XB3-24DMPT-J
XB3-24DMPT-J
    DIGIINTERNATIONAL
    XB3-24DMPT-J
XB3-24DMPT-J 数据手册
DIGI XBEE 3 DIGIMESH 2.4 Wireless connectivity using the innovative and easy-to-deploy DigiMesh® protocol Digi XBee® 3 modules accelerate time to market for designers, OEMs and solution providers by quickly enabling wireless connectivity and easy-to-add functionality. Building on industry-leading technology, pre-certified Digi XBee 3 modules offer the flexibility to switch between multiple frequencies and wireless protocols as needed. These modules use the DigiMesh® networking protocol using a globally deployable 2.4 GHz transceiver. This peerto-peer mesh network offers users added network stability through self-healing, dense network operation, extending the operational life of battery dependent networks and provides an upgrade path to IEEE 802.15.4 or Zigbee mesh protocols, if desired. SIZE AND FLEXIBILITY With Digi Remote Manager®, Digi XBee 3 modules can be easily configured and controlled from a simple, central platform. Built-in Digi TrustFence® security, identity and data privacy features use more than 175 controls to protect against new and evolving cyber threats. MicroPython and Digi XCTU® software tools simplify adding functionality, configuration and testing. From edge computing to future migration, Digi XBee modules offer size, weight, power and performance advantages ideal for scalable device connectivity. A versatile addition to the expanding Digi XBee Ecosystem of wireless modules, adapters and software, the Digi XBee 3 series is engineered to accelerate development and deployment. APPLICATION EXAMPLE – At 13 mm x 19 mm, the new Digi XBee® 3 micro form factor allows for more compact and portable applications – Digi XBee 3 is one module for all protocols including: Zigbee, 802.15.4, DigiMesh®, and BLE, all configurable via Digi XCTU® DIGI REMOTE MANAGER® PROGRAMMABILITY Application – Eliminate the need for an external microcontroller and create smart end nodes using MicroPython – Bluetooth® Low Energy for beaconing, connecting to Bluetooth sensors and local configuration using the Digi XBee Mobile app ZIGBEE MESH NETWORK DIGI® XBEE GATEWAY SECURITY MicroPython Rules Engine – Intrinsic IoT security with Digi TrustFence®, a layered approach securing the edge device, through the gateway, into and out of the IoT ® BlueTooth® low energy Street Light Digi XBee 3 DigiMesh RELATED PRODUCTS AND SERVICES TRUSTFENCE Street Light Development Kits Digi XCTU® Digi TrustFence® Digi Remote Manager® Digi Design Services Digi XBee 3 DigiMesh Street Light Digi XBee 3 DigiMesh SPECIFICATIONS SPECIFICATIONS Digi XBee 3 DigiMesh® Digi XBee 3 DigiMesh® PRO PERFORMANCE TRANSCEIVER CHIPSET Silicon Labs EFR32MG SoC DATA RATE RF 250 Kbps, serial up to 1 Mbps INDOOR/URBAN RANGE* Up to 60 m (200 ft) Up to 90 m (300 ft) OUTDOOR/RF LINE-OF-SIGHT RANGE* Up to 1200 m (4000 ft) Up to 3200 m (2 miles) TRANSMIT POWER +8 dBm +19 dBm RECEIVER SENSITIVITY (1% PER) -103 dBm normal mode FEATURES SERIAL DATA INTERFACE UART, SPI, I2C CONFIGURATION METHOD API or AT commands, local or over-the-air (OTA) FREQUENCY BAND ISM 2.4 GHz FORM FACTOR Micro, through-hole, surface mount INTERFERENCE IMMUNITY DSSS (Direct Sequence Spread Spectrum) ADC INPUTS (4) 10-bit ADC inputs DIGITAL I/O 15 ANTENNA OPTIONS Through-hole: PCB Antenna, U.FL Connector, RPSMA Connector SMT: RF Pad, PCB Antenna, or U.FL Connector Micro: U.FL Antenna, RF Pad, Chip Antenna OPERATING TEMPERATURE -40º C to 85º C (-40º F to 185º F) DIMENSIONS (L X W X H) Through-hole: 2.438 x 2.761 cm (0.960 x 1.087 in) SMT: 2.199 x 3.4 x 0.305 cm (0.866 x 1.33 x 0.120 in) Micro: 13 x 19 x 2 mm (0.533 x 0.76 x 0.087 in) PROGRAMMABILITY MEMORY 1 MB / 128 KB RAM CPU/CLOCK SPEED HCS08 / up to 50.33 MHz NETWORKING AND SECURITY PROTOCOL 802.15.4 ENCRYPTION 128/256 bit AES RELIABLE PACKET DELIVERY Retries/acknowledgements IDS PAN ID and addresses, cluster IDs and endpoints (optional) CHANNELS 16 channels POWER REQUIREMENTS SUPPLY VOLTAGE 2.1 to 3.6 V TRANSMIT CURRENT 135 mA @ 19 dBm RECEIVE CURRENT 17 mA POWER-DOWN CURRENT 2 micro Amp @ 25º C (77º F) REGULATORY APPROVALS FCC, IC (NORTH AMERICA) Yes Yes ETSI (EUROPE) Yes No RCM (AUSTRALIA) Yes Yes ANATEL (BRAZIL) Yes Yes TELECK MIC (JAPAN) Yes No KCC (SOUTH KOREA) Yes Yes *Range figure estimates are based on free-air terrain with limited sources of interference. Actual range will vary based on transmitting power, orientation of transmitter and receiver, height of transmitting antenna, height of receiving antenna, weather conditions, interference sources in the area, and terrain between receiver and transmitter, including indoor and outdoor structures such as walls, trees, buildings, hills, and mountains. DIGI.COM PART NUMBERS DESCRIPTION XB3-24DMRM-J Digi XBee 3, 2.4 Ghz, DigiMesh, Micro, RF Pad Ant, MMT XB3-24DMUM-J Digi XBee 3, 2.4 Ghz, DigiMesh, Micro, U.FL Ant, MMT XB3-24DMCM-J Digi XBee 3, 2.4 Ghz, DigiMesh, Micro, Chip Ant, MMT XB3-24DMUS-J Digi XBee 3, 2.4 Ghz, DigiMesh, SMT, U.FL XB3-24DMPS-J Digi XBee 3, 2.4 Ghz, DigiMesh, SMT, PCB ANT XB3-24DMRS-J Digi XBee 3, 2.4 Ghz, DigiMesh, SMT, RF Pad XB3-24DMUT-J Digi XBee 3, 2.4 Ghz, DigiMesh, TH, U.FL XB3-24DMPT-J Digi XBee 3, 2.4 Ghz, DigiMesh, TH, PCB ANT XB3-24DMST-J Digi XBee 3, 2.4 Ghz, DigiMesh, TH, RPSMA XB3-24DMRM Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, Micro, RF Pad Ant, MMT XB3-24DMUM Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, Micro, U.FL Ant, MMT XB3-24DMCM Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, Micro, Chip Ant, MMT XB3-24DMUS Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, U.FL Antenna, SMT XB3-24DMPS Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, PCB Antenna, SMT XB3-24DMRS Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, RF Pad Antenna, SMT XB3-24DMUT Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, TH U.FL XB3-24DMPT Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, TH PCB ANT XB3-24DMST Digi XBee 3 PRO, 2.4 Ghz, DigiMesh, TH RPSMA A24-HABUF-P5I Antenna - 2.4 GHz, half wave dipole, 2.1 dBi, U.FL female, articulating A24-HASM-450 Antenna - 2.4 GHz, half wave dipole, 2.1 dBi, RPSMA male, articulating A24-HASM-525 Antenna - 2.4 GHz, half wave dipole, 2.1 dBi, RPSMA male, articulating DC-ANT-24DT Antenna - Wi-Fi, table-top mount, 2450 Mhz, 0.5 m cable                ACTUAL SIZE   DIGI XBEE 3 MICRO          PRODUCT DIMENSIONS  19 mm © 1996-2021 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004233 B2/221        ACTUAL SIZE DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support.            13 mm             DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA  +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
XB3-24DMPT-J 价格&库存
很抱歉,暂时无法提供与“XB3-24DMPT-J”相匹配的价格&库存,您可以联系我们找货
