SDVL5650SD380PTHS122
    SUNLORD(顺络)
SDVL5650SD380PTHS122 数据手册
High Surge type multilayer Chip Varistor for Surge Current Suppression-SDVL-HS Series Operating Temp. : -55℃~+125℃ FEATURES SMD type, small size suitable for high density mounting High surge and strong capability of voltage surge suppression Excellent solderability (Ni, Sn plating) ● ● ● APPLICATIONS  Lightning protection and voltage surge suppression for Power supply, Network Interface, LED lighting.  Lightning protection and voltage surge suppression for security system, base station.  Industrial instrument, smart meters, etc. PRODUCT IDENTIFICATION SDVL ① ① 5650 S ② ③ Type SDVL Chip Varistor for Voltage Surge Suppression ④ ② D 480 P ④ ⑤ ⑥ External Dimensions (L×W) (mm) 1608 [0603] 1.6×0.8 2016 [0806] 2.2×1.6 3216 [1206] 3.2×1.6 3225 [1210] 3.2×2.5 4532 [1812] 4.5×3.2 5650 [2220] 5.9×5.1 ③ T HS 901 ⑦ ⑧ ⑨ Tolerance of Varistor Voltage S Special ⑥ P ⑦ Packing Type of Working Voltage D DC Working Voltage ⑧ Series Code HS Terminal Code Ni, Sn Plating High-surge type T ⑤ Tape & Reel ⑨ Max. Continuous Working Voltage Example Nominal value 090 9V 140 14V 480 48V Peak Surge Current Example Nominal value 300 30A 801 800A 502 5000A SHAPE AND DIMENSIONS Unit: mm [inch] Type SDVL3216 [1206] SDVL3225 [1210] SDVL4532 [1812] SDVL5650 [2220] Sunlord L W T a 3.2±0.2 1.6±0.2 1.60 Max. [.126±.008] [.063±.008] [.063] 3.2+0.6/-0.2 2.5+0.4/-0.2 2.6 Max. [.126+0.024/-.008] [.098+.016/-0.08] [.102] 4.5±0.4 3.2±0.3 2.5 Max. [.177±.016] [.126±.012] [.098] 5.9±0.2 5.1±0.2 2.6 ±0.2 [.232±.008] [.201±.008] [.102±.008] Specifications subject to change without notice. Please check our website for latest information. 0.2~0.8 [.008~.031] 0.25~0.75 [.010~.029] 0.25~1.0 [.010~.039] 0.40~0.90 [.016~.034] Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SDVL1608-HS TYPE Part Number Test Condition Units Symbol SDVL1608SD090PTHS151 SDVL1608SD180PTHS121 SDVL1608SD300PTHS101 SDVL1608SD380PTHS800 SDVL1608SD480PTHS600 SDVL1608SD560PTHS300 SDVL1608SD600PTHS300 SDVL1608SD650PTHS300 SDVL1608SD850PTHS200 SDVL1608SD101PTHS200 Max. Working Voltage
SDVL5650SD380PTHS122 价格&库存
很抱歉,暂时无法提供与“SDVL5650SD380PTHS122”相匹配的价格&库存,您可以联系我们找货
