. 2017 - Rev. 1.2 WD3153 Absolute maximum ratings (1) Parameter MIN MAX Unit Power supply VCC -0.3 6.0 V Analog pins (LED0, LED1, LED2) -0.3 6.0 V Digital pins (SDA, SCL, INTN) -0.3 Storage temperature Tstg -65 VCC+0.3V with 6.0 max V 150 ℃ Junction temperature TJMAX 150 ℃ Maximum lead temperature 260 ℃ Junction-to-ambient thermal resistance (DFN10L) ESD HBM Latch-up (1) ℃/W 45 -4 4 kV -450 450 mA Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Recommended Operating Conditions Parameter MIN MAX Unit Power supply VCC 2.4 5.5 V Digital pins 1.8 VCC V Junction temperature TJ -40 125 ℃ Ambient temperature TA -40 85 ℃ Will Semiconductor Ltd. 3 Nov. 2017 - Rev. 1.2 WD3153 Electronics Characteristics Unless otherwise specified, TA = 25℃ and VCC = 3.6V. Symbol Description ISD Shut down current ISB Standby current Test Conditions MIN CHIPEN=0 (device off) CHIPEN=1 (device on); LE0~2=0 (all LEDs off) TYP MAX Unit 0.1 1 uA 35 50 uA 80 120 uA 5 % CHIPEN=1 (device on); ICC Operating current LE0~2=1 (all LEDs on); LCFG0~2=03h (all LEDs set to 15mA); FOSC Oscillator frequency Internal -5 LED driver (LED0, LED1, LED2) electrical characteristics (GCR=01h, PWM0~2=FFh) IMAX Maximum sink current LCFG0~2=04h 24.25 25 25.75 LCFG0~2=03h 14.55 15 15.45 LCFG0~2=02h 9.7 10 10.3 LCFG0~2=01h 4.85 5 5.15 LCFG0~2=00h (2) mA 0 Imatch Matching (2) LCFG0~2=03h, 15mA Set VSAT Saturation voltage (3) LCFG0~2=03h FLED PWM switching frequency -1 +1 % 80 100 mV PWM_HF=0 237.5 250 262.5 Hz PWM_HF=1 475 500 525 Hz Output current accuracy is the difference between the actual value of the output current and programmed value of this current. Matching is the maximum difference from the average. For the constant current outputs on the part, the following are determined: the maximum output current (MAX), the minimum output current (MIN), and the average output current of all outputs (AVG). Two matching numbers are calculated: (MAX - AVG)/AVG and (AVG - MIN)/AVG. The largest number of the two (worst case) is considered the matching figure. Note that some manufacturers have different definitions in use. (3) Saturation voltage is defined as the voltage when the LED current has dropped 10% from the set value. Will Semiconductor Ltd. 4 Nov. 2017 - Rev. 1.2 WD3153 Logic interface characteristics Unless otherwise specified: limits for typical values are for TA = 25℃ and minimum and maximum limits apply over the operating ambient temperature range (-40℃ < TA < 85℃); VCC=3.6V and range (2.4V < VCC < 5.5V). Symbol VDD_I2C Description MIN 2 Power supply range for I C TYP 1.65 MAX Unit 5.5 V Logic input SCL and SDA characteristics VIH Input high level 1.2 V VIL Input low level IIH High level input current 5 nA IIL Low level input current 5 nA 0.6 V Logic output SDA characteristics VOL Output low level (IOUT = 3mA) IL 0.3 Output leakage current 0.5 V 1 uA 400 kHz 2 I C timing requirements (4) 2 FSCL I C clock frequency tBUF Bus-free time between a STOP and a START condition 1.3 uS Hold time (repeated) START condition 0.6 uS tLOW Clock low time 1.3 uS tHIGH Clock high time 0.6 uS Setup time for a repeated START condition 1.3 uS Data hold time 0.05 uS tSU,DAT Data setup time 0.1 uS tR Rise time of SCL 0.3 uS tF Fall time of SCL 0.3 uS tHD,STA tSU,STA tHD,DAT tSU,STO TSP Cb (4) Set-up time for STOP condition 0.6 uS SCL input deglitch 200 nS SDA input deglitch 250 nS Capacitive load for each bus line 400 pF Specification is ensured by design and is not tested in production. 2 Fig4 is the timing parameters of I C interface (SCL, SDA). Stop Start Start Stop VIH VIL SDA tBUF tLOW tF tHIGH TDEG VIH VIL SCL tHD,STA tR tHD,DAT tSU,DAT tSU,STA tSU,STO 2 Fig4 I C timing parameters Will Semiconductor Ltd. 5 Nov. 2017 - Rev. 1.2 WD3153 Option Mode Power On Reset Power On Reset (POR) will activate when VCC rises above 2V (typical), which will reset all the internal registers to the default values, and then the chip will enter the Shut Down Mode. The POR flag bit will be set to “1” when POR operation occurs, which will be cleared by a read of the Flags Register. Usually the POR flag bit can be used to check whether a unexpected POR event has taken place. Software Reset Reset is down always if “55h” is written to Reset Register. All the internal registers are reset to the default values and the chip will enter the Shut Down Mode. Shut Down Mode The WD3153 enters into Shut Down Mode when CHRG is low, and CHIPEN bit (GCR Register) is set to 0 or SCL is pulled to low for over 130ms. In the Shut Down Mode, the internal registers (except Flags) are reset to the default values and all blocks are 2 turned off. The current consumption is less than 1uA. The I C interface is accessible, but only Reset and GCR Registers can be configured. Standby Mode When CHIPEN bit (GCR Register) is set to “1”, WD3153 enters into Standby Mode. In the Standby Mode, the needed internal blocks (VBG, UVLO, OSC, OTP etc) are enabled. All the registers can be configured. And the power consumption is about 33uA. Operating Mode If LE bit (LCTR Register) is set to “1”, the chip will enter operating mode. In the operating mode, the power consumption is about 80uA. Under Voltage Lock Out The WD3153 has an internal comparator that monitors the voltage of VCC and force the WD3153 into Shut Down Mode if VCC drops to 2.2V. If VCC rises above 2.2V, setting the CHIPEN bit to “1”, the WD3153 will enter into Standby Mode again. If the UVLO monitor threshold is tripped, the UVLO flag bit is set to “1” in the Flags Register. Upon a read, the Flag register can be cleared. Over Temperature Protect IF the WD3153 reaches 135℃, the LED driver block will be disabled, until temperature drops below 120℃, 2 and the OTP flag bit will be set to “1” in the Flags Register, until there is an I C read of Flags Register. Will Semiconductor Ltd. 6 Nov. 2017 - Rev. 1.2 WD3153 2 I C Interface Interface Overview 2 The I C interface is built in the WD3153. It can be compatible with 1.8V to 5.5V. It provides access to the programmable functions and registers on the device. This protocol uses a two-wire interface for bidirectional communications between the IC's connected to the bus. The two interface lines are the Serial Data Line (SDA), and the Serial Clock Line (SCL). These lines should be connected to a positive supply, via a pull-up resistor (4.7kΩ) and remain HIGH even when the bus is idle. Data Transactions One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line during the high state of the SCL and in the middle of a transaction, aborts the current transaction. New data should be sent during the low SCL state. This protocol permits a single data line to transfer both command/control information and data using the synchronous serial clock. Each data transaction is composed of a Start Condition, a number of byte transfers (set by the software) and a Stop Condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits long and is transferred with the most significant bit first. After each byte, an Acknowledge signal must follow. The following sections provide further details of this process. The Master device on the bus always generates the Start and Stop Conditions (control codes). After a Start Condition is generated, the bus is considered busy and it retains this status until a certain time after a Stop Condition is generated. A high-to-low transition of the data line (SDA) while the clock (SCL) is high indicates a Start Condition. A low-to-high transition of the SDA line while the SCL is high indicates a Stop Condition. In addition to the first Start Condition, a repeated Start Condition can be generated in the middle of a transaction. This allows another device to be accessed, or a register read cycle. Stop Start SDA MSB SCL 1 2 3,4,5,6 7 LSB Ack MSB 8 9 1 2 3,4,5,6 LSB Ack 8 9 7 Fig5 I2C data transactions Addressing Transfer Formats The WD3153 operates as a slave device with the 7-bit address. If 8-bit address is used for programming, the 8th bit is 1 for read and 0 for write. Bit7 Bi6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 IADR IADR IADR IADR IADR IADR IADR R/W Before any data is transmitted, the master transmits the address of the slave being addressed. The slave device should send an acknowledge signal on the SDA line, once it recognizes its address. Will Semiconductor Ltd. 7 Nov. 2017 - Rev. 1.2 WD3153 The slave address is the first seven bits after a Start Condition. The direction of the data transfer (R/W) depends on the bit sent after the slave address - the eighth bit. When the slave address is sent, each device in the system compares this slave address with its own. If there is a match, the device considers itself addressed and sends an acknowledge signal. Depending upon the state of the R/W bit (1:read, 0:write), the device acts as a transmitter or a receiver. The default device address is 45h. The WD3153 allows the user to modify the device address. Through configuration the register IADR (address 77h), the address can be replaced by other values. Bit7 Bi6 Bit5 ASEL DA Bit4 Bit3 Bit2 Bit1 Bit0 When ASEL = 0, device address =45h (default); When ASEL = 1, device address = DA. Once the device address is redefined, the master must use the new address. After power-on-reset or soft reset, the device address will be reset to the default value (45h). Control Register Write Cycle ① Master device generates start condition. ② Master device sends slave address IADR and the data direction bit (R/W=0). ③ Slave device sends acknowledge signal if the slave address is correct. ④ Master sends control register address (8bits). ⑤ Slave sends acknowledge signal. ⑥ Master sends data byte to be written to the addressed register (8bits). ⑦ Slave sends acknowledge signal. ⑧ If master will send further data bytes the control register address will be incremented by one after acknowledge signal. ⑨ Write cycle ends when the master creates stop condition. Start Stop SDA SCL RAD 1 2,3,4,5,6 R/W Ack 8 9 7 Ack ADDR1 1 2,3,4,5,6,7 8 9 Ack DATA1 1 2,3,4,5,6,7 8 9 DATA2 1 2,3,4,5,6,7 8 Ack …… Ack 9 …… 9 2 Fig6 I C Write Cycle Control Register Read Cycle ① Master device generates a start condition. Master device sends slave address IADR and the data direction bit (R/W=0). ② Slave device sends acknowledge signal if the slave address is correct. ③ Master sends control register address (8 bits). ④ Slave sends acknowledge signal. ⑤ Master device generates repeated start condition. Will Semiconductor Ltd. 8 Nov. 2017 - Rev. 1.2 WD3153 ⑥ Master sends the slave address IADR and the data direction bit (R/W=1). ⑦ Slave sends acknowledge signal if the slave address is correct. ⑧ Slave sends data byte from addressed register. ⑨ If the master device sends acknowledge signal, the control register address will be incremented by one. Slave device sends data byte from addressed register. ⑩ Read cycle ends when the master does not generate acknowledge signal after data byte and generates stop condition. Start SDA IADR SCL 1 R/W Ack 8 9 7 2,3,4,5,6 Ack ADDR1 1 8 2,3,4,5,6,7 9 Repeat Start Stop SDA IADR SCL 1 2,3,4,5,6 R/W Ack 8 9 7 Ack DATA1 1 2,3,4,5,6,7 8 DATA2 9 1 Ack …… Ack 9 …… 9 8 2,3,4,5,6,7 Stop Start Stop SDA SCL IADR 1 2,3,4,5,6 7 R/W Ack 8 9 Ack DATA1 1 2,3,4,5,6,7 8 9 2 Fig7 I C Read Cycle Interrupt INTN is the interrupt open-drain output pin. It will output low when the following 4 conditions occur: a. Power on Reset b. The programmable lighting sequence running time duration is complete c. Under Voltage Lock Out d. Over Temperature Protect The interrupt function is enabled by the high 5-bits of Register GCR. When the interrupt occurs, the master reads the ISR register to determine the interrupt source. The ISR register is read-only and can be cleared. If no new interrupt is generated, the INTN will output high. LED Controller LED Controller Overview The WD3153 has three independent programmable channels (LED0, LED1, LED2). Trigger connections between channels are common for all channels. All channels have own program memories for storing complex patterns. Brightness control and patterns are done with 8-bit PWM control to get accurate and smooth color control. Will Semiconductor Ltd. 9 Nov. 2017 - Rev. 1.2 WD3153 Disabled Each channel can be configured to disabled mode. LED output current will be 0 during this mode. LED Output Current Setting LED output current is defined by IMAX bit (Register LCFG0~3). PWM Setting Set PWM output value from 0 to 255 by Register PWM0~2. Direct Control Mode 2 I C direct control mode is enabled by the MD bit of Register LCFGx. Changes to the PWM value registers are reflected immediately to the LED brightness. The WD3153 has fade-in and fade-out function. Fade-in / out close LCFGx-FI = 0 LCFGx-FO = 0 Fade-in / out open Fade-in LCFGx-FI = 1 LCFGx-FO = 1 Fade-out time Set PWM=FFH Set PWM=00H Fig8 Fade-in and Fade-out Function Program Execution Engines Use of program execution engines is the other LED output PWM control method available in the WD3153. The device has 3 program execution engines. These engines can be enabled by MD bit of Register LCFGx, and create PWM controlled lighting patterns to the mapped LED outputs according to program codes developed by the user. Program coding is done using programming commands. Programs are loaded into SRAM memory and engine control bits are used to run these programs autonomously. The engines have different operation modes, program execution states, and program counters. Each engine has its own section of the SRAM memory. The LED pattern is illustrated in the Fig9 below. The cycle is defined with T0~T4 (Fig9). It is possible to program very fast and also very low ramps. The repeat time is defined by REPEAT bits of LEDxT2. T0 T1 T2 T3 T4 T1 T2 T3 T4 One Cycle Fig9 LED Lighting Pattern for Program Execution Engines Will Semiconductor Ltd. 10 Nov. 2017 - Rev. 1.2 WD3153 Auto Charging Indication In application of mobile phone, when battery voltage is too low and the PMU cannot work, the LED driver 2 cannot be controlled by application processor via I C interface. In this case, extra LED control circuit is necessary to be built in for charging status indication. WD3153 provides the auto charging indication function for low battery voltage application. When the external USB power is inserts to phone, the pin CHRG is pulled high, WD3153 will enter active state automatically. The predefined pattern output only on pin LED0, the LED1 and LED2 keep off status. The pattern parameter is showed in fig10. The maximum current is 5mA, breathing period is about 5s or continuous, which is set by SET pin (SET=L, period is 5s; SET=H, continuous). Once the CHRG pin goes low, the device comes back to Shut Down state again and stops LED0 output. Current 1.04S 2.08S 0.13S 2.08S 1.04S 2.08S 0.13S 2.08S 1.04S Time Fig10 Auto Charging Indication Pattern Parameter The auto charging indication function should be closed by configured FCTR register CHRG_EN bit to 1 when 2 the processor is able to configure WD3153 via I C interface, then the lighting effects will have no relation with the CHRG status. When special charger IC is used and pin CHRG is recommend to be connected to status pin of charger IC (Fig1), the pin LED0 of WD3153 can indicate the real battery charging status. When no charger IC is applied, and battery charging is managed by PMU (Fig2), no real charging status signal can be adapted, so the LED0 status can only indicate whether the USB power is plugged in or not. When the pull-up resistance is 30KΩ, VBUS range can be 5V ~ 15V. Synchronously Lighting In Real Color Breathing Lighting application, the SYN_EN (Register LEDSYN) should be set to 1. The three LED channels will lighting synchronously. The color can be set by IMAX (Register LCFG0~3) and PWM duty (Register PWM0~2). Will Semiconductor Ltd. 11 Nov. 2017 - Rev. 1.2 WD3153 Register Definition Register List Addr (HEX) Register Function 00 Chip ID and Software Reset Register Chip ID and Reset all registers 01 Operation Enable Register Chip enable and interrupt enable 02 Interrupt Register Interrupt status 03 Function Control Register Function enable 30 Channel Enable Register Channel enable 31~33 Lighting Mode Register LED0~LED2 lighting mode 34~36 PWM Control Register PWM value of LED0~2 37/3A/3D T1 & T2 Setting Register T1 & T2 setting 38/3B/3E T3 & T4 Setting Register T3 & T4 setting 39/3C/3F T0 & Repeat time Setting Register T0 & repeat time setting Redefined ID Register Redefined ID 77 Register Maps Addr Register Type Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 00h RSTR WR 0 0 1 1 0 0 1 1 01h GCR WR LIE2 LIE1 LIE0 UVLO_IE OTP_IE 02h ISR R LIS2 LIS1 LIS0 PUIS UVLO_IS 03h FCTR WR 30h LCTR WR 31h LCFG0 WR 0 FO FI MD 0 IMAX 32h LCFG1 WR 0 FO FI MD 0 IMAX 33h LCFG2 WR 0 FO FI MD 0 IMAX 34h PWM0 WR PWM 35h PWM1 WR PWM 36h PWM2 WR PWM 37h LED0T0 WR 0 T1 0 T2 38h LED0T1 WR 0 T3 0 T4 39h LED0T2 WR 3Ah LED1T0 WR 0 T1 0 T2 3Bh LED1T1 WR 0 T3 0 T4 3Ch LED1T2 WR 3Dh LED2T0 WR 0 T1 0 T2 3Eh LED2T1 WR 0 T3 0 T4 3Fh LED2T2 WR 4Ah LEDSYN WR 77h IADR WR Will Semiconductor Ltd. Reserved Reserved OTP_IS CHIPEN Reserved OTP_EN UVLO_EN CHRG_EN PWM_HF Reserved LE2 T0 LE1 LOG_EN LE0 REPEAT T0 REPEAT T0 REPEAT Reserved ASEL SYN_EN Reserved DA[6:0] 12 Nov. 2017 - Rev. 1.2 WD3153 Register Description Chip ID and Software Reset Register RSTR Address: 00h Default value: 33h Bit7 Bi6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 RST RST RST RST RST RST RST RST Description: Symbol Bit Type RST 7:0 WR Active Description Chip ID: 33h Reset: write 55h to RSTR, reset logic and all registers. Global Control Register GCR Address: 01h Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 LIE2 LIE1 LIE0 UVLO_IE OTP_IE Bit2 Bit1 Reserved Bit0 CHIPEN Description: Symbol Bit Type Active Description LIE2 7 WR High LED2 interrupt enable LIE1 6 WR High LED1 interrupt enable LIE0 5 WR High LED0 interrupt enable UVLO_IE 4 WR High UVLO interrupt enable OTP_IE 3 WR High OTP interrupt enable Reserved 2:1 WR ENABLE 0 WR High Chip enable. Interrupt Register ISR Address: 02h Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 Bit2 LIS2 LIS1 LIS0 PUIS UVLO_IS OTP_IS Bit1 Bit0 Reserved Description: Symbol Bit Type Active LIS2 7 WR High LED2 interrupt status (0: no interrupt; 1: interrupt) LIS1 6 WR High LED1 interrupt status (0: no interrupt; 1: interrupt) LIS0 5 WR High LED0 interrupt status (0: no interrupt; 1: interrupt) PUIS 4 WR High Power on reset interrupt. UVLO_IS 3 R High UVLO interrupt status (1: under voltage) OTP_IS 2 R High OTP interrupt status (1: over temperature) Reserved 1:0 WR Will Semiconductor Ltd. Description 13 Nov. 2017 - Rev. 1.2 WD3153 Function Control Register FCTR Address: 03h Default value: 11h Bit7 Bi6 Bit5 Reserved Bit4 Bit3 Bit2 Bit1 Bit0 OTP_EN UVLO_EN CHRG_EN PWM_HF LOG_EN Description: Symbol Bit Type Active Description Reserved 7:5 WR OTP_EN 4 WR High Over Temperature Protection enable UVLO_EN 3 WR High Under Voltage Lock Out enable CHRG_EN 2 WR Low Charge function enable PWM_HF 1 WR LOG_EN 0 WR PWM Frequency Shift (0: 250Hz; 1: 500Hz) High Log and Linear Shift (0: linear; 1: Log) LED Control Register LCTR Address: 30h Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 Reserved Bit2 Bit1 Bit0 LE2 LE1 LE0 Bit1 Bit0 Description: Symbol Bit Type Active Description Reserved 7:3 WR LE2 2 WR High LED2 enable. LE1 1 WR High LED1 enable. LE0 0 WR High LED0 enable. Lighting Mode Register LCFG0~2 Address: 31~33h Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 0 FO FI MD 0 Bit2 IMAX Description: Symbol Bit Type Active Description Fade-out enable FO 6 WR High 1: Fade-out time = T3 0: Disable. This function is enabled during Direct Control Mode Fade-in enable FI 5 WR High 1: Fade-in time = T1 0: Disable This function is enabled during Direct Control Mode Will Semiconductor Ltd. 14 Nov. 2017 - Rev. 1.2 WD3153 Lighting mode control MD 4 WR High 0: Direct Control Mode 1: Programmable Lighting Mode Output current setting 000: 0mA (default) IMAX 2:0 001: 5mA WR 010: 10mA 011: 15mA 1xx: 25mA PWM Control Register PWM0~2 Address: 34~36h Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Bit1 Bit0 PWM Description: Symbol Bit Type Active Description Output PWM value setting PWM 7:0 WR 0: no PWM 255: 100% duty T1 & T2 Setting Register LEDiT0 Address: 37h, 3Ah, 3Dh Default value: 00h Bit7 Bi6 0 Bit5 Bit4 Bit3 T1 Bit2 0 T2 Description: Symbol Bit Type Active Description Fade-in time setting T1 6:4 WR 000: 0.13s 001: 0.26s 010: 0.52s 011: 1.04s 100: 2.08s 101: 4.16s 110: 8.32s 111: 16.64s Hold time setting after fade-in T2 2:0 WR 000: 0.13s 001: 0.26s 010: 0.52s 011: 1.04s 100: 2.08s 101: 4.16s Others: 4.16s Will Semiconductor Ltd. 15 Nov. 2017 - Rev. 1.2 WD3153 T3 & T4 Setting Register LEDiT1 Address: 38h, 3Bh, 3Eh Default value: 00h Bit7 Bi6 Bit5 0 Bit4 Bit3 T3 Bit2 Bit1 0 Bit0 T4 Description: Symbol Bit Type Active Description Fade-out time setting T3 6:4 WR 000: 0.13s 001: 0.26s 010: 0.52s 011: 1.04s 100: 2.08s 101: 4.16s 110: 8.32s 111: 16.64s Hold time setting after fade-out T4 2:0 WR 000: 0.13s 001: 0.26s 010: 0.52s 011: 1.04s 100: 2.08s 101: 4.16s 110: 8.32s 111: 16.64s T0 & Repeat time Setting Register LEDiT2 Address: 39h, 3Ch, 3Fh Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 Bit2 T0 Bit1 Bit0 REPEAT Description: Symbol Bit Type Active Description Delay time setting before auto blinking T0 7:4 WR 000: 0s 001: 0.13s 010: 0.26s 011: 0.52s 100: 1.04s 101: 2.08s 110: 4.16s 111: 8.32s 1000: 16.64s Others: 16.64s Blinking times setting 0000: Continuous blinking REPEAT 3:0 WR 0001: 1 time 0010: 2 times …… 1111: 15 times Will Semiconductor Ltd. 16 Nov. 2017 - Rev. 1.2 WD3153 Synchronously Lighting Register LEDSYN Address: 4Ah Default value: 00h Bit7 Bi6 Bit5 Bit4 Bit3 Reserved Bit2 SYN_EN Bit1 Bit0 Reserved Description: Symbol Bit Type Reserved 7:3 WR SYN_EN 2 WR Reserved 1:0 WR Active High Description Synchronously Lighting enable Redefined ID Register IADR Address: 77h Default value: 45h Bit7 Bi6 Bit5 Bit4 ASEL Bit3 Bit2 Bit1 Bit0 DA Description: Symbol Bit Type Active Description ID select: ASEL 7 WR High 0: ID 45h (default) 1: ID DA[6:0] DA 6:0 Will Semiconductor Ltd. WR Redefined ID only if ASEL=1 17 Nov. 2017 - Rev. 1.2 PACKAGE OUTLINE DIMENSIONS DFN2x2-10L D K 1 D2 b e E E2 R L TOP VIEW BOTTOM VIEW A1 A A3 SIDE VIEW Symbol Dimensions in Millimeters Min. Typ. Max. A 0.70 0.75 0.80 A1 0.00 0.02 0.05 A3 0.20 Ref. b 0.15 0.20 0.25 D 1.90 2.00 2.10 E 1.90 2.00 2.10 D2 0.80 0.90 1.00 E2 1.30 1.40 1.50 e 0.30 0.40 0.50 K 0.15 0.25 0.35 L 0.25 0.30 0.35 R Will Semiconductor Ltd. 0.10 Ref. TAPE AND REEL INFORMATION Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 RD Reel Dimension W Overall width of the carrier tape P1 Pitch between successive cavity centers Pin1 Pin1 Quadrant Will Semiconductor Ltd. User Direction of Feed 7inch 13inch 1 8mm 12mm 16mm 2mm 4mm 8mm Q1 Q2 Q3 Q4
WD3153D-10/TR 价格&库存
很抱歉,暂时无法提供与“WD3153D-10/TR”相匹配的价格&库存,您可以联系我们找货
