ZM4728A - ZM4758A
Taiwan Semiconductor
1W, 5% Tolerance Hermetically Sealed Glass
Zener Voltage Regulators
FEATURES
KEY PARAMETERS
● Wide zener voltage range selection: 3.3V to 56V
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
3.3-56
V
PD
1
W
TJ Max.
175
°C
APPLICATIONS
● Low voltage stabilizers or voltage references
● Adapters
● On-board DC/DC converter
Package
MELF
Configuration
Single die
MECHANICAL DATA
● Case: MELF
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Polarity: Indicated by cathode band
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Power dissipation
SYMBOL
VALUE
UNIT
PD
1
W
Junction temperature range
TJ
-65 to +175
°C
Storage temperature range
TSTG
-65 to +200
°C
SYMBOL
TYP
UNIT
RӨJA
170
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:D1804
ZM4728A - ZM4758A
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
TEST
REGULAR
TEST
LEAKAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
IR @ V R
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
Max.
Max.
ZM4728A
3.3
76
10
400
1.0
100
1.0
ZM4729A
3.6
69
10
400
1.0
100
1.0
ZM4730A
3.9
64
9
400
1.0
50
1.0
ZM4731A
4.3
58
9
400
1.0
10
1.0
ZM4732A
4.7
53
8
500
1.0
10
1.0
ZM4733A
5.1
49
7
550
1.0
10
1.0
ZM4734A
5.6
45
5
600
1.0
10
2.0
ZM4735A
6.2
41
2
700
1.0
10
3.0
ZM4736A
6.8
37
3.5
700
1.0
10
4.0
ZM4737A
7.5
34
4.0
700
0.5
10
5.0
ZM4738A
8.2
31
4.5
700
0.5
10
6.0
ZM4739A
9.1
28
5.0
700
0.5
10
7.0
ZM4740A
10
25
7.0
700
0.25
10
7.6
ZM4741A
11
23
8.0
700
0.25
5.0
8.4
ZM4742A
12
21
9.0
700
0.25
5.0
9.1
ZM4743A
13
19
10
700
0.25
5.0
9.9
ZM4744A
15
17
14
700
0.25
5.0
11.4
ZM4745A
16
15.5
16
700
0.25
5.0
12.2
ZM4746A
18
14.0
0.25
5.0
13.7
ZM4747A
22
750
0.25
5.0
15.2
ZM4748A
22
11.5
23
750
0.25
5.0
16.7
ZM4749A
24
10.5
25
750
0.25
5.0
18.2
ZM4750A
27
9.5
35
750
0.25
5.0
20.6
ZM4751A
30
8.5
40
1000
0.25
5.0
22.8
ZM4752A
33
7.5
45
1000
0.25
5.0
25.1
ZM4753A
36
7.0
50
1000
0.25
5.0
27.4
ZM4754A
39
6.5
60
1000
0.25
5.0
29.7
ZM4755A
43
6.0
70
1500
0.25
5.0
32.7
ZM4756A
47
5.5
80
1500
0.25
5.0
35.8
ZM4757A
51
5.0
95
1500
0.25
5.0
38.8
ZM4758A
56
4.5
110
2000
0.25
5.0
42.6
PART NUMBER
µA
V
Max.
Notes:
1. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%.
2. For detailed information on price, availability and delivery of nominal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
3. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an rms value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK.
2
Version:D1804
ZM4728A - ZM4758A
ORDERING INFORMATION
PART NO.
(Note 1)
PACKAGE
PACKING
ZM47xxA L0
MELF
5K / 13" Reel
ZM47xxA L0G
MELF
5K / 13" Reel
Note:
1. "xx" defines voltage from 3.3V (ZM4728A) to 56V (ZM4758A)
3
Version:D1804
ZM4728A - ZM4758A
PACKAGE OUTLINE DIMENSION
MELF
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
4.80
5.50
0.189
0.217
B
2.25
2.67
0.089
0.105
C
0.30
0.60
0.012
0.024
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
C
4.80
0.189
G
3.30
0.130
X
1.50
0.059
X1
6.30
0.248
Y
2.70
0.106
DIM.
4
Version:D1804
ZM4728A - ZM4758A
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version:D1804
很抱歉,暂时无法提供与“ZM4756A L0G”相匹配的价格&库存,您可以联系我们找货
