NXB0108PWJ
NXB0108PWJ
    NEXPERIA(安世)
    TSSOP20
    NXB0108PWJ
NXB0108PWJ 数据手册
NXB0108 Dual supply translating transceiver; auto direction sensing; 3-state Rev. 2 — 3 November 2021 Product data sheet 1. General description The NXB0108 is an 8-bit, dual supply translating transceiver with auto direction sensing, that enables bidirectional voltage level translation. It features two 8-bit input-output ports (An and Bn), one output enable input (OE) and two supply pins (VCC(A) and VCC(B)). VCC(A) can be supplied at any voltage between 1.2 V and 3.6 V and VCC(B) can be supplied at any voltage between 1.65 V and 5.5 V, making the device suitable for translating between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins An and OE are referenced to VCC(A) and pins Bn are referenced to VCC(B). A LOW level at pin OE causes the outputs to assume a high-impedance OFF-state. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • Wide supply voltage range: • VCC(A): 1.2 V to 3.6 V and VCC(B): 1.65 V to 5.5 V IOFF circuitry provides partial Power-down mode operation Inputs accept voltages up to 5.5 V ESD protection: • HBM: ANSI/ESDA/Jedec JS-001 Class 2 exceeds 2500 V for A port • HBM: ANSI/ESDA/Jedec JS-001 Class 3B exceeds 15000 V for B port • CDM: ANSI/ESDA/Jedec JS-002 Class C3 exceeds 1500 V Latch-up performance exceeds 100 mA per JESD 78B Class II Multiple package options Specified from −40 °C to +85 °C and −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version NXB0108PW −40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 NXB0108BQ −40 °C to +125 °C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm SOT764-1 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 4. Functional diagram OE 4 kΩ ONE SHOT An ONE SHOT Bn 4 kΩ VCC(A) To other channels VCC(B) aaa-030666 Fig. 1. Functional diagram (for one channel) 5. Pinning information 5.1. Pinning A1 1 VCC(A) 2 19 VCC(B) A2 3 18 B2 A3 4 17 B3 A4 5 16 B4 A5 6 15 B5 A6 7 A7 8 A8 9 20 B1 VCC(A) 2 19 VCC(B) A2 3 18 B2 A3 4 17 B3 A4 5 16 B4 A5 6 15 B5 A6 7 14 B6 A7 8 13 B7 A8 9 12 B8 OE 10 Product data sheet 12 B8 aaa-032227 (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 11 GND Pin configuration SOT360-1 (TSSOP20) NXB0108 13 B7 Transparent top view aaa-032226 Fig. 2. 14 B6 GND(1) OE 10 1 GND 11 NXB0108 A1 20 B1 NXB0108 terminal 1 index area Fig. 3. Pin configuration SOT764-1 (DHVQFN20) All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 2 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description A1, A2, A3, A4, A5, A6, A7, A8 1, 3, 4, 5, 6, 7, 8, 9 data input or output (referenced to VCC(A)) VCC(A) 2 supply voltage A OE 10 output enable input (active HIGH; referenced to VCC(A)) GND 11 ground (0 V) B1, B2, B3, B4, B5, B6, B7, B8 20, 18, 17, 16, 15, 14, 13, 12 data input or output (referenced to VCC(B)) VCC(B) 19 supply voltage B 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Input/output VCC(A) VCC(B) OE An Bn 1.2 V to VCC(B) 1.65 V to 5.5 V L Z Z 1.2 V to VCC(B) 1.65 V to 5.5 V H input or output output or input GND[1] GND[1] X Z Z Supply voltage [1] When either VCC(A) or VCC(B) is at GND level, the device goes into power-down mode. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC(A) VCC(B) VI input voltage VO output voltage Conditions Min Max Unit supply voltage A -0.5 +6.5 V supply voltage B -0.5 +6.5 V [1] -0.5 +6.5 V [1] [2] [3] -0.5 VCCO + 0.5 V [1] -0.5 +6.5 V Active mode Power-down or 3-state mode IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current VO = 0 V to VCCO - ±50 mA ICC supply current ICC(A) or ICC(B) - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] [4] Tamb = -40 °C to +125 °C [2] [4] The minimum input and minimum output voltage ratings may be exceeded if the input and output current ratings are observed. VCCO is the supply voltage associated with the output. VCCO + 0.5 V should not exceed 6.5 V. For SOT360-1 (TSSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C. For SOT764-1 (DHVQFN20) package: Ptot derates linearly with 12.9 mW/K above 111 °C. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 3 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions [1] [2] Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 1.2 3.6 V VCC(B) supply voltage B 1.65 5.5 V VI input voltage 0 5.5 V VO output voltage 0 3.6 V Power-down or 3-state mode; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V A port B port Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] [2] 0 5.5 V -40 +125 °C - 40 VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V ns/V The A and B sides of an unused I/O pair must be held in the same state, both at VCCI or both at GND. VCC(A) must be less than or equal to VCC(B). 9. Static characteristics Table 6. Typical static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C. Symbol Parameter Conditions Min Typ Max VOH HIGH-level output voltage A port; VCC(A) = 1.2 V; IO = -20 μA VOL - 1.1 - V LOW-level output A port; VCC(A) = 1.2 V; IO = 20 μA voltage - 0.09 - V II input leakage current - - ±1 μA IOZ OFF-state output A or B port; VO = 0 V to VCCO; VCC(A) = 1.2 V to 3.6 V; current VCC(B) = 1.65 V to 5.5 V - - ±1 μA IOFF power-off leakage current A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V; VCC(B) = 0 V to 5.5 V - - ±1 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 0 V to 3.6 V - - ±1 μA - 5 - pF A port; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V - 5 - pF B port; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V - 8 - pF OE input; VI = 0 V to 3.6 V; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V CI input capacitance OE input; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V CI/O input/output capacitance [1] [1] Unit VCCO is the supply voltage associated with the output. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 4 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Table 7. Typical supply current At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C. VCC(A) VCC(B) 1.8 V Unit 2.5 V 3.3 V 5.0 V ICC(A) ICC(B) ICC(A) ICC(B) ICC(A) ICC(B) ICC(A) ICC(B) 1.2 V 10 10 10 10 10 20 10 1050 nA 1.5 V 10 10 10 10 10 10 10 650 nA 1.8 V 10 10 10 10 10 10 10 350 nA 2.5 V - - 10 10 10 10 10 40 nA 3.3 V - - - - 10 10 10 10 nA Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH Conditions HIGH-level input voltage A or B port and OE input LOW-level input voltage A or B port and OE input VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V A or B port; IO = 20 μA LOW-level output voltage A port; VCC(A) = 1.4 V to 3.6 V Unit Min Max Min Max 0.65VCCI - 0.65VCCI - V - 0.35VCCI - 0.35VCCI V VCCO - 0.4 - VCCO - 0.4 - V VCCO - 0.4 - VCCO - 0.4 - V - 0.4 - 0.4 V - 0.4 - 0.4 V - ±2 - ±5 μA - ±2 - ±10 μA [1] [2] B port; VCC(B) = 1.65 V to 5.5 V VOL -40 °C to +125 °C [1] VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V A or B port; IO = -20 μA HIGH-level output voltage A port; VCC(A) = 1.4 V to 3.6 V -40 °C to +85 °C [2] B port; VCC(B) = 1.65 V to 5.5 V II input leakage current OE input; VI = 0 V to 3.6 V; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCC(A) = 1.2 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V IOFF power-off leakage current A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V; VCC(B) = 0 V to 5.5 V - ±2 - ±10 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 0 V to 3.6 V - ±2 - ±10 μA NXB0108 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 5 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Min Max Min Max OE = LOW; VCC(A) = 1.4 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V - 5 - 15 μA OE = HIGH; VCC(A) = 1.4 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V - 5 - 20 μA VCC(A) = 3.6 V; VCC(B) = 0 V - 2 - 15 μA VCC(A) = 0 V; VCC(B) = 5.5 V - -2 - -15 μA OE = LOW; VCC(A) = 1.4 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V - 5 - 20 μA OE = HIGH; VCC(A) = 1.4 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V - 13 - 65 μA VCC(A) = 3.6 V; VCC(B) = 0 V - -2 - -15 μA VCC(A) = 0 V; VCC(B) = 5.5 V - 2 - 15 μA - 15 - 70 μA supply current VI = 0 V or VCCI; IO = 0 A ICC Unit [1] ICC(A) ICC(B) ICC(A) + ICC(B) VCC(A) = 1.4 V to 3.6 V; VCC(B) = 1.65 V to 5.5 V [1] [2] VCCI is the supply voltage associated with the input. VCCO is the supply voltage associated with the output. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 6 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 10. Dynamic characteristics Table 9. Typical dynamic characteristics for temperature 25 °C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6; for waveforms see Fig. 4 and Fig. 5. Symbol Parameter Conditions VCC(B) Unit 1.8 V 2.5 V 3.3 V 5.0 V A to B 6.9 5.6 5.1 4.9 ns B to A 7.1 5.8 5.0 5.1 ns VCC(A) = 1.2 V; Tamb = 25 °C tpd propagation delay ten enable time OE to A, B 500 500 500 500 ns tdis disable time OE to A; no external load [2] 14.5 14.5 14.5 14.5 ns OE to B; no external load [2] 12.2 10.1 9.3 8.7 ns OE to A; see Fig. 5 87 87 87 87 ns OE to B; see Fig. 5 98 71 101 68 ns A port 4.2 4.2 4.2 4.2 ns B port 2.7 2.0 1.7 1.5 ns 1.4 0.7 0.6 0.5 ns 13 13 13 13 ns 60 60 60 60 Mbps tt transition time tsk(o) output skew time between channels tW pulse width data inputs fdata data rate [1] [2] [3] [3] tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. tt is the same as tTHL and tTLH These values are guaranteed by design. Skew between any two outputs of the same package switching in the same direction. Table 10. Dynamic characteristics for temperature range -40 °C to +85 °C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6; for waveforms see Fig. 4 and Fig. 5. Symbol Parameter Conditions VCC(B) Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max VCC(A) = 1.5 V ± 0.1 V tpd propagation delay A to B 1.4 11.4 1.2 8.0 1.1 6.7 0.8 6.2 ns B to A 0.9 10.8 0.7 8.3 0.4 7.8 0.3 7.2 ns ten enable time OE to A, B - 1.0 - 1.0 - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] 3.7 18.0 3.7 18.0 3.7 18.0 3.7 18.0 ns OE to B; no external load [2] 3.7 19.5 3.5 15.0 3.0 13.0 1.7 11.5 ns - 100 - 100 - 100 - 100 ns OE to A; see Fig. 5 - 150 - 105 - 150 - 105 ns transition time OE to B; see Fig. 5 A port 0.8 6.5 0.8 6.3 0.8 6.3 0.8 6.3 ns B port 1.0 7.3 0.7 4.9 0.7 4.6 0.6 4.6 ns tsk(o) output skew time between channels - 2.6 - 1.9 - 1.6 - 1.3 ns tW pulse width data inputs 20 - 20 - 20 - 20 - ns fdata data rate - 50 - 50 - 50 - 50 tt NXB0108 Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Mbps Nexperia B.V. 2021. All rights reserved 7 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Symbol Parameter Conditions VCC(B) Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max VCC(A) = 1.8 V ± 0.15 V propagation delay A to B 1.6 10.8 1.4 7.9 1.3 6.2 1.2 5.3 ns B to A 1.5 9.2 1.3 7.2 0.8 6.3 0.5 5.8 ns ten enable time OE to A, B - 1.0 - 1.0 - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] 2.9 13.0 2.9 13.0 2.9 13.0 2.9 OE to B; no external load [2] tpd 13.0 ns 4.0 18.0 3.0 13.0 2.5 11.5 1.5 9.5 ns OE to A; see Fig. 5 - 120 - 120 - 120 - 120 ns OE to B; see Fig. 5 - 150 - 105 - 150 - 105 ns transition time A port 0.7 5.1 0.7 5.0 1.0 5.0 0.7 5.0 ns B port 1.0 7.3 0.7 5.0 0.7 3.9 0.6 3.8 ns tsk(o) output skew time between channels - 0.8 - 0.7 - 0.6 - 0.6 ns tW pulse width data inputs 19 - 17 - 17 - 17 - ns fdata data rate - 52 - 60 - 60 - 60 Mbps tt [3] VCC(A) = 2.5 V ± 0.2 V propagation delay A to B - - 1.1 7.5 1.0 5.2 0.9 4.2 ns B to A - - 1.0 5.6 0.6 5.0 0.3 4.2 ns ten enable time OE to A, B - - - 1.0 - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] - - 2.5 8.0 2.5 8.0 2.5 8.0 ns OE to B; no external load [2] - - 2.0 11.5 2.8 9.5 1.2 8.0 ns OE to A; see Fig. 5 - - - 85 - 85 - 85 ns OE to B; see Fig. 5 - - - 105 - 150 - 100 ns transition time A port - - 0.8 3.6 0.6 3.6 0.5 3.5 ns B port - - 0.6 4.9 0.7 3.9 0.6 3.2 ns tsk(o) output skew time between channels - - - 0.4 - 0.3 - 0.3 ns tW pulse width data inputs - - 13 - 10 - 10 - ns fdata data rate - - - 80 - 100 - 100 tpd tt NXB0108 Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Mbps Nexperia B.V. 2021. All rights reserved 8 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Symbol Parameter Conditions VCC(B) Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max VCC(A) = 3.3 V ± 0.3 V propagation delay A to B - - - - 0.9 4.8 0.8 3.9 ns B to A - - - - 0.5 4.3 0.2 3.7 ns ten enable time OE to A, B - - - - - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] - - - - 2.1 6.5 2.0 6.5 ns OE to B; no external load [2] - - - - 1.0 8.5 1.7 7.0 ns OE to A; see Fig. 5 - - - - - 125 - 125 ns OE to B; see Fig. 5 - - - - - 150 - 100 ns transition time A port - - - - 0.5 3.0 0.5 3.0 ns B port - - - - 0.7 3.9 0.6 3.2 ns tsk(o) output skew time between channels - - - - - 0.4 - 0.3 ns tW pulse width data inputs - - - - 9.0 - 9.0 - ns fdata data rate - - - - - 110 - 110 tpd tt [1] [2] [3] [3] Mbps tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. tt is the same as tTHL and tTLH These values are guaranteed by design. Skew between any two outputs of the same package switching in the same direction. Table 11. Dynamic characteristics for temperature range -40 °C to +125 °C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6; for waveforms see Fig. 4 and Fig. 5. Symbol Parameter Conditions VCC(B) Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max VCC(A) = 1.5 V ± 0.1 V propagation delay A to B 1.4 11.9 1.2 9.0 1.1 7.3 0.8 6.5 ns B to A 0.9 10.9 0.7 8.8 0.4 7.9 0.3 7.7 ns ten enable time OE to A, B - 1.0 - 1.0 - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] 3.7 19.0 3.7 19.0 3.7 19.0 3.7 19.0 ns OE to B; no external load [2] 3.7 22.0 3.5 16.0 3.0 14.0 1.7 12.5 ns OE to A; see Fig. 5 - 105 - 105 - 105 - 105 ns OE to B; see Fig. 5 - 155 - 110 - 155 - 105 ns 0.8 8.1 0.8 7.9 0.8 7.9 0.8 7.9 ns 1.0 9.1 0.7 6.1 0.7 5.8 0.6 5.8 ns - 2.6 - 1.9 - 1.6 - 1.3 ns 25 - 25 - 25 - 25 - ns - 40 - 40 - 40 - 40 tpd tt transition time A port tsk(o) output skew time between channels tW pulse width data inputs fdata data rate NXB0108 Product data sheet B port [3] All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Mbps Nexperia B.V. 2021. All rights reserved 9 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Symbol Parameter Conditions VCC(B) Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max VCC(A) = 1.8 V ± 0.15 V propagation delay A to B 1.6 11.1 1.4 8.1 1.3 6.5 1.2 5.5 ns B to A 1.5 9.6 1.2 7.8 0.8 6.6 0.5 6.3 ns ten enable time OE to A, B - 1.0 - 1.0 - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] 2.9 14.0 2.9 14.0 2.9 14.0 2.9 14.0 ns OE to B; no external load [2] 10.5 ns tpd 4.0 20.5 3.0 14.5 2.5 12.5 1.5 OE to A; see Fig. 5 - 125 - 125 - 125 - 125 ns OE to B; see Fig. 5 - 150 - 105 - 150 - 105 ns transition time A port 0.8 6.4 0.7 6.3 1.0 6.3 0.7 6.3 ns B port 1.0 9.1 0.7 6.3 0.7 4.9 0.6 4.8 ns tsk(o) output skew time between channels - 0.8 - 0.7 - 0.6 - 0.6 ns tW pulse width data inputs 22 - 18 - 18 - 18 - ns fdata data rate - 45 - 55 - 55 - 55 Mbps tt [3] VCC(A) = 2.5 V ± 0.2 V propagation delay A to B - - 1.1 7.6 1.0 5.8 0.9 4.4 ns B to A - - 1.0 7.1 0.6 5.1 0.3 4.8 ns ten enable time OE to A, B - - - 1.0 - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] - - 2.5 9.0 2.5 9.0 2.5 9.0 ns OE to B; no external load [2] - - 2.0 13.0 2.8 10.5 1.2 8.5 ns OE to A; see Fig. 5 - - - 85 - 85 - 85 ns OE to B; see Fig. 5 - - - 105 - 150 - 100 ns transition time A port - - 0.8 4.5 0.6 4.5 0.5 4.4 ns B port - - 0.6 6.1 0.7 4.9 0.6 4.0 ns tsk(o) output skew time between channels - - - 0.4 - 0.3 - 0.3 ns tW pulse width data inputs - - 13 - 13 - 13 - ns fdata data rate - - - 75 - 80 - 80 tpd tt NXB0108 Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Mbps Nexperia B.V. 2021. All rights reserved 10 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Symbol Parameter Conditions VCC(B) Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max VCC(A) = 3.3 V ± 0.3 V propagation delay A to B - - - - 0.9 5.3 0.8 4.2 ns B to A - - - - 0.5 4.4 0.2 4.0 ns ten enable time OE to A, B - - - - - 1.0 - 1.0 μs tdis disable time OE to A; no external load [2] - - - - 2.1 7.0 2.0 7.0 ns OE to B; no external load [2] - - - - 1.0 9.5 1.7 7.5 ns OE to A; see Fig. 5 - - - - - 125 - 125 ns OE to B; see Fig. 5 - - - - - 150 - 100 ns transition time A port - - - - 0.5 3.8 0.5 3.8 ns B port - - - - 0.7 4.9 0.6 4.0 ns tsk(o) output skew time between channels - - - - - 0.4 - 0.3 ns tW pulse width data inputs - - - - 10 - 10 - ns fdata data rate - - - - - 100 - 100 tpd tt [1] [2] [3] [3] Mbps tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. tt is the same as tTHL and tTLH These values are guaranteed by design. Skew between any two outputs of the same package switching in the same direction. Table 12. Typical power dissipation capacitance [1] [2] Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC(A) 2.5 V Unit 1.2 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 1.8 V 5.0 V 1.8 V 1.8 V 2.5 V 7.0 6.5 7.2 7.6 7.6 7.0 8.0 pF VCC(B) 5.0 V 3.3 V to 5.0 V Tamb = 25 °C outputs enabled; OE = VCC(A) power dissipation A port: (direction A to B) capacitance A port: (direction B to A) CPD 9.6 10.0 9.8 10.1 10.5 10.3 10.8 pF B port: (direction A to B) 23.3 28.7 23.1 23.1 23.7 25.9 25.9 pF B port: (direction B to A) 17.8 25.5 17.1 16.8 17.4 21.0 20.5 pF A port: (direction A to B) 0.2 0.2 0.2 0.3 0.3 0.3 0.3 pF A port: (direction B to A) 0.01 0.01 0.01 0.01 0.01 0.01 0.01 pF B port: (direction A to B) 0.01 0.02 0.01 0.01 0.01 0.01 0.01 pF B port: (direction B to A) 0.2 0.3 0.2 0.2 0.3 0.3 0.3 pF outputs disabled; OE = GND [1] [2] 2 2 CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; 2 N = number of inputs switching; Σ(CL x VCC x fo) = sum of the outputs. fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 11 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 10.1. Waveforms and test circuit VI An, Bn input VM GND tPHL VOH Bn, An output tPLH 90 % VM 10 % VOL tTHL tTLH 001aal918 Measurement points are given in Table 13. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 4. The data input (An, Bn) to data output (Bn, An) propagation delay times VI OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCCO VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aal919 Measurement points are given in Table 13. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. 3-state enable and disable times Table 13. Measurement points [1] Supply voltage Input Output VCCO VM VM VX VY 1.2 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.5 V ± 0.1 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.8 V ± 0.15 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 2.5 V ± 0.2 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.3 V ± 0.3 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V 5.0 V ± 0.5 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] VCCI is the supply voltage associated with the input and VCCO is the supply voltage associated with the output. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 12 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT CL RL 001aal920 Test data is given in Table 14. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; ZO = 50 Ω; dV/dt ≥ 1.0 V/ns. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. VEXT = External voltage for measuring switching times. Fig. 6. Test circuit for measuring switching times Table 14. Test data Supply voltage Input VCC(A) VI [1] VCC(B) 1.2 V to 3.6 V 1.65 V to 5.5 V VCCI [1] [2] [3] Load VEXT Δt/ΔV CL RL [2] ≤ 1.0 ns/V 15 pF 50 kΩ, 1 MΩ open tPLH, tPHL tPZH, tPHZ tPZL, tPLZ [3] open 2VCCO VCCI is the supply voltage associated with the input. For measuring data rate, pulse width, propagation delay and output rise and fall measurements, RL = 1 MΩ; for measuring enable and disable times, RL = 50 kΩ. VCCO is the supply voltage associated with the output. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 13 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 11. Application information 11.1. Applications Voltage level-translation applications. The NXB0108 can be used to interface between devices or systems operating at different supply voltages. See Fig. 7 for a typical operating circuit using the NXB0108. 1.8 V 3.3 V 0.1 µF VCC(A) 1.8 V 0.1 µF VCC(B) 3.3 V OE SYSTEM CONTROLLER A1 B1 A2 B2 A3 B3 A4 DATA A5 NXB0108 SYSTEM B4 B5 A6 B6 A7 B7 A8 B8 DATA GND aaa-032228 Fig. 7. Typical operating circuit 11.2. Architecture The architecture of the NXB0108 is shown in Fig. 8. The device does not require an extra input signal to control the direction of data flow from A to B or from B to A. In a static state, the output drivers of the NXB0108 can maintain a defined output level, but the output architecture is designed to be weak, so that they can be overdriven by an external driver when data on the bus starts flowing in the opposite direction. The output one shots detect rising or falling edges on the A or B ports. During a rising edge, the one shots turn on the PMOS transistors (T1, T3) for a short duration, accelerating the low-to-high transition. Similarly, during a falling edge, the one shots turn on the NMOS transistors (T2, T4) for a short duration, accelerating the high-to-low transition. During output transitions the typical output impedance is 70 Ω at VCCO = 1.2 V to 1.8 V, 50 Ω at VCCO = 1.8 V to 3.3 V and 40 Ω at VCCO = 3.3 V to 5.0 V. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 14 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state VCC(A) VCC(B) ONE SHOT T1 4 kΩ ONE SHOT T2 B A ONE SHOT T3 4 kΩ T4 Fig. 8. ONE SHOT 001aal921 Architecture of NXB0108 I/O cell (one channel) 11.3. Input driver requirements For correct operation, the device driving the data I/Os of the NXB0108 must have a minimum drive capability of ±2 mA See Fig. 9 for a plot of typical input current versus input voltage. II VT/4 kΩ VI - (VD - VT)/4 kΩ 001aal922 VT: input threshold voltage of the NXB0108 (typically VCCI / 2). VD: supply voltage of the external driver. Fig. 9. Typical input current versus input voltage graph 11.4. Power up During operation VCC(A) must never be higher than VCC(B), however during power-up VCC(A) ≥ VCC(B) does not damage the device, so either power supply can be ramped up first. There is no special power-up sequencing required. The NXB0108 includes circuitry that disables all output ports when either VCC(A) or VCC(B) is switched off. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 15 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 11.5. Enable and disable An output enable input (OE) is used to disable the device. Setting OE = LOW causes all I/Os to assume the high-impedance OFF-state. The disable time (tdis with no external load) indicates the delay between when OE goes LOW and when outputs actually become disabled. The enable time (ten) indicates the amount of time the user must allow for one one-shot circuitry to become operational after OE is taken HIGH. To ensure the high-impedance OFF-state during power-up or power-down, pin OE should be tied to GND through a pull-down resistor, the minimum value of the resistor is determined by the current-sourcing capability of the driver. 11.6. Pull-up or pull-down resistors on I/O lines As mentioned previously the NXB0108 is designed with low static drive strength to drive capacitive loads of up to 70 pF. To avoid output contention issues, any pull-up or pull-down resistors used must be kept higher than 50 kΩ. For this reason the NXB0108 is not recommended for use in 2 open drain driver applications such as 1-Wire or I C. For these applications, the NXS0108 level translator is recommended. NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 16 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 12. Package outline TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 10. Package outline SOT360-1 (TSSOP20) NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 17 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- sot764-1_po European projection Issue date 03-01-27 14-12-12 Fig. 11. Package outline SOT764-1 (DHVQFN20) NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 18 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 13. Abbreviations Table 15. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD Electro Static Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 16. Revision history Document ID Release date Data sheet status Change notice Supersedes NXB0108 v.2 20211103 Product data sheet - NXB0108 v.1 Modifications: • NXB0108 v.1 20200903 Product data sheet - - NXB0108 Product data sheet Fig. 1 updated All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 19 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal NXB0108 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 20 / 21 NXB0108 Nexperia Dual supply translating transceiver; auto direction sensing; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 7 10.1. Waveforms and test circuit...................................... 12 11. Application information............................................14 11.1. Applications..............................................................14 11.2. Architecture.............................................................. 14 11.3. Input driver requirements......................................... 15 11.4. Power up..................................................................15 11.5. Enable and disable.................................................. 16 11.6. Pull-up or pull-down resistors on I/O lines................16 12. Package outline........................................................ 17 13. Abbreviations............................................................ 19 14. Revision history........................................................19 15. Legal information......................................................20 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 3 November 2021 NXB0108 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 3 November 2021 © Nexperia B.V. 2021. All rights reserved 21 / 21
NXB0108PWJ 价格&库存
很抱歉,暂时无法提供与“NXB0108PWJ”相匹配的价格&库存,您可以联系我们找货
NXB0108PWJ
  • 211+5.71773211+0.69239
  • 250+5.56228250+0.67356
  • 500+3.73165500+0.45188
  • 1000+3.204781000+0.38808
  • 2500+3.166632500+0.38346
  • 5000+3.046735000+0.36894
库存:2500
NXB0108PWJ
    • 211+4.15835
    • 250+4.04530
    • 500+3.60011
    • 1000+3.40906
    库存:35000
