20579-001E
20579-001E
    I-PEX(第一精工)
    SMD
    射频和同轴连接器 12GHz
20579-001E 数据手册
MHF® 4L The M.2 industry standard, mated height of 1.2 mm max., excellent electrical performance up to 12 GHz Maximum height (mm) Outside dimension of receptacle (mm) Small form factor with big performance through 12 GHz Solderless micro-coax termination technology "i-Fit®" provides consistent performance MHF® 4L Plug available cable O.D. (AWG) : 0.81 mm (36), 0.64 mm (36). 1.2 2.0 x 2.0 Applicable wire gauge O.D. 0.81 mm / AWG 36 O.D. 0.64 mm / AWG 36 Frequency DC~3 GHz 3 GHz~6 GHz VSWR 6 GHz~9 GHz (L=100 mm) 9 GHz~12 GHz 12 GHz~15 GHz Service temp. (Celsius) Characteristic impedance Rated voltage Contact resistance Withstand voltage Insulation resistance DC~12 GHz 1.3 max. 1.45 max. 1.6 max. 1.9 max. -40 degree ~ +90 degree 50 ohm AC60V 20m ohm max. AC200V/min 500M ohm min./DC100V Small form factor with big performance through 12 GHz L=100 mm (Harness) VSWR Insertion Loss L=100 mm (Harness) Solderless micro-coax termination technology "i-Fit®" provides consistent performance Center Conductor Contact Dielectric Core Center Conductor Outer Conductor Jacket Crimping MHF® 4L Plug available cable O.D. (AWG) : 0.81 mm (36), 0.64 mm (36). Coax O.D. (Center Conductor AWG) 2.00 mm (26) 1.80 mm (30) 1.37 mm (30) 1.32 mm (32) 1.13 mm (32) 0.95 mm (33) 0.81 mm (33) 0.81 mm (36) 0.64 mm (36) 0.48 mm (38) Receptacle 1.7 mm max. Mating Height 1.4 mm max. 1.2 mm max. ○ ○ ○ ○ ○ MHF 4 receptacle , MHF 4L receptacle Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4L Component Parts Detail MHF® 4L plug Ni top (0.81,0.64) Rev.6 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4L plug Ni top (0.81,0.64) Rev.6 MHF® 4L plug Ni top (0.81,0.64) Rev.6 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 Accessories for MHF® 4L (0.81,0.64) Rev.6 MHF® 4L Receptacle Rev.8 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4L Receptacle Rev.8 MHF® 4L Receptacle Rev.8 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4L Receptacle Rev.8 MHF® 4 Receptacle Rev.15 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 Receptacle Rev.15 MHF® 4 Receptacle Rev.15 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 Receptacle Rev.15 MHF® 4 Receptacle Rev.15 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 Accessories for MHF® 4L Receptacle Rev.15 Copyright © I-PEX Inc. 2020. All rights reserved. I-PEX, MHF, CABLINE, NOVASTACK, EVAFLEX, MINIFLEX, ISH, IARPB, IASLP, ESTORQ, i-Fit and ISFIT are registered trademarks of I-PEX Inc. Please note that the contents in the catalog might be changed without prior notification. I-PEX Inc. assumes no responsibility for any inaccuracies or obligation to update Information on these documents. Please be sure to read and understand the latest "Precautions for Use" and "Instruction Manual" before you use our products. We shall not be responsible for any defects, damages or troubles in case you use our products without following the precautions for use. Please feel free to contact our sales representatives when you use our products for any applications that require very high reliability and safety, or that relate to human life (ex. nuclear power control, aerospace, transportation, medical equipment, safety equipment etc.). Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0
20579-001E 价格&库存
很抱歉,暂时无法提供与“20579-001E”相匹配的价格&库存,您可以联系我们找货
20579-001E
    20579-001E
      • 1+4.64000
      • 30+4.48000
      • 100+4.16000
      • 500+3.84000
      • 1000+3.68000
      20579-001E
      • 10000+5.9040810000+0.76624
      库存:115936
      20579-001E
      • 1+11.296311+1.46606
      • 10+9.6157410+1.24795
      • 25+9.0131325+1.16974
      • 50+8.5822150+1.11382
      • 100+8.17071100+1.06041
      • 250+7.65899250+0.99400
      • 500+7.29308500+0.94651
      • 1000+6.944951000+0.90133
      • 2500+6.510232500+0.84491
      库存:115936
      20579-001E
        库存:10000
